TDA4AL-Q1: ISSI LPDDR4 configuration
Part Number: TDA4AL-Q1
Hi TI Team,
We wound need you support to load the right paramenter of the ISSI LPDDR4 we are currently using on our system.
Attached you can see the datasheet and Register Configuration spreadsheet for Jacinto7 DDRSS.
Thanks a lot for you support.
 Final_SPRACU8A_Jacinto7_DDRSS_RegConfigTool_TIEdit_Jan17-2023.xlsm8Gb LPDDR4-4X Datasheet (x32) IS43-46LQ32256B(L).pdf
  • Hi Matias,
    The purpose of the DDR register configuration tool is to allow customers to easily customize the DDR register settings for their specific system. The information required to fill in the tool is mostly high level information pertaining to the customer's system, or specific timing information that can be found in the LPDDR4 datasheet of the LPDDR4 device selected by the customer.
    We understand that some inputs may be unclear, and we are happy to clarify any specific questions you may have.
    Can you please let us know which parameters you are unclear on?
    Kevin
  • Hi Kevin,
    We are using TDA4AL ->
    1) Shall we complete only DDRSS0? what about rest columns DDRSS1, DDRSS2,...? can be remain with any value?
    2) How shall we update items 13,14 and 15 (based on LPDDR4 datasheet shared?
    Thanks in advance
  • Hi Matias,
    1) Yes, only the values for DDRSS0 need to be filled in. As a side note, we recently released an online version using SYSCONFIG which should remove the extra DDRSS when selecting TDA4AL.
    https://dev.ti.com/sysconfig/?product=TDA4x_DRA8x_AM67x-AM69x_DDR_Config&device=J721S2_TDA4VE_TDA4AL_TDA4VL_AM68x
    2) Since you only have a single DDRSS, NA is fine for the configuration (13), and the granularity (15) is a "don't care" - you can leave as-is. You can set the memory size (14) to match the total memory on your PCB.
    Kevin
