sd card compatibility issue
Other Parts Discussed in Thread: TMDXEVM3358
while inserting a SD card, insert detected, but
mmcblk1: mmc1:0002 00000 7.49 GiB
 mmcblk1:
mmcblk1: retrying using single block read
mmcblk1: error -84 transferring data, sector 0, nr 8, card status 0x900
end_request: I/O error, dev mmcblk1, sector 0
mmcblk1: error -84 transferring data, sector 1, nr 7, card status 0x900
end_request: I/O error, dev mmcblk1, sector 1
mmcblk1: error -84 transferring data, sector 2, nr 6, card status 0x900
end_request: I/O error, dev mmcblk1, sector 2
mmcblk1: error -84 transferring data, sector 3, nr 5, card status 0x900
end_request: I/O error, dev mmcblk1, sector 3
mmcblk1: error -84 transferring data, sector 4, nr 4, card status 0x900
end_request: I/O error, dev mmcblk1, sector 4
mmcblk1: error -84 transferring data, sector 5, nr 3, card status 0x900
end_request: I/O error, dev mmcblk1, sector 5
mmcblk1: error -84 transferring data, sector 6, nr 2, card status 0x900
end_request: I/O error, dev mmcblk1, sector 6
mmcblk1: error -84 transferring data, sector 7, nr 1, card status 0x900
end_request: I/O error, dev mmcblk1, sector 7
Buffer I/O error on device mmcblk1, logical block 0
ldm_validate_partition_table(): Disk read failed.
 unable to read partition table
any idea how to fix this driver error ?
    Are you getting this error with all the SD cards you are using or is it with only one SD card?
    Regards, Sudhakar
  • Hi, Sudhakar:
    thanks for reply, I have this problem with some of the sd cards, not only one. but most of the compatibility report by users.
    I happened to get this while using a Transcend 8G SDHC card comes with my Nikon digital camera.
    please give me a clue how to solve this problem, I'll try to modify the latest SDK to make it done.
    thanks.
    Power Pan
    I have not seen this kind of error on any of the platform while using my software. What is the SDK version you are using? Which is the platform?
    Regards, Sudhakar
    Regards, Sudhakar
    Hello, I've almost the same problem too.
    I'm using TMDXEVM3358 evaluation kit with prebuild kernel and root from am335x-evm-sdk-src-05.06.00.00.
    The supplied with evkit sdmmc card is used as boot card, on the base board of evaliation kit.
    When I plug the sdmmc card class 6 in the daugther card, it works properly(available to mounting, i/o operations on it).
    But Whet I plug the sdmmc card class 10 the board is stuck and no answering on serial console.
    Before the board is stucked, it is writing this from the serial line console:
    [ 845.513061] mmc1: new high speed SDHC card at address b368
    [ 845.526184] mmcblk1: mmc1:b368 F0F0F 7.49 GiB
    [ 845.534210] mmcblk1: p1 p2 p3 p4
    [ 845.571105] mmcblk1: error -84 transferring data, sector 376, nr 8, cmd response 0x900, card status 0xb00
    [ 845.581115] mmcblk1: retrying using single block read
    [ 847.226806] mmcblk1: error -84 transferring data, sector 5386589, nr 8, cmd response 0x900, card status 0xb00
    [ 847.237365] mmcblk1: retrying using single block read
    [ 847.260070] mmcblk1: error -84 transferring data, sector 5386595, nr 2, cmd response 0x900, card status 0x0
    [ 847.270416] end_request: I/O error, dev mmcblk1, sector 5386595
    [ 847.276580] Buffer I/O error on device mmcblk1p1, logical block 478
  • I have exactly the same problem. May I know how you've solved it?
  • Hi Stephan,
    Could you please create new thread for your issue.
