Hi ,
Setting:
Edgeai sdk : 09_02_07_00
AM68PA/J721E (TDA4VM)
When i run my custom model for fp32 mode , it works well for -d can -c and get the expected op results but when i enable
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 1 Models - ['Blockage_FNC_FWC']
***** WARNING : tensor_bits = 32 -- Compiling for floating point - target execution is not supported for 32 bit compilation !! *****
tidl_tools_path = /home/root/tidl_tools
artifacts_folder = ../../../model-artifacts//Blockage_FNC_FWC/
tidl_tensor_bits = 32
debug_level = 4
num_tidl_subgraphs = 16
tidl_denylist =
tidl_denylist_layer_name =
tidl_denylist_layer_type =
tidl_allowlist_layer_name =
model_type =
tidl_calibration_accuracy_level = 64
tidl_calibration_options:num_frames_calibration = 4
tidl_calibration_options:bias_calibration_iterations = 3
mixed_precision_factor = -1.000000
model_group_id = 0
power_of_2_quantization = 2
ONNX QDQ Enabled = 0
enable_high_resolution_optimization = 0
pre_batchnorm_fold = 1
add_data_convert_ops = 0
output_feature_16bit_names_list =
m_params_16bit_names_list =
m_single_core_layers_names_list =
reserved_compile_constraints_flag = 1601
ti_internal_reserved_1 =
****** WARNING : Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options******
Supported TIDL layer type --- Conv -- /base/base_layer/base_layer.0/Conv
Supported TIDL layer type --- Relu -- /base/base_layer/base_layer.2/Relu
Supported TIDL layer type --- Conv -- /base/level0/level0.0/Conv
Supported TIDL layer type --- Relu -- /base/level0/level0.2/Relu
Supported TIDL layer type --- Conv -- /base/level1/level1.0/Conv
Supported TIDL layer type --- Relu -- /base/level1/level1.2/Relu
Supported TIDL layer type --- Conv -- /base/level2/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level2/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level2/tree1/conv2/Conv
Supported TIDL layer type --- MaxPool -- /base/level2/downsample/MaxPool
Supported TIDL layer type --- Conv -- /base/level2/project/project.0/Conv
Supported TIDL layer type --- Add -- /base/level2/tree1/Add
Supported TIDL layer type --- Relu -- /base/level2/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level2/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level2/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level2/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level2/tree2/Add
Supported TIDL layer type --- Relu -- /base/level2/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level2/root/Concat
Supported TIDL layer type --- Conv -- /base/level2/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level2/root/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree1/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree1/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree1/tree1/conv2/Conv
Supported TIDL layer type --- MaxPool -- /base/level3/tree1/downsample/MaxPool
Supported TIDL layer type --- Conv -- /base/level3/tree1/project/project.0/Conv
Supported TIDL layer type --- Add -- /base/level3/tree1/tree1/Add
Supported TIDL layer type --- Relu -- /base/level3/tree1/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree1/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree1/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree1/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level3/tree1/tree2/Add
Supported TIDL layer type --- Relu -- /base/level3/tree1/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level3/tree1/root/Concat
Supported TIDL layer type --- Conv -- /base/level3/tree1/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree1/root/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree2/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree2/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree2/tree1/conv2/Conv
Supported TIDL layer type --- Add -- /base/level3/tree2/tree1/Add
Supported TIDL layer type --- Relu -- /base/level3/tree2/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree2/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree2/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level3/tree2/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level3/tree2/tree2/Add
Supported TIDL layer type --- Relu -- /base/level3/tree2/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level3/tree2/root/Concat
Supported TIDL layer type --- Conv -- /base/level3/tree2/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level3/tree2/root/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree1/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree1/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree1/tree1/conv2/Conv
Supported TIDL layer type --- MaxPool -- /base/level4/tree1/downsample/MaxPool
Supported TIDL layer type --- Conv -- /base/level4/tree1/project/project.0/Conv
Supported TIDL layer type --- Add -- /base/level4/tree1/tree1/Add
Supported TIDL layer type --- Relu -- /base/level4/tree1/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree1/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree1/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree1/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level4/tree1/tree2/Add
Supported TIDL layer type --- Relu -- /base/level4/tree1/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level4/tree1/root/Concat
Supported TIDL layer type --- Conv -- /base/level4/tree1/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree1/root/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree2/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree2/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree2/tree1/conv2/Conv
Supported TIDL layer type --- Add -- /base/level4/tree2/tree1/Add
Supported TIDL layer type --- Relu -- /base/level4/tree2/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree2/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree2/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level4/tree2/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level4/tree2/tree2/Add
Supported TIDL layer type --- Relu -- /base/level4/tree2/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level4/tree2/root/Concat
Supported TIDL layer type --- Conv -- /base/level4/tree2/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level4/tree2/root/relu/Relu
Supported TIDL layer type --- Conv -- /base/level5/tree1/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level5/tree1/relu/Relu
Supported TIDL layer type --- Conv -- /base/level5/tree1/conv2/Conv
Supported TIDL layer type --- MaxPool -- /base/level5/downsample/MaxPool
Supported TIDL layer type --- Conv -- /base/level5/project/project.0/Conv
Supported TIDL layer type --- Add -- /base/level5/tree1/Add
Supported TIDL layer type --- Relu -- /base/level5/tree1/relu_1/Relu
Supported TIDL layer type --- Conv -- /base/level5/tree2/conv1/Conv
Supported TIDL layer type --- Relu -- /base/level5/tree2/relu/Relu
Supported TIDL layer type --- Conv -- /base/level5/tree2/conv2/Conv
Supported TIDL layer type --- Add -- /base/level5/tree2/Add
Supported TIDL layer type --- Relu -- /base/level5/tree2/relu_1/Relu
Supported TIDL layer type --- Concat -- /base/level5/root/Concat
Supported TIDL layer type --- Conv -- /base/level5/root/conv/Conv
Supported TIDL layer type --- Relu -- /base/level5/root/relu/Relu
Supported TIDL layer type --- Conv -- /bl/upconv_4_0/upconv_4_0.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_4_0/upconv_4_0.2/Relu
Supported TIDL layer type --- Conv -- /bl/shuffle_conv_4_0/conv/Conv
Supported TIDL layer type --- DepthToSpace -- /bl/shuffle_conv_4_0/shuffle/DepthToSpace
Supported TIDL layer type --- Concat -- /bl/Concat
Supported TIDL layer type --- Conv -- /bl/upconv_4_1/upconv_4_1.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_4_1/upconv_4_1.2/Relu
Supported TIDL layer type --- Conv -- /bl/upconv_3_0/upconv_3_0.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_3_0/upconv_3_0.2/Relu
Supported TIDL layer type --- Conv -- /bl/shuffle_conv_3_0/conv/Conv
Supported TIDL layer type --- DepthToSpace -- /bl/shuffle_conv_3_0/shuffle/DepthToSpace
Supported TIDL layer type --- Concat -- /bl/Concat_1
Supported TIDL layer type --- Conv -- /bl/upconv_3_1/upconv_3_1.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_3_1/upconv_3_1.2/Relu
Supported TIDL layer type --- Conv -- /bl/upconv_2_0/upconv_2_0.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_2_0/upconv_2_0.2/Relu
Supported TIDL layer type --- Conv -- /bl/shuffle_conv_2_0/conv/Conv
Supported TIDL layer type --- DepthToSpace -- /bl/shuffle_conv_2_0/shuffle/DepthToSpace
Supported TIDL layer type --- Concat -- /bl/Concat_2
Supported TIDL layer type --- Conv -- /bl/upconv_2_1/upconv_2_1.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_2_1/upconv_2_1.2/Relu
Supported TIDL layer type --- Conv -- /bl/upconv_1_0/upconv_1_0.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_1_0/upconv_1_0.2/Relu
Supported TIDL layer type --- Conv -- /bl/shuffle_conv_1_0/conv/Conv
Supported TIDL layer type --- DepthToSpace -- /bl/shuffle_conv_1_0/shuffle/DepthToSpace
Supported TIDL layer type --- Concat -- /bl/Concat_3
Supported TIDL layer type --- Conv -- /bl/upconv_1_1/upconv_1_1.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_1_1/upconv_1_1.2/Relu
Supported TIDL layer type --- Conv -- /bl/upconv_0_0/upconv_0_0.0/Conv
Supported TIDL layer type --- Relu -- /bl/upconv_0_0/upconv_0_0.2/Relu
Supported TIDL layer type --- Conv -- /bl/shuffle_conv_0_0/conv/Conv
Supported TIDL layer type --- DepthToSpace -- /bl/shuffle_conv_0_0/shuffle/DepthToSpace
Supported TIDL layer type --- Conv -- /bl/semantic_conv_0/Conv
Preliminary subgraphs created = 1
Final number of subgraphs created are : 1, - Offloaded Nodes - 125, Total Nodes - 125
SUGGESTION -- [TIDL_DepthToSpaceLayer] Standalone DepthToSpace layer is not optimal in this version, it is optimal if it is next to 1x1 convolutions
Running runtimes graphviz - /home/root/tidl_tools/tidl_graphVisualiser_runtimes.out ../../../model-artifacts//Blockage_FNC_FWC//allowedNode.txt ../../../model-artifacts//Blockage_FNC_FWC//tempDir/graphvizInfo.txt ../../../model-artifacts//Blockage_FNC_FWC//tempDir/runtimes_visualization.svg
*** In TIDL_createStateImportFunc ***
Compute on node : TIDLExecutionProvider_TIDL_0_0
0, Conv, 3, 1, input.1, /base/base_layer/base_layer.0/Conv_output_0
1, Relu, 1, 1, /base/base_layer/base_layer.0/Conv_output_0, /base/base_layer/base_layer.2/Relu_output_0
2, Conv, 3, 1, /base/base_layer/base_layer.2/Relu_output_0, /base/level0/level0.0/Conv_output_0
3, Relu, 1, 1, /base/level0/level0.0/Conv_output_0, /base/level0/level0.2/Relu_output_0
4, Conv, 3, 1, /base/level0/level0.2/Relu_output_0, /base/level1/level1.0/Conv_output_0
5, Relu, 1, 1, /base/level1/level1.0/Conv_output_0, /base/level1/level1.2/Relu_output_0
6, MaxPool, 1, 1, /base/level1/level1.2/Relu_output_0, /base/level2/downsample/MaxPool_output_0
7, Conv, 3, 1, /base/level2/downsample/MaxPool_output_0, /base/level2/project/project.0/Conv_output_0
8, Conv, 3, 1, /base/level1/level1.2/Relu_output_0, /base/level2/tree1/conv1/Conv_output_0
9, Relu, 1, 1, /base/level2/tree1/conv1/Conv_output_0, /base/level2/tree1/relu/Relu_output_0
10, Conv, 3, 1, /base/level2/tree1/relu/Relu_output_0, /base/level2/tree1/conv2/Conv_output_0
11, Add, 2, 1, /base/level2/tree1/conv2/Conv_output_0, /base/level2/tree1/Add_output_0
12, Relu, 1, 1, /base/level2/tree1/Add_output_0, /base/level2/tree1/relu_1/Relu_output_0
13, Conv, 3, 1, /base/level2/tree1/relu_1/Relu_output_0, /base/level2/tree2/conv1/Conv_output_0
14, Relu, 1, 1, /base/level2/tree2/conv1/Conv_output_0, /base/level2/tree2/relu/Relu_output_0
15, Conv, 3, 1, /base/level2/tree2/relu/Relu_output_0, /base/level2/tree2/conv2/Conv_output_0
16, Add, 2, 1, /base/level2/tree2/conv2/Conv_output_0, /base/level2/tree2/Add_output_0
17, Relu, 1, 1, /base/level2/tree2/Add_output_0, /base/level2/tree2/relu_1/Relu_output_0
18, Concat, 2, 1, /base/level2/tree2/relu_1/Relu_output_0, /base/level2/root/Concat_output_0
19, Conv, 3, 1, /base/level2/root/Concat_output_0, /base/level2/root/conv/Conv_output_0
20, Relu, 1, 1, /base/level2/root/conv/Conv_output_0, /base/level2/root/relu/Relu_output_0
21, MaxPool, 1, 1, /base/level2/root/relu/Relu_output_0, /base/level3/tree1/downsample/MaxPool_output_0
22, Conv, 3, 1, /base/level3/tree1/downsample/MaxPool_output_0, /base/level3/tree1/project/project.0/Conv_output_0
23, Conv, 3, 1, /base/level2/root/relu/Relu_output_0, /base/level3/tree1/tree1/conv1/Conv_output_0
24, Relu, 1, 1, /base/level3/tree1/tree1/conv1/Conv_output_0, /base/level3/tree1/tree1/relu/Relu_output_0
25, Conv, 3, 1, /base/level3/tree1/tree1/relu/Relu_output_0, /base/level3/tree1/tree1/conv2/Conv_output_0
26, Add, 2, 1, /base/level3/tree1/tree1/conv2/Conv_output_0, /base/level3/tree1/tree1/Add_output_0
27, Relu, 1, 1, /base/level3/tree1/tree1/Add_output_0, /base/level3/tree1/tree1/relu_1/Relu_output_0
28, Conv, 3, 1, /base/level3/tree1/tree1/relu_1/Relu_output_0, /base/level3/tree1/tree2/conv1/Conv_output_0
29, Relu, 1, 1, /base/level3/tree1/tree2/conv1/Conv_output_0, /base/level3/tree1/tree2/relu/Relu_output_0
30, Conv, 3, 1, /base/level3/tree1/tree2/relu/Relu_output_0, /base/level3/tree1/tree2/conv2/Conv_output_0
31, Add, 2, 1, /base/level3/tree1/tree2/conv2/Conv_output_0, /base/level3/tree1/tree2/Add_output_0
32, Relu, 1, 1, /base/level3/tree1/tree2/Add_output_0, /base/level3/tree1/tree2/relu_1/Relu_output_0
33, Concat, 2, 1, /base/level3/tree1/tree2/relu_1/Relu_output_0, /base/level3/tree1/root/Concat_output_0
34, Conv, 3, 1, /base/level3/tree1/root/Concat_output_0, /base/level3/tree1/root/conv/Conv_output_0
35, Relu, 1, 1, /base/level3/tree1/root/conv/Conv_output_0, /base/level3/tree1/root/relu/Relu_output_0
36, Conv, 3, 1, /base/level3/tree1/root/relu/Relu_output_0, /base/level3/tree2/tree1/conv1/Conv_output_0
37, Relu, 1, 1, /base/level3/tree2/tree1/conv1/Conv_output_0, /base/level3/tree2/tree1/relu/Relu_output_0
38, Conv, 3, 1, /base/level3/tree2/tree1/relu/Relu_output_0, /base/level3/tree2/tree1/conv2/Conv_output_0
39, Add, 2, 1, /base/level3/tree2/tree1/conv2/Conv_output_0, /base/level3/tree2/tree1/Add_output_0
40, Relu, 1, 1, /base/level3/tree2/tree1/Add_output_0, /base/level3/tree2/tree1/relu_1/Relu_output_0
41, Conv, 3, 1, /base/level3/tree2/tree1/relu_1/Relu_output_0, /base/level3/tree2/tree2/conv1/Conv_output_0
42, Relu, 1, 1, /base/level3/tree2/tree2/conv1/Conv_output_0, /base/level3/tree2/tree2/relu/Relu_output_0
43, Conv, 3, 1, /base/level3/tree2/tree2/relu/Relu_output_0, /base/level3/tree2/tree2/conv2/Conv_output_0
44, Add, 2, 1, /base/level3/tree2/tree2/conv2/Conv_output_0, /base/level3/tree2/tree2/Add_output_0
45, Relu, 1, 1, /base/level3/tree2/tree2/Add_output_0, /base/level3/tree2/tree2/relu_1/Relu_output_0
46, Concat, 4, 1, /base/level3/tree2/tree2/relu_1/Relu_output_0, /base/level3/tree2/root/Concat_output_0
47, Conv, 3, 1, /base/level3/tree2/root/Concat_output_0, /base/level3/tree2/root/conv/Conv_output_0
48, Relu, 1, 1, /base/level3/tree2/root/conv/Conv_output_0, /base/level3/tree2/root/relu/Relu_output_0
49, MaxPool, 1, 1, /base/level3/tree2/root/relu/Relu_output_0, /base/level4/tree1/downsample/MaxPool_output_0
50, Conv, 3, 1, /base/level4/tree1/downsample/MaxPool_output_0, /base/level4/tree1/project/project.0/Conv_output_0
51, Conv, 3, 1, /base/level3/tree2/root/relu/Relu_output_0, /base/level4/tree1/tree1/conv1/Conv_output_0
52, Relu, 1, 1, /base/level4/tree1/tree1/conv1/Conv_output_0, /base/level4/tree1/tree1/relu/Relu_output_0
53, Conv, 3, 1, /base/level4/tree1/tree1/relu/Relu_output_0, /base/level4/tree1/tree1/conv2/Conv_output_0
54, Add, 2, 1, /base/level4/tree1/tree1/conv2/Conv_output_0, /base/level4/tree1/tree1/Add_output_0
55, Relu, 1, 1, /base/level4/tree1/tree1/Add_output_0, /base/level4/tree1/tree1/relu_1/Relu_output_0
56, Conv, 3, 1, /base/level4/tree1/tree1/relu_1/Relu_output_0, /base/level4/tree1/tree2/conv1/Conv_output_0
57, Relu, 1, 1, /base/level4/tree1/tree2/conv1/Conv_output_0, /base/level4/tree1/tree2/relu/Relu_output_0
58, Conv, 3, 1, /base/level4/tree1/tree2/relu/Relu_output_0, /base/level4/tree1/tree2/conv2/Conv_output_0
59, Add, 2, 1, /base/level4/tree1/tree2/conv2/Conv_output_0, /base/level4/tree1/tree2/Add_output_0
60, Relu, 1, 1, /base/level4/tree1/tree2/Add_output_0, /base/level4/tree1/tree2/relu_1/Relu_output_0
61, Concat, 2, 1, /base/level4/tree1/tree2/relu_1/Relu_output_0, /base/level4/tree1/root/Concat_output_0
62, Conv, 3, 1, /base/level4/tree1/root/Concat_output_0, /base/level4/tree1/root/conv/Conv_output_0
63, Relu, 1, 1, /base/level4/tree1/root/conv/Conv_output_0, /base/level4/tree1/root/relu/Relu_output_0
64, Conv, 3, 1, /base/level4/tree1/root/relu/Relu_output_0, /base/level4/tree2/tree1/conv1/Conv_output_0
65, Relu, 1, 1, /base/level4/tree2/tree1/conv1/Conv_output_0, /base/level4/tree2/tree1/relu/Relu_output_0
66, Conv, 3, 1, /base/level4/tree2/tree1/relu/Relu_output_0, /base/level4/tree2/tree1/conv2/Conv_output_0
67, Add, 2, 1, /base/level4/tree2/tree1/conv2/Conv_output_0, /base/level4/tree2/tree1/Add_output_0
68, Relu, 1, 1, /base/level4/tree2/tree1/Add_output_0, /base/level4/tree2/tree1/relu_1/Relu_output_0
69, Conv, 3, 1, /base/level4/tree2/tree1/relu_1/Relu_output_0, /base/level4/tree2/tree2/conv1/Conv_output_0
70, Relu, 1, 1, /base/level4/tree2/tree2/conv1/Conv_output_0, /base/level4/tree2/tree2/relu/Relu_output_0
71, Conv, 3, 1, /base/level4/tree2/tree2/relu/Relu_output_0, /base/level4/tree2/tree2/conv2/Conv_output_0
72, Add, 2, 1, /base/level4/tree2/tree2/conv2/Conv_output_0, /base/level4/tree2/tree2/Add_output_0
73, Relu, 1, 1, /base/level4/tree2/tree2/Add_output_0, /base/level4/tree2/tree2/relu_1/Relu_output_0
74, Concat, 4, 1, /base/level4/tree2/tree2/relu_1/Relu_output_0, /base/level4/tree2/root/Concat_output_0
75, Conv, 3, 1, /base/level4/tree2/root/Concat_output_0, /base/level4/tree2/root/conv/Conv_output_0
76, Relu, 1, 1, /base/level4/tree2/root/conv/Conv_output_0, /base/level4/tree2/root/relu/Relu_output_0
77, MaxPool, 1, 1, /base/level4/tree2/root/relu/Relu_output_0, /base/level5/downsample/MaxPool_output_0
78, Conv, 3, 1, /base/level5/downsample/MaxPool_output_0, /base/level5/project/project.0/Conv_output_0
79, Conv, 3, 1, /base/level4/tree2/root/relu/Relu_output_0, /base/level5/tree1/conv1/Conv_output_0
80, Relu, 1, 1, /base/level5/tree1/conv1/Conv_output_0, /base/level5/tree1/relu/Relu_output_0
81, Conv, 3, 1, /base/level5/tree1/relu/Relu_output_0, /base/level5/tree1/conv2/Conv_output_0
82, Add, 2, 1, /base/level5/tree1/conv2/Conv_output_0, /base/level5/tree1/Add_output_0
83, Relu, 1, 1, /base/level5/tree1/Add_output_0, /base/level5/tree1/relu_1/Relu_output_0
84, Conv, 3, 1, /base/level5/tree1/relu_1/Relu_output_0, /base/level5/tree2/conv1/Conv_output_0
85, Relu, 1, 1, /base/level5/tree2/conv1/Conv_output_0, /base/level5/tree2/relu/Relu_output_0
86, Conv, 3, 1, /base/level5/tree2/relu/Relu_output_0, /base/level5/tree2/conv2/Conv_output_0
87, Add, 2, 1, /base/level5/tree2/conv2/Conv_output_0, /base/level5/tree2/Add_output_0
88, Relu, 1, 1, /base/level5/tree2/Add_output_0, /base/level5/tree2/relu_1/Relu_output_0
89, Concat, 3, 1, /base/level5/tree2/relu_1/Relu_output_0, /base/level5/root/Concat_output_0
90, Conv, 3, 1, /base/level5/root/Concat_output_0, /base/level5/root/conv/Conv_output_0
91, Relu, 1, 1, /base/level5/root/conv/Conv_output_0, /base/level5/root/relu/Relu_output_0
92, Conv, 3, 1, /base/level5/root/relu/Relu_output_0, /bl/upconv_4_0/upconv_4_0.0/Conv_output_0
93, Relu, 1, 1, /bl/upconv_4_0/upconv_4_0.0/Conv_output_0, /bl/upconv_4_0/upconv_4_0.2/Relu_output_0
94, Conv, 2, 1, /bl/upconv_4_0/upconv_4_0.2/Relu_output_0, /bl/shuffle_conv_4_0/conv/Conv_output_0
95, DepthToSpace, 1, 1, /bl/shuffle_conv_4_0/conv/Conv_output_0, /bl/shuffle_conv_4_0/shuffle/DepthToSpace_output_0
96, Concat, 2, 1, /bl/shuffle_conv_4_0/shuffle/DepthToSpace_output_0, /bl/Concat_output_0
97, Conv, 3, 1, /bl/Concat_output_0, /bl/upconv_4_1/upconv_4_1.0/Conv_output_0
98, Relu, 1, 1, /bl/upconv_4_1/upconv_4_1.0/Conv_output_0, /bl/upconv_4_1/upconv_4_1.2/Relu_output_0
99, Conv, 3, 1, /bl/upconv_4_1/upconv_4_1.2/Relu_output_0, /bl/upconv_3_0/upconv_3_0.0/Conv_output_0
100, Relu, 1, 1, /bl/upconv_3_0/upconv_3_0.0/Conv_output_0, /bl/upconv_3_0/upconv_3_0.2/Relu_output_0
101, Conv, 2, 1, /bl/upconv_3_0/upconv_3_0.2/Relu_output_0, /bl/shuffle_conv_3_0/conv/Conv_output_0
102, DepthToSpace, 1, 1, /bl/shuffle_conv_3_0/conv/Conv_output_0, /bl/shuffle_conv_3_0/shuffle/DepthToSpace_output_0
103, Concat, 2, 1, /bl/shuffle_conv_3_0/shuffle/DepthToSpace_output_0, /bl/Concat_1_output_0
104, Conv, 3, 1, /bl/Concat_1_output_0, /bl/upconv_3_1/upconv_3_1.0/Conv_output_0
105, Relu, 1, 1, /bl/upconv_3_1/upconv_3_1.0/Conv_output_0, /bl/upconv_3_1/upconv_3_1.2/Relu_output_0
106, Conv, 3, 1, /bl/upconv_3_1/upconv_3_1.2/Relu_output_0, /bl/upconv_2_0/upconv_2_0.0/Conv_output_0
107, Relu, 1, 1, /bl/upconv_2_0/upconv_2_0.0/Conv_output_0, /bl/upconv_2_0/upconv_2_0.2/Relu_output_0
108, Conv, 2, 1, /bl/upconv_2_0/upconv_2_0.2/Relu_output_0, /bl/shuffle_conv_2_0/conv/Conv_output_0
109, DepthToSpace, 1, 1, /bl/shuffle_conv_2_0/conv/Conv_output_0, /bl/shuffle_conv_2_0/shuffle/DepthToSpace_output_0
110, Concat, 2, 1, /bl/shuffle_conv_2_0/shuffle/DepthToSpace_output_0, /bl/Concat_2_output_0
111, Conv, 3, 1, /bl/Concat_2_output_0, /bl/upconv_2_1/upconv_2_1.0/Conv_output_0
112, Relu, 1, 1, /bl/upconv_2_1/upconv_2_1.0/Conv_output_0, /bl/upconv_2_1/upconv_2_1.2/Relu_output_0
113, Conv, 3, 1, /bl/upconv_2_1/upconv_2_1.2/Relu_output_0, /bl/upconv_1_0/upconv_1_0.0/Conv_output_0
114, Relu, 1, 1, /bl/upconv_1_0/upconv_1_0.0/Conv_output_0, /bl/upconv_1_0/upconv_1_0.2/Relu_output_0
115, Conv, 2, 1, /bl/upconv_1_0/upconv_1_0.2/Relu_output_0, /bl/shuffle_conv_1_0/conv/Conv_output_0
116, DepthToSpace, 1, 1, /bl/shuffle_conv_1_0/conv/Conv_output_0, /bl/shuffle_conv_1_0/shuffle/DepthToSpace_output_0
117, Concat, 2, 1, /bl/shuffle_conv_1_0/shuffle/DepthToSpace_output_0, /bl/Concat_3_output_0
118, Conv, 3, 1, /bl/Concat_3_output_0, /bl/upconv_1_1/upconv_1_1.0/Conv_output_0
119, Relu, 1, 1, /bl/upconv_1_1/upconv_1_1.0/Conv_output_0, /bl/upconv_1_1/upconv_1_1.2/Relu_output_0
120, Conv, 3, 1, /bl/upconv_1_1/upconv_1_1.2/Relu_output_0, /bl/upconv_0_0/upconv_0_0.0/Conv_output_0
121, Relu, 1, 1, /bl/upconv_0_0/upconv_0_0.0/Conv_output_0, /bl/upconv_0_0/upconv_0_0.2/Relu_output_0
122, Conv, 2, 1, /bl/upconv_0_0/upconv_0_0.2/Relu_output_0, /bl/shuffle_conv_0_0/conv/Conv_output_0
123, DepthToSpace, 1, 1, /bl/shuffle_conv_0_0/conv/Conv_output_0, /bl/shuffle_conv_0_0/shuffle/DepthToSpace_output_0
124, Conv, 2, 1, /bl/shuffle_conv_0_0/shuffle/DepthToSpace_output_0, 656
Input tensor name - input.1
Output tensor name - 656
Graph Domain TO version : 14In TIDL_onnxRtImportInit subgraph_name=subgraph_0
Layer 0, subgraph id subgraph_0, name=656
Layer 1, subgraph id subgraph_0, name=input.1
In TIDL_runtimesOptimizeNet: LayerIndex = 127, dataIndex = 126
************** Frame index 1 : Running float import *************
In TIDL_runtimesPostProcessNet
In TIDL_runtimesPostProcessNet 1
In TIDL_runtimesPostProcessNet 2
In TIDL_runtimesPostProcessNet 3
** ALL MODEL CHECK PASSED **
In TIDL_runtimesPostProcessNet 4
************ in TIDL_subgraphRtCreate ************
The soft limit is 2048
The hard limit is 2048
MEM: Init ... !!!
MEM: Init ... Done !!!
0.0s: VX_ZONE_INIT:Enabled
0.3s: VX_ZONE_ERROR:Enabled
0.4s: VX_ZONE_WARNING:Enabled
0.1860s: VX_ZONE_INIT:[tivxInit:185] Initialization Done !!!
************ TIDL_subgraphRtCreate done ************
********** Frame Index 1 : Running float inference **********
********** Frame Index 2 : Running float inference **********
********** Frame Index 3 : Running float inference **********
************ Frame index 4 : Running float inference ****************
************ in TIDL_subgraphRtDelete ************
MEM: Deinit ... !!!
MEM: Alloc's: 26 alloc's of 350150041 bytes
MEM: Free's : 26 free's of 350150041 bytes
MEM: Open's : 0 allocs of 0 bytes
MEM:
Running_Model : Blockage_FNC_FWC
Running shape inference on model /home/root/lucid/model_onnx/blockage_v1.onnx
***************Running_Inference Section **********
This is Lucid Model for image : /home/root/lucid/data_onnx/blockage_tst_imgs/1lPI05-cam-03-PRIMAX-IMX390-20220127_134757-000000.png
*********The Model output is :[[[[[[0. 0. 0. ... 0. 0. 0.]
[0. 0. 0. ... 0. 0. 0.]]
[0. 0. 0. ... 0. 0. 0.]]]]]]
*********The Model output shape is :(1, 1, 1, 2, 256, 384)
/n The max value in the op :0.0
***************Running_Benchmark_Section **********
This is Lucid Model for image : /home/root/lucid/data_onnx/blockage_tst_imgs/BCMr0p-cam-03-PRIMAX-IMX390-20220127_142921-000270.png
This is Lucid Model for image : /home/root/lucid/data_onnx/blockage_tst_imgs/Dh020b-cam-03-PRIMAX-IMX390-20220127_185825-000180.png
This is Lucid Model for image : /home/root/lucid/data_onnx/blockage_tst_imgs/dQcJ01-cam-03-PRIMAX-IMX390-20220415_160448-000001.png
Completed_Model : 1, Name : Blockage_FNC_FWC , Total time : -3030295561403.24, Offload Time : -1299569907245.47 , DDR RW MBs : 0, Output File : py_out_Blockage_FNC_FWC_dQcJ01-cam-03-PRIMAX-IMX390-20220415_160448-000001.png
debug_level = 4
tidl_denylist =
model_type =
model_group_id = 0
add_data_convert_ops = 3
WARNING: Conv Layer /bl/upconv_4_1/upconv_4_1.0/Conv's coeff cannot be found(or not match) in coef file, Random coeff will be generated! Only for evaluation usage! Results are all random!
WARNING: Conv Layer /bl/upconv_3_1/upconv_3_1.0/Conv's coeff cannot be found(or not match) in coef file, Random coeff will be generated! Only for evaluation usage! Results are all random!
WARNING: Conv Layer /bl/upconv_2_1/upconv_2_1.0/Conv's coeff cannot be found(or not match) in coef file, Random coeff will be generated! Only for evaluation usage! Results are all random!
WARNING: Conv Layer /bl/upconv_1_1/upconv_1_1.0/Conv's coeff cannot be found(or not match) in coef file, Random coeff will be generated! Only for evaluation usage! Results are all random!
WARNING: Conv Layer /bl/semantic_conv_0/Conv's coeff cannot be found(or not match) in coef file, Random coeff will be generated! Only for evaluation usage! Results are all random!
In TI
*********The Model output is :[[[[[[0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.]
[0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.]]
[0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.]]]]]]
*********The Model output shape is :(1, 1, 1, 2, 8, 12)
Completed_Model : 1, Name : Blockage_FNC_FWC , Total time : -3030290789126.60, Offload Time : -1299569907245.47 , DDR RW MBs : 0, Output File : py_out_Blockage_FNC_FWC_dQcJ01-cam-03-PRIMAX-IMX390-20220415_160448-000001.png
