AM4376: AM4376-evm
Part Number: AM4376
Other Parts Discussed in Thread: TPS65218, AM4372, TPS62360
I am trying to boot from NAND memory, but I am encountering an UBIFS filesystem error. I need support to resolve this issue. I am following these steps, but I keep getting errors. I have included the relevant details and logs below
steps
nand erase.part NAND.SPL
nand erase.part NAND.u-boot
nand erase.part NAND.kernel
nand erase.part NAND.u-boot-spl-os
nand erase.part NAND.file-system
fatload mmc 0:1 0x82000000 MLO
nand write 0x82000000 NAND.SPL 0x2973D
fatload mmc 0:1 0x82000000 u-boot.img
nand write 0x82000000 NAND.u-boot 0xBB408
fatload mmc 0:1 0x82000000 zImage
nand write 0x82000000 NAND.kernel 0x4CA200
fatload mmc 0:1 0x82000000 am437x-idk-evm.dtb
nand write 0x82000000 NAND.u-boot-spl-os 0x12159
fatload mmc 0:1 0x82000000 rootfs.ubi
nand write 0x82000000 NAND.file-system 0x3D40000
creat ubifs file system im flow this steps
file name ubinize.cfg
[ubifs]
mode=ubi
image=rootfs.ubifs
vol_id=0
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
vol_size=70MiB
tar -xJf tisdk-base-image-am437x-evm-20240723134619.rootfs.tar.xz -C /home/zumipc/tftp/image/rootfs
sudo mkfs.ubifs -r /home/zumipc/tftp/image/rootfs -o rootfs.ubifs -F -m 2048 -e 129024  -c 4800
sudo ubinize -o rootfs.ubi -m 2048 -p 256KiB -s 512 -O 512 ubinize.cfg
 Logs
U-Boot SPL 2023.04-00001-g782d146723-dirty (Jul 24 2024 - 14:13:59 +0000)
Boot mode as per spl_boot_device is 5
---Trying to boot from--- NAND - 5
Trying to load image from device : 5SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
Loading Image Success  from device : 5
U-Boot 2023.04-00001-g782d146723-dirty (Jul 24 2024 - 14:13:59 +0000)
CPU  : AM437X-GP rev 1.2
Model: TI AM437x ETH
DRAM:  512 MiB
 Board init is in process ...Please wait 11
Core:  41 devices, 16 uclasses, devicetree: separate
Warning: Device tree includes old 'u-boot,dm-' tags: please fix by 2023.07!
PMIC:  TPS65218
NAND:  512 MiB
MMC:   OMAP SD/MMC: 0
Loading Environment from FAT... OK
Net:   Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000
Hit any key to stop autoboot:  0
=> nand erase.part NAND.file-system
NAND erase.part: device 0 offset 0xa00000, size 0x1f600000
Erasing at 0x1ffe0000 -- 100% complete.
OK
=> fatload mmc 0:1 0x82000000 rootfs.ubi
57409536 bytes read in 4433 ms (12.4 MiB/s)
=> nand write 0x82000000 NAND.file-system 0x3D40000
NAND write: device 0 offset 0xa00000, size 0x3d40000
 64225280 bytes written: OK
=> <INTERRUPT>
=> mtdparts
device nand0 <nand.0>, # parts = 10
 #: name                size            offset          mask_flags
 0: NAND.SPL            0x00040000      0x00000000      0
 1: NAND.SPL.backup1    0x00040000      0x00040000      0
 2: NAND.SPL.backup2    0x00040000      0x00080000      0
 3: NAND.SPL.backup3    0x00040000      0x000c0000      0
 4: NAND.u-boot-spl-os  0x00080000      0x00100000      0
 5: NAND.u-boot         0x00100000      0x00180000      0
 6: NAND.u-boot-env     0x00040000      0x00280000      0
 7: NAND.u-boot-env.backup10x00040000   0x002c0000      0
 8: NAND.kernel         0x00700000      0x00300000      0
 9: NAND.file-system    0x1f600000      0x00a00000      0
active partition: nand0,0 - (NAND.SPL) 0x00040000 @ 0x00000000
defaults:
mtdids  : nand0=nand.0
mtdparts: mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),)
=> <INTERRUPT>
=> ubi part NAND.file-system
ubi0: attaching mtd10
ubi0: scanning is finished
ubi0: volume 0 ("rootfs") re-sized from 283 to 3932 LEBs
ubi0: attached mtd10 (name "NAND.file-system", size 502 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 129024 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
ubi0: VID header offset: 512 (aligned 512), data offset: 2048
ubi0: good PEBs: 4016, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 166875711
ubi0: available PEBs: 0, total reserved PEBs: 4016, PEBs reserved for bad PEB handling: 80
=> <INTERRUPT>
=> ubi part NAND.file-system<INTERRUPT>
=> ubi
  ubi ubifsload ubifsls ubifsmount ubifsumount
=> ubifsmount ubi0:rootfs
UBIFS error (ubi0:0 pid 0): ubifs_recover_master_node: failed to recover master node                                        // Error
Error reading superblock on volume 'ubi0:rootfs' errno=-22!
=> <INTERRUPT>
=> boot
** Invalid partition 2 **
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
No EFI system partition
Failed to persist EFI variables
BootOrder not defined
EFI boot manager: Cannot load any image
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
Booting from nand ...
NAND read: device 0 offset 0x100000, size 0x80000
 524288 bytes read: OK
NAND read: device 0 offset 0x300000, size 0x700000
 7340032 bytes read: OK
Kernel image @ 0x82000000 [ 0x000000 - 0x474200 ]
Working FDT set to 88000000
   Loading Device Tree to 8ffea000, end 8ffff004 ... OK
Working FDT set to 8ffea000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.106-g023faefa70 (oe-user@oe-host) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 PREEMPT Thu Jun 27 06:59:07 UTC 204
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM437x Industrial Development Kit
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9d000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (neon)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048 rootfstype=ubifs rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 454800K/524288K available (9216K kernel code, 304K rwdata, 3108K rodata, 1024K init, 259K bss, 20336K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b4/0x470 with crng_init=0
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000024] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000063] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000085] OMAP clocksource: timer1 at 24000000 Hz
[    0.001207] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.001228] OMAP clocksource: 32k_counter at 32768 Hz
[    0.002557] Console: colour dummy device 80x30
[    0.002656] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[    0.060376] pid_max: default: 32768 minimum: 301
[    0.060812] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.060845] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.062607] CPU: Testing write buffer coherency: ok
[    0.062706] CPU0: Spectre v2: using BPIALL workaround
[    0.064217] Setting up static identity map for 0x80100000 - 0x80100060
[    0.064520] rcu: Hierarchical SRCU implementation.
[    0.064685] EFI services will not be available.
[    0.065384] devtmpfs: initialized
[    0.095832] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.096589] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.096634] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.102834] pinctrl core: initialized pinctrl subsystem
[    0.104204] DMI not present or invalid.
[    0.104990] NET: Registered protocol family 16
[    0.108556] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.167113] cpuidle: using governor ladder
[    0.167187] cpuidle: using governor menu
[    0.224224] No ATAGs?
[    0.224260] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.224293] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.263997] debugfs: Directory '49000000.edma' with parent 'dmaengine' already present!
[    0.264048] edma 49000000.edma: TI EDMA DMA engine driver
[    0.267071] V3_3D: supplied by V24_0D
[    0.267868] VDD_COREREG: supplied by V24_0D
[    0.268688] VDD_CORE: supplied by VDD_COREREG
[    0.269486] V1_8DREG: supplied by V24_0D
[    0.270852] V1_8D: supplied by V1_8DREG
[    0.271774] V1_5DREG: supplied by V24_0D
[    0.272579] V1_5D: supplied by V1_5DREG
[    0.275365] iommu: Default domain type: Translated
[    0.281240] SCSI subsystem initialized
[    0.282445] mc: Linux media interface: v0.10
[    0.282534] videodev: Linux video capture interface: v2.00
[    0.282741] pps_core: LinuxPPS API ver. 1 registered
[    0.282759] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.282808] PTP clock support registered
[    0.282883] EDAC MC: Ver: 3.0.0
[    0.285323] Advanced Linux Sound Architecture Driver Initialized.
[    0.287486] clocksource: Switched to clocksource timer1
[    0.305456] thermal_sys: Registered thermal governor 'fair_share'
[    0.305470] thermal_sys: Registered thermal governor 'bang_bang'
[    0.305498] thermal_sys: Registered thermal governor 'step_wise'
[    0.305515] thermal_sys: Registered thermal governor 'user_space'
[    0.305531] thermal_sys: Registered thermal governor 'power_allocator'
[    0.306772] NET: Registered protocol family 2
[    0.308307] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.308377] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.308485] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.308613] TCP: Hash tables configured (established 4096 bind 4096)
[    0.308799] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.308847] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.309174] NET: Registered protocol family 1
[    0.310192] RPC: Registered named UNIX socket transport module.
[    0.310218] RPC: Registered udp transport module.
[    0.310233] RPC: Registered tcp transport module.
[    0.310248] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.310276] PCI: CLS 0 bytes, default 64
[    0.314276] Initialise system trusted keyrings
[    0.314761] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.326484] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.328174] NFS: Registering the id_resolver key type
[    0.328237] Key type id_resolver registered
[    0.328253] Key type id_legacy registered
[    0.328359] ntfs: driver 2.1.32 [Flags: R/O].
[    0.329775] Key type asymmetric registered
[    0.329801] Asymmetric key parser 'x509' registered
[    0.329901] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.329922] io scheduler mq-deadline registered
[    0.329940] io scheduler kyber registered
[    0.341146] OMAP GPIO hardware version 0.1
[    0.382147] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.444213] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[    0.566936] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.575213] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.576738] printk: console [ttyS0] disabled
[    0.576910] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 67, base_baud = 3000000) is a 8250
[    1.259587] printk: console [ttyS0] enabled
[    1.270009] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.277714] random: fast init done
[    1.281509] random: crng init done
[    1.325946] brd: module loaded
[    1.345989] loop: module loaded
[    1.364303] libphy: Fixed MDIO Bus: probed
[    1.437574] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.445295] libphy: 4a101000.mdio: probed
[    1.449649] mdio_bus 4a101000.mdio: MDIO device at address 0 is missing.
[    1.456964] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.463426] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.468858] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.476119] cpsw 4a100000.ethernet: Detected MACID = 88:01:f9:59:b2:23
[    1.486284] i2c /dev entries driver
[    1.496559] cpuidle: enable-method property 'ti,am4372' found operations
[    1.504823] sdhci: Secure Digital Host Controller Interface driver
[    1.511100] sdhci: Copyright(c) Pierre Ossman
[    1.518953] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.527772] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.561575] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.568794] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.578705] ledtrig-cpu: registered to indicate activity on CPUs
[    1.593991] NET: Registered protocol family 10
[    1.600859] Segment Routing with IPv6
[    1.604863] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.612383] NET: Registered protocol family 17
[    1.617672] Key type dns_resolver registered
[    1.622358] omap_voltage_late_init: Voltage driver support not added
[    1.630004] Loading compiled-in X.509 certificates
[    1.642117] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.660946] mmc0: new high speed SDHC card at address aaaa
[    1.678308] mmcblk0: mmc0:aaaa SK32G 29.7 GiB
[    1.688076] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    1.693272] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    1.700614]  mmcblk0: p1
[    1.707884] Could not find a valid ONFI parameter page, trying bit-wise majority to recover it
[    1.716698] ONFI parameter recovery failed, aborting
[    1.721794] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[    1.728261] nand: Micron NAND 512MiB 3,3V 8-bit
[    1.732832] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    1.740753] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[    1.746300] 10 fixed-partitions partitions found on MTD device omap2-nand.0
[    1.753355] Creating 10 MTD partitions on "omap2-nand.0":
[    1.758828] 0x000000000000-0x000000040000 : "NAND.SPL"
[    1.766744] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
[    1.775269] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
[    1.783817] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"
[    1.792267] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os"
[    1.800933] 0x000000180000-0x000000280000 : "NAND.u-boot"
[    1.809082] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env"
[    1.817420] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1"
[    1.826540] 0x000000300000-0x000000a00000 : "NAND.kernel"
[    1.835392] 0x000000a00000-0x000020000000 : "NAND.file-system"
[    1.927613] tps62360 0-0060: tps62360_init_dcdc(): register 4 write failed with err -121
[    1.935774] tps62360 0-0060: tps62360_probe(): Init failed with err = -121
[    1.942900] tps62360: probe of 0-0060 failed with error -121
[    1.949022] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
[    1.957286] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz
[    1.977255] omap_reset_deassert: timedout waiting for gfx:0
[    1.983003] ti-sysc: probe of 44000000.ocp:target-module@56000000 failed with error -110
[    1.993096] ubi0: attaching mtd9
[    1.998003] ubi0 error: validate_ec_hdr: bad VID header offset 512, expected 2048
[    2.005551] ubi0 error: validate_ec_hdr: bad EC header
[    2.010836] Erase counter header dump:
[    2.014616]  magic          0x55424923
[    2.018459]  version        1
[    2.021450]  ec             1
[    2.024437]  vid_hdr_offset 512
[    2.027629]  data_offset    2048
[    2.030880]  image_seq      166875711
[    2.034565]  hdr_crc        0xcd26725d
[    2.038357] erase counter header hexdump:
[    2.042449] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.106-g023faefa70 #1
[    2.049388] Hardware name: Generic AM43 (Flattened Device Tree)
[    2.055400] [<c010eb08>] (unwind_backtrace) from [<c010b2f0>] (show_stack+0x10/0x14)
[    2.063240] [<c010b2f0>] (show_stack) from [<c0667128>] (validate_ec_hdr+0x98/0xdc)
[    2.070996] [<c0667128>] (validate_ec_hdr) from [<c0667c54>] (ubi_io_read_ec_hdr+0x160/0x1f0)
[    2.079623] [<c0667c54>] (ubi_io_read_ec_hdr) from [<c066d20c>] (ubi_attach+0x19c/0x13e0)
[    2.087894] [<c066d20c>] (ubi_attach) from [<c0661850>] (ubi_attach_mtd_dev+0x464/0xaf4)
[    2.096068] [<c0661850>] (ubi_attach_mtd_dev) from [<c0e248d8>] (ubi_init+0x1ac/0x238)
[    2.104089] [<c0e248d8>] (ubi_init) from [<c0102648>] (do_one_initcall+0x58/0x1c4)
[    2.111751] [<c0102648>] (do_one_initcall) from [<c0e00ee4>] (kernel_init_freeable+0x124/0x1c0)
[    2.120562] [<c0e00ee4>] (kernel_init_freeable) from [<c096fadc>] (kernel_init+0x8/0x110)
[    2.128835] [<c096fadc>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    2.136450] Exception stack(0xdc45ffb0 to 0xdc45fff8)
[    2.141566] ffa0:                                     00000000 00000000 00000000 00000000
[    2.149826] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.158081] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    2.164757] ubi0 error: ubi_io_read_ec_hdr: validation failed for PEB 71
[    2.171547] ubi0 error: ubi_attach_mtd_dev: failed to attach mtd9, error -22
[    2.178722] UBI error: cannot attach mtd9
[    2.184477] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[    2.192847] hctosys: unable to open rtc device (rtc0)
[    2.200050] ALSA device list:
[    2.203062]   No soundcards found.
[    2.207919] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -19
[    2.215979] Please append a correct "root=" boot option; here are the available partitions:
[    2.224508] 0100           65536 ram0
[    2.224515]  (driver?)
[    2.230750] 0101           65536 ram1
[    2.230756]  (driver?)
[    2.236910] 0102           65536 ram2
[    2.236915]  (driver?)
[    2.243134] 0103           65536 ram3
[    2.243140]  (driver?)
[    2.249322] 0104           65536 ram4
[    2.249328]  (driver?)
[    2.255480] 0105           65536 ram5
[    2.255486]  (driver?)
[    2.261665] 0106           65536 ram6
[    2.261670]  (driver?)
[    2.267844] 0107           65536 ram7
[    2.267849]  (driver?)
[    2.274000] 0108           65536 ram8
[    2.274005]  (driver?)
[    2.280180] 0109           65536 ram9
[    2.280186]  (driver?)
[    2.286335] 010a           65536 ram10
[    2.286339]  (driver?)
[    2.292603] 010b           65536 ram11
[    2.292609]  (driver?)
[    2.298872] 010c           65536 ram12
[    2.298877]  (driver?)
[    2.305115] 010d           65536 ram13
[    2.305120]  (driver?)
[    2.311384] 010e           65536 ram14
[    2.311389]  (driver?)
[    2.317652] 010f           65536 ram15
[    2.317657]  (driver?)
[    2.323906] b300        31166976 mmcblk0
[    2.323913]  driver: mmcblk
[    2.330789]   b301        31165440 mmcblk0p1 0523ae98-01
[    2.330795]
[    2.337668] 1f00             256 mtdblock0
[    2.337673]  (driver?)
[    2.344261] 1f01             256 mtdblock1
[    2.344267]  (driver?)
[    2.350879] 1f02             256 mtdblock2
[    2.350885]  (driver?)
[    2.357495] 1f03             256 mtdblock3
[    2.357501]  (driver?)
[    2.364088] 1f04             512 mtdblock4
[    2.364093]  (driver?)
[    2.370703] 1f05            1024 mtdblock5
[    2.370708]  (driver?)
[    2.377292] 1f06             256 mtdblock6
[    2.377297]  (driver?)
[    2.383908] 1f07             256 mtdblock7
[    2.383914]  (driver?)
[    2.390527] 1f08            7168 mtdblock8
[    2.390532]  (driver?)
[    2.397118] 1f09          514048 mtdblock9
[    2.397123]  (driver?)
[    2.403730] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    2.412056] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.8 | VT102 | Offline | ttyUSB0
