Other Parts Discussed in Thread: OMAP3530
Hi everyone
Previously i had worked with Beagleboard(OMAP3530) using CCSv5.x environment. I had experience in that.
But now i had different third party kit called devkit 8000 (OMAP3530) from Embest Info&Tech Co., LTD. Already i had so many codes that i had developed with beagleboard. So while connecting this kit using XDS100v2 i had trouble , but i am able to launch the target . PID/VID value, driver configuration i checked , its fine.
One more thing is that when some guys came to our college for the demo, they said in the kit, flash is already programmed with some code , i don't which code it is . One doubt i had, is there any special gel file is there , just like for beagle , Bsquare and mistral we have?
I had some error and logs in the console window which i am posting here. So please help me if any body knows it
Console logs were like this
CS_DAP_PC_0: Trouble Writing Memory Block at 0x48002948 on Page 0 of Length 0x4: (Error -180) @ 1207970120 (0x48002948)
IcePick_C_0: Power Failure on Target CPU: (Error -180) @ 0 (0x0)
IcePick_C_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
CS_DAP_PC_0: The GEL callback "OnTargetConnect()" is no longer running atomically
CS_DAP_PC_0: Trouble Writing Memory Block at 0x4800299c on Page 0 of Length 0x4: (Error -180) @ -180 (0xFFFFFF4C)
CS_DAP_PC_0: GEL: Error while executing OnTargetConnect(): target is not connected.
IcePick_C_0: Power Failure on Target CPU: (Error -180) @ -180 (0xFFFFFF4C)
CS_DAP_PC_0: Error connecting to the target: (Error -180) @ 0 (0x0)
With Regards
Nitin Mewada
