Audio/DSP integration with VC3 application in DM8168
Hi
We are trying to integrate audio codecs using OMX framework available with SDK-05.02.01.59 to VC3 application.
Can any one suggest the memory map and other related changes/files to change to support the same.
We are comfortable with adding audio encoder component to the SDK and adding relevant code in the application.
So I am specifically looking at the memory map(including which files to be changed) and other generic changes related to heap/shared memory etc, if any.
Thanks in advance
Nitish James
