There are the following Ethernet Throughput benchmark results in the document of Processor SDK Linux for j721e 08_06_00 and 09_01_00.
It seems that TCP Bidirectional Throughput performance becomes significantly worse from SDK 8.6 to SDK 9.1. Especially CPU Load.
Could you please help to explain why it becomes worse ?
In the document of 08_06_00
2.2.1.5.1. CPSW/CPSW2g/CPSW3g Ethernet Driver
Command Used |
j721e-idk-gw: THROUGHPUT (Mbits/sec) |
j721e-idk-gw: CPU Load % (LOCAL_CPU_UTIL) |
netperf -H 192.168.0.1 -j -c -C -l 60 -t TCP_STREAM; netperf -H 192.168.0.1 -j -c -C -l 60 -t TCP_MAERTS |
1844.71 |
27.81 |
In the document of 09_01_00
Command Used |
1834.33 |
73.50 |
Thanks and regards,
Hideaki
