Part Number: TDA4VM
I have been following this [LINK].
The yolo.zip (in the link) file contains import and infer config files.
However, as per documentation [LINK], it does not support parameters provided in import_config files.
Please guide, if I am going wrong somewhere.
I also followed the steps provided in [LINK], I am encountering this error:
model_config :
'yolop' : {
'model_path' : os.path.join(models_base_path, 'yolop.onnx'),
'source' : {'model_url': '', 'opt': True, 'infer_shape' : True, \
'meta_arch_url' : ''},
'mean': [0, 0, 0],
'std' : [0.003921568627, 0.003921568627, 0.003921568627],
'num_images' : numImages,
'num_classes': 1000,
'model_type': 'classification',
'meta_layers_names_list' : os.path.join(models_base_path, 'yolop.prototxt'),
'session_name' : 'onnxrt' ,
'meta_arch_type' : 6
_______________________________________________________________________
ERROR :
root@81731c42f150:/home/examples/osrt_python/ort# python3 onnxrt_ep.py -c
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
Running 1 Models - ['yolop']
Running_Model : yolop
-111-------------> ['../../../test_data/airshow.jpg', '../../../test_data/ADE_val_00001801.jpg']
WARNING : 'meta_layers_names_list' is not provided - running OD post processing in ARM mode
TIDL Meta PipeLine (Proto) File :
Number of OD backbone nodes = 0
Size of odBackboneNodeIds = 0
Preliminary subgraphs created = 4
Final number of subgraphs created are : 1, - Offloaded Nodes - 252, Total Nodes - 356
--222----------> 0 0
------4444-----> {'images': array([[[[0.7137255 , 0.7137255 , 0.7137255 , ..., 0.65882355,
0.65882355, 0.65882355],
[0.1764706 , 0.1764706 , 0.17254902, ..., 0.49803925,
0.49411768, 0.49411768],
0.49803925, 0.49803925],
0.49803925, 0.49803925]],
[[0.7058824 , 0.7058824 , 0.7058824 , ..., 0.64705884,
0.64705884, 0.64705884],
[0.1764706 , 0.1764706 , 0.17254902, ..., 0.47450984,
0.47450984, 0.47450984],
[0.1764706 , 0.1764706 , 0.17254902, ..., 0.4784314 ,
0.4784314 , 0.4784314 ],
0.4784314 , 0.4784314 ]],
[[0.7254902 , 0.7254902 , 0.7254902 , ..., 0.6745098 ,
0.6745098 , 0.6745098 ],
[0.1764706 , 0.1764706 , 0.17254902, ..., 0.4039216 ,
0.40000004, 0.39607847],
0.4039216 , 0.4039216 ],
0.40784317, 0.40784317]]]], dtype=float32)}
************** Frame index 1 : Running float import *************
INFORMATION: [TIDL_ResizeLayer] Resize_107 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_125 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1175 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1192 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1209 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1216 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1233 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
INFORMATION: [TIDL_ResizeLayer] Resize_1250 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
WARNING: [TIDL_E_DATAFLOW_INFO_NULL] ti_cnnperfsim.out fails to allocate memory in MSMC. Please look into perfsim log. This model can only be used on PC emulation, it will get fault on target.
** 9 WARNINGS 0 ERRORS **
0.0s: VX_ZONE_INIT:Enabled
0.25s: VX_ZONE_ERROR:Enabled
0.29s: VX_ZONE_WARNING:Enabled
0.1657s: VX_ZONE_INIT:[tivxInit:178] Initialization Done !!!
0.88408s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:344] Calling ialg.algAlloc failed with status = -1110
0.88434s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:659] tivxAlgiVisionCreate returned NULL
0.88639s: VX_ZONE_ERROR:[ownContextSendCmd:817] Command ack message returned failure cmd_status: -1
0.88660s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
0.88666s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
0.88670s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
0.88674s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
0.88681s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
0.88688s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
0.88692s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
0.101669s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:344] Calling ialg.algAlloc failed with status = -1110
0.101694s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:659] tivxAlgiVisionCreate returned NULL
0.101919s: VX_ZONE_ERROR:[ownContextSendCmd:817] Command ack message returned failure cmd_status: -1
0.101956s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
0.101964s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
0.101970s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
0.101975s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
0.101984s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
0.101992s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
0.101998s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
0.102119s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
0.102126s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
0.102131s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
ERROR: Running TIDL graph ... Failed !!!
********** Frame Index 1 : Running float inference **********
2024-06-14 13:48:42.507268027 [E:onnxruntime:, sequential_executor.cc:339 Execute] Non-zero status code returned while running Slice node. Name:'Slice_896' Status Message: 'axes' has an axis outside of the tensor dimension count
Traceback (most recent call last):
File "onnxrt_ep.py", line 261, in <module>
run_model(model, mIdx)
File "onnxrt_ep.py", line 186, in run_model
imgs, output, proc_time, sub_graph_time, height, width = infer_image(sess, input_images, config)
File "onnxrt_ep.py", line 100, in infer_image
output = list(sess.run(None, {input_name: input_data}))
File "/usr/local/lib/python3.6/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 188, in run
return self._sess.run(output_names, input_feed, run_options)
onnxruntime.capi.onnxruntime_pybind11_state.InvalidArgument: [ONNXRuntimeError] : 2 : INVALID_ARGUMENT : Non-zero status code returned while running Slice node. Name:'Slice_896' Status Message: 'axes' has an axis outside of the tensor dimension count
------4444-----> {'images': (1, 3, 640, 640)}
0.30s: VX_ZONE_ERROR:Enabled
0.32s: VX_ZONE_WARNING:Enabled
0.1384s: VX_ZONE_INIT:[tivxInit:178] Initialization Done !!!
0.86043s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:344] Calling ialg.algAlloc failed with status = -1110
0.86078s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:659] tivxAlgiVisionCreate returned NULL
0.86294s: VX_ZONE_ERROR:[ownContextSendCmd:817] Command ack message returned failure cmd_status: -1
0.86331s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
0.86339s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
0.86344s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
0.86349s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
0.86358s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
0.86367s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
0.86372s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
0.100158s: VX_ZONE_ERROR:[tivxAlgiVisionCreate:344] Calling ialg.algAlloc failed with status = -1110
0.100183s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:659] tivxAlgiVisionCreate returned NULL
0.100367s: VX_ZONE_ERROR:[ownContextSendCmd:817] Command ack message returned failure cmd_status: -1
0.100397s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
0.100404s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
0.100410s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
0.100415s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
0.100424s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
0.100432s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
0.100440s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
0.100597s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
0.100608s: VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
0.100613s: VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
2024-06-14 13:49:24.034944762 [E:onnxruntime:, sequential_executor.cc:339 Execute] Non-zero status code returned while running Slice node. Name:'Slice_896' Status Message: 'axes' has an axis outside of the tensor dimension count
onnxruntime.capi.onnxruntime_pybind11_state.InvalidArgument: [ONNXRuntimeError] : 2 : INVALID_ARGUMENT : Non-zero status code returned while running Slice node. Name:'Slice_896' Status Message: 'axes' has an axis outside of the tensor dimension countThank you
Best
Prabhat
