Dear TI,
I am using the SDK MCU-SDK-AM64X 09.02.01.05, I want to run the freeRTOS in a53 core of the AM6442 with SMP moe, but there is no IPC example support on FreeRTOS SMP A53
Dose the newest SDK can support FreeRTOS SMP on A53 now? Any plan to support IPC on A53+SMP+FreeRTOS?
sincerely
Hi Chen,
Thanks for your query.
I have taken your inputs and working on it. Please allow some time to revert back.
Tushar
Tushar: I had been understanding that there was no real driver to support the 64 bit A53 core with FreeRTOS instead of enbedded Linux - does the Sitara product line desires to change that for the SDK v 10 releases later this year?
thanks
Jim
Hello Jim,
Thanks for your patience.
Yes, the current SDK has support for A53 FreeRTOS SMP as an experimental feature. Please refer Release Notes for details.
Unfortunately, there are no plans to support IPC A53+FreeRTOS+SMP mode.
If you want to develop IPC example for A53 FreeRTOS SMP, you can take reference of existing SMP examples provided as a part of MCU+SDK. This features are experimental and will not be supported by TI.
Hope the above information helps.
Tushar
Hi Jim,
The driver support for 64-bit A53 core with FreeRTOS is already there in the MCU+SDK.
Tushar
Hello Tushar
Thank you for your reply.
I will inform my team and make corresponding attempts regarding IPC。
