PROCESSOR-SDK-AM64X: openssl version
Part Number: PROCESSOR-SDK-AM64X
A question about openssl version:
Based on OTP Keywriter User Guide:
Note
OpenSSL (1.1.1 11 Sep 2018) is required for building the OTP Keywriter.
You can check if OpenSSL is installed by typing “openssl version” in your command prompt.
If it's not installed, download and install OpenSSL for your OS.
We use Ubuntu 22 Linux which has openssl version of :
Package: openssl
Architecture: amd64
Version: 3.0.2-0ubuntu1
Multi-Arch: foreign
Then I tried to do openssl packages:
      # download binary openssl packages
      wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1f-1ubuntu2.22_amd64.deb
      wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl-dev_1.1.1f-1ubuntu2.22_amd64.deb
      wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.22_amd64.deb
      # install downloaded binary packages
      sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.22_amd64.deb
      sudo dpkg -i libssl-dev_1.1.1f-1ubuntu2.22_amd64.deb
      sudo dpkg -i openssl_1.1.1f-1ubuntu2.22_amd64.deb
      sudo ldconfig -v
      Validate the version
      openssl version -a
OpenSSL 1.1.1f  31 Mar 2020
built on: Fri Feb 16 15:41:31 2024 UTC
platform: debian-amd64
options:  bn(64,64) rc4(16x,int) des(int) blowfish(ptr)
compiler: gcc -fPIC -pthread -m64 -Wa,--noexecstack -Wall -Wa,--noexecstack -g -O2 -fdebug-prefix-map=/build/openssl-ANcB0E/openssl-1.1.1f=. -fstack-protector-strong -Wformat -Werror=format-security -DOPENSSL_TLS_SECURITY_LEVEL=2 -DOPENSSL_USE_NODELETE -DL_ENDIAN -DOPENSSL_PIC -DOPENSSL_CPUID_OBJ -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DKECCAK1600_ASM -DRC4_ASM -DMD5_ASM -DAESNI_ASM -DVPAES_ASM -DGHASH_ASM -DECP_NISTZ256_ASM -DX25519_ASM -DPOLY1305_ASM -DNDEBUG -Wdate-time -D_FORTIFY_SOURCE=2
OPENSSLDIR: "/usr/lib/ssl"
ENGINESDIR: "/usr/lib/x86_64-linux-gnu/engines-1.1"
Seeding source: os-specific
I am wondering if it is good or not to meet document requirements?
I am going to use default keys under folder of keys_devel/ to generate Keywriter Certificate by command:
./gen_keywr_cert.sh -t tifek/ti_fek_public.pem --msv 0xC0FFE -b keys_devel/bmpk.pem
--bmek keys_devel/bmek.key -s keys_devel/smpk.pem --smek keys_devel/smek.key --keycnt 2 --keyrev 1
I want to make sure that this won't brick the AM64x EVM!
Thank you very much!
  • 1, cd $HOME/ti/mcu_plus_sdk_am64x_09_00_00_31/source/security/sbl_keywriter/scripts/cert_gen/am64x
    ./gen_keywr_cert.sh -t tifek/ti_fek_public.pem --msv 0xC0FFE -b keys_devel/bmpk.pem --bmek keys_devel/bmek.key -s keys_devel/smpk.pem --smek keys_devel/smek.key --keycnt 2 --keyrev 1
    2,  cd $HOME/ti/mcu_plus_sdk_am64x_09_00_00_31/source/security/sbl_keywriter/scripts/x509cert
    python3 ../../../../../tools/bin2c/bin2c.py final_certificate.bin keycert.h KEYCERT
    3, cd $HOME/ti/mcu_plus_sdk_am64x_09_00_00_31/source/security/sbl_keywriter/am64x-evm/r5fss0-0_nortos/ti-arm-clang
    make -sj clean PROFILE=debug
    make -sj PROFILE=debug
    4, Copy tiboot3.bin to the SD card, then bootup from SD, it looks success.
    Starting Keywriting
    Enabled VPP
    keys Certificate found: 0x70042b00
    Keywriter Debug Response:0x0
    Success Programming Keys
    5, Set the boot mode switches into UART boot mode, then power up board. The terminal will print the SoC ID followed by "CCC" (ping characters). Copy the entire string up until "CCC" (ping characters)
    02000000011a0000616d3634780000000000000048535345000002000000020002a6000001000200b018658ad99dc903c8c9bfb27b12751099920a042ad1dfea7b7ba57369f15546de285edde6a7b39a8bdc40a27b237f8fb1e57f245e80b929c1e28b024aa2ecc61f6002b07cd9b0b7c47d9ca8d1aae57b8e8784a12f636b2b760d7d98a18f189760dfd0f23e2b0cb10ec7edc7c6edac3d9bdfefe0eddc3fff7fe9ad875195527d2b64b3c78c81e0b285febd4cb3d6f503944485f0daac9ffd672fdf600546c1e8
    6, Paste the string in <MCU_PLUS_SDK_INSTALL_DIR>/source/security/sbl_keywriter/
    tools/socid.txt
    7, Run the command below in the following directory: <MCU_PLUS_SDK_INSTALL_DIR>/source/
    security/sbl_keywriter/tools
    $ python parse_uart_boot_socid.py socid.txt
    This will parse the SoC ID and show the information below.
    SoC ID Header Info:
    NumBlocks : 2
    SoC ID Public ROM Info:
    SubBlockId : 1
    SubBlockSize : 26
    DeviceName : am64x
    DeviceType : HSSE
    DMSC ROM Version : [0, 2, 0, 0]
    R5 ROM Version : [0, 2, 0, 0]
    SoC ID Secure ROM Info:
    Sec SubBlockId : 2
    Sec SubBlockSize : 166
    Sec Prime : 0
    Sec Key Revision : 1
    Sec Key Count : 2
    Sec TI MPK Hash : b018658ad99dc903c8c9bfb27b12751099920a042ad1dfea7b7ba57369f15546de285edde6a7b39a8bdc40a27b237f8fb1e57f245e80b929c1e28b024aa2ecc6
    Sec Cust MPK Hash : 1f6002b07cd9b0b7c47d9ca8d1aae57b8e8784a12f636b2b760d7d98a18f189760dfd0f23e2b0cb10ec7edc7c6edac3d9bdfefe0eddc3fff7fe9ad875195527d
    Sec Unique ID : 2b64b3c78c81e0b285febd4cb3d6f503944485f0daac9ffd672fdf600546c1e8
    8, copy ~/ti/mcu_plus_sdk_am64x_09_00_00_31/source/security/sbl_keywriter/scripts/cert_gen/am64x/keys_devel/smpk.pem to u boot/board/ti/keys/custMpk.pem and cp custMpk.pem to custMpk.key and  use blow command make custMpk.crt:
    openssl req -batch -new -x509 -key custMpk.pem -out custMpk.crt
    last step to recompiled tiboot3.bin, tispl.bin, and u-boot.img
    9, copy tiboot3.bin, tispl.bin, and u-boot.img to SD card
    10, power up board and fail to load Fit-image
    U-Boot SPL 2023.04 (Jun 04 2024 - 17:37:06 -0400)
    Resetting on cold boot to workaround ErrataID:i2331
    Please resend tiboot3.bin in case of UART/DFU boot
    resetting ...
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
    SPL initial stack usage: 13376 bytes
    Trying to boot from MMC2
    Authentication passed
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb
    NOTICE: BL31: Built : 17:35:44, Jun 4 2024
    I/TC:
    I/TC: OP-TEE version: 3.20.0 (gcc version 11.3.1 20220712 (Arm GNU Toolchain 11.3.Rel1)) #1 Tue Jun 4 21:36:54 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2023.04 (Jun 04 2024 - 17:38:44 -0400)
    U-Boot 2023.04 (Jun 04 2024 - 17:38:44 -0400)
    SoC: AM64X SR2.0 HS-SE
    Model: Texas Instruments AM642 EVM
    Board: AM64-EVM rev C
    DRAM: 2 GiB
    Core: 59 devices, 29 uclasses, devicetree: separate
    MMC: mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from MMC... OK
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Unidentified board claims AM64-EVM in eeprom header
    Net: eth0: ethernet@8000000port@1
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    Failed to load 'uEnv.txt'
    Failed to load '/boot/fitImage'
    name_fit_config=conf-ti_k3-am642-evm.dtb
    Wrong Image Format for bootm command
    ERROR: can't get kernel image!
    mmc0(part 0) is current device
    Scanning mmc 0:1...
    No EFI system partition
    Failed to persist EFI variables
    BootOrder not defined
    EFI boot manager: Cannot load any image
    Scanning mmc 1:1...
    starting USB...
    No working controllers found
    USB is stopped. Please issue 'usb start' first.
    starting USB...
    ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
    am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
    am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
    missing environment variable: pxeuuid
    Retrieving file: pxelinux.cfg/01-1c-63-49-1a-d7-81
    Retrieving file: pxelinux.cfg/00000000
    Retrieving file: pxelinux.cfg/default-arm-k3-am64x
    Config file not found
    starting USB...
  • Hi Weijun,
    I see you have successfully converted the device to HSSE and could also boot U-Boot successfully.
    May I know what the open issue is now?
    Prashant
  • Hello Prashant,
    yes, you are right.
    as what you might see is the "Failed to load '/boot/fitImage' " in dumping information.
    We are wondering to know what reason causes failing to load fitImage?
    The fitimage is the same as what was when AM64x evm was HSFS.
    Do we need to update fitimage and how to do it?
    Thank you
    Weijun
    The issue to me looks more like the U-Boot failing to even read the Kernel fitimage.
    Could you please run the following commands from the U-Boot commands and share the output
    => printenv mmcdev
    => printenv bootpart
    => ls mmc $mmcdev:1
    => ls mmc $mmcdev:2 /boot
    Prashant
  • sure, all are listed below:
    => printenv mmcdev
    mmcdev=1
    bootpart=1:2
    => ls mmc $mmcdev:1
    521430 tiboot3-am64x-gp-evm.bin
    524019 tiboot3-am64x_sr2-hs-evm.bin
    524019 tiboot3-am64x_sr2-hs-fs-evm.bin
    524019 tiboot3.bin
    847535 tispl.bin
    1006843 u-boot.img
    System Volume Information/
    6 file(s), 1 dir(s)
    <DIR> 4096 .
    <DIR> 4096 ..
    53765120 Image
    <SYM> 28 initrd.img
    <DIR> 4096 dtb
    11333874 vmlinuz-6.6.25-arm64-vyos
    <SYM> 25 vmlinuz
    <DIR> 4096 grub
    13688710 initrd.img-6.6.25-arm64-vyos
    241900 config-6.6.25-arm64-vyos
    3942599 System.map-6.6.25-arm64-vyos
    it looks that we did not have fitimage under boot/
    thank you.
    Weijun
  • it looks that we did not have fitimage under boot/
    Yes. That explains the failure.
    How are you flashing the rootfs to SD card? The prebuilt WIC image already comes with Kernel fitimage in the boot directory
    => ls mmc 1:2 /boot
    <DIR>       4096 .
    <DIR>       4096 ..
    <DIR>       4096 EFI
    <SYM>         24 Image
            20302336 Image-6.1.46-g247b2535b2
    <DIR>       4096 dtb
    <SYM>         27 fitImage
             8686514 fitImage-6.1.46-g247b2535b2
  • Hi Prashant,
    We are using ti-bdebstrap to build custom bootstrap images  for TI platforms.
    we use our buildvyosti.sh script instead of default build.sh to build bsp images with am64x_bookworm_09.00.00.006 package.
    then use create-sdcard.sh to create SD card.
    I did use the same scripts as what I did for HSFS before.
    I will compare our buildvyosti.sh with build.sh to figure out what problem it is. I did not pay any attention to it though.
    Weijun
    update after hours:
    By comparing buildvyosti.sh and build.sh and check out the root file system of tisdk-bookworm-am64x-am64xx-evm-rootfs/.
    there is not a fitIamge file under boot/.
    It sounds that ti-bdebstrap only takes care of bootstrap images and does not take care of kernel and fitImage though.
    Hi Prashant,
    What do you recommend us to do test with my current HSSE device?
  • Hi Weijun,
    I am not the expert on these supposedly Yocto things. So, I don't really know if this is expected or not. You may raise this query on a separate thread so it could be assigned to the right expert.
    For now, you can actually generate the FitImage manually from the Linux Kernel and DTB.
    https://software-dl.ti.com/processor-sdk-linux/esd/AM64X/latest/exports/docs/linux/Foundational_Components_Kernel_Users_Guide.html#fitimage-for-hs
    On another note, the things were working on HSFS because U-Boot loads the Kernel Image, DTB as separate images. It uses fitimage only on HSSE.
    https://software-dl.ti.com/processor-sdk-linux/esd/AM64X/latest/exports/docs/linux/Foundational_Components_Migration_Guide.html#linux-kernel
    Prashant
  • Hi Prashant,
    I created a fitImage following instructions of link
    with message of mkimage: verify_header failed for FIT Image support with exit code 1.
    the fitImage fails to boot up with dumping information below:
    U-Boot 2023.04 (Jun 13 2024 - 12:24:08 -0400)
    DRAM: 2 GiB
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    20562587 bytes read in 902 ms (21.7 MiB/s)
    ## Loading kernel from FIT Image at 90000000 ...
    Bad FIT kernel image format! (err=-42)
    do you have any idea about it?
    have a good weekend.
    Weijun
  • Hi Weijun,
    Do you mean the mkimage itself failed to create the correct fitImage on the host machine?
    Prashant
  • Hi Prashant,
    yes, you are right. we can boot up our AM64x EVM board(HSSE state) with fitImage-6.1.33-g40c32565ca which is from Ti though.
    addition information:
    mkimage -l fitImage-my-2024-06-14
    GP Header: Size d00dfeed LoadAddr 139c29b
    Thank you.
  • Hi Weijun,
    Can you please once go through the following thread which discusses booting FIT image on HSSE device
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1345798/processor-sdk-am62x-am6231-secure-boot-hs-se-verifying-hash-integrity-fit_config_verify_required_keys-no-signature-node-found-fdtd-bad-data-hash
    There is also a reference FIT image config is available in the PSDK as shown
    ❯ cat ~/ti/psdk/am64x/09.02.01.10/board-support/prebuilt-images/am64xx-evm/fitImage-its-am64xx-evm
    /dts-v1/;
            description = "Kernel fitImage for Arago/6.1.83+gitAUTOINC+c1c2f1971f/am64xx-evm";
            #address-cells = <1>;
            images {
                    kernel-1 {
                            description = "Linux kernel";
                            data = /incbin/("linux.bin");
                            type = "kernel";
                            arch = "arm64";
                            os = "linux";
                            compression = "gzip";
                            load = <0x81000000>;
                            entry = <0x81000000>;
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am642-sk.dtb {
                            description = "Flattened Device Tree blob";
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am642-sk.dtb");
                            type = "flat_dt";
                            arch = "arm64";
                            compression = "none";
                            load = <0x83000000>;
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am642-evm.dtb {
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am642-evm.dtb");
                            type = "flat_dt";
                            arch = "arm64";
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am642-evm-icssg1-dualemac.dtbo {
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am642-evm-icssg1-dualemac.dtbo");
                            type = "flat_dt";
                            arch = "arm64";
                            load = <0x83080000>;
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am642-evm-nand.dtbo {
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am642-evm-nand.dtbo");
                            type = "flat_dt";
                            arch = "arm64";
                            hash-1 {
                                    algo = "sha512";
                    fdt-ti_k3-am642-evm-icssg1-dualemac-mii.dtbo {
                            data = /incbin/("arch/arm64/boot/dts/ti/k3-am642-evm-icssg1-dualemac-mii.dtbo");
                            type = "flat_dt";
                            arch = "arm64";
                            hash-1 {
                                    algo = "sha512";
            configurations {
                    default = "conf-ti_k3-am642-sk.dtb";
                    conf-ti_k3-am642-sk.dtb {
                            description = "1 Linux kernel, FDT blob";
                            kernel = "kernel-1";
                            fdt = "fdt-ti_k3-am642-sk.dtb";
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
                                    algo = "sha512,rsa4096";
                                    key-name-hint = "custMpk";
                                    padding = "pkcs-1.5";
                                    sign-images = "kernel", "fdt";
                    conf-ti_k3-am642-evm.dtb {
                            description = "0 Linux kernel, FDT blob";
                            fdt = "fdt-ti_k3-am642-evm.dtb";
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
                    conf-ti_k3-am642-evm-icssg1-dualemac.dtbo {
                            description = "0 FDT blob";
                            fdt = "fdt-ti_k3-am642-evm-icssg1-dualemac.dtbo";
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
                                    sign-images = "fdt";
                    conf-ti_k3-am642-evm-nand.dtbo {
                            fdt = "fdt-ti_k3-am642-evm-nand.dtbo";
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
                    conf-ti_k3-am642-evm-icssg1-dualemac-mii.dtbo {
                            fdt = "fdt-ti_k3-am642-evm-icssg1-dualemac-mii.dtbo";
                            hash-1 {
                                    algo = "sha512";
                            signature-1 {
    Prashant
  • Hi Prashant,
    this is a good example for me.
    after I update my fitImage.its, I successfully get my fitImage and boot up Linux kernel.
    thank you a lot.
    Weijun
  • Thanks for the update, Weijun.
    Closing the thread...
