AM625-Q1: Audio codec Mcasp2 bring up
Part Number: AM625-Q1
Hi ,
We are trying to bring up MCASP 2 lines for audio codec on AM6254-Q1 similar to EVM .
Only change is we are using 0x18 address and mcasp2 .
Aplay command exits after playing audio in EVM but in our board after aplay ,it's stuck and need to give Ctrl+c to exit
We doubt on mcasp2 fragment definition in device tree
Board test log:
root@am62xx-evm:~# cd /usr/share/sounds/alsa/
root@am62xx-evm:/usr/share/sounds/alsa# aplay Front_Left.wav
Playing WAVE 'Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
^CAborted by signal Interrupt...
aplay: pcm_write:2127: write error: Interrupted system call
root@am62xx-evm:/usr/share/sounds/alsa# lsmod
Module                  Size  Used by
can_raw                24576  2
can                    24576  1 can_raw
iptable_nat            16384  0
nf_nat                 49152  1 iptable_nat
nf_conntrack          126976  1 nf_nat
nf_defrag_ipv6         20480  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
libcrc32c              16384  2 nf_conntrack,nf_nat
iptable_mangle         16384  0
iptable_filter         16384  0
bluetooth             581632  2
ecdh_generic           16384  1 bluetooth
ecc                    36864  1 ecdh_generic
rpmsg_ctrl             16384  0
rpmsg_char             16384  1 rpmsg_ctrl
crct10dif_ce           16384  1
snd_soc_simple_card    20480  0
snd_soc_simple_card_utils    24576  1 snd_soc_simple_card
pvrsrvkm             1347584  8
display_connector      16384  0
phy_can_transceiver    16384  3
brcmfmac              249856  0
brcmutil               20480  1 brcmfmac
cfg80211              888832  1 brcmfmac
ti_k3_r5_remoteproc    28672  0
virtio_rpmsg_bus       20480  0
rpmsg_ns               16384  1 virtio_rpmsg_bus
rtc_ti_k3              16384  1
k3_j72xx_bandgap       20480  0
rti_wdt                16384  0
ti_k3_m4_remoteproc    16384  0
ti_k3_common           16384  1 ti_k3_m4_remoteproc
snd_soc_davinci_mcasp    32768  2
snd_soc_ti_udma        16384  1 snd_soc_davinci_mcasp
snd_soc_ti_edma        16384  1 snd_soc_davinci_mcasp
sa2ul                  36864  0
snd_soc_ti_sdma        16384  1 snd_soc_davinci_mcasp
cdns_dphy_rx           16384  0
mcrc                   16384  0
ilitek_ts_i2c          20480  0
snd_soc_tlv320aic3x_i2c    16384  1
sii902x                20480  0
m_can_platform         16384  0
snd_soc_tlv320aic3x    77824  1 snd_soc_tlv320aic3x_i2c
m_can                  24576  1 m_can_platform
can_dev                36864  1 m_can
spi_omap2_mcspi        24576  0
optee_rng              16384  0
rng_core               20480  2 optee_rng
fuse                  131072  1
ip_tables              32768  3 iptable_filter,iptable_nat,iptable_mangle
x_tables               40960  4 iptable_filter,ip_tables,iptable_nat,iptable_mangle
ipv6                  479232  56
root@am62xx-evm:/usr/share/sounds/alsa# lsmod |grep snd
root@am62xx-evm:/usr/share/sounds/alsa# i2cdetect -r 1
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-1 using receive byte commands.
I will probe address range 0x08-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@am62xx-evm:/usr/share/sounds/alsa# 18 is audio codec i2c address
-sh: 18: command not found
root@am62xx-evm:/usr/share/sounds/alsa# pinmux proper
-sh: pinmux: command not found
Provided below Device tree for your reference
// SPDX-License-Identifier: GPL-2.0
 * AM625 Minimal dts file
 * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "k3-pinctrl.h"
#include "k3-am625.dtsi"
    compatible = "ti,am625-sk","ti,am625";
    model = " debug ";
    aliases {
        serial0 = &mcu_uart0;
        serial1 = &wkup_uart0;
        serial2 = &main_uart0;
        serial3 = &main_uart1;
        serial4 = &main_uart4;
        serial5 = &main_uart6;
        mmc0 = &sdhci0;
        mmc1 = &sdhci1;
        mmc2 = &sdhci2;
        spi0 = &ospi0;
        spi1 = &main_spi0;
        gpio0 = &main_gpio0;
        gpio1 = &main_gpio1;
        gpio2 = &mcu_gpio0;
        i2c0 = &main_i2c0;
        i2c1 = &main_i2c1;
        i2c2 = &main_i2c2;
        i2c3 = &main_i2c3;
        i2c4 = &wkup_i2c0;
        i2c5 = &mcu_i2c0;
        can0 = &main_mcan0;
        can1 = &mcu_mcan0;
        can2 = &mcu_mcan1;
    cpus {
        /delete-node/ cpu@2;
        /delete-node/ cpu@3;
    chosen {
        #address-cells = <2>;
        #size-cells = <2>;
        ranges;
        stdout-path = "serial2:115200n8";
        bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
        framebuffer0: framebuffer@0 {
            compatible = "simple-framebuffer";
            power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
            clocks = <&k3_clks 186 6>,
                 <&k3_clks 186 0>,
                 <&k3_clks 186 2>;
            display = <&dss>;
            status = "disabled";
    opp-table {
        /* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
        opp-1400000000 {
            opp-hz = /bits/ 64 <1400000000>;
            opp-supported-hw = <0x01 0x0004>;
            clock-latency-ns = <6000000>;
    memory@80000000 {
        device_type = "memory";
        /* 2G RAM */
        reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
    reserved-memory {
        #size-cells = <2>;
        ranges;
        ramoops@9c700000 {
            compatible = "ramoops";
            reg = <0x00 0x9c700000 0x00 0x00100000>;
            record-size = <0x8000>;
            console-size = <0x8000>;
            ftrace-size = <0x00>;
            pmsg-size = <0x8000>;
        /* global cma region */
        linux,cma {
            compatible = "shared-dma-pool";
            reusable;
            size = <0x00 0x8000000>;
            linux,cma-default;
        rtos_ipc_memory_region: ipc-memories@9c800000 {
            reg = <0x00 0x9c800000 0x00 0x00300000>;
            no-map;
        mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
            reg = <0x00 0x9cb00000 0x00 0x100000>;
            no-map;
        mcu_m4fss_memory_region: m4f-memory@9cc00000 {
            reg = <0x00 0x9cc00000 0x00 0xe00000>;
            no-map;
        wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9da00000 {
            reg = <0x00 0x9da00000 0x00 0x00100000>;
            no-map;
        wkup_r5fss0_core0_memory_region: r5f-memory@9db00000 {
            reg = <0x00 0x9db00000 0x00 0x00c00000>;
            no-map;
        secure_tfa_ddr: tfa@9e780000 {
            reg = <0x00 0x9e780000 0x00 0x80000>;
            alignment = <0x1000>;
            no-map;
        secure_ddr: optee@9e800000 {
            reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
            no-map;
    vmain_pd: regulator-0 {
        /* TPS65988 PD CONTROLLER OUTPUT */
        compatible = "regulator-fixed";
        regulator-name = "vmain_pd";
        regulator-min-microvolt = <5000000>;
        regulator-max-microvolt = <5000000>;
        regulator-always-on;
        regulator-boot-on;
    vcc_5v0: regulator-1 {
        /* Output of LM34936 */
        regulator-name = "vcc_5v0";
        vin-supply = <&vmain_pd>;
        regulator-boot-on;
    vcc_3v3_sys: regulator-2 {
        /* output of LM61460-Q1 */
        regulator-name = "vcc_3v3_sys";
        regulator-min-microvolt = <3300000>;
        regulator-max-microvolt = <3300000>;
        regulator-boot-on;
    vdd_mmc1: regulator-3 {
        /* TPS22918DBVR */
        regulator-name = "vdd_mmc1";
        pinctrl-names = "default";
        pinctrl-0 = <&vdd_3v3_sd_pins_default>;
        regulator-boot-on;
        enable-active-high;
        vin-supply = <&vcc_3v3_sys>;
        gpio = <&main_gpio0 76 GPIO_ACTIVE_HIGH>;
    vdd_sd_dv: regulator-4 {
        /* Output of TLV71033 */
        compatible = "regulator-gpio";
        regulator-name = "tlv71033";
        pinctrl-0 = <&vdd_sd_dv_pins_default>;
        regulator-min-microvolt = <1800000>;
        regulator-boot-on;
        vin-supply = <&vcc_5v0>;
        gpios = <&main_gpio0 40 GPIO_ACTIVE_HIGH>;
        states = <1800000 0x0>,
                 <3300000 0x1>;
    vcc_1v8: regulator-5 {
        /* output of TPS6282518DMQ */
        regulator-name = "vcc_1v8";
        regulator-max-microvolt = <1800000>;
        regulator-boot-on;
    bt_en: regulator-6 {
        regulator-name = "bt_en";
        enable-active-high;
        gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
        pinctrl-0 = <&bt_en_pins_default>;
    wlan_en: regulator-7 {
        regulator-name = "wlan_en";
        enable-active-high;
        gpios = <&main_gpio0 36 GPIO_ACTIVE_HIGH>;
        pinctrl-0 = <&wlan_en_pins_default>;
    vdd_core: regulator-8 {
        /* output of TPS62826DMQ */
        regulator-name = "vdd_core";
        regulator-min-microvolt = <850000>;
        regulator-max-microvolt = <850000>;
        regulator-boot-on;
    tlv320_mclk: clk-0 {
        #clock-cells = <0>;
        compatible = "fixed-clock";
        clock-frequency = <12288000>;
    codec_audio: sound {
        compatible = "simple-audio-card";
        simple-audio-card,name = "AM62x-SKEVM";
        simple-audio-card,widgets =
            "Headphone",    "Headphone Jack",
            "Line",     "Line In",
            "Microphone",   "Microphone Jack";
        simple-audio-card,routing =
            "Headphone Jack",   "HPLOUT",
            "Headphone Jack",   "HPROUT",
            "LINE1L",       "Line In",
            "LINE1R",       "Line In",
            "MIC3R",        "Microphone Jack",
            "Microphone Jack",  "Mic Bias";
        simple-audio-card,format = "dsp_b";
        simple-audio-card,bitclock-master = <&sound_master>;
        simple-audio-card,frame-master = <&sound_master>;
        simple-audio-card,bitclock-inversion;
        simple-audio-card,cpu {
            sound-dai = <&mcasp2>;
        sound_master: simple-audio-card,codec {
            sound-dai = <&tlv320aic3106>;
            clocks = <&tlv320_mclk>;
    hdmi0: connector {
        compatible = "hdmi-connector";
        label = "hdmi";
        type = "a";
        port {
            hdmi_connector_in: endpoint {
                remote-endpoint = <&sii9022_out>;
    transceiver1: can-phy0 {
        compatible = "ti,tcan1042";
        #phy-cells = <0>;
        max-bitrate = <5000000>;
    transceiver2: can-phy1 {
        #phy-cells = <0>;
    transceiver3: can-phy2 {
        #phy-cells = <0>;
    leds {
        compatible = "gpio-leds";
        pinctrl-0 = <&usr_led_pins_default>;
        led-0 {
            label = "am62-sk:green:heartbeat";
            gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
            linux,default-trigger = "heartbeat";
            function = LED_FUNCTION_HEARTBEAT;
            default-state = "off";
&cluster0 {
    /delete-node/ core2;
    /delete-node/ core3;
&main_pmx0 {
    gpio0_pins_default: gpio0-pins-default {
        pinctrl-single,pins = <
            AM62X_IOPAD(0x0004, PIN_OUTPUT, 7) /* (G18) OSPI0_LBCLKO.GPIO0_1 */
            AM62X_IOPAD(0x0030, PIN_OUTPUT, 7) /* (F17) OSPI0_CSn1 */ /* OSPI Reset */
            AM62X_IOPAD(0x0034, PIN_OUTPUT, 7) /* (E17) OSPI0_CSn2 */ /* OSPI Interrupt */
            AM62X_IOPAD(0x0038, PIN_OUTPUT, 7) /* (E18) OSPI0_CSn3.GPIO0_14 */
            AM62X_IOPAD(0x003c, PIN_INPUT, 7) /* (K19) GPMC0_AD0.GPIO0_15 */
            AM62X_IOPAD(0x0040, PIN_INPUT, 7) /* (L19) GPMC0_AD1.GPIO0_16 */
            AM62X_IOPAD(0x0044, PIN_INPUT, 7) /* (L20) GPMC0_AD2.GPIO0_17 */
            AM62X_IOPAD(0x0048, PIN_INPUT, 7) /* (L21) GPMC0_AD3.GPIO0_18 */
            AM62X_IOPAD(0x004c, PIN_INPUT, 7) /* (M21) GPMC0_AD4.GPIO0_19 */
            AM62X_IOPAD(0x0050, PIN_INPUT, 7) /* (L17) GPMC0_AD5.GPIO0_20 */
            AM62X_IOPAD(0x0054, PIN_INPUT, 7) /* (L18) GPMC0_AD6.GPIO0_21 */
            AM62X_IOPAD(0x00a8, PIN_OUTPUT, 7) /* (J18) GPMC0_CSn0.GPIO0_41 */
            AM62X_IOPAD(0x0130, PIN_OUTPUT, 7) /* (W16) RGMII1_TXC.GPIO0_74 */
            AM62X_IOPAD(0x013c, PIN_OUTPUT, 7) /* (Y17) RGMII1_TD2.GPIO0_77 */
            AM62X_IOPAD(0x0140, PIN_OUTPUT, 7) /* (AA18) RGMII1_TD3.GPIO0_78 */
            AM62X_IOPAD(0x0144, PIN_INPUT, 7) /* (W14) RGMII1_RX_CTL.GPIO0_79 */
            AM62X_IOPAD(0x0148, PIN_INPUT, 7) /* (AA16) RGMII1_RXC.GPIO0_80 */
            AM62X_IOPAD(0x014c, PIN_INPUT, 7) /* (W15) RGMII1_RD0.GPIO0_81 */
            AM62X_IOPAD(0x0150, PIN_INPUT, 7) /* (Y16) RGMII1_RD1.GPIO0_82 */
            AM62X_IOPAD(0x0154, PIN_INPUT, 7) /* (AA17) RGMII1_RD2.GPIO0_83 */
            AM62X_IOPAD(0x0158, PIN_INPUT, 7) /* (Y15) RGMII1_RD3.GPIO0_84 */
            AM62X_IOPAD(0x015c, PIN_OUTPUT, 7) /* (U16) MDIO0_MDIO.GPIO0_85 */
            AM62X_IOPAD(0x0160, PIN_OUTPUT, 7) /* (V17) MDIO0_MDC.GPIO0_86 */
            AM62X_IOPAD(0x0164, PIN_OUTPUT, 7) /* (Y21) RGMII2_TX_CTL.GPIO0_87 */
            AM62X_IOPAD(0x0168, PIN_OUTPUT, 7) /* (Y18) RGMII2_TXC.GPIO0_88 */
    gpio1_pins_default: gpio1-pins-default {
            AM62X_IOPAD(0x017c, PIN_INPUT, 7) /* (W19) RGMII2_RX_CTL.GPIO1_1 */
            AM62X_IOPAD(0x0188, PIN_OUTPUT, 7) /* (Y20) RGMII2_RD1.GPIO1_4 */
            AM62X_IOPAD(0x0190, PIN_OUTPUT, 7) /* (W20) RGMII2_RD3.GPIO1_6 */
            AM62X_IOPAD(0x01f0, PIN_OUTPUT, 7) /* (C14) EXT_REFCLK1.GPIO1_30 */ /* ADC Reset */
            AM62X_IOPAD(0x01f4, PIN_INPUT, 7) /* (B16) EXTINTn.GPIO1_31 */
            AM62X_IOPAD(0x0254, PIN_OUTPUT, 7) /* (D17) USB0_DRVVBUS.GPIO1_50 */
    main_i2c0_pins_default: main-i2c0-pins-default {
            AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (E12) I2C0_SCL */
            AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (D14) I2C0_SDA */
    main_i2c1_pins_default: main-i2c1-pins-default {
            AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SCL */
            AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A16) I2C1_SDA */
    main_i2c2_pins_default: main-i2c2-pins-default {
            AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (H18) GPMC0_CSn2.I2C2_SCL */
            AM62X_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (H19) GPMC0_CSn3.I2C2_SDA */
    main_i2c3_pins_default: main-i2c3-pins-default {
            AM62X_IOPAD(0x01d0, PIN_INPUT_PULLUP, 2) /* (B14) UART0_CTSn.I2C3_SCL */
            AM62X_IOPAD(0x01d4, PIN_INPUT_PULLUP, 2) /* (C13) UART0_RTSn.I2C3_SDA */
    main_uart0_pins_default: main-uart0-pins-default {
            AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
            AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    main_uart1_pins_default: main-uart1-pins-default {
            AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */
            AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */
            AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */
            AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */
    main_uart4_pins_default: main-uart4-pins-default {
            AM62X_IOPAD(0x0124, PIN_INPUT, 3) /* (D20) MMC2_SDCD.UART4_RXD */
            AM62X_IOPAD(0x0128, PIN_OUTPUT, 3) /* (C20) MMC2_SDWP.UART4_TXD */
    main_uart6_pins_default: main-uart6-pins-default {
            AM62X_IOPAD(0x009c, PIN_INPUT, 3) /* (P17) GPMC0_WAIT1.UART6_RXD */
            AM62X_IOPAD(0x00a0, PIN_OUTPUT, 3) /* (J20) GPMC0_WPn.UART6_TXD */
    main_mmc0_pins_default: main-mmc0-pins-default {
            AM62X_IOPAD(0x0220, PIN_INPUT_PULLUP, 0) /* (Y3) MMC0_CMD */
            AM62X_IOPAD(0x0218, PIN_OUTPUT, 0) /* (AB1) MMC0_CLK */
            AM62X_IOPAD(0x0214, PIN_INPUT_PULLUP, 0) /* (AA2) MMC0_DAT0 */
            AM62X_IOPAD(0x0210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */
            AM62X_IOPAD(0x020c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */
            AM62X_IOPAD(0x0208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */
            AM62X_IOPAD(0x0204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */
            AM62X_IOPAD(0x0200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */
            AM62X_IOPAD(0x01fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */
            AM62X_IOPAD(0x01f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */
    main_mmc1_pins_default: main-mmc1-pins-default {
            AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */
            AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */
            AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */
            AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */
            AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */
            AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */
            AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */
    main_mmc2_pins_default: main-mmc2-pins-default {
            AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
            AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
            AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
            AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
            AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
            AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
            AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
    ospi0_pins_default: ospi0-pins-default {
            AM62X_IOPAD(0x0000, PIN_OUTPUT, 0) /* (G19) OSPI0_CLK */
            AM62X_IOPAD(0x002c, PIN_OUTPUT, 0) /* (F19) OSPI0_CSn0 */
            AM62X_IOPAD(0x000c, PIN_INPUT, 0) /* (F18) OSPI0_D0 */
            AM62X_IOPAD(0x0010, PIN_INPUT, 0) /* (G17) OSPI0_D1 */
            AM62X_IOPAD(0x0014, PIN_INPUT, 0) /* (F21) OSPI0_D2 */
            AM62X_IOPAD(0x0018, PIN_INPUT, 0) /* (F20) OSPI0_D3 */
            AM62X_IOPAD(0x001c, PIN_INPUT, 0) /* (G21) OSPI0_D4 */
            AM62X_IOPAD(0x0020, PIN_INPUT, 0) /* (H21) OSPI0_D5 */
            AM62X_IOPAD(0x0024, PIN_INPUT, 0) /* (G20) OSPI0_D6 */
            AM62X_IOPAD(0x0028, PIN_INPUT, 0) /* (J21) OSPI0_D7 */
            AM62X_IOPAD(0x0008, PIN_INPUT, 0) /* (H20) OSPI0_DQS */
    main_spi0_pins_default: main-spi0-pins-default {
            AM62X_IOPAD(0x01bc, PIN_OUTPUT, 0) /* (D12) SPI0_CLK */
            AM62X_IOPAD(0x01b4, PIN_OUTPUT, 0) /* (C11) SPI0_CS0 */
            AM62X_IOPAD(0x01b8, PIN_INPUT, 0) /* (D13) SPI0_CS1 */
            AM62X_IOPAD(0x01c0, PIN_OUTPUT, 0) /* (C12) SPI0_D0 */
            AM62X_IOPAD(0x01c4, PIN_INPUT, 0) /* (A14) SPI0_D1 */
    main_mcasp2_pins_default: main-mcasp2-pins-default {
            AM62X_IOPAD(0x0178, PIN_INPUT, 2) /* (V16) RGMII2_TD3.MCASP2_ACLKX */
            AM62X_IOPAD(0x0174, PIN_INPUT, 2) /* (W17) RGMII2_TD2.MCASP2_AFSX */
            AM62X_IOPAD(0x018c, PIN_INPUT, 2) /* (Y19) RGMII2_RD2.MCASP2_AXR0 */
            AM62X_IOPAD(0x0180, PIN_INPUT, 2) /* (V18) RGMII2_RXC.MCASP2_AXR1 */
    main_dss0_pins_default: main-dss0-pins-default {
            AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */
            AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
            AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */
            AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */
            AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
            AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */
            AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */
            AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */
            AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */
            AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */
            AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */
            AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */
            AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */
            AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */
            AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */
            AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */
            AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */
            AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */
            AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */
            AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */
            AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */
            AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */
            AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */
            AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */
            AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
            AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */
            AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */
            AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */
    vdd_3v3_sd_pins_default: vdd-3v3-sd-pins-default {
            AM62X_IOPAD(0x0138, PIN_OUTPUT, 7) /* (AA19) RGMII1_TD1.GPIO0_76 */
    vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
            AM62X_IOPAD(0x00a4, PIN_OUTPUT, 7) /* (J19) GPMC0_DIR.GPIO0_40 */
    bt_en_pins_default: bt-en-pins-default {
            AM62X_IOPAD(0x007c, PIN_OUTPUT, 7) /* (M19) GPMC0_CLK.GPIO0_31 */ /* BT Regulator */
    wlan_en_pins_default: wlan-en-pins-default {
            AM62X_IOPAD(0x0094, PIN_OUTPUT, 7) /* (K18) GPMC0_BE1n.GPIO0_36 */
    main_wlirq_pins_default: main-wlirq-pins-default {
            AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (H17) GPMC0_CSn1.GPIO0_42 */
    main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default {
            AM62X_IOPAD(0x0184, PIN_INPUT, 7) /* (W18) RGMII2_RD0.GPIO1_3 */
    hdmi_pins_default: hdmi-pins-default {
            AM62X_IOPAD(0x0134, PIN_INPUT, 7) /* (U14) RGMII1_TD0.GPIO0_75 */ /* HDMI Interrupt */
            AM62X_IOPAD(0x012c, PIN_OUTPUT, 7) /* (V15) RGMII1_TX_CTL.GPIO0_73 */ /* HDMI Reset */
    main_mcan0_pins_default: main-mcan0-pins-default {
            AM62X_IOPAD(0x01dc, PIN_INPUT, 0) /* (E15) MCAN0_RX */
            AM62X_IOPAD(0x01d8, PIN_OUTPUT, 0) /* (C15) MCAN0_TX */
    touch_pins_default: touch-pins-default {
            AM62X_IOPAD(0x016c, PIN_INPUT, 7) /* (AA20) RGMII2_TD0.GPIO0_89 */ /* Touch Interrupt */
            AM62X_IOPAD(0x0170, PIN_OUTPUT, 7) /* (U15) RGMII2_TD1.GPIO0_90 */ /* Touch Reset */
    usr_led_pins_default: usr-led-pins-default {
            AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17/B15) MMC1_SDWP.GPIO1_49 */
&mcu_pmx0 {
    mcu_mcan0_pins_default: mcu-mcan0-pins-default {
            AM62X_MCU_IOPAD(0x0038, PIN_INPUT, 0) /* (B3) MCU_MCAN0_RX */
            AM62X_MCU_IOPAD(0x0034, PIN_OUTPUT, 0) /* (D6) MCU_MCAN0_TX */
    mcu_mcan1_pins_default: mcu-mcan1-pins-default {
            AM62X_MCU_IOPAD(0x0040, PIN_INPUT, 0) /* (D4) MCU_MCAN1_RX */
            AM62X_MCU_IOPAD(0x003c, PIN_OUTPUT, 0) /* (E5) MCU_MCAN1_TX */
&main_rti2 {
&main_rti3 {
&main_uart0 {
    status = "okay";
    pinctrl-0 = <&main_uart0_pins_default>;
    interrupts-extended = <&gic500 GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>,
                   <&main_pmx0 0x1c8>; /* (D14) UART0_RXD PADCONFIG114 */
    interrupt-names = "irq", "wakeup";
&main_uart1 {
    status = "okay";
        pinctrl-0 = <&main_uart1_pins_default>;
&main_uart4 {
    status = "okay";
        pinctrl-0 = <&main_uart4_pins_default>;
&main_uart6 {
    status = "okay";
        pinctrl-0 = <&main_uart6_pins_default>;
&main_uart2 {
&main_uart3 {
&main_uart5 {
&main_i2c0 {
    pinctrl-0 = <&main_i2c0_pins_default>;
    clock-frequency = <400000>;
    status = "okay";
&main_i2c1 {
    status = "okay";
    pinctrl-0 = <&main_i2c1_pins_default>;
    tlv320aic3106: audio-codec@18 {
        #sound-dai-cells = <0>;
        compatible = "ti,tlv320aic3106";
        reg = <0x18>;
        ai3x-micbias-vg = <1>;  /* 2.0V */
        /* Regulators */
        AVDD-supply = <&vcc_3v3_sys>;
        IOVDD-supply = <&vcc_3v3_sys>;
        DRVDD-supply = <&vcc_3v3_sys>;
    sii9022: sii9022@3b {
        compatible = "sil,sii9022";
        reg = <0x3b>;
        pinctrl-0 = <&hdmi_pins_default>;
        interrupt-parent = <&main_gpio0>;
        interrupts = <75 IRQ_TYPE_EDGE_FALLING>;
        irq-gpios = <&main_gpio0 75 GPIO_ACTIVE_LOW>;
        reset-gpios = <&main_gpio0 73 GPIO_ACTIVE_LOW>;
        sil,i2s-data-lanes = < 0 >;
        ports {
            #address-cells = <1>;
            #size-cells = <0>;
            port@0 {
                reg = <0>;
                sii9022_in: endpoint {
                    remote-endpoint = <&dpi1_out>;
            port@1 {
                reg = <1>;
                sii9022_out: endpoint {
                    remote-endpoint = <&hdmi_connector_in>;
        ili2130: touchscreen@41 {
            status = "okay";
            compatible = "ilitek,ili2130";
            reg = <0x41>;
        pinctrl-0 = <&touch_pins_default>;
            interrupts = <89 IRQ_TYPE_EDGE_FALLING>;
            irq-gpios = <&main_gpio0 89 GPIO_ACTIVE_LOW>;
            reset-gpios = <&main_gpio0 90 GPIO_ACTIVE_LOW>;
&main_i2c2 {
    status = "okay";
    pinctrl-0 = <&main_i2c2_pins_default>;
&main_i2c3 {
    status = "okay";
    pinctrl-0 = <&main_i2c3_pins_default>;
    clock-frequency = <100000>;
    exp1: gpio@23 {
        compatible = "ti,tca6424";
        reg = <0x23>;
        gpio-controller;
        #gpio-cells = <2>;
        gpio-line-names = "12V_GPI1_OUT", "12V_GPI2_OUT",
                   "12V_GPI3_OUT", "12V_GPI4_OUT",
                   "12V_GPI5_OUT", "12V_GPI6_OUT",
                   "12V_GPI7_OUT", "12V_GPI8_OUT",
                   "12V_GPI9_OUT", "12V_GPI10_OUT",
                   "12V_GPI11_OUT", "12V_GPI12_OUT",
                   "12V_GPO1_IN", "12V_GPO2_IN",
                   "12V_GPO3_IN", "12V_GPO4_IN",
                   "12V_GPO5678_FAULT2", "12V_GPO5678_FAULT1",
                   "12V_GPO1234_FAULT2", "12V_GPO1234_FAULT1",
                   "12V_GPO8_IN", "12V_GPO7_IN",
                   "12V_GPO6_IN", "12V_GPO5_IN";
        pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
        interrupt-parent = <&main_gpio1>;
        interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
        interrupt-controller;
        #interrupt-cells = <2>;
&main_gpio0 {
    status = "okay";
    pinctrl-0 = <&gpio0_pins_default>;
&main_gpio1 {
    status = "okay";
    pinctrl-0 = <&gpio1_pins_default>;
&sdhci0 {
    status = "okay";
    pinctrl-0 = <&main_mmc0_pins_default>;
    disable-wp;
&sdhci1 {
    /* SD/MMC */
    vmmc-supply = <&vdd_mmc1>;
    vqmmc-supply = <&vdd_sd_dv>;
    pinctrl-0 = <&main_mmc1_pins_default>;
    ti,driver-strength-ohm = <50>;
    disable-wp;
    no-1-8-v;
    status = "okay";
&sdhci2 {
    status = "okay";
    vmmc-supply = <&wlan_en>;
        vqmmc-supply = <&bt_en>;
    pinctrl-0 = <&main_mmc2_pins_default>;
    bus-width = <4>;
    non-removable;
    ti,fails-without-test-cd;
    cap-power-off-card;
    keep-power-in-suspend;
    assigned-clocks = <&k3_clks 157 158>;
    assigned-clock-parents = <&k3_clks 157 160>;
    #size-cells = <0>;
&ospi0 {
    status = "okay";
    pinctrl-0 = <&ospi0_pins_default>;
    flash@0{
        compatible = "jedec,spi-nor";
        reg = <0x0>;
        spi-tx-bus-width = <8>;
        spi-rx-bus-width = <8>;
        spi-max-frequency = <25000000>;
        cdns,tshsl-ns = <60>;
        cdns,tsd2d-ns = <60>;
        cdns,tchsh-ns = <60>;
        cdns,tslch-ns = <60>;
        cdns,read-delay = <4>;
        partitions {
            compatible = "fixed-partitions";
            #size-cells = <1>;
            partition@0 {
                label = "ospi.tiboot3";
                reg = <0x0 0x80000>;
            partition@80000 {
                label = "ospi.tispl";
                reg = <0x80000 0x200000>;
            partition@280000 {
                label = "ospi.u-boot";
                reg = <0x280000 0x400000>;
            partition@680000 {
                label = "ospi.env";
                reg = <0x680000 0x40000>;
            partition@6c0000 {
                label = "ospi.env.backup";
                reg = <0x6c0000 0x40000>;
            partition@800000 {
                label = "ospi.rootfs";
                reg = <0x800000 0x37c0000>;
            partition@3fc0000 {
                label = "ospi.phypattern";
                reg = <0x3fc0000 0x40000>;
&main_spi0 {
    status = "okay";
    pinctrl-0 = <&main_spi0_pins_default>;
    adc@0 {
        compatible = "ti,ads8344";
        reg = <0>;
        spi-max-frequency = <1000000>;
        vref-supply = <&vcc_5v0>;
        #io-channel-cells = <1>;
&main_mcan0 {
    pinctrl-0 = <&main_mcan0_pins_default>;
    phys = <&transceiver1>;
    status = "okay";
/* MCU periperhals */
&mcu_uart0 {
&mcu_i2c0 {
&mcu_mcan0 {
    pinctrl-0 = <&mcu_mcan0_pins_default>;
    phys = <&transceiver2>;
    status = "okay";
&mcu_mcan1 {
    pinctrl-0 = <&mcu_mcan1_pins_default>;
    phys = <&transceiver3>;
    status = "okay";
/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */
&mcu_gpio_intr {
    status = "reserved";
&mcu_gpio0 {
/* WKUP periperhals */
&wkup_conf {
    status = "okay";
&chipid {
    status = "okay";
/* wkup_uart0 is reserved for firmware usage */
&wkup_uart0 {
&wkup_i2c0 {
&mcu_m4fss {
    mboxes = <&mailbox0_cluster0 &mbox_m4_0>;
    memory-region = <&mcu_m4fss_dma_memory_region>,
            <&mcu_m4fss_memory_region>;
&wkup_r5fss0_core0 {
    mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
    memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
            <&wkup_r5fss0_core0_memory_region>;
&mailbox0_cluster0 {
    mbox_m4_0: mbox-m4-0 {
        ti,mbox-rx = <0 0 0>;
        ti,mbox-tx = <1 0 0>;
    mbox_r5_0: mbox-r5-0 {
        ti,mbox-rx = <2 0 0>;
        ti,mbox-tx = <3 0 0>;
&mcasp2 {
    status = "okay";
    pinctrl-0 = <&main_mcasp2_pins_default>;
    op-mode = <0>;          /* MCASP_IIS_MODE */
    tdm-slots = <2>;
    serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
           1 2 0 0
           0 0 0 0
           0 0 0 0
           0 0 0 0
    tx-num-evt = <0>;
    rx-num-evt = <0>;
&tlv320aic3106 {
    DVDD-supply = <&vcc_1v8>;
&dphy0 {
    status = "okay";
&dss {
    pinctrl-0 = <&main_dss0_pins_default>;
&dss_ports {
    /* VP2: DPI Output */
    hdmi0_dss: port@1 {
        reg = <1>;
        dpi1_out: endpoint {
            remote-endpoint = <&sii9022_in>;
&pruss {
&cpsw3g {
&cpsw_port1 {
&cpsw3g_mdio {
&epwm0 {
&epwm1 {
&epwm2 {
&ecap0 {
&ecap1 {
&ecap2 {
Kindly do the needful
Pawan
  • Hi Pawan,
    If I understand correctly your part number is 17.2 x 17.2 mm package (AMC) and you are trying to get audio functionality using McASP2 with this SoC. From the Device tree changes, I don't see any issues.
    May I know what software base are you testing this with? Is the SDK software version 9.2.1? Because audio seems to be working fine in both playback and capture on AM62x.
    Suren
  • Hi Suren,
    Yes it's AMC package. We are using ti-linux kernel 6.1y  release  9.2.1.
    In EVM its working.
    Only observation is we get
    How to check if MCASP lines are properly configured from Linux userspace?
    Pawan
  • Hi Pawan,
    On the PinMux, can you change the AXR0 to OUTPUT instead of INPUT as pointed in the below commit:
    git.ti.com/.../
    SDK 10.0 would be released by 16th August. Please have it tested with that release and see if it resolves the issue.
    I verified this on my setup:
    root@am62pxx-evm:~# amixer -c 0 cset numid=71 on
    numid=71,iface=MIXER,name='Right PGA Mixer Mic3R Switch'
      ; type=BOOLEAN,access=rw------,values=1
      : values=on
    root@am62pxx-evm:~# amixer -c 0 cset numid=70 on
    numid=70,iface=MIXER,name='Right PGA Mixer Mic3L Switch'
      : values=on
    root@am62pxx-evm:~# amixer -c 0 cset numid=64 on
    numid=64,iface=MIXER,name='Left PGA Mixer Mic3L Switch'
      : values=on
    root@am62pxx-evm:~# amixer -c 0 cset numid=65 on
    numid=65,iface=MIXER,name='Left PGA Mixer Mic3R Switch'
      : values=on
    root@am62pxx-evm:~# amixer -c 0 cset numid=15 127
    numid=15,iface=MIXER,name='PCM Playback Volume'
      ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
      : values=127,127
      | dBscale-min=-63.50dB,step=0.50dB,mute=0
    root@am62pxx-evm:~# i2cdetect -r 1
    Continue? [Y/n] Y
    10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
    20: -- -- UU UU -- -- -- -- -- -- -- -- -- -- -- --
    40: 40 41 -- -- -- 45 -- 47 48 49 -- -- 4c 4d -- --
    root@am62pxx-evm:~# arecord -Dhw:0,0 -r 48000 -c 2 --period-size=64 -d 20 -f S16_LE | aplay -Dhw:0,0
    Recording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
    Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
    root@am62pxx-evm:~#
    And it worked fine without me having to interrupt the playback.
    Or you can take the kernel(6.6) that is part of the  SDK10.0 release
    git.ti.com/.../
    Suren
  • Hi Suren,
    We tried it as output, still no audio.
    Same observation as before.
    Hope it solves. But is there any thing else I need to check ?
    Is everything loaded properly? Or do you need any log to verify driver or check commands ? Please let me know if any
    Pawan
  • Can you check whether the bitclock, framesync are correct?
    If not, I would suggest to retest with 10.0 SDK thats going to be released next week.
    Suren
