Part Number: DRA821U
Other Parts Discussed in Thread: DRA821, TDA4VM, AM62A7,
Dear team,
Kindly assist us on how to flash eMMC through DFU interface. Also provide the tools/application and steps to flash the device.
Kaushal
We have refered below mentioned ti-community link to flash using DFU, seems like it is flashing and observed in bootprints when booting from emmc
URL : e2e.ti.com/.../faq-tda4vm-j721e-j7200-enabling-dfu-boot-on-8-0-linux-sdk
URL : software-dl.ti.com/.../UG-DFU.html
We are using SDK09.02
Please check on the above request
Kaushal
Hi Kaushal
Please go through the appnote to understand the flashing technique on TDA4 devices.
TDA4 Flashing Techniques (ti.com)
Let us know if you still have further question on this.
Diwakar
Hi Diwakar,
We are facing below mentioned error pints in uboot while doing dfu boot and ums command
UMS: LUN 0, dev mmc 0, hwpart 0, sector 0x0, count 0x1d5a000
cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret -61)
cdns-usb3-peripheral usb@6000000: Unable to get USB3 phy (ret -61)
cdns-usb3-peripheral usb@6000000: DRD version v1 (ID: 0004024e, rev: 00000200)
cdns-usb3-peripheral usb@6000000: Initialized ep0 support:
cdns-usb3-peripheral usb@6000000: Initialized ep1out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep2out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep3out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep4out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep5out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep6out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep7out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep8out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep9out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep10out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep11out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep12out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep13out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep14out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep15out support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep1in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep2in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep3in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep4in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep5in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep6in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep7in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep8in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep9in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep10in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep11in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep12in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep13in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep14in support: BULK, INT ISO
cdns-usb3-peripheral usb@6000000: Initialized ep15in support: BULK, INT ISO
We observed there are some open quries on TI forum related to this. is it resolved? or still open. since we observing same error in 09.02 SDK
e2e.ti.com/.../tda4ve-q1-ums-didn-t-work
e2e.ti.com/.../5170492
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1162175/sk-tda4vm-u-boot-ums-does-not-work-stably?tisearch=e2e-sitesearch&keymatch=j7200%2525252520usb%25252525406000000%252525253A%2525252520Unable%2525252520to%2525252520get%2525252520USB2%2525252520phy%2525252520%2525252528ret%2525252520-2%2525252529#
Kaushal
Hi Diwakar,
We are able to flash using DFU Tool, but only tiboot3.bin and tispl.bin binaries are flashing but while trying to send u-boot.img we are facing below error
####MMC: block number 0x2110 exceeds max(0x2000)
Also in flashing documentation it is mentioned to flash tiboot3.bin and sysfw.itb bins separately, but as per i understood sysfw.itb is embedded in tiboot3.bin, so is there any updates need to do while flashing this (like mmc write command block count)
UMS is also a feature important to us to validate usb peripheral mode in uboot.
Kindly do the needful
Kaushal
HI Kaushal,
Are you testing it on EVM or on the custom board ? We have validated the steps so far we haven't came across any issue with the DFU.
Help share the full logs as well.
The documentation was created a while ago based on TDA4VM device which follow legacy boot flow you are using DRA821 which uses combined boot flow no need to send sysfw.itb . TIFS will get packaged with the tiboot3.bin only.
Please raise a separate thread for this.
Diwakar
Hi Diwakar,
Yes, we are using our custom board.
Attached log:
U-Boot SPL 2023.04-dirty (Aug 01 2024 - 20:27:52 +0530)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
i2c_write: error waiting for data ACK (status=0x116)
read error from device: 41c86544 register: x!
-----------spl_board_init----------
Trying to boot from DFU
####DOWNLOAD ... OK
Ctrl+C to exit ...
Loading Environment from nowhere... OK
init_env from device 18 not supported!
Starting ATF on ARM64 core...
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE: BL31: Built : 16:09:05, Feb 9 2024
I/TC:
I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2023.04-dirty (Aug 01 2024 - 20:27:47 +0530)
cdns-usb3-peripheral usb@6000000: Unable to get USB2 phy (ret -2)
#####DOWNLOAD ... OK
Ctrl+C to exit ...
U-Boot 2023.04-dirty (Aug 01 2024 - 20:27:47 +0530)
SoC: J7200 SR2.0 GP
Model: Texas Instruments K3 J7200 SoC
DRAM: 2 GiB
-board-init-----------
Core: 77 devices, 32 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@c000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00294104 Ports:4 mdio_freq:1000000
------board late init---------------
Net: No ethernet found.
Hit any key to stop autoboot: 2 0
=> env default -f -a
## Resetting to default environment
=> setenv mmcdev 0
=> setenv bootpart 0
=> saveenv
Unknown command 'saveenv' - try 'help'
=> setenv dfu_alt_info ${dfu_alt_info_emmc}
=> gpt write mmc 0 ${partitions}
Writing GPT: success!
=> dfu 0 mmc 0
###DOWNLOAD ... OK
Ctrl+C to exit ...
####DOWNLOAD ... OK
Ctrl+C to exit ...
MMC operation failed#
Kaushal
Dear Diwakar,
image size are mentioned below
tiboot3.bin - 530666 bytes
tispl.bin - 1018479 bytes
u-boot.img - 1187547 bytes
We tried to convert u-boot.img size to block (updated in dfu args) and write to emmc, still we are facing same issue
Kaushal
Hi Diwakar,
we have kept block size as 0x910
In the DFU settings the uboot.img try to write from 0x1800 and block count of 0x910 which will exceeds (0x2000), but we are not sure how this limit(0x2000) is set..?
it seems we are not able/allowed to change the starting address of the images in emmc (ex: tiboot3.bin - 0, tispl.bin - 0x800, uboot.img - 0x1800) because sourcecode will expect the binaries from this address.
Kaushal
Hi Kaushal
Please go through my earlier response on how to set the number of blocks
After making above changes you need to build the UBOOT using command "make u-boot".
Diwakar
Dear Diwakar,
We are able to flash and boot in emmc using DFU, but when kernel is loading we observed gpt partition table is created during flashing procedure
and we flashed rootfs using dfu as mentioned below
sudo dfu-util -a rootfs -D rootfs.wic
we suspect gpt partition is causing the issue, while loading kernel from uboot is unable to read this partition and also time took for flashing is more(nearly 1hr).
So is there any method to avoid gpt partition and flash with fat and ext4 partition
Diwakar
HI Kaushal
Please go through the section "3.3 Generating the eMMC tisdk-tiny-image.img" of https://www.ti.com/lit/an/spracy5/spracy5.pdf
The flashing time depends on the size of the image the restriction is from the dfu tool., There are various factor involved for a slow transfer speed, involvement of usb driver stack ,class driver stack and also in DFU only one end point is getting used which is end point 0.
Diwakar
Hi Diwakar,
We are using same DFU tool version for AM62A7 processor and there 7GB of file takes 15mins to flash, but here in DRA821U processor it takes around 1hour. How do we reduce this flashing time.
Kaushal
Hi Diwakar
In AM62A7while flashing .wic image using dfu tool, emmc will automatically formated to vfat and ext4 partition(even if there is no partition table present in emmc), but with DRA821 if there is no partition table exists in emmc we are not able to mount emmc using dfu 0 mmc 0 command.
This is critical for us, kindly support in this.
Kaushal
HI Kaushal,
As said earlier AM62 and DRA821 are using different controller so it is not a ideal comparison.
You need to follow the steps mentioned in the TDA4 flashing document.
Diwakar
