SK-AM64B: Buildroot error while building
Part Number: SK-AM64B
Hello team
I am following FAQ to build the uboot and kernel for AM64x using build root.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1226815/faq-buildroot-support-for-sitara-am62x-am62ax-am62px-am64x-devices
While executing make command, I am facing following error in downloading certain packages:
Can you please help
Amey
  • Hi Amey,
    did you perform the below command that is part of the current FAQ...
    $ git checkout -b am6x-dev 9b25246e9b
    ...or did you use some other commit?
    Regards, Andreas
  • Hello Andreas
    I had used same commit. But just to be sure. I started again with clean chekout and followed all steps from FAQ.
    But even then I am getting following error
    GIT_DIR=/home/ap/ti-buildroot/buildroot/dl/linux/git/.git git init .
    hint: Using 'master' as the name for the initial branch. This default branch name
    hint: is subject to change. To configure the initial branch name to use in all
    hint: of your new repositories, which will suppress this warning, call:
    hint:
    hint: 	git config --global init.defaultBranch <name>
    hint:
    hint: Names commonly chosen instead of 'master' are 'main', 'trunk' and
    hint: 'development'. The just-created branch can be renamed via this command:
    hint:
    hint: 	git branch -m <name>
    Initialized empty Git repository in /home/ap/ti-buildroot/buildroot/dl/linux/git/.git/
    GIT_DIR=/home/ap/ti-buildroot/buildroot/dl/linux/git/.git git remote add origin 'https://git.ti.com/git/ti-linux-kernel/ti-linux-kernel.git'
    GIT_DIR=/home/ap/ti-buildroot/buildroot/dl/linux/git/.git git remote set-url origin 'https://git.ti.com/git/ti-linux-kernel/ti-linux-kernel.git'
    Fetching all references
    GIT_DIR=/home/ap/ti-buildroot/buildroot/dl/linux/git/.git git fetch origin
    remote: Enumerating objects: 11953509, done.
    remote: Counting objects: 100% (11953509/11953509), done.
    remote: Compressing objects: 100% (1750889/1750889), done.
    error: RPC failed; curl 56 Recv failure: Connection reset by peer
    error: 26462 bytes of body are still expected
    fetch-pack: unexpected disconnect while reading sideband packet
    fatal: early EOF
    fatal: fetch-pack: invalid index-pack output
    Detected a corrupted git cache.
    Removing it and starting afresh.
    hint:
    hint:
    hint:
    fatal: unable to access 'https://git.ti.com/git/ti-linux-kernel/ti-linux-kernel.git/': Could not resolve host: git.ti.com
    This is the second time in a row; bailing out
    wget --passive-ftp -nd -t 3 -O '/home/ap/ti-buildroot/buildroot/output/build/.linux-09.02.00.009-br1.tar.gz.JSPJr7/output' 'https://sources.buildroot.net/linux/linux-09.02.00.009-br1.tar.gz'
    --2024-07-10 11:11:53--  https://sources.buildroot.net/linux/linux-09.02.00.009-br1.tar.gz
    Resolving sources.buildroot.net (sources.buildroot.net)... failed: Temporary failure in name resolution.
    wget: unable to resolve host address ‘sources.buildroot.net’
    wget --passive-ftp -nd -t 3 -O '/home/ap/ti-buildroot/buildroot/output/build/.linux-09.02.00.009-br1.tar.gz.fFmfUM/output' 'https://sources.buildroot.net/linux-09.02.00.009-br1.tar.gz'
    --2024-07-10 11:11:53--  https://sources.buildroot.net/linux-09.02.00.009-br1.tar.gz
    make[1]: *** [package/pkg-generic.mk:179: /home/ap/ti-buildroot/buildroot/output/build/linux-headers-09.02.00.009/.stamp_downloaded] Error 1
    make: *** [Makefile:82: _all] Error 2
    Amey
  • Amey,
    to me this looks like you have a generic network issue. There are failures early on when cloning the repos. Do you need a proxy config maybe? Can you discuss the failures with your IT team?
    Without successful clone of the repo the following steps in build will not work I assume.
    Regards, Frank
  • Hello Frank
    The repo was successfully cloned. And the make command ran for around 20-25mins (building various modules) before reaching this error. In between during the build it also downloads many packages successfully
    Amey
  • Hi Amey,
    let me try this build today on my end and report back.
    Regards, Andreas
  • Hi Amey,
    so I just tried out the build as per https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1226815/faq-buildroot-support-for-sitara-am62x-am62ax-am62px-am64x-devices with the following conditions...
    1. Completely fresh clone of the Buildroot repo into a new folder
    2. Checked out Buildroot commit 9b25246e9b to be used as a base (as per above E2E FAQ)
    3. Applied the 0001-configs-ti_am6-2-4-x_sk_tisdk-Add-TI-SDK-v9.2-equiva-7-May-2024.patch patch from the E2E FAQ to go for "TI SDK equivalent", because that seems like what you were trying to do
    4. Build using ti_am64x_sk_tisdk_defconfig (for use on SK-AM64B)
    5. Build on Ubuntu 22.04 (x86_64)
    The build went through successfully on the first try. After that the directory hierarchy looks as follows....  You can see 8.5GB of source was downloaded.
    a0797059@dasso:~/tmp/buildroot (am6x-dev)
    $ du -h -d1
    20G     ./output
    764K    ./boot
    260K    ./fs
    708K    ./toolchain
    8.0K    ./.github
    140K    ./arch
    61M     ./package
    1.2M    ./configs
    5.9M    ./board
    440K    ./utils
    8.5G    ./dl
    5.4M    ./support
    2.5M    ./docs
    152K    ./system
    138M    ./.git
    92K     ./linux
    29G
    As for your errors we need to get to at least some kind of working build. Can you please try the following:
    1. Start over with a completely fresh clone/folder
    2. Try on a different machine (preferably one that's directly connected to the Internet, for example your "home PC")
    Regards, Andreas
  • Hello Andreas
    Thanks for trying it out on your machine. I am running Ubuntu 23.10 on VMWare
    Here is the screenshot of disk usage
    The total size of your folder is around 29G. All this is downloaded & built during the build process?
    As suggested, I will try it natively installing on the machine
    Amey
  • I am running Ubuntu 23.10
    Buildroot is usually pretty good being quite "tolerant" as to the build environment (unlike Yocto, I found). Still, you may also want to try Ubuntu 22.04 if your issues persist.
    As for the total size of the folder after you build it yourself it will probably be larger than 29G because I used the BR2_CCACHE=y option to build locally, not all intermediate files were generated. On a related note I'd highly recommend using this option for your builds, as it will dramatically speed up newly setup builds. Same for the keeping a copy of the download folder and re-using it / sharing it between your different build environments.
    Regards, Andreas
  • Thanks Andreas.
    I had used the option BR2_CCACHE=y before running make. I believe that option is "Use Compiler Cache", that is correct?
    Thanks for letting me know that copy of download folder can be reused
    Amey
  • Hi Amey,
    yes that is correct.
    Regards, Andreas
  • Hello Andreas
    I installed Ubuntu 22.04.4 on VMware and started a clean build. I was able to successfully build the entire source code.
    The total size of folder after build is 29G same as your screenshot above.
    Amey
