Part Number: AM3352
I have followed the same building of TISDK 9.1 1.2. Building the SDK with Yocto — Processor SDK Linux for AM335X Documentation
this below error i was not faced previously(means i am able to build successfully) but if i freshly clone the same build steps as mentioned above.. in same build machine
I observed that we are also getting build error as below,
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:06
Sstate summary: Wanted 3593 Local 0 Mirrors 0 Missed 3593 Current 488 (0% match, 11% complete)
NOTE: Executing Tasks
ERROR: binutils-cross-arm-2.38-r0 do_compile: oe_runmake failed
ERROR: binutils-cross-arm-2.38-r0 do_compile: ExecutionError('/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750', 1, None, None)
ERROR: Logfile of failure stored in: /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/log.do_compile.459750
Log data follows:
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8
| make[1]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi'
| make[1]: Nothing to be done for 'all-target'.
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libiberty'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/zlib'
| true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc " "CFLAGS=-isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe " "CXXFLAGS=-isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe " "CFLAGS_FOR_BUILD=-isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe" "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/hosttools/install -c" "INSTALL_DATA=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/hosttools/install -c -m 644" "INSTALL_PROGRAM=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/hosttools/install -c" "INSTALL_SCRIPT=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/hosttools/install -c" "LDFLAGS=-L/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/lib -L/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/lib -Wl,-O1" "LIBCFLAGS=-isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe " "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000 " "PICFLAG=" "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS=" "exec_prefix=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr" "infodir=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/share/info" "libdir=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/lib/arm-oe-linux-gnueabi" "prefix=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr" "tooldir=/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/arm-oe-linux-gnueabi" "AR=ar --plugin /usr/lib/gcc/x86_64-linux-gnu/11/liblto_plugin.so" "AS=as " "CC=gcc " "CXX=g++ " "LD=ld " "LIBCFLAGS=-isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe " "NM=nm" "PICFLAG=" "RANLIB=ranlib -D --plugin /usr/lib/gcc/x86_64-linux-gnu/11/liblto_plugin.so" "DESTDIR=" DO=all multi-do # make
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/zlib'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libbacktrace'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/intl'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/intl'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/etc'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/etc'
| make all-am
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libbacktrace'
| true DO=all multi-do # make
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libiberty/testsuite'
| make[3]: Nothing to be done for 'all'.
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libiberty/testsuite'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libiberty'
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libbacktrace'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libbacktrace'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| Making info in doc
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/doc'
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/doc'
| Making info in po
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/po'
| make[3]: Nothing to be done for 'info'.
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/po'
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| make[3]: Nothing to be done for 'info-am'.
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| make all-recursive
| Making all in doc
| make[4]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/doc'
| make[4]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/doc'
| Making all in po
| make[4]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/po'
| make[4]: Nothing to be done for 'all'.
| make[4]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd/po'
| make[4]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| make[4]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/bfd'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libctf'
| make all-am
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libctf'
| make[2]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libctf'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/libctf'
| make all-recursive
| make[3]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| Making all in .
| make[4]: Entering directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| /bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../../opcodes -I. -I../../opcodes -I../bfd -I../../opcodes/../include -I../../opcodes/../bfd -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wstack-usage=262144 -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o dis-buf.lo ../../opcodes/dis-buf.c
| /bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../../opcodes -I. -I../../opcodes -I../bfd -I../../opcodes/../include -I../../opcodes/../bfd -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wstack-usage=262144 -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o disassemble.lo -DARCH_arm ../../opcodes/disassemble.c
| /bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../../opcodes -I. -I../../opcodes -I../bfd -I../../opcodes/../include -I../../opcodes/../bfd -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wstack-usage=262144 -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o dis-init.lo ../../opcodes/dis-init.c
| /bin/bash ./libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../../opcodes -I. -I../../opcodes -I../bfd -I../../opcodes/../include -I../../opcodes/../bfd -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wstack-usage=262144 -isystem/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o arm-dis.lo ../../opcodes/arm-dis.c
| /bin/bash: ./libtool: No such file or directory
| make[4]: *** [Makefile:1109: dis-buf.lo] Error 127
| make[4]: *** Waiting for unfinished jobs....
| make[4]: *** [Makefile:1389: disassemble.lo] Error 127
| make[4]: *** [Makefile:1109: dis-init.lo] Error 127
| make[4]: *** [Makefile:1109: arm-dis.lo] Error 127
| make[4]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| make[3]: *** [Makefile:1148: all-recursive] Error 1
| make[3]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| make[2]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/opcodes'
| make[2]: *** [Makefile:787: all] Error 2
| make[1]: *** [Makefile:3529: all-opcodes] Error 2
| make[1]: Leaving directory '/home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi'
| make: *** [Makefile:1000: all] Error 2
| ERROR: oe_runmake failed
| WARNING: /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750:189 exit 1 from 'exit 1'
| WARNING: Backtrace (BB generated script):
| #1: bbfatal_log, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 189
| #2: die, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 173
| #3: oe_runmake, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 168
| #4: autotools_do_compile, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 163
| #5: do_compile, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 158
| #6: main, /home/sem3user/cloned_repo/SEM3T_COM/build/arago-tmp-default-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.459750, line 202
ERROR: Task (/home/sem3user/cloned_repo/SEM3T_COM/sources/oe-core/meta/recipes-devtools/binutils/binutils-cross_2.38.bb:do_compile) failed with exit code '1'
may i know what might be the reason/cause for this?
