Part Number: TDA4VH-Q1
From the perspective of LDC operational efficiency, which of the two methods is more efficient and runs faster, using DCC to generate lookup tables or manually calculating mesh tables?
Hi binqi fan,
LDC uses this LUT as input, so method used in generating LDC LUT does not affect LDC operational efficiency, as long as LUT is correct.
Also, I don't think DCC generates the LUT, it uses the provided LUT and generates the output.
Brijesh
