AM625: Yocto Linux Image doesn't works in eMMC of AM625 EVM
Part Number: AM625
Hello Ti experts,
I've successfully built an wic image of Yocto Linux Image for Ti's AM625 by using this link: Link
Now I'm into a problem that the .wic.xz generated from Yocto build works with the SD card on AM625 EVM.
But when I create an .ext4 using the contents from .wic.xz of Yocto generated Linux Image and flash the created .ext4 on EVM the board isn't booting properly, it's booting in emergency mode
I've attached the logs below:
=> boot
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
Can't set block device
## Error: "main_cpsw0_qsgmii_phyinit" not defined
39154176 bytes read in 236 ms (158.2 MiB/s)
59546 bytes read in 15 ms (3.8 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.80-dirty (lazarus@lazarus) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Apr  5 11:50:34 IST 2024
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf7bd7a00-0xf7bd9fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009c7fffff]
[    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 21 pages/cpu s48040 r8192 d29784 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=1eae32f4-38d4-7a4a-acb3-5e1e485f5ff6 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1828820K/2097152K available (17024K kernel code, 3804K rwdata, 9584K rodata, 7680K init, 625K bss, 137260K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.009784] Console: colour dummy device 80x25
[    0.014423] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.025106] pid_max: default: 32768 minimum: 301
[    0.029885] LSM: Security Framework initializing
[    0.034729] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.042312] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.052185] cblist_init_generic: Setting adjustable number of callback queues.
[    0.059635] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.065935] cblist_init_generic: Setting adjustable number of callback queues.
[    0.073331] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.079748] rcu: Hierarchical SRCU implementation.
[    0.084657] rcu: 	Max phase no-delay instances is 1000.
[    0.090246] Platform MSI: msi-controller@1820000 domain created
[    0.096551] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.105825] fsl-mc MSI: msi-controller@1820000 domain created
[    0.113917] EFI services will not be available.
[    0.118877] smp: Bringing up secondary CPUs ...
[    0.124216] Detected VIPT I-cache on CPU1
[    0.124328] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.124346] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[    0.124404] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.125153] Detected VIPT I-cache on CPU2
[    0.125234] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.125249] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[    0.125284] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.125946] Detected VIPT I-cache on CPU3
[    0.126027] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.126039] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[    0.126071] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.126146] smp: Brought up 1 node, 4 CPUs
[    0.205893] SMP: Total of 4 processors activated.
[    0.210706] CPU features: detected: 32-bit EL0 Support
[    0.215978] CPU features: detected: 32-bit EL1 Support
[    0.221238] CPU features: detected: CRC32 instructions
[    0.226567] CPU: All CPU(s) started at EL2
[    0.230778] alternatives: applying system-wide alternatives
[    0.238846] devtmpfs: initialized
[    0.250948] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.260959] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.273021] pinctrl core: initialized pinctrl subsystem
[    0.280794] DMI not present or invalid.
[    0.285481] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.292767] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.300275] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.308335] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.316517] audit: initializing netlink subsys (disabled)
[    0.322217] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
[    0.323631] thermal_sys: Registered thermal governor 'step_wise'
[    0.330161] thermal_sys: Registered thermal governor 'power_allocator'
[    0.336384] cpuidle: using governor menu
[    0.347326] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.354370] ASID allocator initialised with 65536 entries
[    0.361742] Serial: AMBA PL011 UART driver
[    0.384175] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[    0.400653] KASLR disabled due to lack of seed
[    0.413634] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.420603] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.427061] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.434002] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.440410] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.447349] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.453756] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.460695] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.469151] ACPI: Interpreter disabled.
[    0.475252] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.485991] iommu: Default domain type: Translated
[    0.491011] iommu: DMA domain TLB invalidation policy: strict mode
[    0.497724] SCSI subsystem initialized
[    0.501968] usbcore: registered new interface driver usbfs
[    0.507618] usbcore: registered new interface driver hub
[    0.513079] usbcore: registered new device driver usb
[    0.519648] pps_core: LinuxPPS API ver. 1 registered
[    0.524733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.534083] PTP clock support registered
[    0.538237] EDAC MC: Ver: 3.0.0
[    0.543374] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.550889] FPGA manager framework
[    0.554476] Advanced Linux Sound Architecture Driver Initialized.
[    0.561691] vgaarb: loaded
[    0.564977] clocksource: Switched to clocksource arch_sys_counter
[    0.571480] VFS: Disk quotas dquot_6.6.0
[    0.575537] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.582762] pnp: PnP ACPI: disabled
[    0.592133] NET: Registered PF_INET protocol family
[    0.597448] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.606693] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.615503] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.623444] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.631648] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.639643] TCP: Hash tables configured (established 16384 bind 16384)
[    0.646563] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.653498] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.661035] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.667320] RPC: Registered named UNIX socket transport module.
[    0.673401] RPC: Registered udp transport module.
[    0.678211] RPC: Registered tcp transport module.
[    0.683019] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.689611] NET: Registered PF_XDP protocol family
[    0.694524] PCI: CLS 0 bytes, default 64
[    0.699423] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.708582] kvm [1]: IPA Size Limit: 40 bits
[    0.714587] kvm [1]: vgic-v2@100010000
[    0.718440] kvm [1]: GIC system register CPU interface enabled
[    0.724511] kvm [1]: vgic interrupt IRQ9
[    0.728605] kvm [1]: Hyp mode initialized successfully
[    0.735399] Initialise system trusted keyrings
[    0.740255] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    0.753110] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.759725] NFS: Registering the id_resolver key type
[    0.764969] Key type id_resolver registered
[    0.769247] Key type id_legacy registered
[    0.773414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.780270] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.788052] 9p: Installing v9fs 9p2000 file system support
[    0.828834] Key type asymmetric registered
[    0.833040] Asymmetric key parser 'x509' registered
[    0.838093] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.845831] io scheduler mq-deadline registered
[    0.850473] io scheduler kyber registered
[    0.864561] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.871134] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.878578] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.893874] EINJ: ACPI disabled.
[    0.924351] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.936201] SuperH (H)SCI(F) driver initialized
[    0.941656] msm_serial: driver initialized
[    0.954118] loop: module loaded
[    0.959340] megasas: 07.719.03.00-rc1
[    0.971578] tun: Universal TUN/TAP device driver, 1.6
[    0.978232] thunder_xcv, ver 1.0
[    0.981600] thunder_bgx, ver 1.0
[    0.984924] nicpf, ver 1.0
[    0.989483] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.996884] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.002392] hclge is initializing
[    1.005807] e1000: Intel(R) PRO/1000 Network Driver
[    1.010795] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.016703] e1000e: Intel(R) PRO/1000 Network Driver
[    1.021784] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.027881] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.033463] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.039193] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.045602] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.052241] sky2: driver version 1.30
[    1.057959] VFIO - User Level meta-driver version: 0.3
[    1.066295] usbcore: registered new interface driver usb-storage
[    1.076232] i2c_dev: i2c /dev entries driver
[    1.092109] sdhci: Secure Digital Host Controller Interface driver
[    1.098512] sdhci: Copyright(c) Pierre Ossman
[    1.104273] Synopsys Designware Multimedia Card Interface Driver
[    1.111810] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.120534] ledtrig-cpu: registered to indicate activity on CPUs
[    1.129015] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.136544] usbcore: registered new interface driver usbhid
[    1.142271] usbhid: USB HID core driver
[    1.152765] optee: probing for conduit method.
[    1.157377] optee: revision 4.1 (012cdca4)
[    1.157756] optee: dynamic shared memory is enabled
[    1.167361] optee: initialized driver
[    1.175671] Initializing XFRM netlink socket
[    1.180129] NET: Registered PF_PACKET protocol family
[    1.185450] 9pnet: Installing 9P2000 support
[    1.189902] Key type dns_resolver registered
[    1.194775] registered taskstats version 1
[    1.199011] Loading compiled-in X.509 certificates
[    1.242790] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
[    1.298982] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
[    1.351625] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.359586] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.367087] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.373635] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.383263] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.404226] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.412527] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.424880] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.435068] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.446943] printk: console [ttyS2] disabled
[    1.451417] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 240, base_baud = 3000000) is a 8250
[    1.460308] printk: console [ttyS2] enabled
[    1.468766] printk: bootconsole [ns16550a0] disabled
[    1.484019] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.528994] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.536848] mdio_bus 8000f00.mdio: MDIO device at address 0 is missing.
[    1.543715] mdio_bus 8000f00.mdio: MDIO device at address 1 is missing.
[    1.550385] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.563335] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.570466] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.577030] pps pps0: new PPS source ptp0
[    1.581347] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.591626] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.608409] mmc0: CQHCI version 5.10
[    1.619900] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.626686] pca953x 1-0022: using AI
[    1.653149] pca953x 1-0022: failed writing register
[    1.653811] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.658289] pca953x: probe of 1-0022 failed with error -121
[    1.675188] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.707010] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.716367] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
[    1.729077] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
[    1.744606] ALSA device list:
[    1.747594]   No soundcards found.
[    1.752188] Waiting for root device PARTUUID=1eae32f4-38d4-7a4a-acb3-5e1e485f5ff6...
[    1.765864] mmc0: Command Queue Engine enabled
[    1.770335] mmc0: new HS200 MMC card at address 0001
[    1.776468] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    1.785258]  mmcblk0: p1
[    1.788913] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[    1.795125] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[    1.801381] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (511:0)
[    1.830624] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
[    1.839262] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    1.847212] devtmpfs: mounted
[    1.855612] Freeing unused kernel memory: 7680K
[    1.860378] Run /sbin/init as init process
[    1.951128] systemd[1]: System time before build time, advancing clock.
[    2.006917] NET: Registered PF_INET6 protocol family
[    2.013400] Segment Routing with IPv6
[    2.017127] In-situ OAM (IOAM) with IPv6
[    2.039577] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    2.071803] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    2.130108] systemd[1]: Hostname set to <am62xx-evm>.
[    2.137641] systemd[1]: Initializing machine ID from random generator.
[    2.528769] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.595439] systemd[1]: Queued start job for default target Graphical Interface.
[    2.656800] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    2.679479] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    2.703610] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    2.727360] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    2.749770] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    2.773578] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    2.797966] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    2.813420] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    2.837362] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    2.853296] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    2.928639] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    2.957998] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    2.984601] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    3.021351] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.046262] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.071296] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.094544] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.118844] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.136638] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.164257] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.187433] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.211656] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    3.273924] systemd[1]: Mounting Huge Pages File System...
[    3.295604] systemd[1]: Mounting POSIX Message Queue File System...
[    3.325311] systemd[1]: Mounting Kernel Debug File System...
[    3.342050] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.385772] systemd[1]: Mounting Temporary Directory /tmp...
[    3.410128] systemd[1]: Starting Create List of Static Device Nodes...
[    3.441141] systemd[1]: Starting Load Kernel Module configfs...
[    3.465192] systemd[1]: Starting Load Kernel Module drm...
[    3.487989] systemd[1]: Starting Load Kernel Module fuse...
[    3.510741] fuse: init (API version 7.37)
[    3.513310] systemd[1]: Starting Start psplash boot splash screen...
[    3.548779] systemd[1]: Starting RPC Bind...
[    3.569475] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    3.614483] systemd[1]: Starting Journal Service...
[    3.637675] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
[    3.653876] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[    3.686774] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.715708] systemd[1]: Starting Apply Kernel Variables...
[    3.738872] systemd[1]: Starting Coldplug All udev Devices...
[    3.763805] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    3.781891] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[FAILED] Failed to mount Huge Pages File System.
See 'systemctl status dev-hugepages.mount' for details.
[FAILED] Failed to mount POSIX Message Queue File System.
See 'systemctl status dev-mqueue.mount' for details.
[FAILED] Failed to mount Kernel Debug File System.
See 'systemctl status sys-kernel-debug.mount' for details.
[FAILED] Failed to mount Temporary Directory /tmp.
See 'systemctl status tmp.mount' for details.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Finished Generate network units from Kernel command line.
[FAILED] Failed to start Remount Root and Kernel File Systems.
See 'systemctl status systemd-remount-fs.service' for details.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Reached target Preparation for Network.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    4.300184] systemd-journald[167]: Received client request to flush runtime journal.
         Starting Create System Users...
[FAILED] Failed to mount FUSE Control File System.
See 'systemctl status sys-fs-fuse-connections.mount' for details.
[FAILED] Failed to mount Kernel Configuration File System.
See 'systemctl status sys-kernel-config.mount' for details.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /media/ram...
         Mounting /var/volatile...
[    4.609645] audit: type=1334 audit(1651167747.656:2): prog-id=5 op=LOAD
[    4.616342] audit: type=1334 audit(1651167747.664:3): prog-id=6 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[FAILED] Failed to mount /media/ram.
See 'systemctl status media-ram.mount' for details.
[DEPEND] Dependency failed for Local File Systems.
[FAILED] Failed to mount /var/volatile.
See 'systemctl status var-volatile.mount' for details.
[DEPEND] Dependency failed for Bind mount volatile /srv.
[DEPEND] Dependency failed for Bind mount volatile /var/lib.
[DEPEND] Dependency failed for Bind mount volatile /var/cache.
[DEPEND] Dependency failed for Bind mount volatile /var/spool.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Stopped Dispatch Password …ts to Console Directory Watch.
[  OK  ] Stopped Forward Password R…uests to Wall Directory Watch.
[  OK  ] Reached target Timer Units.
[  OK  ] Closed Syslog Socket.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Network Configuration...
         Starting Load/Save Random Seed...
[  OK  ] Reached target Socket Units.
[  OK  ] Started Emergency Shell.
[  OK  ] Reached target Emergency Mode.
         Starting Rebuild Dynamic Linker Cache...
         Starting Create Volatile Files and Directories...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Finished Create Volatile Files and Directories.
[    5.228434] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.249118] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.256716] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
         Starting Rebuild Journal Catalog...
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Network Configuration.
         Starting Network Name Resolution...
[  OK  ] Finished Rebuild Journal Catalog.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Rebuild Dynamic Linker Cache.
         Starting Update is Completed...
[  OK  ] Finished Record Runlevel Change in UTMP.
[  OK  ] Finished Update is Completed.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Time Set.
[    5.877040] random: crng init done
[  OK  ] Finished Load/Save Random Seed.
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl defaultPress Enter for maintenance
(or press Control-D to continue): [    6.182207] mc: Linux media interface: v0.10
[    6.248103] videodev: Linux video capture interface: v2.00
[    6.427721] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    6.434040] systemd-journald[167]: Time jumped backwards, rotating.
[    6.435774] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:38 UTC (38)
[    6.453505] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[    6.462237] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    6.469909] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[    6.492279] remoteproc remoteproc0: 5000000.m4fss is available
[    6.498641] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[    6.513068] remoteproc remoteproc0: powering up 5000000.m4fss
[    6.520247] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[    6.530562] remoteproc remoteproc0: request_firmware failed: -2
[    6.608850] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    6.623282] platform 78000000.r5f: configured R5F for IPC-only mode
[    6.630953] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[    6.639703] remoteproc remoteproc1: 78000000.r5f is available
[    6.646440] remoteproc remoteproc1: attaching to 78000000.r5f
[    6.681544] platform 78000000.r5f: R5F core initialized in IPC-only mode
[    6.688346] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@9da00000
[    6.697839] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    6.704771] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    6.945828] remoteproc remoteproc2: 30074000.pru is available
[    6.956480] remoteproc remoteproc3: 30078000.pru is available
[    7.037107] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22
[    7.058349] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.058826] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.074893] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.085722] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    7.091357] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    7.099299] xhci-hcd xhci-hcd.2.auto: USB3 root hub has no ports
[    7.105440] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010
[    7.115051] xhci-hcd xhci-hcd.2.auto: irq 420, io mem 0x31100000
[    7.122062] hub 1-0:1.0: USB hub found
[    7.126027] hub 1-0:1.0: 1 port detected
[    7.142213] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: new channel: 0x401 -> 0xd!
[    7.150922] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 1 (src: 0xd)
[    7.159556] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 2 (src: 0xd)
[    7.168073] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 3 (src: 0xd)
[    7.176508] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 4 (src: 0xd)
[    7.184909] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 5 (src: 0xd)
[    7.193276] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 6 (src: 0xd)
[    7.201650] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 7 (src: 0xd)
[    7.209984] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 8 (src: 0xd)
[    7.218290] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 9 (src: 0xd)
[    7.226617] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 10 (src: 0xd)
[    7.235004] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 11 (src: 0xd)
[    7.243403] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 12 (src: 0xd)
[    7.251799] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 13 (src: 0xd)
[    7.260226] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 14 (src: 0xd)
[    7.268622] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 15 (src: 0xd)
[    7.277027] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 16 (src: 0xd)
[    7.285431] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 17 (src: 0xd)
[    7.293833] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 18 (src: 0xd)
[    7.302235] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 19 (src: 0xd)
[    7.310620] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 20 (src: 0xd)
[    7.319022] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 21 (src: 0xd)
[    7.327409] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 22 (src: 0xd)
[    7.335812] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 23 (src: 0xd)
[    7.344197] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 24 (src: 0xd)
[    7.352597] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 25 (src: 0xd)
[    7.360989] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 26 (src: 0xd)
[    7.369383] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 27 (src: 0xd)
[    7.377771] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 28 (src: 0xd)
[    7.386169] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 29 (src: 0xd)
[    7.394557] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 30 (src: 0xd)
[    7.402953] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 31 (src: 0xd)
[    7.411338] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 32 (src: 0xd)
[    7.419737] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 33 (src: 0xd)
[    7.428121] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 34 (src: 0xd)
[    7.436517] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 35 (src: 0xd)
[    7.444906] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 36 (src: 0xd)
[    7.453307] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 37 (src: 0xd)
[    7.461698] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 38 (src: 0xd)
[    7.470096] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 39 (src: 0xd)
[    7.478486] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 40 (src: 0xd)
[    7.486887] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 41 (src: 0xd)
[    7.495308] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 42 (src: 0xd)
[    7.503709] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 43 (src: 0xd)
[    7.512100] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 44 (src: 0xd)
[    7.520495] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 45 (src: 0xd)
[    7.528884] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 46 (src: 0xd)
[    7.537278] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 47 (src: 0xd)
[    7.545669] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 48 (src: 0xd)
[    7.554066] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 49 (src: 0xd)
[    7.562453] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 50 (src: 0xd)
[    7.570849] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 51 (src: 0xd)
[    7.579239] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 52 (src: 0xd)
[    7.587638] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 53 (src: 0xd)
[    7.596027] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 54 (src: 0xd)
[    7.604424] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 55 (src: 0xd)
[    7.612816] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 56 (src: 0xd)
[    7.621213] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 57 (src: 0xd)
[    7.629601] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 58 (src: 0xd)
[    7.637996] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 59 (src: 0xd)
[    7.646386] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 60 (src: 0xd)
[    7.654783] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 61 (src: 0xd)
[    7.663165] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 62 (src: 0xd)
[    7.671556] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 63 (src: 0xd)
[    7.679941] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 64 (src: 0xd)
[    7.688335] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 65 (src: 0xd)
[    7.696723] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 66 (src: 0xd)
[    7.705116] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 67 (src: 0xd)
[    7.713502] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 68 (src: 0xd)
[    7.721893] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 69 (src: 0xd)
[    7.730280] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 70 (src: 0xd)
[    7.738674] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 71 (src: 0xd)
[    7.747061] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 72 (src: 0xd)
[    7.755451] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 73 (src: 0xd)
[    7.763842] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 74 (src: 0xd)
[    7.772234] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 75 (src: 0xd)
[    7.780620] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 76 (src: 0xd)
[    7.789021] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 77 (src: 0xd)
[    7.797408] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 78 (src: 0xd)
[    7.805802] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 79 (src: 0xd)
[    7.814184] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 80 (src: 0xd)
[    7.822573] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 81 (src: 0xd)
[    7.830959] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 82 (src: 0xd)
[    7.839349] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 83 (src: 0xd)
[    7.847732] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 84 (src: 0xd)
[    7.856127] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 85 (src: 0xd)
[    7.864515] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 86 (src: 0xd)
[    7.872915] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 87 (src: 0xd)
[    7.881305] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 88 (src: 0xd)
[    7.889696] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 89 (src: 0xd)
[    7.898083] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 90 (src: 0xd)
[    7.906477] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 91 (src: 0xd)
[    7.914863] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 92 (src: 0xd)
[    7.923253] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 93 (src: 0xd)
[    7.931640] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 94 (src: 0xd)
[    7.940030] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 95 (src: 0xd)
[    7.948416] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 96 (src: 0xd)
[    7.956806] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 97 (src: 0xd)
[    7.965193] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 98 (src: 0xd)
[    7.973587] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 99 (src: 0xd)
[    7.981973] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: incoming msg 100 (src: 0xd)
[    7.990416] rpmsg_client_sample virtio0.ti.ipc4.ping-pong.-1.13: goodbye!
[   17.341662] i2c 1-003b: deferred probe pending
[   17.346272] platform regulator-3: deferred probe pending
[   17.351687] platform regulator-6: deferred probe pending
[   17.357088] platform regulator-7: deferred probe pending
[   17.362483] platform fa00000.mmc: deferred probe pending
[   17.367867] platform fa20000.mmc: deferred probe pending
[   17.373290] platform 30200000.dss: deferred probe pending
sh-5.1#
sh-5.1#
sh-5.1#
sh-5.1#
sh-5.1# vi /etc/systemd/system/chromium.service
sh-5.1# sudo systemctl daemon-reload
sh: sudo: command not found
sh-5.1# systemctl daemon-reload
[  248.723599] audit: type=1334 audit(280.784:4): prog-id=7 op=LOAD
[  248.729700] audit: type=1334 audit(280.792:5): prog-id=8 op=LOAD
[  248.735785] audit: type=1334 audit(280.792:6): prog-id=3 op=UNLOAD
[  248.741998] audit: type=1334 audit(280.792:7): prog-id=4 op=UNLOAD
[  248.748233] audit: type=1334 audit(280.796:8): prog-id=9 op=LOAD
[  248.754348] audit: type=1334 audit(280.804:9): prog-id=10 op=LOAD
[  248.760532] audit: type=1334 audit(280.804:10): prog-id=5 op=UNLOAD
sh-5.1# [  248.766849] audit: type=1334 audit(280.804:11): prog-id=6 op=UNLOAD
systemctl enable chromium.service
Created symlink /etc/systemd/system/graphical.target.wants/chromium.service -> /etc/systemd/system/chromium.service.
Created symlink /etc/systemd/system/multi-user.target.wants/chromium.service -> /etc/systemd/system/chromium.service.
[  259.851517] audit: type=1334 audit(291.912:12): prog-id=11 op=LOAD
[  259.857785] audit: type=1334 audit(291.920:13): prog-id=12 op=LOAD
[  259.864042] audit: type=1334 audit(291.920:14): prog-id=7 op=UNLOAD
[  259.870357] audit: type=1334 audit(291.920:15): prog-id=8 op=UNLOAD
[  259.876686] audit: type=1334 audit(291.924:16): prog-id=13 op=LOAD
[  259.882939] audit: type=1334 audit(291.932:17): prog-id=14 op=LOAD
[  259.889208] audit: type=1334 audit(291.932:18): prog-id=9 op=UNLOAD
sh-5.1# [  259.895527] audit: type=1334 audit(291.932:19): prog-id=10 op=UNLOAD
systemctl start chromium.service
Failed to start chromium.service: Unit docker.socket not found.
sh-5.1# systemctl start chromium.service
[  356.367537] audit: type=1334 audit(388.428:20): prog-id=15 op=LOAD
[  356.373800] audit: type=1334 audit(388.436:21): prog-id=16 op=LOAD
[  356.380045] audit: type=1334 audit(388.436:22): prog-id=11 op=UNLOAD
[  356.386441] audit: type=1334 audit(388.436:23): prog-id=12 op=UNLOAD
[  356.392852] audit: type=1334 audit(388.440:24): prog-id=17 op=LOAD
[  356.399136] audit: type=1334 audit(388.448:25): prog-id=18 op=LOAD
[  356.405401] audit: type=1334 audit(388.448:26): prog-id=13 op=UNLOAD
sh-5.1# [  356.411805] audit: type=1334 audit(388.448:27): prog-id=14 op=UNLOAD
sh-5.1# systemctl enable chromium.service
[  360.786194] audit: type=1334 audit(392.848:28): prog-id=19 op=LOAD
[  360.792457] audit: type=1334 audit(392.852:29): prog-id=20 op=LOAD
You are in emergency mode. After logging in, type "journalctl -xb" toPress Enter for maintenance
Now, my questions are
1. what is difference between the .wic.xz provided by Ti i.e. Image provided on link: Link and the .wic.xz Image generated by me using the Yocto build?
2. What are changes required to be done in the .wic.xz generated from Yocto build so that I can flash it to eMMC and boot directly?
Thanks & Regards,
Aditya T
    Our expert is currently out of office, please expect delays in response.
    Krunal
    I'm still having this issue.
    Is their any update on this issue?
    Kind Regards,
    Aditya T
    Our expert is out of office for next couple of weeks and he will respond once he is back.
    Krunal
    I'm still waiting for this issue to be resolved.
    Kind Regards,
    Aditya T
    Waiting for this issue to get resolved as soon as possible, due to this issue we're having product release issues.
    Please help me finding solution on this.
    Kind Regards,
    Aditya T
  • Hello Ti experts,
    Is anyone going to answer to this thread?
    Kind Regards,
    Aditya T
  • Hi Aditya,
    looks like perhaps your eMMC is missing critical system folders like /proc, /sys, /dev, and /tmp so the Kernel can't mount the respective sysfs nodes.
    Try to program your eMMC using the rootfs tarball, rather than copying files from the WIC image, see the steps here (skip ahead to the "The following instructions can be used to prepare the <your_rootfs.ext4> using tisdk-base-image-am62xx-evm.tar.xz:" section): https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1127618/faq-sk-am62-how-to-flash-emmc-using-usb-dfu-on-am62x-sk-e2
    If you inspect one of the Yocto-generated rootfs tarballs (example below) you'll see how it contains empty directories for those Kernel mountpoints, and extracting said tarballs will create those on the eMMC.
    a0797059@dasso:~/tisdk/am62xx-evm/build/deploy-ti/images/am62xx-evm (dev)
    $ tar -tvf tisdk-tiny-image-am62xx-evm.tar.xz | grep '\/sys\/'
    dr-xr-xr-x 0/0               0 2018-03-09 06:34 ./sys/
    $ tar -tvf tisdk-tiny-image-am62xx-evm.tar.xz | grep '\/proc\/'
    lrwxrwxrwx 0/0               0 2018-03-09 06:34 ./etc/mtab -> /proc/mounts
    dr-xr-xr-x 0/0               0 2018-03-09 06:34 ./proc/
    $ tar -tvf tisdk-tiny-image-am62xx-evm.tar.xz | grep '\/tmp\/'
    drwxrwxrwt 0/0               0 2018-03-09 06:34 ./tmp/
    $ tar -tvf tisdk-tiny-image-am62xx-evm.tar.xz | grep '\/dev\/'
    drwxr-xr-x 0/0               0 2018-03-09 06:34 ./dev/
    lrwxrwxrwx 0/0               0 2018-03-09 06:34 ./etc/tmpfiles.d/etc.conf -> /dev/null
    lrwxrwxrwx 0/0               0 2018-03-09 06:34 ./etc/tmpfiles.d/home.conf -> /dev/nul
    Regards, Andreas
    I followed all the steps mentioned here and created an ext4 file out of tar.xz file. But, still the device enters in emergency mode. I've shared logs for the same
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:52:36 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    SPL initial stack usage: 13424 bytes
    Trying to boot from MMC1
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from MMC... OK
    init_env from device 9 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
    NOTICE:  BL31: Built : 05:06:58, Feb 24 2023
    U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000)
    U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000)
    SoC:   AM62X SR1.0 GP
    Model: Texas Instruments AM625 SK
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed -1
    DRAM:  2 GiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   Could not get PHY for ethernet@8000000port@1: addr 0
    am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
    No ethernet found.
    Hit any key to stop autoboot:  0
    ** Unrecognized filesystem type **
    39154176 bytes read in 225 ms (166 MiB/s)
    60014 bytes read in 5 ms (11.4 MiB/s)
    Starting kernel ...
    [    0.000000] Linux version 6.1.80-dirty (repl@repl-HP-EliteBook-840-G4) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Aug 23 10:49:47 IST 2024
    [    0.000000] NUMA: NODE_DATA [mem 0xf7bd6a00-0xf7bd8fff]
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=00000000-01 rw rootfstype=ext4 rootwait
    [    0.000000] Memory: 1828820K/2097152K available (17024K kernel code, 3804K rwdata, 9588K rodata, 7680K init, 625K bss, 137260K reserved, 131072K cma-reserved)
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.009682] Console: colour dummy device 80x25
    [    0.014325] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.025010] pid_max: default: 32768 minimum: 301
    [    0.029788] LSM: Security Framework initializing
    [    0.034633] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.042217] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.052085] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.059532] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.065831] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.073229] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.079647] rcu: Hierarchical SRCU implementation.
    [    0.084558] rcu: 	Max phase no-delay instances is 1000.
    [    0.090153] Platform MSI: msi-controller@1820000 domain created
    [    0.096454] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.105724] fsl-mc MSI: msi-controller@1820000 domain created
    [    0.113675] EFI services will not be available.
    [    0.118635] smp: Bringing up secondary CPUs ...
    [    0.123955] Detected VIPT I-cache on CPU1
    [    0.124067] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.124085] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
    [    0.124143] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.124887] Detected VIPT I-cache on CPU2
    [    0.124975] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.124990] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
    [    0.125025] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.125659] Detected VIPT I-cache on CPU3
    [    0.125744] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.125757] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
    [    0.125786] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.125859] smp: Brought up 1 node, 4 CPUs
    [    0.205612] SMP: Total of 4 processors activated.
    [    0.210425] CPU features: detected: 32-bit EL0 Support
    [    0.215698] CPU features: detected: 32-bit EL1 Support
    [    0.220959] CPU features: detected: CRC32 instructions
    [    0.226292] CPU: All CPU(s) started at EL2
    [    0.230503] alternatives: applying system-wide alternatives
    [    0.238599] devtmpfs: initialized
    [    0.250845] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.260859] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.272925] pinctrl core: initialized pinctrl subsystem
    [    0.280625] DMI not present or invalid.
    [    0.285318] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.292580] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.300085] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.308146] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.316337] audit: initializing netlink subsys (disabled)
    [    0.322043] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    [    0.323467] thermal_sys: Registered thermal governor 'step_wise'
    [    0.329989] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.336214] cpuidle: using governor menu
    [    0.347146] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.354192] ASID allocator initialised with 65536 entries
    [    0.361578] Serial: AMBA PL011 UART driver
    [    0.382769] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.395013] OF: /backlight: #pwm-cells = 3 found 2
    [    0.403562] KASLR disabled due to lack of seed
    [    0.416555] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.423523] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.429976] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.436916] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.443325] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.450264] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.456672] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.463612] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.472007] ACPI: Interpreter disabled.
    [    0.477996] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.489161] iommu: Default domain type: Translated
    [    0.494188] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.500908] SCSI subsystem initialized
    [    0.505130] usbcore: registered new interface driver usbfs
    [    0.510778] usbcore: registered new interface driver hub
    [    0.516232] usbcore: registered new device driver usb
    [    0.522696] pps_core: LinuxPPS API ver. 1 registered
    [    0.527782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.537133] PTP clock support registered
    [    0.541275] EDAC MC: Ver: 3.0.0
    [    0.546757] FPGA manager framework
    [    0.550368] Advanced Linux Sound Architecture Driver Initialized.
    [    0.557604] vgaarb: loaded
    [    0.560854] clocksource: Switched to clocksource arch_sys_counter
    [    0.567360] VFS: Disk quotas dquot_6.6.0
    [    0.571419] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.578652] pnp: PnP ACPI: disabled
    [    0.588010] NET: Registered PF_INET protocol family
    [    0.593318] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.602590] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.611404] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.619343] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.627546] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.635541] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.642455] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.649384] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.656921] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.663209] RPC: Registered named UNIX socket transport module.
    [    0.669292] RPC: Registered udp transport module.
    [    0.674102] RPC: Registered tcp transport module.
    [    0.678911] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.685504] NET: Registered PF_XDP protocol family
    [    0.690419] PCI: CLS 0 bytes, default 64
    [    0.695317] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.704418] kvm [1]: IPA Size Limit: 40 bits
    [    0.710440] kvm [1]: vgic-v2@100010000
    [    0.714293] kvm [1]: GIC system register CPU interface enabled
    [    0.720365] kvm [1]: vgic interrupt IRQ9
    [    0.724459] kvm [1]: Hyp mode initialized successfully
    [    0.731219] Initialise system trusted keyrings
    [    0.736090] workingset: timestamp_bits=42 max_order=19 bucket_order=0
    [    0.748966] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.755594] NFS: Registering the id_resolver key type
    [    0.760826] Key type id_resolver registered
    [    0.765104] Key type id_legacy registered
    [    0.769271] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.776127] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.783897] 9p: Installing v9fs 9p2000 file system support
    [    0.824229] Key type asymmetric registered
    [    0.828434] Asymmetric key parser 'x509' registered
    [    0.833484] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.841225] io scheduler mq-deadline registered
    [    0.845866] io scheduler kyber registered
    [    0.859412] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.865976] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.873344] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.888122] EINJ: ACPI disabled.
    [    0.917207] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.928950] SuperH (H)SCI(F) driver initialized
    [    0.934333] msm_serial: driver initialized
    [    0.946759] loop: module loaded
    [    0.951962] megasas: 07.719.03.00-rc1
    [    0.963922] tun: Universal TUN/TAP device driver, 1.6
    [    0.970463] thunder_xcv, ver 1.0
    [    0.973839] thunder_bgx, ver 1.0
    [    0.977174] nicpf, ver 1.0
    [    0.981617] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
    [    0.989021] hns3: Copyright (c) 2017 Huawei Corporation.
    [    0.994514] hclge is initializing
    [    0.997931] e1000: Intel(R) PRO/1000 Network Driver
    [    1.002917] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.008828] e1000e: Intel(R) PRO/1000 Network Driver
    [    1.013909] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.020000] igb: Intel(R) Gigabit Ethernet Network Driver
    [    1.025520] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    1.031319] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    1.037735] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.044369] sky2: driver version 1.30
    [    1.049993] VFIO - User Level meta-driver version: 0.3
    [    1.058245] usbcore: registered new interface driver usb-storage
    [    1.068078] i2c_dev: i2c /dev entries driver
    [    1.083672] sdhci: Secure Digital Host Controller Interface driver
    [    1.090066] sdhci: Copyright(c) Pierre Ossman
    [    1.095788] Synopsys Designware Multimedia Card Interface Driver
    [    1.103281] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.111880] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.120294] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.127821] usbcore: registered new interface driver usbhid
    [    1.133552] usbhid: USB HID core driver
    [    1.143952] optee: probing for conduit method.
    [    1.148571] optee: revision 3.20 (8e74d476)
    [    1.148963] optee: dynamic shared memory is enabled
    [    1.158494] optee: initialized driver
    [    1.166676] Initializing XFRM netlink socket
    [    1.171133] NET: Registered PF_PACKET protocol family
    [    1.176449] 9pnet: Installing 9P2000 support
    [    1.180910] Key type dns_resolver registered
    [    1.185773] registered taskstats version 1
    [    1.190001] Loading compiled-in X.509 certificates
    [    1.231404] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar')
    [    1.353427] rtc-m41t80 0-0068: HT bit was set!
    [    1.358007] rtc-m41t80 0-0068: Power Down at 2024-08-23T07:15:15
    [    1.364999] rtc-m41t80 0-0068: registered as rtc0
    [    1.370264] rtc-m41t80 0-0068: setting system clock to 2024-08-23T07:15:26 UTC (1724397326)
    [    1.378886] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.385405] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.395063] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.411167] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.419449] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.431816] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.442009] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.453889] printk: console [ttyS2] disabled
    [    1.458353] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 236, base_baud = 3000000) is a 8250
    [    1.467241] printk: console [ttyS2] enabled
    [    1.475698] printk: bootconsole [ns16550a0] disabled
    [    1.488613] 2820000.serial: ttyS3 at MMIO 0x2820000 (irq = 238, base_baud = 3000000) is a 8250
    [    1.502330] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.548867] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.559138] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.567249] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver SMSC LAN8710/LAN8720
    [    1.576242] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.589208] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.596338] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.603026] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.613414] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.629945] mmc0: CQHCI version 5.10
    [    1.637402] am65-cpsw-nuss 8000000.ethernet: Failed to create device link (0x180) with 601000.gpio
    [    1.656275] mmc1: CQHCI version 5.10
    [    1.661645] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    1.669524] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.670924] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
    [    1.696382] ALSA device list:
    [    1.699417]   No soundcards found.
    [    1.757675] mmc0: Command Queue Engine enabled
    [    1.762160] mmc0: new HS200 MMC card at address 0001
    [    1.768144] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.774743]  mmcblk0: p1
    [    1.778000] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.784167] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.790071] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (511:0)
    [    3.177358] sdhci-am654 fa00000.mmc: Power on failed
    [    3.213501] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    3.239815] EXT4-fs (mmcblk0p1): recovery complete
    [    3.246241] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [    3.255329] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    3.261843] devtmpfs: mounted
    [    3.270518] Freeing unused kernel memory: 7680K
    [    3.275246] Run /sbin/init as init process
    [    3.435043] NET: Registered PF_INET6 protocol family
    [    3.441770] Segment Routing with IPv6
    [    3.445526] In-situ OAM (IOAM) with IPv6
    [    3.486307] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    3.518461] systemd[1]: Detected architecture arm64.
    [    3.577684] systemd[1]: Hostname set to <am62xx-evm>.
    [    3.678200] systemd-sysv-generator[153]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.966860] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.026728] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.098803] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.162332] systemd[1]: Created slice Slice /system/getty.
    [    4.188071] systemd[1]: Created slice Slice /system/modprobe.
    [    4.211969] systemd[1]: Created slice Slice /system/serial-getty.
    [    4.235547] systemd[1]: Created slice User and Session Slice.
    [    4.257506] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.281423] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.305548] systemd[1]: Reached target Path Units.
    [    4.325112] systemd[1]: Reached target Remote File Systems.
    [    4.345146] systemd[1]: Reached target Slice Units.
    [    4.365156] systemd[1]: Reached target Swaps.
    [    4.441580] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.465562] systemd[1]: Reached target RPC Port Mapper.
    [    4.504115] systemd[1]: Listening on Process Core Dump Socket.
    [    4.525991] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.551121] systemd[1]: Listening on Journal Audit Socket.
    [    4.574519] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.599838] systemd[1]: Listening on Journal Socket.
    [    4.625042] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.651985] systemd[1]: Listening on udev Control Socket.
    [    4.675278] systemd[1]: Listening on udev Kernel Socket.
    [    4.699602] systemd[1]: Listening on User Database Manager Socket.
    [    4.761582] systemd[1]: Mounting Huge Pages File System...
    [    4.788454] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.841649] systemd[1]: Mounting Kernel Debug File System...
    [    4.866319] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.880050] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
    [    4.897735] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.933298] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.993973] systemd[1]: Starting Load Kernel Module configfs...
    [    5.028084] systemd[1]: Starting Load Kernel Module drm...
    [    5.056740] systemd[1]: Starting Load Kernel Module fuse...
    [    5.077583] fuse: init (API version 7.37)
    [    5.090161] systemd[1]: Starting Start psplash boot splash screen...
    [    5.158105] systemd[1]: Starting RPC Bind...
    [    5.177467] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    5.204351] systemd[1]: Starting Journal Service...
    [    5.234093] systemd[1]: Starting Load Kernel Modules...
    [    5.255957] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.291188] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.320659] systemd[1]: Starting Coldplug All udev Devices...
    [    5.343950] systemd[1]: Started RPC Bind.
    [    5.357805] systemd[1]: Started Journal Service.
    [  OK  ] Finished Load Kernel Modules.
    [    5.813519] systemd-journald[168]: Received client request to flush runtime journal.
    [    6.087435] audit: type=1334 audit(1724397331.212:2): prog-id=5 op=LOAD
    [    6.094148] audit: type=1334 audit(1724397331.220:3): prog-id=6 op=LOAD
    [    6.828269] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.863760] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.871196] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Finished Synchronize System and HW clocks.
    [  OK  ] Reached target Host and Network Nam[    7.458315] pwm-backlight backlight: supply power not found, using dummy regulator
    e Lookups.
    [    7.489883] panel-simple panel: supply power not found, using dummy regulator
    [    7.499040] OF: /backlight: #pwm-cells = 3 found 2
    [    7.503933] of_pwm_get(): can't parse "pwms" property
    [    7.509513] pwm-backlight backlight: unable to request PWM
    [    7.516481] pwm-backlight: probe of backlight failed with error -22
    [    7.568922] random: crng init done
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
    system logs, "systemctl reboot" to reboot, "systemctl default" oPress Enter for maintenance
    (or press Control-D to continue): [    7.786006] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    7.796382] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    7.805210] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    7.809757] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [    7.814404] remoteproc remoteproc0: 5000000.m4fss is available
    [    7.820074] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    7.848425] remoteproc remoteproc0: powering up 5000000.m4fss
    [    7.848456] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016
    [    7.850574] k3-m4-rproc 5000000.m4fss: mbox_request_channel failed: -517
    [    7.850597] remoteproc remoteproc0: can't start rproc 5000000.m4fss: -16
    [    7.851220] Console: switching to colour frame buffer device 160x50
    [    7.858771] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: SoC supports only single core R5 but num_cores is set to 0
    [    7.976277] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
    [    8.045533] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [    8.056245] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rmii link mode
    [    8.091792] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.101455] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    8.136570] pvrsrvkm: loading out-of-tree module taints kernel.
    [    8.191704] PVR_K:  201: Device: fd00000.gpu
    [    8.221566] PVR_K:  201: Read BVNC 33.15.11.3 from HW device registers
    [    8.233165] PVR_K:  201: RGX Device registered with BVNC 33.15.11.3
    [    8.250629] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1
    [    8.672765] remoteproc remoteproc1: 30074000.pru is available
    [    8.687244] remoteproc remoteproc2: 30078000.pru is available
    [    8.728469] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    8.734351] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
    [    8.742359] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports
    [    8.748501] xhci-hcd xhci-hcd.1.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010
    [    8.758031] xhci-hcd xhci-hcd.1.auto: irq 420, io mem 0x31100000
    [    8.765247] hub 1-0:1.0: USB hub found
    [    8.769191] hub 1-0:1.0: 1 port detected
    [    9.028987] usb 1-1: new low-speed USB device number 2 using xhci-hcd
    [    9.221983] input: Usb KeyBoard Usb KeyBoard as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:C0F4:04F5.0001/input/input0
    [    9.299034] hid-generic 0003:C0F4:04F5.0001: input: USB HID v1.10 Keyboard [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.1.auto-1/input0
    [    9.322134] input: Usb KeyBoard Usb KeyBoard Consumer Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:C0F4:04F5.0002/input/input1
    [    9.398036] input: Usb KeyBoard Usb KeyBoard System Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:C0F4:04F5.0002/input/input2
    [    9.415134] hid-generic 0003:C0F4:04F5.0002: input: USB HID v1.10 Device [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.1.auto-1/input1
    sh-5.1# [   18.862959] platform sound: deferred probe pending
    sh-5.1# journalctl -xb > a.txt
    sh-5.1# [   50.533862] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [   50.540364] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
    sh-5.1# ifconfig
    eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 1c:63:49:1c:04:8c  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.1.60  netmask 255.255.255.0  broadcast 192.168.1.255
            inet6 fe80::1e63:49ff:fe1c:48c  prefixlen 64  scopeid 0x20<link>
            RX packets 53  bytes 4296 (4.1 KiB)
            RX errors 0  dropped 15  overruns 0  frame 0
            TX packets 20  bytes 2088 (2.0 KiB)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 2  bytes 140 (140.0 B)
            TX packets 2  bytes 140 (140.0 B)
    sh-5.1# scp a.txt repl@192.168.1.164:/home/repl
    Host '192.168.1.164' is not in the trusted hosts file.
    (ssh-ed25519 fingerprint sha1!! 6b:57:4b:b4:77:d5:57:ee:6c:21:a7:a3:e5:ff:00:d3:c3:3b:51:b8)
    Do you want to continue connecting? (y/n)
    /usr/bin/dbclient: Connection to repl@192.168.1.164:22 exited: Didn't validate host key
    lost connection
    Do you want to continue connecting? (y/n) y
    repl@192.168.1.164's password:
    a.txt                                         100%   95KB  95.3KB/s   00:00
    sh-5.1# ls -l /
    total 72
    drwxr-xr-x   2 weston weston  4096 Mar  9  2018 bin
    drwxr-xr-x   3 weston weston  4096 Aug 23 06:25 boot
    drwxr-xr-x  17 root   root    3760 Aug 23 07:15 dev
    drwxr-xr-x  55 weston weston  4096 Aug 23 07:10 etc
    drwxr-xr-x   4 weston weston  4096 Mar  9  2018 home
    drwxr-xr-x  10 weston weston  4096 Mar  9  2018 lib
    lrwxrwxrwx   1 weston weston    19 Mar  9  2018 linuxrc -> /bin/busybox.nosuid
    drwx------   2 root   root   16384 Aug 23 04:52 lost+found
    drwxr-xr-x   3 weston weston  4096 Aug 23 07:10 media
    drwxr-xr-x   2 weston weston  4096 Mar  9  2018 mnt
    drwxr-xr-x   3 weston weston  4096 Mar  9  2018 opt
    dr-xr-xr-x 154 root   root       0 Aug 23 07:15 proc
    drwxr-xr-x  11 root   root     320 Aug 23 07:15 run
    drwxr-xr-x   2 weston weston  4096 Mar  9  2018 sbin
    drwxr-xr-x   2 weston weston  4096 Mar  9  2018 srv
    dr-xr-xr-x  13 root   root       0 Aug 23 07:15 sys
    drwxrwxrwt   4 root   root    4096 Aug 23 07:15 tmp
    drwxr-xr-x  12 weston weston  4096 Mar  9  2018 usr
    drwxr-xr-x   9 weston weston  4096 Aug 23 07:10 var
    drwxr-xr-x   3 weston weston  4096 Mar  9  2018 www
    sh-5.1#
    Also attached output for command "journalctl -xb" in file below
    journalctl_logs.txt
    Please update regarding it as soon as possible
    Yes the empty directories are present on my system also, checked it.
    Also I need to ask is why to use data for filesystem from .tar.xz and not from root partition of SD card, which is flashed from .wic.xz generated?
    Because in my case, the ext4 created using any of the way is containing the directories /proc, /sys, /dev, and /tmp so the Kernel can mount the respective sysfs nodes, but still kernel goes into emergency mode.
    Do I need to do yocto build again?
    Thanks & Regards,
    Aditya T
    Is there any update on this query?
    Kind Regards,
    Aditya T
  • Hello ,
    Is there any update on this issue?
    Kind Regards,
    Aditya T
  • Is anyone going to answer this query?
    this is an very important issue to resolve or my custom board will not go into production
  • Also I need to ask is why to use data for filesystem from .tar.xz and not from root partition of SD card, which is flashed from .wic.xz generated?
    It's not just about the presence of those folders but there could also be specific permission related issues. Perhaps also files/folders are missing
    Programming the rootfs from a Yocto-generated tarball is a known-good method to program the rootfs, so we should try to re-create this and use this as a known-good baseline.
    Can you program your eMMC using...
    1) The TI-provided rootfs tarball, and
    2) Your own Yocto-generated rootfs tarball
    ...to see if either or both those methods work?
    (they should)
    Then, if you must use your own process/method, you can then compare the filesystems side by side in detail what is different between your working and non-working SD cards and their respective file systems.
    Regards, Andreas
    Yes, using Ti-provided rootfs it is possible to boot in eMMC.
    No, in this case the kernel enters into emergency mode
    The both Ti provided as well as Yocto image works fine wit the SD card, but the Yocto built one is failing when I flash the rootfs into eMMC, The image fails to boot even in EVK
    Aditya T
  • Hi Aditya.
    How did you Yocto-build this failing rootfs tarball (detailed steps). I would like to understand what exactly you did there.
    Thanks, Andreas
  • Well, I did followed the steps provided in manual only
    The manual link: linkhttps://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_02_01_10/exports/docs/linux/Overview_Building_the_SDK.html
    Also I was getting some errors in building a Yocto Image, the query link which helped me completing my build is: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1336065/am625-errors-in-building-yocto-kirkstone-linux-for-custom-am625-som
    This is it, I've followed these steps and solved the errors came across.
    Kind Regards,
    Aditya T
  • Hi Aditya,
    So you no longer have this issue; and we can close this support case?
    Can you please let me know if there's some specific issue/mistake in the documentation? If something needs improvement I want to provide feedback to the respective team.
    Thanks, Andreas
  • So you no longer have this issue; and we can close this support case?
    I can build the Yocto Image successfully, but the Image built isn't working into eMMC. That's my issue
    No, there ain't any mistake in documentation, if followed the documentation anyone can built their own yocto Image
    Kind Regards,
    Aditya T
    This issue is not resolved. Still I'm not able to boot the Yocto built Image from eMMC of AM625
    Kind Regards,
    Aditya T
    Andreas is out of office for over a week. Please expect delayed response.
  • Okay, Thanks for letting me know!
  • Hi Aditya,
    Yes Andreas is just back in office, but please give him some time to catch up the work until he can reply on the e2e forums.
  • Okay, but this issue needs to be get resolved as soon as possible. Please try to understand the seriousness of this issue to get resolved, because this issue is must to get resolved.
    Is anyone going to solve this issue?
  • Please close this thread as anyone is not responding to it. So we've decided to leave it!
  • Is anyone been trying to solve this issue?
