Kindly let us know the part numbers of the MIPI DSI and LVDS displays that are used for directly connecting and Testing them with the SK-AM62P-LP EVK.
Thanks & Regards,
Rohith M Ravi
Thanks & Regards,
Rohith M Ravi
LVDS: https://www.ti.com/tool/SK-LCD1
DSI: https://www.raspberrypi.com/products/raspberry-pi-touch-display/
Krunal
Hi Krunal,
Thanks for the update.
As per my knowledge, the MIPI Display mentioned is 2 Lane. Any 4 Lane MIPI Tested with the EVK?
Also, we plan to validate 4 cameras using the Virtual Camera feature on the EVK. For the same, we would like to confirm if we can make use of the below mentioned development board for the same. Also confirm if the support for the same is added in the Linux and Android sdk.
Thanks & Regards,
Rohith M Ravi
For Camera please create another thread and as of now, we have not tested 4 Lane MIPI on the EVK.
Krunal
Hi Krunal,
Thanks for the update. I will be closing this case here and raise a new request for the Camera.
Thanks & Regards,
Rohith M Ravi
Hi Krunal,
Regarding the DSI: https://www.raspberrypi.com/products/raspberry-pi-touch-display/ , the Display connector is for 15pin, while the DSI Connector in the EVK is 22 pin. Kindly let us know if any adapters were used for converting 22pin to 15pin so that we can interface the display with the EVK.
Thanks & Regards,
Rohith M Ravi
The panel comes with a 22pin to 15pin connector. You can also buy the following:
https://www.amazon.com/dp/B094WC68WH?ref=ppx_yo2ov_dt_b_product_details&th=1
https://www.amazon.com/uxcell-Flexible-Cable-Player-Laptop/dp/B07RS4S5ZJ?th=1
Krunal
