J721S2XSOMXEVM: [J721S2XSOMXEVM] TIDL concat layer Issue
Part Number: J721S2XSOMXEVM
Hello, TI member,
We are currently verifying our network model using TIDL RT.
We got expected results in host emulation mode, but the results are different in target mode with same environment.
This problem occurred while using the current PSDK 9.0 version, and in PSDK 8.6, both the host emulation mode and target mode results were the same.
 As a result of comparing each layer dump, the different results started from the concat layer.
Num|TIDL Layer Name |Out Data Name |Group |#Ins |#Outs |Inbuf Ids |Outbuf Id |In NCHW |Out NCHW |MACS |
81|TIDL_CustomLayer | | 0| 3| 1| 74Q4 76Q1 60Q2 x x x x x | 81Q2 | 1 1 256 640 | 1 32 256 1 | 0 |
114|TIDL_DataConvertLayer | | 0| 1| 1|112Q0 x x x x x x x |114Q2 | 1 4 256 1 | 1 4 256 1 | 4096 |
116|TIDL_ConcatLayer | | 0| 2| 1| 81Q2 114Q2 x x x x x x |116Q2 | 1 32 256 1 | 1 36 256 1 | 9216 |
Input 0 : TIDL_CustomLayer
Input 1 : TIDL_DataConvertLayer
Output : TIDL_ConcatLayer
PSDK09.00.01.03_Host_Target_Dump.zip
I hope I can get help with this issue.
    I do apologize for the late response. Is this still a blocking issue for you?
    From my understanding, with SDK 8.6 you are not seeing issues (host emulation or target). However on 9.0 SDK, you are seeing the correct output with host emulation, but differing output when running on target.
    If so, are you able to test this with 9.2 SDK and see what the results are?
    Can you also provide the compilation log and inference logs when running on 9.0 SDK with debugTraceLevel =2 ?
    Asha
