DMVA1INPC - Montavista Kernel 2.6.18
Does anyone have successfully configured the Montavista kernel 2.6.18 for DMVA1 or DMVA2INPC with USB OTG in host mode?. I configured the USB OTG in host mode, but the USB doesn't enumerate my device.
john
  • john,
    please send the output of "cat /proc/driver/musb_hdrc" after device is connected.
    ajay
  • Ajay,
    Message during boot up...
    musb_hdrc: version 6.0/dbg, cppi-dma, host, debug=3
    musb_hdrc musb_hdrc: No DMA interrupt line
    musb_hdrc: USB Host mode controller at c3068000 using DMA, IRQ 12
    musb_hdrc musb_hdrc: MUSB HDRC host driver
    musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
    usb usb1: Product: MUSB HDRC host driver
    usb usb1: Manufacturer: Linux 2.6.18_pro500-davinci musb-hcd
    usb usb1: SerialNumber: musb_hdrc
    usb usb1: configuration #1 chosen from 1 choice
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    1. After the reboot
    # cat /proc/driver/musb_hdrc
    Status: MHDRC, Mode=Host (Power=e0, DevCtl=80)
    OTG state: a_idle; inactive
    Options: cppi-dma, host, debug=3 [eps=5]
    Root port status: 00000100
    DaVinci: ctrl=00 stat=0 phy=21c0
            rndis=00000 auto=0000 intsrc=00000000 intmsk=01ff1e1f
    CPPI: txcr=1 txsrc=0 txena=f; rxcr=1 rxsrc=0 rxena=f
    2. Plugged powered USB device
    3. Plugged non-powered USB device
  • whats the result in non-DMA mode?
    Ajay
  • Ajay,
    Here's the non-dma mode.
    musb_hdrc: version 6.0/dbg, pio, host, debug=3
    musb_hdrc: USB Host mode controller at c3066000 using PIO, IRQ 12
    usb usb1: Manufacturer: Linux 2.6.18_pro500-davinci_IPNC_DM365_2.6.0 musb-hcd
    After the reboot (non-DMA mode)
    1. cat /proc/driver/musb_hdrc
    Options: pio, host, debug=3 [eps=5]
    2. cat /proc/driver/musb_hdrc (plugged usb device)
    3. cat /proc/driver/musb_hdrc (plugged self-powered usb device)
  • Vbus in both DMA and nonDMA case is not switched ON. The devCTL register value should be  D[3:4] == '11' for this but in your case it's '00'.
    See if you have option to start the session using "echo F > /proc/driver/musb_hdrc"
    Ajay
  • Ajay,
    I got the info from APPRO (courtesy of one of the TI's tech guy) that the reference design of DMVA1 does not support USB host.
    john
  • John,
    That answers why Vbus is not switched on. Now do you plan to use another platform or do hw modification to support host mode?
    Ajay
  • Yes, we will do the hw modification.
    john
