TDA4VM: edgeai-modelmaker
Part Number: TDA4VM
Hello.
I am using edgeai-modelmaker. And I followed the step in README.
When I handling the Step 3, console showed me SUCCESS, but the model I compiled cannot work successfully.
So I checked the run.log which is generated by this tool, then I found some errors.
What shoud I do?
※The run.log is attached.
The pip information maybe useful, I atattch it as pip.txt.
※The pip.tx is attached.
commandline:
./run_modelmaker.sh TDA4VM config_detection.yaml > command.log
※The command.log is attached.
To repeat my errors,
put my 20240604-111044_yolox_nano_lite_onnxrt_TDA4VM.tar.gz into the board, and unzip it
※The 20240604-111044_yolox_nano_lite_onnxrt_TDA4VM.tar.gz is attached.
root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# ls /opt/model_zoo/custom_model/
artifacts config.yaml dataset.yaml model param.yaml run.log
Edit the /opt/edgeai-gst-apps/configs/object_detection.yaml
※The object_detection.yaml is attached as object_detection.yaml.txt because the limit of file type when uploading
Then run:
root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# python3 app_edgeai.py ../configs/object_detection.yaml
libtidl_onnxrt_EP loaded 0x27433e70
Final number of subgraphs created are : 1, - Offloaded Nodes - 283, Total Nodes - 283
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=5) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
596100.197813 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
596100.198001 s: VX_ZONE_INIT:Enabled
596100.198047 s: VX_ZONE_ERROR:Enabled
596100.198772 s: VX_ZONE_WARNING:Enabled
596100.199339 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
596100.199471 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
596100.199553 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
596100.199643 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
596100.199655 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
596100.200244 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
596100.215100 s: VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
596100.215149 s: VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
596100.215167 s: VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
596100.215184 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
596100.215203 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
596100.215225 s: VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
596100.215243 s: VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
[ERROR] Flow output resolution can not be greater than input resolution
596100.253998 s: VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
596100.258457 s: VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
APP: Deinit ... !!!
REMOTE_SERVICE: Deinit ... !!!
REMOTE_SERVICE: Deinit ... Done !!!
IPC: Deinit ... !!!
IPC: DeInit ... Done !!!
MEM: Deinit ... !!!
DDR_SHARED_MEM: Alloc's: 8 alloc's of 9687228 bytes
DDR_SHARED_MEM: Free's : 8 free's of 9687228 bytes
DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes
MEM: Deinit ... Done !!!
APP: Deinit ... Done !!!
command.log20240604-111044_yolox_nano_lite_onnxrt_TDA4VM.tar.gz
title: "Object Detection"
log_level: 2
inputs:
    input1:
        source: /opt/edgeai-test-data/videos/video0_1280_768.h264
        format: h264
        width: 1280
        height: 768
        framerate: 30
        loop: True
models:
    model2:
        model_path: /opt/model_zoo/custom_model
        viz_threshold: 0.6
outputs:
    output3:
        sink: remote
        width: 1920
        height: 1080
        port: 8081
        host: 127.0.0.1
        encoding: jpeg
        overlay-perf-type: graph
    output0:
        sink: kmssink
        width: 1920
        height: 1080
flows:
    flow0: [input1,model2,output3]
absl-py==2.1.0
addict==2.4.0
appdirs==1.4.4
asgiref==3.8.1
attr==0.3.1
attrs==23.2.0
azure-core==1.30.1
azure-storage-blob==12.20.0
bleach==5.0.1
boto==2.49.0
boto3==1.16.63
botocore==1.19.63
boxing==0.1.4
cachetools==5.3.3
certifi==2024.2.2
cffi==1.16.0
charset-normalizer==3.3.2
click==8.1.7
cloudpickle==3.0.0
colorama==0.4.6
coloredlogs==15.0.1
contourpy==1.2.1
cryptography==42.0.7
cycler==0.12.1
Cython==3.0.10
debugpy==1.8.1
decorator==5.1.1
defusedxml==0.7.1
distro==1.9.0
Django==3.2.20
django-annoying==0.10.6
django-cors-headers==3.6.0
django-debug-toolbar==3.2.1
django-environ==0.10.0
django-extensions==3.1.0
django-filter==2.4.0
django-model-utils==4.1.1
django-ranged-fileresponse==0.1.2
django-rq==2.5.1
django-storages==1.12.3
django-user-agents==0.4.0
djangorestframework==3.13.1
dlr @ https://software-dl.ti.com/jacinto7/esd/tidl-tools/09_02_06_00/OSRT_TOOLS/X86_64_LINUX/UBUNTU_22_04/dlr-1.13.0-py3-none-any.whl#sha256=f2a6f2814c60ceb2d2aa2de92714f559dc10d16919b7dbc73f733e7605f93176
drf-dynamic-fields==0.3.0
drf-flex-fields==0.9.5
drf-generators==0.3.0
-e git+https://gitclone.com/github.com/TexasInstruments/edgeai-tensorlab@9d595574ee4eeebb145a56376ac91a60c68d7873#egg=edgeai_benchmark&subdirectory=edgeai-benchmark
-e git+https://gitclone.com/github.com/TexasInstruments/edgeai-tensorlab@9d595574ee4eeebb145a56376ac91a60c68d7873#egg=edgeai_modelmaker&subdirectory=edgeai-modelmaker
edgeai-torchmodelopt @ git+https://github.com/TexasInstruments/edgeai-modeloptimization.git@c6958abce6a177d90add2b21bedd1f8b77c44354#subdirectory=torchmodelopt
-e git+https://gitclone.com/github.com/TexasInstruments/edgeai-tensorlab@9d595574ee4eeebb145a56376ac91a60c68d7873#egg=edgeai_xvision&subdirectory=edgeai-torchvision/references/edgeailite
exceptiongroup==1.2.1
expiringdict==1.2.2
filelock==3.14.0
flatbuffers==1.12
fonttools==4.51.0
google-api-core==2.11.0
google-auth==2.14.1
google-auth-oauthlib==0.4.6
google-cloud-appengine-logging==1.1.0
google-cloud-audit-log==0.2.0
google-cloud-core==2.3.2
google-cloud-logging==2.7.2
google-cloud-storage==2.5.0
google-crc32c==1.5.0
google-resumable-media==2.3.3
googleapis-common-protos==1.56.4
graphviz==0.20.3
grpc-google-iam-v1==0.12.4
grpcio==1.64.0
grpcio-status==1.48.2
h5py==3.11.0
htmlmin==0.1.12
humanfriendly==10.0
humansignal-drf-yasg==1.21.9
idna==3.7
ijson==3.2.3
imageio==2.34.1
importlib_metadata==7.1.0
inflection==0.5.1
iniconfig==2.0.0
isodate==0.6.1
Jinja2==3.1.4
jmespath==0.10.0
joblib==1.4.2
json-tricks==3.17.3
jsonschema==3.2.0
kiwisolver==1.4.5
label-studio==1.9.0
label-studio-converter==0.0.55
label-studio-tools==0.0.4
launchdarkly-server-sdk==7.5.0
lazy_loader==0.4
lockfile==0.12.2
loguru==0.7.2
lxml==5.2.2
Markdown==3.6
markdown-it-py==3.0.0
MarkupSafe==2.1.5
matplotlib==3.9.0
mdurl==0.1.2
mmcv-full==1.4.8
-e git+https://gitclone.com/github.com/TexasInstruments/edgeai-tensorlab@9d595574ee4eeebb145a56376ac91a60c68d7873#egg=mmdet&subdirectory=edgeai-mmdetection
mpmath==1.3.0
munkres==1.1.4
networkx==3.3
ninja==1.11.1.1
nltk==3.6.7
numpy==1.23.0
oauthlib==3.2.2
onnx==1.13.0
onnx-simplifier==0.4.10
onnxruntime-tidl @ https://software-dl.ti.com/jacinto7/esd/tidl-tools/09_02_06_00/OSRT_TOOLS/X86_64_LINUX/UBUNTU_22_04/onnxruntime_tidl-1.14.0-cp310-cp310-linux_x86_64.whl#sha256=4f3fe7407a7892bea916f63d796f25fa4062f519a92863ebc6da02ba3f5c657d
onnxsim==0.4.36
opencv-python==4.9.0.80
opencv-python-headless==4.9.0.80
ordered-set==4.0.2
osrt-model-tools @ git+https://github.com/TexasInstruments/edgeai-tidl-tools.git@196a4f1258e289ad08058c8db8251d7f3ca85f71#subdirectory=scripts
packaging==24.0
pandas==2.2.2
Pillow==9.3.0
Pillow-SIMD==9.0.0.post1
platformdirs==4.2.2
pluggy==1.5.0
plyfile==0.7.4
progiter==2.0.0
progressbar==2.5
proto-plus==1.23.0
protobuf==3.20.2
psutil==5.9.8
psycopg2-binary==2.9.6
pyasn1==0.6.0
pyasn1_modules==0.4.0
pycocotools==2.0.7
pycparser==2.22
pydantic==1.10.15
Pygments==2.18.0
pyparsing==3.1.2
pyRFC3339==1.1
pyrsistent==0.20.0
pytest==8.2.1
python-dateutil==2.9.0.post0
python-json-logger==2.0.4
pytz==2022.7.1
PyYAML==6.0.1
redis==3.5.3
regex==2024.5.15
requests==2.31.0
requests-oauthlib==2.0.0
rich==13.7.1
rq==1.10.1
rsa==4.9
rules==2.2
s3transfer==0.3.7
scikit-image==0.23.2
scikit-learn==1.5.0
scipy==1.13.1
seaborn==0.11.2
semver==2.13.0
sentry-sdk==2.3.1
six==1.16.0
sqlparse==0.5.0
sympy==1.12
tabulate==0.9.0
tensorboard==2.11.2
tensorboard-data-server==0.6.1
tensorboard-plugin-wit==1.8.1
terminaltables==3.1.10
tflite==2.10.0
tflite-runtime @ https://software-dl.ti.com/jacinto7/esd/tidl-tools/09_02_06_00/OSRT_TOOLS/X86_64_LINUX/UBUNTU_22_04/tflite_runtime-2.8.2-cp310-cp310-linux_x86_64.whl#sha256=a5bf53a437f48324a61c6f315c1fdb79cde7d8ec87689c1efa8f14f621152b0d
thop==0.1.1.post2209072238
threadpoolctl==3.5.0
tifffile==2024.5.22
tomli==2.0.1
torch==2.0.1+cpu
torchinfo==1.8.0
torchvision==0.15.2+cpu
tornado==6.4
tqdm==4.66.4
tvm @ https://software-dl.ti.com/jacinto7/esd/tidl-tools/09_02_06_00/OSRT_TOOLS/X86_64_LINUX/UBUNTU_22_04/tvm-0.12.0-cp310-cp310-linux_x86_64.whl#sha256=7af4695a6c377e34c47c688a1b60329dfcde6db657f2915efaea9b58813009eb
typing_extensions==4.12.0
tzdata==2024.1
ua-parser==0.18.0
ujson==5.10.0
uritemplate==4.1.1
urllib3==1.26.16
user-agents==2.2.0
webencodings==0.5.1
Werkzeug==3.0.3
wurlitzer==3.1.0
xmljson==0.2.0
yapf==0.40.0
-e git+https://gitclone.com/github.com/TexasInstruments/edgeai-tensorlab@9d595574ee4eeebb145a56376ac91a60c68d7873#egg=yolox&subdirectory=edgeai-yolox
zipp==3.18.2
INFO:20240604-113753: running - od-8200
INFO:20240604-113753: pipeline_config - {'task_type': 'detection', 'dataset_category': 'coco', 'calibration_dataset': <edgeai_benchmark.datasets.modelmaker_datasets.ModelMakerDetectionDataset object at 0x7848bfefb970>, 'input_dataset': <edgeai_benchmark.datasets.modelmaker_datasets.ModelMakerDetectionDataset object at 0x7848f2918070>, 'preprocess': <edgeai_benchmark.preprocess.PreProcessTransforms object at 0x784898e3ac50>, 'session': <edgeai_benchmark.sessions.onnxrt_session.ONNXRTSession object at 0x784898e3acb0>, 'postprocess': <edgeai_benchmark.postprocess.PostProcessTransforms object at 0x784898e3af50>, 'metric': {'label_offset_pred': 1}, 'model_info': {'metric_reference': {'accuracy_ap[.5:.95]%': None}, 'model_shortlist': 10}}
INFO:20240604-113753: import  - od-8200 - this may take some time...
Processing config file #0 : /home/arvis/projects/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240604-111044/yolox_nano_lite/compilation/TDA4VM/work/od-8200/artifacts/tempDir/detslabels_tidl_io_.qunat_stats_config.txt
 Freeing memory for user provided Net
 ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
#    0 . .. T    1372.75  .... ..... ... .... .....
#    1 . .. T    1353.69  .... ..... ... .... .....
#    2 . .. T    1368.71  .... ..... ... .... .....
#    3 . .. T    1340.36  .... ..... ... .... .....
#    4 . .. T    1332.33  .... ..... ... .... .....
#    5 . .. T    1355.60  .... ..... ... .... .....
#    6 . .. T    1363.89  .... ..... ... .... .....
#    7 . .. T    1358.27  .... ..... ... .... .....
#    8 . .. T    1360.99  .... ..... ... .... .....
#    9 . .. T    1328.45  .... ..... ... .... .....
#    0 . .. T     520.74  .... ..... ... .... .....
#    1 . .. T     508.98  .... ..... ... .... .....
#    2 . .. T     520.40  .... ..... ... .... .....
#    3 . .. T     510.23  .... ..... ... .... .....
#    4 . .. T     521.07  .... ..... ... .... .....
#    5 . .. T     509.37  .... ..... ... .... .....
#    6 . .. T     516.73  .... ..... ... .... .....
#    7 . .. T     511.12  .... ..... ... .... .....
#    8 . .. T     510.52  .... ..... ... .... .....
#    9 . .. T     511.61  .... ..... ... .... .....
#    0 . .. T     521.54  .... ..... ... .... .....
#    1 . .. T     509.28  .... ..... ... .... .....
#    2 . .. T     510.79  .... ..... ... .... .....
#    3 . .. T     510.01  .... ..... ... .... .....
#    4 . .. T     509.81  .... ..... ... .... .....
#    5 . .. T     512.77  .... ..... ... .... .....
#    6 . .. T     511.57  .... ..... ... .... .....
#    7 . .. T     515.17  .... ..... ... .... .....
#    8 . .. T     508.99  .... ..... ... .... .....
#    9 . .. T     510.94  .... ..... ... .... .....
#    0 . .. T     509.84  .... ..... ... .... .....
#    1 . .. T     508.33  .... ..... ... .... .....
#    2 . .. T     507.98  .... ..... ... .... .....
#    3 . .. T     513.50  .... ..... ... .... .....
#    4 . .. T     508.66  .... ..... ... .... .....
#    5 . .. T     517.78  .... ..... ... .... .....
#    6 . .. T     510.58  .... ..... ... .... .....
#    7 . .. T     513.58  .... ..... ... .... .....
#    8 . .. T     513.75  .... ..... ... .... .....
#    9 . .. T     512.76  .... ..... ... .... .....
#    0 . .. T     513.77  .... ..... ... .... .....
#    1 . .. T     509.26  .... ..... ... .... .....
#    2 . .. T     514.88  .... ..... ... .... .....
#    3 . .. T     508.51  .... ..... ... .... .....
#    4 . .. T     519.64  .... ..... ... .... .....
#    5 . .. T     508.66  .... ..... ... .... .....
#    6 . .. T     510.75  .... ..... ... .... .....
#    7 . .. T     510.82  .... ..... ... .... .....
#    8 . .. T     508.89  .... ..... ... .... .....
#    9 . .. T     508.28  .... ..... ... .... .....yolox is meta arch name
yolox
Number of OD backbone nodes = 192
Size of odBackboneNodeIds = 192
Preliminary subgraphs created = 1
 Graph Domain TO version : 11TIDL Meta PipeLine (Proto) File  : /home/arvis/projects/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240604-111044/yolox_nano_lite/compilation/TDA4VM/work/od-8200/model/model.prototxt
yolox
yolox
Warning : Requested Output Data Convert Layer is not Added to the network, It is currently not Optimal
 ************** Frame index 1 : Running float import *************
INFORMATION: [TIDL_ResizeLayer] /neck/upsample/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] /neck/upsample_1/Resize Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
**          2 WARNINGS          0 ERRORS          **
The soft limit is 2048
The hard limit is 2048
MEM: Init ... !!!
 0.0s:  VX_ZONE_INIT:Enabled
 0.9s:  VX_ZONE_ERROR:Enabled
 0.10s:  VX_ZONE_WARNING:Enabled
 0.4710s:  VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
**********  Frame Index 1 : Running float inference **********
**********  Frame Index 2 : Running float inference **********
**********  Frame Index 3 : Running float inference **********
**********  Frame Index 4 : Running float inference **********
**********  Frame Index 5 : Running float inference **********
**********  Frame Index 6 : Running float inference **********
**********  Frame Index 7 : Running float inference **********
**********  Frame Index 8 : Running float inference **********
**********  Frame Index 9 : Running float inference **********
**********  Frame Index 10 : Running fixed point mode for calibration **********
Parameters unavailable, running calibration!
~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
 *****************   Calibration iteration number 0 started ************************
 *****************   Calibration iteration number 0 completed ************************
 *****************   Calibration iteration number 1 started ************************
 *****************   Calibration iteration number 1 completed ************************
 *****************   Calibration iteration number 2 started ************************
 *****************   Calibration iteration number 2 completed ************************
 *****************   Calibration iteration number 3 started ************************
 *****************   Calibration iteration number 3 completed ************************
#    0 . .. T     513.30  .... ..... ... .... .....
#    1 . .. T     508.92  .... ..... ... .... .....
#    2 . .. T     510.15  .... ..... ... .... .....
#    3 . .. T     511.18  .... ..... ... .... .....
#    4 . .. T     512.36  .... ..... ... .... .....
#    5 . .. T     517.61  .... ..... ... .... .....
#    6 . .. T     509.62  .... ..... ... .... .....
#    7 . .. T     512.09  .... ..... ... .... .....
#    8 . .. T     509.60  .... ..... ... .... .....
#    9 . .. T     511.74  .... ..... ... .... .....
#    0 . .. T     513.99  .... ..... ... .... .....
#    1 . .. T     510.15  .... ..... ... .... .....
#    2 . .. T     512.10  .... ..... ... .... .....
#    3 . .. T     511.35  .... ..... ... .... .....
#    4 . .. T     515.11  .... ..... ... .... .....
#    5 . .. T     511.54  .... ..... ... .... .....
#    6 . .. T     518.69  .... ..... ... .... .....
#    7 . .. T     510.90  .... ..... ... .... .....
#    8 . .. T     509.48  .... ..... ... .... .....
#    9 . .. T     511.21  .... ..... ... .... .....
#    0 . .. T     525.72  .... ..... ... .... .....
#    1 . .. T     508.73  .... ..... ... .... .....
#    2 . .. T     508.22  .... ..... ... .... .....
#    3 . .. T     510.48  .... ..... ... .... .....
#    4 . .. T     507.76  .... ..... ... .... .....
#    5 . .. T     509.05  .... ..... ... .... .....
#    6 . .. T     508.69  .... ..... ... .... .....
#    7 . .. T     513.02  .... ..... ... .... .....
#    8 . .. T     507.40  .... ..... ... .... .....
#    9 . .. T     510.77  .... ..... ... .... .....
#    0 . .. T     514.55  .... ..... ... .... .....
#    1 . .. T     509.63  .... ..... ... .... .....
#    2 . .. T     511.27  .... ..... ... .... .....
#    3 . .. T     514.48  .... ..... ... .... .....
#    4 . .. T     513.76  .... ..... ... .... .....
#    5 . .. T     512.73  .... ..... ... .... .....
#    6 . .. T     508.84  .... ..... ... .... .....
#    7 . .. T     514.83  .... ..... ... .... .....
#    8 . .. T     513.76  .... ..... ... .... .....
#    9 . .. T     509.66  .... ..... ... .... .....
#    0 . .. T     525.33  .... ..... ... .... .....
#    1 . .. T     508.45  .... ..... ... .... .....
#    2 . .. T     509.07  .... ..... ... .... .....
#    3 . .. T     511.64  .... ..... ... .... .....
#    4 . .. T     509.95  .... ..... ... .... .....
#    5 . .. T     508.44  .... ..... ... .... .....
#    6 . .. T     511.87  .... ..... ... .... .....
#    7 . .. T     512.12  .... ..... ... .... .....
#    8 . .. T     509.16  .... ..... ... .... .....
#    9 . .. T     508.25  .... ..... ... .... .....
#    0 . .. T     511.01  .... ..... ... .... .....
#    1 . .. T     511.14  .... ..... ... .... .....
#    2 . .. T     508.89  .... ..... ... .... .....
#    3 . .. T     511.59  .... ..... ... .... .....
#    4 . .. T     509.40  .... ..... ... .... .....
#    5 . .. T     514.80  .... ..... ... .... .....
#    6 . .. T     512.21  .... ..... ... .... .....
#    7 . .. T     515.02  .... ..... ... .... .....
#    8 . .. T     509.90  .... ..... ... .... .....
#    9 . .. T     509.34  .... ..... ... .... .....
------------------ Network Compiler Traces -----------------------------
================================ import model =============
ration number 4 started ************************
 *****************   Calibration iteration number 4 completed ************************
 *****************   Calibration iteration number 5 started ************************
 *****************   Calibration iteration number 5 completed ************************
 *****************   Calibration iteration number 6 started ************************
 *****************   Calibration iteration number 6 completed ************************
 *****************   Calibration iteration number 7 started ************************
 *****************   Calibration iteration number 7 completed ************************
 *****************   Calibration iteration number 8 started ************************
 *****************   Calibration iteration number 8 completed ************************
 *****************   Calibration iteration number 9 started ************************
 *****************   Calibration iteration number 9 completed ************************
Output network quant params prototxt file path: /home/arvis/projects/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240604-111044/yolox_nano_lite/compilation/TDA4VM/work/od-8200/artifacts/tempDir/detslabels_tidl_net_quant_params.prototxt
Calibrated Quant Parameters stored in protoTxt format
Could not open /home/arvis/projects/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240604-111044/yolox_nano_lite/compilation/TDA4VM/work/od-8200/artifacts/tempDir/detslabels_tidl_net/perfSimInfo.bin
WARNING: [TIDL_E_DATAFLOW_INFO_NULL] Network compiler returned with error or didn't executed, this model can only be used on PC/Host emulation mode, it is not expected to work on target/EVM.
**          3 WARNINGS          0 ERRORS          **
INFO:20240604-113919: import completed  - od-8200 - 86 sec
SUCCESS:20240604-113919: benchmark results - {}
INFO:20240604-113919: running - od-8200
INFO:20240604-113919: pipeline_config - {'task_type': 'detection', 'dataset_category': 'coco', 'calibration_dataset': <edgeai_benchmark.datasets.modelmaker_datasets.ModelMakerDetectionDataset object at 0x7848bfefb970>, 'input_dataset': <edgeai_benchmark.datasets.modelmaker_datasets.ModelMakerDetectionDataset object at 0x7848f2918070>, 'preprocess': <edgeai_benchmark.preprocess.PreProcessTransforms object at 0x784898e3ac50>, 'session': <edgeai_benchmark.sessions.onnxrt_session.ONNXRTSession object at 0x784898e3acb0>, 'postprocess': <edgeai_benchmark.postprocess.PostProcessTransforms object at 0x784898e3af50>, 'metric': {'label_offset_pred': 1}, 'model_info': {'metric_reference': {'accuracy_ap[.5:.95]%': None}, 'model_shortlist': 10}}
INFO:20240604-113919: infer  - od-8200 - this may take some time...
infer : od-8200                                             |   0%|          || 0/107 [00:00<?, ?it/s]
infer : od-8200                                             |          |     0% 0/107| [< ]
Traceback (most recent call last):
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/pipelines/pipeline_runner.py", line 203, in _run_pipeline
    result = cls._run_pipeline_impl(basic_settings, pipeline_config, description)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/pipelines/pipeline_runner.py", line 176, in _run_pipeline_impl
    accuracy_result = accuracy_pipeline(description)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/pipelines/accuracy_pipeline.py", line 87, in __call__
    param_result = self._run(description=description)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/pipelines/accuracy_pipeline.py", line 138, in _run
    output_list = self._infer_frames(description)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/pipelines/accuracy_pipeline.py", line 231, in _infer_frames
    output, info_dict = postprocess(output, info_dict)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/utils/transforms_utils.py", line 41, in __call__
    tensor, info_dict = t(tensor, info_dict)
  File "/home/arvis/projects/edgeai-tensorlab/edgeai-benchmark/edgeai_benchmark/postprocess/transforms.py", line 599, in __call__
    self.color_map = info_dict['dataset_info']['color_map']
KeyError: 'color_map'
'color_map'
SUCCESS: ModelMaker - Compilation completed.
  • Hi Makoto,
    Which SDK version are you using? Assuming you are using the latest SDK version, could you try running the application with the configuration file below?
    root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# ./app_edgeai.py ../configs/object_detection.yaml
    log_level: 2
    inputs:
        input0:
            source: /dev/video-usb-cam0
            format: jpeg
            width: 1280
            height: 720
            framerate: 30
        input1:
            format: h264
            width: 1280
            height: 768
            framerate: 30
            loop: True
        input2:
            source: /opt/edgeai-test-data/images/%04d.jpg
            width: 1280
            height: 720
            index: 0
            framerate: 1
            loop: True
    models:
        model0:
            model_path: /opt/model_zoo/TVM-OD-5120-ssdLite-mobDet-DSP-coco-320x320
            viz_threshold: 0.6
        model1:
            model_path: /opt/model_zoo/TFL-OD-2020-ssdLite-mobDet-DSP-coco-320x320
            viz_threshold: 0.6
        model2:
            model_path: /opt/model_zoo/ONR-OD-8200-yolox-nano-lite-mmdet-coco-416x416
            viz_threshold: 0.6
        model3:
            viz_threshold: 0.6
    outputs:
        output0:
            sink: kmssink
            width: 1920
            height: 1080
        output1:
            sink: /opt/edgeai-test-data/output/output_video0.mkv
            width: 1920
            height: 1080
        output2:
            sink: /opt/edgeai-test-data/output/output_image_%04d.jpg
            width: 1920
            height: 1080
        output3:
            sink: remote
            width: 1920
            height: 1080
            port: 8081
            host: 127.0.0.1
            encoding: jpeg
    flows:
        flow0: [input1,model3,output0,[320,150,1280,720]]
    Thank you,
    Fabiana
  • https://github.com/TexasInstruments/edgeai-tensorlab has branch names which corresponds to SDK versions. For example the branch r9.2 corresponds to SDK version 09.02 version of SDK. As of now the main branch in github correspond to r9.2
    Does this match with what you are using?
    There is an error at the end of your compilation. Any other details that you can give to replicate the setup that you have?
    'color_map'
  • Hi Fabiana,
    I am using SDK 9.2 to deal with the work about edgeai-modelmaker.
    I tried your configuration.
    I attached it's log.
    Is this helpful to resolve my problem about using edgeai-modelmaker?
    Thank you,
    Mokoto
    root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# cat ../configs/object_detection.yaml
    title: Object Detection
    log_level: 2
    inputs:
        input0:
            format: jpeg
            width: 1280
            height: 720
            framerate: 30
        input1:
            format: h264
            width: 1280
            height: 768
            framerate: 30
            loop: True
        input2:
            width: 1280
            height: 720
            index: 0
            framerate: 1
            loop: True
    models:
        model0:
            viz_threshold: 0.6
        model1:
            viz_threshold: 0.6
        model2:
            viz_threshold: 0.6
        model3:
            viz_threshold: 0.6
    outputs:
        output0:
            sink: kmssink
            width: 1920
            height: 1080
        output1:
            width: 1920
            height: 1080
        output2:
            width: 1920
            height: 1080
        output3:
            sink: remote
            width: 1920
            height: 1080
            port: 8081
            host: 127.0.0.1
            encoding: jpeg
    flows:
    libtidl_onnxrt_EP loaded 0x937d250
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
    100558.513974 s: GTC Frequency = 200 MHz
    100558.515128 s:  VX_ZONE_INIT:Enabled
    100558.515182 s:  VX_ZONE_ERROR:Enabled
    100558.515221 s:  VX_ZONE_WARNING:Enabled
    100558.515788 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
    100558.516732 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
    100558.516839 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
    100558.517296 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
    100558.517316 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
    100558.518040 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
    100558.531873 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
    100558.531922 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
    100558.531942 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
    100558.531958 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
    100558.531977 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
    100558.531999 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
    100558.532015 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
    [ERROR] Could not get allowed GstCaps of device
    100558.734194 s:  VX_ZONE_ERROR:[vxGetStatus:1020] Reference is NULL
    100558.737897 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
    100558.742355 s:  VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 15 alloc's of 37680924 bytes
    DDR_SHARED_MEM: Free's : 15 free's  of 37680924 bytes
  • Hi Manu,
    Before I post this question, I already used github.com/.../edgeai-tensorlab repo, To check I're right, I contained command output.
    $ git remote get-url origin
    gitclone.com/.../edgeai-tensorlab
    $ git branch
    r9.0
    * r9.2
    $ cat docs/release_notes.md | grep 9.2
    Note: I follow the EdgeAI-SDK (Processor SDK Linux with Edge AI) release numbering. For example, the models compiled with 9.2.0 version (r9.2 branch) works in 09.02.00 (09_02_00) SDK release.
    ## 9.2.0
    ### Git branch name: r9.2
    - Updated to support TIDL & SDK version 9.2
    It's correctly? I think already used correctly SDK version.
    Thank you
    Makoto
  • Hi Makoto,
    Thank you for specifying the SDK and git versions. Could you please call out any other details/steps followed to replicate the issue?
    Fabiana
  • Due to the recent version updates in pip and setuptools, we need to update the repository in github anyway (Otherwise the setup wouldn't even complete as of now). So may be what I can do is push a new version to github and we can base our conclusions on that.
  • New commits have been pushed to r9.2 and main branches.
    Makoto, please try again after pulling r9.2 branch and let us know if you face any issues with that.
  • Hi Manu,
    I tried the newest r9.2, then the compile errors were disappeared.
    But when running the model, I got many errors.
    ※I attached the log as 202406014.txt
    root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# uname -a
    Linux tda4vm-sk 6.1.80-ti-g2e423244f8c0 #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
    log_level: 2
    inputs:
        input0:
            format: jpeg
            width: 1280
            height: 720
            framerate: 30
        input1:
            format: h264
            width: 1280
            height: 768
            framerate: 30
            loop: True
        input2:
            width: 1280
            height: 720
            index: 0
            framerate: 1
            loop: True
    models:
        model0:
            viz_threshold: 0.6
        model1:
            viz_threshold: 0.6
        model2:
            viz_threshold: 0.6
        model3:
            viz_threshold: 0.6
    outputs:
        output0:
            sink: kmssink
            width: 1920
            height: 1080
        output1:
            width: 1920
            height: 1080
        output2:
            width: 1920
            height: 1080
        output3:
            sink: remote
            width: 1920
            height: 1080
            port: 8081
            host: 127.0.0.1
            encoding: jpeg
    flows:
        flow0: [input1,model3,output1,[320,150,1280,720]]
    libtidl_onnxrt_EP loaded 0x139e4f30
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
      7947.968951 s: GTC Frequency = 200 MHz
      7947.969038 s:  VX_ZONE_INIT:Enabled
      7947.969049 s:  VX_ZONE_ERROR:Enabled
      7947.969074 s:  VX_ZONE_WARNING:Enabled
      7947.969596 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
      7947.972405 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
      7947.972592 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
      7947.972762 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
      7947.972826 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
      7947.973349 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
      7947.998854 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7947.999033 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7947.999078 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7947.999128 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7947.999170 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7947.999216 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7947.999255 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
    ==========[INPUT PIPELINE(S)]==========
    [PIPE-0]
    multifilesrc location=/opt/edgeai-test-data/videos/video0_1280_768.h264 loop=True ! h264parse ! v4l2h264dec capture-io-mode=5 ! tiovxmemalloc pool-size=12 ! capsfilter caps="video/x-raw, format=(string)NV12;" ! tiovxmultiscaler name=split_01
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1280, height=(int)720;" ! tiovxdlcolorconvert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop=True name=sen_0
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)416, height=(int)416;" ! tiovxdlpreproc out-pool-size=4 data-type=3 tensor-format=1 ! capsfilter caps="application/x-tensor-tiovx;" ! appsink max-buffers=2 drop=True name=pre_0
    ==========[OUTPUT PIPELINE]==========
    appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1280, height=(int)720;" ! queue ! mosaic_0.sink_0
    tiovxmosaic target=1 background=/tmp/background_0 name=mosaic_0 src::pool-size=2
    sink_0::startx="<320>" sink_0::starty="<150>" sink_0::widths="<1280>" sink_0::heights="<720>"
    ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! v4l2h264enc extra-controls="controls, frame_level_rate_control_enable=(int)1, video_bitrate=(int)10000000, video_gop_size=(int)30;" ! h264parse ! matroskamux writing-app=GStreamer Matroska muxer ! filesink sync=False location=/opt/edgeai-test-data/output/output_video0.mkv
      7948.240359 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.240496 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.240541 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.240581 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.240622 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.240668 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.240706 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.240797 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.240836 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.240875 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
    ERROR: Running TIDL graph ... Failed !!!
      7948.262624 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.262665 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.262692 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.262710 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.262730 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.262757 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.262773 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.262878 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.262907 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.262922 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.296805 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.296847 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.296861 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.296876 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.296887 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.296906 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.296915 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.296980 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.296989 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.296999 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.329408 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.329442 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.329474 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.329492 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.329513 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.329538 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.329555 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.329620 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.329629 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.329637 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.362205 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.362403 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.362471 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.362527 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.362583 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.362651 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.362704 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.362819 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.362887 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.362938 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.452437 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.452624 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.452681 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.452733 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.452783 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.452844 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.452893 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.452998 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.453051 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.453165 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.476271 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.476325 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.476343 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.476360 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.476378 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.476401 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.476416 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.476483 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.476503 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.476517 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.486257 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.486286 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.486316 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.486334 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.486352 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.486373 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.486390 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.486454 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.486472 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.486487 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.501048 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.501161 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.501181 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.501249 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.501298 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.501324 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.501340 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.501408 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.501430 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.501446 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.531013 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.531067 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.531085 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.531101 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.531120 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.531142 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.531159 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.531224 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.531248 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.531264 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.563366 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.563418 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.563438 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.563453 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.563474 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.563501 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.563518 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.563584 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.563601 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.563616 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.595828 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.595860 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.595882 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.595900 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.596525 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.596568 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.596585 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.596655 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.596673 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.596687 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.629258 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.629290 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.629302 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.629313 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.629323 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.629338 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.629346 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.629403 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.629412 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.629420 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.662512 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.662665 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.662676 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.662717 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.662751 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.662837 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.662876 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.662981 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.662991 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.663023 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.695805 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.695838 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.695944 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.695954 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.696089 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.696114 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.696151 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.696259 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.696269 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.696300 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.729195 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.729227 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.729352 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.729361 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.729368 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.729381 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.729387 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.729443 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.729452 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.729457 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.762493 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.762527 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.762683 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.762718 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.762753 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.762817 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.762826 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.762931 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.762940 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.762971 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.795793 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.795825 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.795977 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.796014 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.796085 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.796149 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.796158 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.796261 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.796271 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.796277 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
    ^C  7948.829308 s:  VX_ZONE_ERROR:[ownContextSendCmd:875] Command ack message returned failure cmd_status: -1
      7948.829340 s:  VX_ZONE_ERROR:[ownNodeKernelInit:590] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
      7948.829492 s:  VX_ZONE_ERROR:[ownNodeKernelInit:591] Please be sure the target callbacks have been registered for this core
      7948.829501 s:  VX_ZONE_ERROR:[ownNodeKernelInit:592] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
      7948.829539 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:608] kernel init for node 0, kernel com.ti.tidl:1:2 ... failed !!!
      7948.829604 s:  VX_ZONE_ERROR:[vxVerifyGraph:2159] Node kernel init failed
      7948.829614 s:  VX_ZONE_ERROR:[vxVerifyGraph:2213] Graph verify failed
      7948.829718 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:885] graph is not in a state required to be scheduled
      7948.829727 s:  VX_ZONE_ERROR:[vxProcessGraph:813] schedule graph failed
      7948.829758 s:  VX_ZONE_ERROR:[vxProcessGraph:818] wait graph failed
      7948.973350 s:  VX_ZONE_INIT:[tivxHostDeInitLocal:115] De-Initialization Done for HOST !!!
      7948.977863 s:  VX_ZONE_INIT:[tivxDeInitLocal:204] De-Initialization Done !!!
    APP: Deinit ... !!!
    IPC: Deinit ... !!!
    MEM: Deinit ... !!!
    DDR_SHARED_MEM: Alloc's: 75 alloc's of 132240740 bytes
    DDR_SHARED_MEM: Free's : 75 free's  of 132240740 bytes
    Thank you,
    Mokoto
  • Hi Makoto,
    These errors seem to be due to some model issue rather than edgeai-gst-apps. I will let Manu comment on this.
    Thank you,
    Fabiana
  • Hi Makoto,
    Is it possible to attach the compiled model?
    edgeai-modelmaker/data/projects/<dtaset name>/run/<run id>/<model name>/compilation/<target device>/pkg/
    There will be the compiled packaged model (.tar.gz file)
  • Hi Manu,
    I've attached that before.
    Attach again.
    4214.20240604-111044_yolox_nano_lite_onnxrt_TDA4VM.tar.gz
    Thank you,
    Makoto
  • Thank you for sharing. Please allow some time for review.
    -Fabiana
  • Hi Makoto,
    Attached is a model that I generated yesterday by running config_detection.yaml  It is confirmed to be running fine on the 9.2 SDK. Attaching the model:
    manu_ti_20240618-135553_yolox_nano_lite_onnxrt_TDA4VM.tar.gz
    But the model that you generated is not running. From this I suspect that the something is not correct in the environment that you are using. Can you do a fresh start i.e. delete the edgeai-tensorlab and clone it again. Create a new python environment and try again.
  • In the compilation log that you attached above, can you see the lines:
    That indicates that the compilation did not work as expected. (The compilation should have stopped at the point, but it did not stop - that is something for the TIDL to fix).
    Once you try with a fresh environment, please check the logs and see if that error is there or not.
  • Hello Manu,
    I tried to create new clear Ubuntu environment. And I following the steps on the github of edgeai-tensorlab. The build proccess was seemed OK. But when running the model, different errors appeared, and program exited.
    ※I've recreated the environment for many times.
    Attached the history.txt, which shows how I create the enviroment with newly installed Ubuntu. Is there any problem with my step?
    And also attach the model I build, and the log when I run it.
      366  sudo apt update
      367  sudo apt install build-essential curl libbz2-dev libffi-dev liblzma-dev libncursesw5-dev libreadline-dev libsqlite3-dev libssl-dev libxml2-dev libxmlsec1-dev llvm make tk-dev xz-utils wget curl
      368  curl -L https://github.com/pyenv/pyenv-installer/raw/master/bin/pyenv-installer | bash
      371  git config --global --unset http.proxy
      372  git config --global --unset https.proxy
      373  curl -L https://github.com/pyenv/pyenv-installer/raw/master/bin/pyenv-installer | bash
      374  echo '# pyenv settings ' >> ${HOME}/.bashrc
      375  echo 'command -v pyenv >/dev/null || export PATH=":${HOME}/.pyenv/bin:$PATH"' >> ${HOME}/.bashrc
      376  echo 'eval "$(pyenv init -)"' >> ${HOME}/.bashrc
      377  echo 'eval "$(pyenv virtualenv-init -)"' >> ${HOME}/.bashrc
      378  echo '' >> ${HOME}/.bashrc
      379  exec ${SHELL}
      380  pyenv install 3.10
      381  pyenv virtualenv 3.10 py310
      382  pyenv rehash
      383  pyenv activate py310
      384  pip install --upgrade pip setuptools
      385  git clone https://github.com/TexasInstruments/edgeai-tensorlab
      386  cd edgeai-tensorlab/
      387  ./setup_all.sh
      388  cd edgeai-modelmaker/
      389  ./setup_all.sh
      401  ./run_modelmaker.sh TDA4VM config_detection.yaml
      402  nano requirements_freeze.txt
      403  pip install mmcv-full==1.4.8
      404  pyenv activate py310
      405  pip install mmcv-full==1.4.8
      406  cd edgeai-tensorlab/edgeai-modelmaker/
      407  ls
      408  ./run_modelmaker.sh TDA4VM config_detection.yaml
      412  ls -l /home/wjx/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240620-151129/yolox_nano_lite/compilation/TDA4VM/pkg/20240620-151129_yolox_nano_lite_onnxrt_TDA4VM.tar.gz
      413  ping 192.168.1.110
      414  scp /home/wjx/edgeai-tensorlab/edgeai-modelmaker/data/projects/tiscapes2017_driving/run/20240620-151129/yolox_nano_lite/compilation/TDA4VM/pkg/od-8200.tar.gz root@192.168.1.110:~/
    root@tda4vm-sk:/opt/edgeai-gst-apps/apps_python# python3 app_edgeai.py ../configs/object_detection.yam        l
    libtidl_onnxrt_EP loaded 0x3f244d90
    ERROR : artifacts_folder not a directory
    ******** WARNING ******* : Could not open ConstantFolding/allowedNode.txt for reading... Entire model        will run on ARM without any delegation to TIDL !
    Final number of subgraphs created are : 1, - Offloaded Nodes - 0, Total Nodes - 0
    APP: Init ... !!!
    MEM: Init ... !!!
    MEM: Initialized DMA HEAP (fd=6) !!!
    IPC: Init ... !!!
     12879.285192 s: GTC Frequency = 200 MHz
     12879.290680 s:  VX_ZONE_INIT:Enabled
     12879.290691 s:  VX_ZONE_ERROR:Enabled
     12879.290696 s:  VX_ZONE_WARNING:Enabled
     12879.292946 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
     12879.293045 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
     12879.293117 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
     12879.293494 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
     12879.293508 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
     12879.298019 s:  VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
    [PIPE-0]
    multifilesrc location=/opt/edgeai-test-data/videos/video0_1280_768.h264 loop=True ! h264parse ! v4l2h2        64dec capture-io-mode=5 ! tiovxmemalloc pool-size=12 ! capsfilter caps="video/x-raw, format=(string)NV        12;" ! tiovxmultiscaler name=split_01
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)1280, height=(int)720;" ! tiovxdlcolorcon        vert out-pool-size=4 ! capsfilter caps="video/x-raw, format=(string)RGB;" ! appsink max-buffers=2 drop        =True name=sen_0
    split_01. ! queue ! capsfilter caps="video/x-raw, width=(int)416, height=(int)416;" ! tiovxdlpreproc o        ut-pool-size=4 data-type=3 tensor-format=1 ! capsfilter caps="application/x-tensor-tiovx;" ! appsink m        ax-buffers=2 drop=True name=pre_0
    appsrc do-timestamp=True format=3 block=True name=post_0 ! tiovxdlcolorconvert ! capsfilter caps="vide        o/x-raw, format=(string)NV12, width=(int)1280, height=(int)720;" ! queue ! mosaic_0.sink_0
    ! capsfilter caps="video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080;" ! v4l2h264enc        extra-controls="controls, frame_level_rate_control_enable=(int)1, video_bitrate=(int)10000000, video_        gop_size=(int)30;" ! h264parse ! matroskamux writing-app=GStreamer Matroska muxer ! filesink sync=Fals        e location=/opt/edgeai-test-data/output/output_video0.mkv
    [   82.024228] unclassified data detected!
    [   82.072778] unclassified data detected!
    [   82.110373] kauditd_printk_skb: 1 callbacks suppressed
    [   82.110381] audit: type=1701 audit(1718861225.813:24): auid=4294967295 uid=0 gid=0 ses=4294967295 p        id=1485 comm="python3" exe="/usr/bin/python3.10" sig=11 res=1
    [   82.146287] audit: type=1334 audit(1718861225.849:25): prog-id=17 op=LOAD
    [   82.153114] audit: type=1334 audit(1718861225.857:26): prog-id=18 op=LOAD
    Segmentation fault (core dumped)
    log_level: 2
    inputs:
        input0:
            format: jpeg
            width: 1280
            height: 720
            framerate: 30
        input1:
            format: h264
            width: 1280
            height: 768
            framerate: 30
            loop: True
        input2:
            width: 1280
            height: 720
            index: 0
            framerate: 1
            loop: True
    models:
        model0:
            viz_threshold: 0.6
        model1:
            viz_threshold: 0.6
        model2:
            viz_threshold: 0.6
        model3:
            viz_threshold: 0.6
    outputs:
        output0:
            sink: kmssink
            width: 1920
            height: 1080
        output1:
            width: 1920
            height: 1080
        output2:
            width: 1920
            height: 1080
        output3:
            sink: remote
            width: 1920
            height: 1080
            port: 8081
            host: 127.0.0.1
            encoding: jpeg
    flows:
    root@tda4vm-sk:/opt/edgeai-gst-apps# ls /opt/model_zoo/custom_model
    root@tda4vm-sk:/opt/model_zoo# tar -zcvf custom_model.tgz custom_model/
    custom_model/
    custom_model/dataset.yaml
    custom_model/model/
    custom_model/model/model.prototxt
    custom_model/model/model.onnx
    custom_model/param.yaml
    custom_model/config.yaml
    custom_model/run.log
    6330.custom_model.zip
    Thank you,
    Makoto
  • Inside the zip file that you shared, I can see the model folder. But the artifacts folder is missing. Wondering why is it so.
  • Hello Manu,
    Yes, the log also show that problem (artifacts folder is missing). I am sure I followed the steps on the github of edgeai-tensorlab. So I don't know why this happened.
    Can you tell me how should I do to deal with this?
    Thank you,
    Makoto
  • Given that it works in my machine and it doesn't work in your case, I can think of two options:
    (1) How about asking one of your colleague to try it. We can see if it is something specific to your machine.
    (2) Or is it possible to share a sample or a small subset of your dataset? I can train/compile it and share with you for you to check.
