David,
It appears that this thread was moved to the BIOS forum by someone from a different forum, although I can't tell who or from where. It also appears that this issue has nothing to do with BIOS, so I'm going to move it to the Linux forum in hopes that it will get a faster response there. I would also comment that there may not be enough detail in your problem description to really help you, so if you can provide more detail about which products (and versions) you are using and what you are trying to do.
My platform is dm6467T with dvsdk3.1. I try to run a "boa web service on arm-side" while the dsp-side do some codecs such as h.264.
-David
My application can run for about 3 minutes .Then it crashs for a moment,and give the error posted above, after that only the "boa process" was killed,other parts of the app(both arm-side and dsp-side)run normally.
-David
To confirm, you can run the "boa web service" for 3 minutes WITHOUT the DSP codecs executing? Null pointer panics are usually very hard to diagnose. I fear you won't get much response on a TI forum for non-TI program like boa.
Your kernel panic seems to be occuring in the network area. Maybe double check that you network is good.
