AM6442: IPCnotify for baremetal OS
Part Number: AM6442
I could see the example given under SDK 8.06 (IPCnotify) which uses freeRTOS. It first creates a task and call ipc_notify_echo_main() that I believe takes care of the interrupt while sending/recev data over IPC. Now how can we implement the same in baremetal OS. Please suggest. I could see ,the code stuck at ipcnotify_syncALL()
  • Hello Zaki,
    Thanks for reaching out to Texas Instruments E2E support forum.
    Can you please tell how are you running the example? Are you loading and running the ipc_notify_echo example on each remote core and still seeing the code stuck issue?
    I have tried to run the ipc_notify_echo nortos example on my end and I am able to run it without getting stuck anywhere.
    Please refer below video for reference.
    Tushar
  • The example code runs perfectly fine. And I can see,  It uses freeRTOS. Now I am trying to implement the IPCnotify in our baremetal OS. So far, I am not successful yet. It stucks at sync_ALL() function.
  • Hello Zaki,
    Can you please confirm by baremetal OS you mean the nortos example for ipc_notify_echo is not there in our MCU+SDK offering?
    You can port the existing ipc_notfiy_echo freertos example to nortos using any empty_nortos project provided in MCU+SDK examples.
    I have created a nortos version of ipc_notify_echo_r5fss0-0 project attached below.
    Project - ipc_notify_echo_am64x_evm_r5fss0_0_nortos.zip
    Please let us know if the above attached project works.
    Tushar
