Part Number: SK-AM62A-LP
Hi, build a yocto image with sdk-9.2 analytics for edge AI.
The build of the image is ok. But i have this error when i try to build the sdk
Build Configuration: BB_VERSION = "2.0.0" BUILD_SYS = "x86_64-linux" NATIVELSBSTRING = "ubuntu-22.04" TARGET_SYS = "arm-oe-eabi" MACHINE = "am62axx-evm-k3r5" DISTRO = "arago" DISTRO_VERSION = "2023.10" TUNE_FEATURES = "arm armv7a vfp thumb callconvention-hard" TARGET_FPU = "hard" meta-arago-distro meta-arago-extras meta-arago-demos meta-arago-test = "HEAD:98f178314931635c8641d1394dfd4341b86b6be2" meta-qt5 = "HEAD:ae8a97f79364bed1abc297636f7933d0e35f22be" meta-virtualization = "HEAD:cb2bc17e96552cdfc141d27bd9f4dbd95a872846" meta-networking meta-python meta-oe meta-gnome meta-filesystems = "HEAD:8bb16533532b6abc2eded7d9961ab2a108fd7a5b" meta-ti-extras meta-ti-bsp = "HEAD:376a2143533c6497b4e79304eccca2a630784436" meta-arm meta-arm-toolchain = "HEAD:d7b7b6fb6c7c5545e718e44f38853d1718ce5446" meta = "HEAD:1b5405955c7c2579ed1f52522e2e177d0281fa33" meta-tisdk = "HEAD:b127f5f2a16fdc092a339939cf04c2fc92f15a34" meta-edgeai = "HEAD:0de8484d01ea85a7c366e6b56b1119613321dddb" meta-eco-compteur = "main:422a480ebb764d1fd57c16978ae43d232aa394c3" Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:23 Sstate summary: Wanted 519 Local 518 Mirrors 0 Missed 1 Current 2835 (99% match, 99% complete) NOTE: Executing Tasks ERROR: tisdk-edgeai-image-1.0-r0_edgeai_8 do_populate_sdk: Unable to install packages. Command '/data/mlestephan/ti/yocto-build/build/arago-tmp-default-glibc/work/am62axx_evm-oe-linux/tisdk-edgeai-image/1.0-r0_edgeai_8/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /data/mlestephan/ti/yocto-build/build/arago-tmp-default-glibc/work/am62axx_evm-oe-linux/tisdk-edgeai-image/1.0-r0_edgeai_8/opkg-sdk-target.conf -t /data/mlestephan/ti/yocto-build/build/arago-tmp-default-glibc/work/am62axx_evm-oe-linux/tisdk-edgeai-image/1.0-r0_edgeai_8/temp/ipktemp/ -o /data/mlestephan/ti/yocto-build/build/arago-tmp-default-glibc/work/am62axx_evm-oe-linux/tisdk-edgeai-image/1.0-r0_edgeai_8/sdk/image/usr/local/oe-sdk-hardcoded-buildpath/sysroots/aarch64-oe-linux --force_postinstall --add-ignore-recommends ti-llvm3.6-dev --add-ignore-recommends opencl-monitor-dev --add-ignore-recommends libulm-dev --add-ignore-recommends gdbserver-c6x-dev --add-ignore-recommends coreutils --add-ignore-recommends coreutils-dev --add-ignore-recommends busybox-syslog install acl-dbg acl-src alsa-state-dbg alsa-state-dev alsa-utils-dbg alsa-utils-dev alsa-utils-src amsdk-av-files-dbg amsdk-av-files-dev arago-feed-config-dbg arago-feed-config-dev arago-gpl-notice-dbg arago-gpl-notice-dev arm-benchmarks-dbg arm-benchmarks-dev arm-benchmarks-src at-dbg at-dev at-src attr-dbg attr-src autoconf-dbg autoconf-dev automake-dbg automake-dev avahi-dbg avahi-src base-files-dbg base-passwd-dbg base-passwd-src bash-completion-dbg bc-dbg bc-dev bc-src binutils-dbg binutils-dev binutils-src bluez5-dbg bluez5-src bonnie++-dbg bonnie++-dev boost-dbg boost-dev boost-src bridge-utils-dbg bridge-utils-dev bridge-utils-src brotli-dbg brotli-dev brotli-src bt-enable-dbg bt-enable-dev bt-fw-dbg bt-fw-dev build-essential-dbg build-essential-dev bzip2-dbg bzip2-src ca-certificates-dbg ca-certificates-dev can-utils-dbg can-utils-dev can-utils-src cc33xx-driver-dbg cc33xx-driver-dev ccid-dbg ccid-dev ccid-src ccief-basic-dbg ccief-basic-dev cifs-utils-dbg cifs-utils-dev cifs-utils-src cjson-dbg cjson-dev cjson-src cmake-dbg cmake-src cnm-wave-fw-dbg cnm-wave-fw-dev containerd-opencontainers-dbg containerd-opencontainers-dev cors-dbg cors-dev cpio-dbg cpio-dev cpio-src cpuloadgen-dbg cpuloadgen-dev cpuloadgen-src cracklib-dbg cracklib-src cronie-dbg cronie-dev cronie-src cryptodev-linux-dbg cryptodev-module-dbg cryptodev-module-dev cryptodev-module-src cryptodev-tests-dbg cryptodev-tests-dev cryptodev-tests-src curl-dbg curl-src dbus-broker-dbg dbus-broker-dev dbus-broker-src dbus-dbg dbus-src devil-dbg devil-src devmem2-dbg devmem2-dev devmem2-src dialog-dbg dialog-dev dialog-src dma-heap-tests-dbg dma-heap-tests-dev dma-heap-tests-src docker-ce-dbg docker-ce-dev dosfstools-dbg dosfstools-dev dosfstools-src dropbear-dbg dropbear-dev dropbear-src e2fsprogs-dbg e2fsprogs-dev e2fsprogs-src edgeai-dl-inferer-dbg edgeai-dl-inferer-src edgeai-gst-apps-dbg edgeai-gst-apps-dev edgeai-gst-apps-src edgeai-gst-plugins-dbg edgeai-gst-plugins-src edgeai-gui-app-dbg edgeai-gui-app-dev edgeai-gui-app-src edgeai-init-dbg edgeai-init-dev edgeai-studio-agent-dbg edgeai-studio-agent-dev edgeai-test-data-dbg edgeai-test-data-dev edgeai-tidl-models-dbg edgeai-tidl-models-dev edgeai-tiovx-apps-dbg edgeai-tiovx-apps-src edgeai-tiovx-kernels-dbg edgeai-tiovx-kernels-src edgeai-tiovx-modules-dbg edgeai-tiovx-modules-src elfutils-dbg elfutils-dev elfutils-src ethtool-dbg ethtool-dev ethtool-src eventdump-dbg eventdump-dev evtest-dbg evtest-dev evtest-src expect-dbg expect-dev expect-src express-dbg express-dev fbset-dbg fbset-dev fbset-modes-dbg fbset-modes-dev ffmpeg-dbg ffmpeg-src file-dbg file-dev file-src fio-dbg fio-dev fio-src flac-dbg flac-src flex-dbg flex-src gawk-dbg gawk-dev gawk-src gcc-dbg gcc-dev gcc-runtime-dbg gcc-src gdb-dbg gdb-dev gdb-src gettext-dbg gettext-dev gettext-src gflags-dbg gflags-src git-dbg git-dev git-src glib-networking-dbg glib-networking-dev glib-networking-src glibc-locale-dbg glibc-mtrace-dbg glibc-mtrace-dev glmark2-dbg glmark2-dev glmark2-src glslang-dbg glslang-dev glslang-src go-runtime-dbg go-runtime-dev gobject-introspection-dbg gobject-introspection-src grub-bootconf-dbg grub-bootconf-dev grub-dbg grub-dev grub-efi-dbg grub-efi-dev grub-efi-src grub-src gstreamer1.0-dbg gstreamer1.0-libav-dbg gstreamer1.0-libav-src gstreamer1.0-plugins-bad-dbg gstreamer1.0-plugins-bad-src gstreamer1.0-plugins-base-dbg gstreamer1.0-plugins-base-src gstreamer1.0-plugins-good-dbg gstreamer1.0-plugins-good-src gstreamer1.0-src gtk+3-dbg gtk+3-dev gtk+3-src gzip-dbg gzip-dev gzip-src hdparm-dbg hdparm-dev hdparm-src hicolor-icon-theme-dbg hicolor-icon-theme-dev hidapi-dbg hidapi-dev hidapi-src hostapd-dbg hostapd-dev hostapd-src htop-dbg htop-dev htop-src i2c-tools-dbg i2c-tools-dev i2c-tools-src icu-dbg icu-src initscript-telnetd-dbg initscript-telnetd-dev input-utils-dbg input-utils-dev input-utils-src iozone3-dbg iozone3-dev iozone3-src iperf3-dbg iperf3-dev iperf3-src iproute2-dbg iproute2-dev iproute2-src iptables-dbg iptables-dev iptables-src irqbalance-dbg irqbalance-dev irqbalance-src iso-codes-dbg iw-dbg iw-dev iw-src k3conf-dbg k3conf-dev k3conf-src kbd-dbg kbd-dev kbd-src kernel-dbg kernel-dev kernel-selftest-dbg kernel-selftest-dev kexec-tools-dbg kexec-tools-dev kexec-tools-src kmod-dbg kmod-src kms++-dbg kms++-dev kms++-src kmscube-dbg kmscube-dev kmscube-src lame-dbg lame-src lcms-dbg lcms-dev lcms-src less-dbg less-dev less-src libaio-dbg libaio-dev libaio-src libarchive-dbg libarchive-src libasound-dbg libasound-src libatk-1.0-dbg libatk-1.0-dev libatk-1.0-src libatomic-ops-dbg libatomic-ops-src libc6-src libcairo-dbg libcairo-src libcamera-dbg libcamera-dev libcamera-src libcap-dbg libcap-ng-dbg libcap-ng-src libcap-src libcares-dbg libcares-dev libcares-src libcroco-dbg libcroco-src libcrypt-dbg libcrypt-src libdaemon-dbg libdaemon-src libdrm-dbg libdrm-src libedgeai-apps-utils-dbg libedgeai-apps-utils-src libell-dbg libell-src libepoxy-dbg libepoxy-dev libepoxy-src libevdev-dbg libevdev-dev libevdev-src libevent-2.1-dbg libevent-2.1-dev libevent-2.1-src libexif-dbg libexif-src libexpat-dbg libexpat-src libffi-dbg libffi-src libfmt-dbg libfmt-dev libfmt-src libfontconfig-dbg libfontconfig-src libfreetype-dbg libfreetype-src libfribidi-dbg libfribidi-src libgcc-s-dbg libgcc-s-src libgdbm-dbg libgdbm-src libgdk-pixbuf-2.0-dbg libgdk-pixbuf-2.0-src libgles1-mesa-dev libglib-2.0-dbg libglib-2.0-src libglog-dbg libglog-src libgmp-dbg libgmp-dev libgmp-src libgphoto2-dbg libgphoto2-src libgpiod-dbg libgpiod-dev libgpiod-src libgudev-1.0-dbg libgudev-1.0-src libharfbuzz-dbg libharfbuzz-src libical-dbg libical-src libidn2-dbg libidn2-dev libidn2-src libinput-dbg libinput-dev libinput-src libjitterentropy-dbg libjitterentropy-dev libjitterentropy-src libjpeg-dbg libjpeg-src libjson-c-dbg libjson-c-dev libjson-c-src libloki-dbg libloki-dev libloki-src liblzo2-dbg liblzo2-src libmbim-dbg libmbim-dev libmbim-src libmicrohttpd-dbg libmicrohttpd-dev libmicrohttpd-src libmnl-dbg libmnl-dev libmnl-src libmpc-dbg libmpc-dev libmpc-src libmpfr-dbg libmpfr-dev libmpfr-src libndp-dbg libndp-dev libndp-src libnetconf2-dbg libnetconf2-dev libnetconf2-src libnl-3-dbg libnl-3-dev libnl-3-src libnsl-dbg libnsl-src libnss-mdns-dbg libnss-mdns-dev libnss-mdns-src libogg-dbg libogg-src libonnxruntime-dbg libpam-dbg libpam-src libpcap-dbg libpcap-dev libpcap-src libpciaccess-dbg libpciaccess-src libpcre-dbg libpcre-src libpcre2-dbg libpcre2-dev libpcre2-src libpixman-1-dbg libpixman-1-src libpng16-dbg libpng16-src libpopt-dbg libpopt-dev libpopt-src libprotobuf-dbg libprotobuf-dev libprotobuf-src libpsl-dbg libpsl-src libqmi-dbg libqmi-dev libqmi-src libqt5charts-dbg libqt5charts-dev libqt5charts-src libqt5mqtt-dbg libqt5mqtt-dev libqt5mqtt-src libqt5sensors-dbg libqt5sensors-dev libqt5sensors-src libqt5serialport-dbg libqt5serialport-dev libqt5serialport-src libqt5svg-dbg libqt5svg-dev libqt5svg-src libqt5virtualkeyboard-dbg libqt5virtualkeyboard-dev libqt5virtualkeyboard-src libqt5webchannel-dbg libqt5webchannel-dev libqt5webchannel-src libreadline-dbg libreadline-src librsvg-2-dbg librsvg-2-src libsamplerate-dbg libsamplerate-dev libsamplerate-src libsbc-dbg libsbc-src libseccomp-dbg libseccomp-src libsndfile-dbg libsndfile-src libsolv-dbg libsolv-dev libsolv-src libsoup-2.4-dbg libsoup-2.4-src libspeex-dbg libspeex-src libspeexdsp-dbg libspeexdsp-src libssh-dbg libssh-dev libssh-src libstd-rs-dbg libtag-dbg libtag-src libtheora-dbg libtheora-src libti-rpmsg-char-dbg libti-rpmsg-char-src libtiff-dbg libtiff-src libtirpc-dbg libtirpc-src libtivision-apps-dbg libtool-dbg libtool-src libubootenv-dbg libubootenv-dev libubootenv-src libunistring-dbg libunistring-dev libunistring-src libunwind-dbg libunwind-src libusb-1.0-dbg libusb-1.0-src libuuid-dbg libuuid-src libuv-dbg libuv-dev libuv-src libvorbis-dbg libvorbis-src libvulkan-dbg libvulkan-src libwaffle-1-dbg libwaffle-1-dev libwaffle-1-src libwebp-dbg libwebp-src libwebsockets-dbg libwebsockets-dev libwebsockets-src libwrap-dev libxkbcommon-dbg libxkbcommon-dev libxkbcommon-src libxml2-dbg libxml2-src libxslt-dbg libxslt-dev libxslt-src libyaml-0-dbg libyaml-0-src libyaml-cpp-dbg libyaml-cpp-src libyang-dbg libyang-dev libyang-src libz-dbg libz-src linux-firmware-dbg linux-firmware-dev linux-ti-staging-src linuxptp-dbg linuxptp-dev linuxptp-src lmbench-dbg lmbench-dev lmbench-src logrotate-dbg logrotate-dev logrotate-src lrzsz-dbg lrzsz-dev lrzsz-src lsof-dbg lsof-dev lsof-src ltp-ddt-dbg ltp-ddt-dev ltp-ddt-src ltrace-dbg ltrace-dev ltrace-src m4-dbg m4-src make-dbg make-dev make-src mbedtls-dbg mbedtls-dev mbedtls-src memtester-dbg memtester-dev memtester-src mesa-dbg mesa-dev mesa-src meson-dbg minicom-dbg minicom-dev minicom-src mmc-utils-dbg mmc-utils-dev mmc-utils-src mobile-broadband-provider-info-dbg modemmanager-dbg modemmanager-dev modemmanager-src mosquitto-dbg mosquitto-dev mosquitto-src mpg123-dbg mpg123-src mstpd-dbg mstpd-dev mstpd-src mtd-utils-dbg mtd-utils-dev mtd-utils-src mtdev-dbg mtdev-dev mtdev-src nbench-byte-dbg nbench-byte-dev nbench-byte-src ncurses-dbg ncurses-src net-snmp-dbg net-snmp-dev net-snmp-src net-tools-dbg net-tools-dev net-tools-src netbase-dbg netbase-dev netkit-ftp-dbg netkit-ftp-src netopeer2-server-dbg netopeer2-server-dev netopeer2-server-src netperf-dbg netperf-dev netperf-src nettle-dbg nettle-dev nettle-src networkmanager-dbg networkmanager-dev networkmanager-src nfs-utils-dbg nfs-utils-dev nfs-utils-src ninja-dbg ninja-src nodejs-dbg nodejs-dev nodejs-src nspr-dbg nspr-dev nspr-src nss-dbg nss-dev nss-src numactl-dbg numactl-dev numactl-src nw-configurator-dbg nw-configurator-dev nw-configurator-src ofono-dbg ofono-src oob-demo-dbg oob-demo-dev open62541-dbg open62541-dev open62541-src opencv-dbg opencv-src opengl-es-cts-dbg opengl-es-cts-dev opengl-es-cts-src openjpeg-dbg openjpeg-dev openjpeg-src openntpd-dbg openntpd-dev openntpd-src opensc-dbg opensc-dev opensc-src openssh-dbg openssh-dev openssh-src openssl-dbg openssl-src opkg-arch-config-dbg opkg-arch-config-dev opkg-bash-completion-dbg opkg-bash-completion-dev opkg-dbg opkg-dev opkg-src opkg-utils-dbg oprofile-dbg oprofile-dev oprofile-src optee-client-dbg optee-client-dev optee-client-src optee-examples-dbg optee-examples-dev optee-examples-src optee-os-dbg optee-os-dev optee-os-src optee-test-dbg optee-test-dev optee-test-src orc-dbg orc-src os-release-dbg os-release-dev packagegroup-arago-base-dbg packagegroup-arago-base-dev packagegroup-arago-console-dbg packagegroup-arago-console-dev packagegroup-arago-gst-dbg packagegroup-arago-gst-dev packagegroup-arago-gst-sdk-target-dbg packagegroup-arago-gst-sdk-target-dev packagegroup-arago-qte-dbg packagegroup-arago-qte-dev packagegroup-arago-tisdk-addons-dbg packagegroup-arago-tisdk-addons-dev packagegroup-arago-tisdk-addons-extra-dbg packagegroup-arago-tisdk-addons-extra-dev packagegroup-arago-tisdk-connectivity-dbg packagegroup-arago-tisdk-connectivity-dev packagegroup-arago-tisdk-crypto-dbg packagegroup-arago-tisdk-crypto-dev packagegroup-arago-tisdk-graphics-dbg packagegroup-arago-tisdk-graphics-dev packagegroup-arago-tisdk-gtk-dbg packagegroup-arago-tisdk-gtk-dev packagegroup-arago-tisdk-hmi-dbg packagegroup-arago-tisdk-hmi-dev packagegroup-arago-tisdk-multimedia-dbg packagegroup-arago-tisdk-multimedia-dev packagegroup-arago-tisdk-qte-dbg packagegroup-arago-tisdk-qte-dev packagegroup-arago-tisdk-sysrepo-dbg packagegroup-arago-tisdk-sysrepo-dev packagegroup-base-zeroconf-dbg packagegroup-base-zeroconf-dev packagegroup-core-boot-dbg packagegroup-core-boot-dev packagegroup-core-buildessential-dbg packagegroup-core-buildessential-dev packagegroup-core-standalone-sdk-target-dbg packagegroup-core-standalone-sdk-target-dev packagegroup-core-tools-debug-dbg packagegroup-core-tools-debug-dev packagegroup-edgeai-tisdk-addons-dbg packagegroup-edgeai-tisdk-addons-dev pango-dbg pango-src parted-dbg parted-dev parted-src pcitest-dbg pcitest-dev pcitest-src pciutils-dbg pciutils-dev pciutils-src pcsc-lite-dbg pcsc-lite-dev pcsc-lite-src perf-dbg perf-dev perl-dbg phytool-dbg phytool-dev phytool-src piglit-dbg piglit-dev pm-qa-dbg pm-qa-dev pm-qa-src powertop-dbg powertop-dev powertop-src ppp-dbg ppp-dev ppp-src procps-dbg procps-dev procps-src psplash-dbg psplash-dev psplash-src ptpd-dbg ptpd-dev ptpd-src pulseaudio-dbg pulseaudio-src python3-aiofiles-dbg python3-aiofiles-dev python3-anyio-dbg python3-anyio-dev python3-cffi-dbg python3-cffi-dev python3-cffi-src python3-click-dbg python3-click-dev python3-dbg python3-dbus-dbg python3-dbus-src python3-fastapi-dbg python3-fastapi-dev python3-h11-dbg python3-h11-dev python3-idna-dbg python3-idna-dev python3-mako-dbg python3-mako-dev python3-numpy-dbg python3-numpy-src python3-paho-mqtt-dbg python3-paho-mqtt-dev python3-pillow-dbg python3-pillow-dev python3-pillow-src python3-pip-dbg python3-pip-dev python3-ply-dbg python3-ply-dev python3-psutil-dbg python3-psutil-dev python3-psutil-src python3-pybind11-dbg python3-pybind11-dev python3-pycairo-dbg python3-pycairo-src python3-pycparser-dbg python3-pycparser-dev python3-pydantic-dbg python3-pydantic-dev python3-pygobject-dbg python3-pygobject-src python3-python-multipart-dbg python3-python-multipart-dev python3-pyyaml-dbg python3-pyyaml-src python3-setuptools-dbg python3-setuptools-dev python3-six-dbg python3-six-dev python3-sniffio-dbg python3-sniffio-dev python3-src python3-starlette-dbg python3-starlette-dev python3-typing-extensions-dbg python3-typing-extensions-dev python3-uvicorn-dbg python3-uvicorn-dev python3-websocket-client-dbg python3-websocket-client-dev python3-websockets-dbg python3-websockets-dev python3-websockets-src python3-wheel-dbg python3-wheel-dev python3-yamlloader-dbg qt-tstat-dbg qt-tstat-dev qt-tstat-src qt3d-dbg qt3d-dev qt3d-src qtbase-conf-dbg qtbase-conf-dev qtbase-dbg qtbase-dev qtbase-src qtconnectivity-dbg qtconnectivity-dev qtconnectivity-src qtdeclarative-dbg qtdeclarative-dev qtdeclarative-src qtgraphicaleffects-dbg qtgraphicaleffects-dev qtgraphicaleffects-src qtlocation-dbg qtlocation-dev qtlocation-src qtmultimedia-dbg qtmultimedia-dev qtmultimedia-src qtquick3d-dbg qtquick3d-dev qtquick3d-src qtquickcontrols-dbg qtquickcontrols-dev qtquickcontrols-src qtquickcontrols2-dbg qtquickcontrols2-dev qtquickcontrols2-src qtscript-dbg qtscript-dev qtscript-src qtwayland-dbg qtwayland-dev qtwayland-src qtwebkit-dbg qtwebkit-dev qtwebkit-src quota-dbg quota-dev quota-src resize-rootfs-dbg resize-rootfs-dev rng-tools-dbg rng-tools-dev rng-tools-src rpcbind-dbg rpcbind-dev rpcbind-src rt-tests-dbg rt-tests-dev rt-tests-src run-postinsts-dbg run-postinsts-dev runc-opencontainers-dbg runc-opencontainers-dev rwmem-dbg rwmem-dev rwmem-src serialcheck-dbg serialcheck-dev serialcheck-src shadow-dbg shadow-securetty-dbg shadow-src shared-mime-info-dbg shared-mime-info-src slang-dbg slang-dev slang-src smcroute-dbg smcroute-dev smcroute-src softap-udhcpd-config-dbg softap-udhcpd-config-dev sqlite3-dbg sqlite3-src statcol-dbg statcol-dev statcol-src strace-dbg strace-dev strace-src stream-dbg stream-dev stress-ng-dbg stress-ng-dev stress-ng-src strongswan-dbg strongswan-dev strongswan-plugin-aes-dbg strongswan-plugin-attr-dbg strongswan-plugin-cmac-dbg strongswan-plugin-constraints-dbg strongswan-plugin-curl-dbg strongswan-plugin-des-dbg strongswan-plugin-dnskey-dbg strongswan-plugin-drbg-dbg strongswan-plugin-fips-prf-dbg strongswan-plugin-gcm-dbg strongswan-plugin-hmac-dbg strongswan-plugin-kdf-dbg strongswan-plugin-kernel-netlink-dbg strongswan-plugin-md5-dbg strongswan-plugin-mgf1-dbg strongswan-plugin-nonce-dbg strongswan-plugin-openssl-dbg strongswan-plugin-pem-dbg strongswan-plugin-pgp-dbg strongswan-plugin-pkcs1-dbg strongswan-plugin-pkcs12-dbg strongswan-plugin-pkcs7-dbg strongswan-plugin-pkcs8-dbg strongswan-plugin-pubkey-dbg strongswan-plugin-random-dbg strongswan-plugin-rc2-dbg strongswan-plugin-resolve-dbg strongswan-plugin-revocation-dbg strongswan-plugin-sha1-dbg strongswan-plugin-sha2-dbg strongswan-plugin-socket-default-dbg strongswan-plugin-sqlite-dbg strongswan-plugin-sshkey-dbg strongswan-plugin-stroke-dbg strongswan-plugin-updown-dbg strongswan-plugin-vici-dbg strongswan-plugin-x509-dbg strongswan-plugin-xauth-generic-dbg strongswan-plugin-xcbc-dbg strongswan-src sudo-dbg sudo-dev sudo-src switch-config-dbg switch-config-dev sysrepo-dbg sysrepo-dev sysrepo-src systemd-compat-units-dbg systemd-conf-dbg systemd-conf-dev systemd-dbg systemd-src systemd-telnetd-dbg systemd-telnetd-dev tar-dbg tar-dev tar-src target-sdk-provides-dummy-dbg target-sdk-provides-dummy-dev tbb-dbg tbb-src tcl-dbg tcl-dev tcl-src tcp-wrappers-dbg tcp-wrappers-src tcpdump-dbg tcpdump-dev tcpdump-src thermal-init-dbg thermal-init-dev ti-analytics-dbg ti-analytics-dev ti-demos-dbg ti-demos-dev ti-edgeai-firmware-dbg ti-edgeai-firmware-dev ti-gpio-cpp-dbg ti-gpio-cpp-dev ti-gpio-cpp-src ti-gpio-py-dbg ti-gpio-py-dev ti-rpmsg-char-examples-dbg ti-rpmsg-char-examples-dev ti-rpmsg-char-examples-src ti-rtos-firmware-dbg ti-rtos-firmware-dev ti-test-dbg ti-test-dev ti-test-extras-dbg ti-test-extras-dev ti-tidl-dbg tini-dbg tini-dev tini-src tsn-yang-models-dbg tsn-yang-models-dev udev-extraconf-dbg udev-extraconf-dev unzip-dbg unzip-dev unzip-src update-rc.d-dbg usbutils-dbg usbutils-dev usbutils-src util-linux-dbg util-linux-src uvc-gadget-dbg uvc-gadget-dev uvc-gadget-src v4l-utils-dbg v4l-utils-src vala-dbg vala-src volatile-binds-dbg vulkan-cts-dbg vulkan-cts-dev vulkan-cts-src vulkan-headers-dbg watchdog-config-dbg watchdog-config-dev watchdog-dbg watchdog-dev watchdog-src wayland-dbg wayland-src websocketd-dbg websocketd-dev weston-dbg weston-dev weston-init-dbg weston-init-dev weston-src which-dbg which-dev which-src wl18xx-calibrator-dbg wl18xx-calibrator-dev wl18xx-calibrator-src wl18xx-fw-dbg wl18xx-fw-dev wl18xx-target-scripts-dbg wl18xx-target-scripts-dev wlconf-dbg wlconf-dev wpa-supplicant-dbg wpa-supplicant-dev wpa-supplicant-src xkeyboard-config-dbg xkeyboard-config-dev xz-dbg xz-src yavta-dbg yavta-dev yavta-src zstd-dbg zstd-src' returned 2: * Solver encountered 2 problem(s): * Problem 1/2: * - conflicting requests * - nothing provides edgeai-gst-apps = 0+21dce9bd8d-r0_edgeai_2.0 needed by edgeai-gst-apps-dev-0+21dce9bd8d-r0_edgeai_2.0.aarch64 * * Solution 1: * - do not ask to install a package providing edgeai-gst-apps-dev * Problem 2/2: * - conflicting requests * - nothing provides ti-gpio-cpp = 1.0-r0_edgeai_2.0 needed by ti-gpio-cpp-dev-1.0-r0_edgeai_2.0.aarch64 * * Solution 1: * - do not ask to install a package providing ti-gpio-cpp-dev Disfavor package: busybox-syslog Disfavor package: coreutils-dev Disfavor package: coreutils ERROR: Logfile of failure stored in: /data/mlestephan/ti/yocto-build/build/arago-tmp-default-glibc/work/am62axx_evm-oe-linux/tisdk-edgeai-image/1.0-r0_edgeai_8/temp/log.do_populate_sdk.238 ERROR: Task (/data/mlestephan/ti/yocto-build/sources/meta-edgeai/recipes-core/images/tisdk-edgeai-image.bb:do_populate_sdk) failed with exit code '1' NOTE: Tasks Summary: Attempted 10305 tasks of which 10304 didn't need to be rerun and 1 failed. NOTE: Writing buildhistory NOTE: Writing buildhistory took: 7 seconds NOTE: Writing buildhistory NOTE: Writing buildhistory took: 7 seconds Summary: 1 task failed: /data/mlestephan/ti/yocto-build/sources/meta-edgeai/recipes-core/images/tisdk-edgeai-image.bb:do_populate_sdk Summary: There was 1 ERROR message, returning a non-zero exit code.
Can you help on this please ?
