Part Number: SK-TDA4VM
Hello!
I tested single ScatterElements operator with this onnx file.
Compiling as 8 bit artifacts and inference on PC emulation environment works well and I checked reasonable result with sample input as below:
indices_sample = np.array([[
[3, 2, 1, 0, 4, 5],
[3, 2, 1, 0, 4, 5],
]], dtype=np.int32)
data_sample = np.zeros((1, 2, 8), dtype=np.float32)
updates_sample = np.array([[
[3, 2, 1, 0, 4, 5],
[13, 12, 11, 10, 14, 15],
]], dtype=np.float32)
Output tensor:
[[[[[ 0. 1. 2. 3. 4. 5. 0. 0.]
[ 0. 11. 12. 13. 14. 15. 0. 0.]]]]]
But inference on board doesn't work at all. It stops on VX initialization step and it hangs there and doesn't terminate.
tda4vm-sk:~/tidl_python_env# python3 tools/ti/scatter.py --file scatter.onnx /home/root/tidl_python_env/model-artifacts/scatter_8bit libtidl_onnxrt_EP loaded 0x16288140 artifacts_folder = /home/root/tidl_python_env/model-artifacts/scatter_8bit debug_level = 3 target_priority = 0 max_pre_empt_delay = 340282346638528859811704183484516925440.000000 Final number of subgraphs created are : 1, - Offloaded Nodes - 1, Total Nodes - 1 In TIDL_createStateInfer Compute on node : TIDLExecutionProvider_TIDL_0_0 ************ in TIDL_subgraphRtCreate ************ APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=5) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 488273.922438 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 488273.922537 s: VX_ZONE_INIT:Enabled 488273.922559 s: VX_ZONE_ERROR:Enabled 488273.922574 s: VX_ZONE_WARNING:Enabled 488273.923730 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 488273.924589 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
I saw this log below with executing `/opt/vx_app_arm_remote_log.out`
[C7x_1 ] 484370.240919 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 484370.241090 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 484370.241104 s: APP: Init ... Done !!! [C7x_1 ] 484370.241113 s: APP: Run ... !!! [C7x_1 ] 484370.241121 s: IPC: Starting echo test ... [C7x_1 ] 484370.241270 s: APP: Run ... Done !!! [C7x_1 ] 484370.247644 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s] [C7x_1 ] 484370.247837 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 484370.263217 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 484370.298073 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 487704.699498 s: TIDL_ScatterElementslayer Un suported layerParams.scatterElementsParams.axis !!! [C7x_1 ] 487704.704158 s: 0 1.00000 0.00000 0.00000 6 [C7x_1 ] 487719.717053 s: 3 128.00000 0.00000 0.00000 1 [C7x_1 ] 487719.747507 s: 2 1.00000 0.00000 15.00000 6 [C7x_1 ] 487719.777771 s: 4 8.00000 0.00000 15.00000 1 [C7x_1 ] 487719.808022 s: 1 1.00000 0.00000 255.00000 5
