SK-AM62B-P1: alsactl restore does not work
Part Number: SK-AM62B-P1
Dear TI
I'm using ti-processor-sdk-linux-am62xx-evm-09.02.01.09.
When I execute "alsactl store -f config", it worked correctly.
But when I tried to restore it, it report below error.
root@am62xx-evm:~# sudo alsactl restore -f config
alsa-lib ../../../alsa-lib-1.2.6.1/src/ucm/main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
If I did not use alsactl command to restore alsa config, could you let me know how to verify "alsactl restore" command with sample configuration file ?
BR
Jace
  • Hi Jace,
    Could you refer to the below link and see if it helps:
    askubuntu.com/.../how-to-save-alsamixer-settings
    Suren
  • Hi Suren.
    Above link explains how to save / restore alsa config and my test command is exactly same how to save / restore via specific file.
    Is it possible to test it with SK-62B-P1 ?
    I think that it's your EVM issue.
    During boot-up, it reports same error message like below
    root@am62xx-evm:~# journalctl | grep hw
    Apr 28 17:42:26 am62xx-evm kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    Apr 28 17:42:26 am62xx-evm kernel: hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    Jan 01 00:00:15 am62xx-evm alsactl[706]: alsa-lib ../../../alsa-lib-1.2.6.1/src/ucm/main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
    BR
    Jace
    alsactl --no-ucm restore
    should solve the problem.
    Suren
