First of all, I know that there are some hazard things in my problem, but until this point everything worked well on my SK-TDA4VM board, I mean the PSL boot worked well using the EdgeAI linux and installing above this the RTOS linux with command: make linux_fs_install_sd.
I want to boot my board using the SBL Boot App method. The PSDKLA is: ti-processor-sdk-linux-edgeai-j721e-evm-09_02_00_05, and the PSDKRA is: ti-processor-sdk-rtos-j721e-evm-09_02_00_05/sdk_builder. I have made modifications in the PSDKLA using this thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1210640/faq-tda4vm-run-vision_apps-in-sbl-boot-flow-with-combined_appimage. The SBL boot works well when initializing all the remote cores except the A72 core. When the A72 linux tries to initialize occurs the following error:
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 [ 0.000000] Machine model: Texas Instruments J721e EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff] [ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff] [ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff] [ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 3303328K/4194304K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 366688K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008391] Console: colour dummy device 80x25 [ 0.012957] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023628] pid_max: default: 32768 minimum: 301 [ 0.028362] LSM: Security Framework initializing [ 0.033135] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040705] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049465] cblist_init_generic: Setting adjustable number of callback queues. [ 0.056863] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.063124] cblist_init_generic: Setting adjustable number of callback queues. [ 0.070510] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.076812] rcu: Hierarchical SRCU implementation. [ 0.081710] rcu: Max phase no-delay instances is 1000. [ 0.087216] Platform MSI: msi-controller@1820000 domain created [ 0.093451] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.102866] EFI services will not be available. [ 0.107596] smp: Bringing up secondary CPUs ... ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.126568] Detected PIPT I-cache on CPU1 [ 0.126627] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.126639] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.126668] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.126716] smp: Brought up 1 node, 2 CPUs [ 0.156058] SMP: Total of 2 processors activated. [ 0.160862] CPU features: detected: 32-bit EL0 Support [ 0.166116] CPU features: detected: CRC32 instructions [ 0.171390] CPU: All CPU(s) started at EL2 [ 0.175571] alternatives: applying system-wide alternatives [ 0.182063] devtmpfs: initialized [ 0.191941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.201923] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.216257] pinctrl core: initialized pinctrl subsystem [ 0.221914] DMI not present or invalid. [ 0.226161] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.232755] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.240058] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.248055] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.256175] audit: initializing netlink subsys (disabled) [ 0.261785] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1 [ 0.262000] thermal_sys: Registered thermal governor 'step_wise' [ 0.269705] thermal_sys: Registered thermal governor 'power_allocator' [ 0.275910] cpuidle: using governor menu [ 0.286647] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.293608] ASID allocator initialised with 32768 entries [ 0.308760] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts [ 0.320456] KASLR enabled [ 0.325909] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.332852] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.339254] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.346187] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.352588] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.359521] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.365922] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.372855] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.379940] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.389220] iommu: Default domain type: Translated [ 0.394207] iommu: DMA domain TLB invalidation policy: strict mode [ 0.400721] SCSI subsystem initialized [ 0.404703] usbcore: registered new interface driver usbfs [ 0.410324] usbcore: registered new interface driver hub [ 0.415761] usbcore: registered new device driver usb [ 0.421145] pps_core: LinuxPPS API ver. 1 registered [ 0.426215] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.435552] PTP clock support registered [ 0.439633] EDAC MC: Ver: 3.0.0 [ 0.443333] FPGA manager framework [ 0.446840] Advanced Linux Sound Architecture Driver Initialized. [ 0.453430] clocksource: Switched to clocksource arch_sys_counter [ 0.459766] VFS: Disk quotas dquot_6.6.0 [ 0.463797] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.473671] NET: Registered PF_INET protocol family [ 0.478866] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.487888] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.496649] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.504571] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.512777] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.521307] TCP: Hash tables configured (established 32768 bind 32768) [ 0.528078] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.534988] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.542417] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.548479] RPC: Registered named UNIX socket transport module. [ 0.554540] RPC: Registered udp transport module. [ 0.559342] RPC: Registered tcp transport module. [ 0.564145] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.570735] NET: Registered PF_XDP protocol family [ 0.575636] PCI: CLS 0 bytes, default 64 [ 0.580000] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.589155] Initialise system trusted keyrings [ 0.593795] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.602299] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.608516] NFS: Registering the id_resolver key type [ 0.613700] Key type id_resolver registered [ 0.617971] Key type id_legacy registered [ 0.622086] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.628935] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.656209] Key type asymmetric registered [ 0.660393] Asymmetric key parser 'x509' registered [ 0.665398] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.673024] io scheduler mq-deadline registered [ 0.677656] io scheduler kyber registered [ 0.683950] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.690366] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.696995] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.706449] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.714844] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.723002] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.730087] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.737845] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.748708] loop: module loaded [ 0.752548] megasas: 07.719.03.00-rc1 [ 0.757849] tun: Universal TUN/TAP device driver, 1.6 [ 0.763410] VFIO - User Level meta-driver version: 0.3 [ 0.769052] usbcore: registered new interface driver usb-storage [ 0.775510] i2c_dev: i2c /dev entries driver [ 0.780445] sdhci: Secure Digital Host Controller Interface driver [ 0.786766] sdhci: Copyright(c) Pierre Ossman [ 0.791356] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.797488] ledtrig-cpu: registered to indicate activity on CPUs [ 0.803720] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.810462] usbcore: registered new interface driver usbhid [ 0.816155] usbhid: USB HID core driver [ 0.820567] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.825125] optee: revision 4.1 (012cdca4) [ 0.841543] optee: dynamic shared memory is enabled [ 0.850924] optee: initialized driver [ 0.855854] Initializing XFRM netlink socket [ 0.860240] NET: Registered PF_PACKET protocol family [ 0.865444] Key type dns_resolver registered [ 0.869962] registered taskstats version 1 [ 0.874162] Loading compiled-in X.509 certificates [ 0.884577] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)') [ 0.945858] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 0.952150] pca953x 1-0020: supply vcc not found, using dummy regulator [ 0.958972] pca953x 1-0020: using no AI [ 0.985476] pca953x 1-0020: failed writing register [ 0.990526] pca953x: probe of 1-0020 failed with error -121 [ 0.996385] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.003188] pca953x 1-0022: using AI [ 1.006891] pca953x 1-0022: failed writing register [ 1.011926] pca953x: probe of 1-0022 failed with error -121 [ 1.017653] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz [ 1.023768] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz [ 1.030526] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz [ 1.036637] pca953x 4-0020: supply vcc not found, using dummy regulator [ 1.043463] pca953x 4-0020: using no AI [ 1.069475] pca953x 4-0020: failed writing register [ 1.074523] pca953x: probe of 4-0020 failed with error -121 [ 1.080395] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz [ 1.086523] pca953x 5-0020: supply vcc not found, using dummy regulator [ 1.093341] pca953x 5-0020: using no AI [ 1.117476] pca953x 5-0020: failed writing register [ 1.122521] pca953x: probe of 5-0020 failed with error -121 [ 1.128250] omap_i2c 2060000.i2c: bus 5 rev0.12 at 400 kHz [ 1.134022] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created [ 1.142554] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created [ 1.151879] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created [ 1.160463] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.175855] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.185749] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.192508] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.201568] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.211711] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.218469] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.226375] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 194, base_baud = 6000000) is a 8250 [ 1.235806] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 195, base_baud = 3000000) is a 8250 [ 1.244653] printk: console [ttyS2] enabled [ 1.244653] printk: console [ttyS2] enabled [ 1.253096] printk: bootconsole [ns16550a0] disabled [ 1.253096] printk: bootconsole [ns16550a0] disabled [ 1.263479] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 196, base_baud = 3000000) is a 8250 [ 1.272431] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 197, base_baud = 3000000) is a 8250 [ 1.281388] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 198, base_baud = 3000000) is a 8250 [ 1.291390] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.337436] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.346081] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.354352] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.367206] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.374414] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.380574] pps pps0: new PPS source ptp0 [ 1.384694] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 1.394937] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.403688] mmc0: CQHCI version 5.10 [ 1.448017] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.478776] vdd_ddr_1v1: Bringing 850000uV into 1100000-1100000uV [ 1.709068] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0 [ 1.715033] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock [ 1.985681] pca953x 2-0020: supply vcc not found, using dummy regulator [ 1.992360] pca953x 2-0020: using no AI [ 2.017477] pca953x 2-0020: failed writing register [ 2.022414] pca953x: probe of 2-0020 failed with error -121 [ 2.028308] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.035082] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.041856] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.048626] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.055377] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.068609] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.079196] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 2.092948] spi-nor: probe of spi0.0 failed with error -22 [ 2.100395] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 2.107612] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.153443] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.162115] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.170386] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 2.183245] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.190454] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.196592] pps pps0: new PPS source ptp1 [ 2.200704] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 2.210872] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.222363] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.238027] ALSA device list: [ 2.240988] No soundcards found. [ 2.244788] /dev/root: Can't open blockdev [ 2.248881] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6 [ 2.256346] Please append a correct "root=" boot option; here are the available partitions: [ 2.264686] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 2.272928] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.80-ti-g2e423244f8c0 #1 [ 2.280304] Hardware name: Texas Instruments J721e EVM (DT) [ 2.285859] Call trace: [ 2.288293] dump_backtrace.part.0+0xdc/0xf0 [ 2.292557] show_stack+0x18/0x30 [ 2.295859] dump_stack_lvl+0x68/0x84 [ 2.299511] dump_stack+0x18/0x34 [ 2.302813] panic+0x188/0x348 [ 2.305854] mount_block_root+0x188/0x23c [ 2.309851] mount_root+0x208/0x248 [ 2.313325] prepare_namespace+0x130/0x170 [ 2.317406] kernel_init_freeable+0x258/0x284 [ 2.321747] kernel_init+0x24/0x130 [ 2.325225] ret_from_fork+0x10/0x20 [ 2.328788] SMP: stopping secondary CPUs [ 2.332698] Kernel Offset: 0x80000 from 0xffff800008000000 [ 2.338166] PHYS_OFFSET: 0x80000000 [ 2.341640] CPU features: 0x40000,20128084,0000420b [ 2.346502] Memory Limit: none [ 2.349544] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]--- NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Mar 20 14:43:33 UTC 2024 [ 0.000000] Machine model: Texas Instruments J721e EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff] [ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff] [ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff] [ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 3303328K/4194304K available (11712K kernel code, 1258K rwdata, 3812K rodata, 1984K init, 438K bss, 366688K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008398] Console: colour dummy device 80x25 [ 0.012964] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023634] pid_max: default: 32768 minimum: 301 [ 0.028369] LSM: Security Framework initializing [ 0.033140] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040711] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049483] cblist_init_generic: Setting adjustable number of callback queues. [ 0.056881] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.063141] cblist_init_generic: Setting adjustable number of callback queues. [ 0.070527] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.076831] rcu: Hierarchical SRCU implementation. [ 0.081728] rcu: Max phase no-delay instances is 1000. [ 0.087233] Platform MSI: msi-controller@1820000 domain created [ 0.093468] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.102881] EFI services will not be available. [ 0.107611] smp: Bringing up secondary CPUs ... ERROR: GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.126587] Detected PIPT I-cache on CPU1 [ 0.126646] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.126658] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.126686] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.126735] smp: Brought up 1 node, 2 CPUs [ 0.156080] SMP: Total of 2 processors activated. [ 0.160884] CPU features: detected: 32-bit EL0 Support [ 0.166137] CPU features: detected: CRC32 instructions [ 0.171412] CPU: All CPU(s) started at EL2 [ 0.175593] alternatives: applying system-wide alternatives [ 0.182095] devtmpfs: initialized [ 0.192022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.202002] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.215806] pinctrl core: initialized pinctrl subsystem [ 0.221461] DMI not present or invalid. [ 0.225708] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.232311] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.239613] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.247609] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.255733] audit: initializing netlink subsys (disabled) [ 0.261345] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1 [ 0.261565] thermal_sys: Registered thermal governor 'step_wise' [ 0.269264] thermal_sys: Registered thermal governor 'power_allocator' [ 0.275473] cpuidle: using governor menu [ 0.286209] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.293172] ASID allocator initialised with 32768 entries [ 0.308322] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts [ 0.320016] KASLR enabled [ 0.325463] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.332405] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.338806] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.345740] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.352141] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.359074] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.365475] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.372408] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.379494] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.388767] iommu: Default domain type: Translated [ 0.393753] iommu: DMA domain TLB invalidation policy: strict mode [ 0.400268] SCSI subsystem initialized [ 0.404249] usbcore: registered new interface driver usbfs [ 0.409869] usbcore: registered new interface driver hub [ 0.415307] usbcore: registered new device driver usb [ 0.420684] pps_core: LinuxPPS API ver. 1 registered [ 0.425755] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.435092] PTP clock support registered [ 0.439174] EDAC MC: Ver: 3.0.0 [ 0.442871] FPGA manager framework [ 0.446378] Advanced Linux Sound Architecture Driver Initialized. [ 0.452963] clocksource: Switched to clocksource arch_sys_counter [ 0.459300] VFS: Disk quotas dquot_6.6.0 [ 0.463329] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.473195] NET: Registered PF_INET protocol family [ 0.478350] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.487362] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.496126] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.504047] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.512252] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.520786] TCP: Hash tables configured (established 32768 bind 32768) [ 0.527556] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.534467] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.541895] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.547956] RPC: Registered named UNIX socket transport module. [ 0.554017] RPC: Registered udp transport module. [ 0.558820] RPC: Registered tcp transport module. [ 0.563623] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.570213] NET: Registered PF_XDP protocol family [ 0.575114] PCI: CLS 0 bytes, default 64 [ 0.579475] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.588602] Initialise system trusted keyrings [ 0.593242] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.601751] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.607971] NFS: Registering the id_resolver key type [ 0.613151] Key type id_resolver registered [ 0.617423] Key type id_legacy registered [ 0.621537] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.628386] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.655548] Key type asymmetric registered [ 0.659732] Asymmetric key parser 'x509' registered [ 0.664737] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.672362] io scheduler mq-deadline registered [ 0.676994] io scheduler kyber registered [ 0.683255] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.689670] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.696298] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.705704] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.714033] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.722190] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.729286] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.737059] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.747914] loop: module loaded [ 0.751748] megasas: 07.719.03.00-rc1 [ 0.757049] tun: Universal TUN/TAP device driver, 1.6 [ 0.762614] VFIO - User Level meta-driver version: 0.3 [ 0.768256] usbcore: registered new interface driver usb-storage [ 0.774707] i2c_dev: i2c /dev entries driver [ 0.779629] sdhci: Secure Digital Host Controller Interface driver [ 0.785948] sdhci: Copyright(c) Pierre Ossman [ 0.790534] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.796643] ledtrig-cpu: registered to indicate activity on CPUs [ 0.802879] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.809622] usbcore: registered new interface driver usbhid [ 0.815316] usbhid: USB HID core driver [ 0.819724] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.824281] optee: revision 4.1 (012cdca4) [ 0.840697] optee: dynamic shared memory is enabled [ 0.850077] optee: initialized driver [ 0.855009] Initializing XFRM netlink socket [ 0.859394] NET: Registered PF_PACKET protocol family [ 0.864592] Key type dns_resolver registered [ 0.869121] registered taskstats version 1 [ 0.873320] Loading compiled-in X.509 certificates [ 0.883752] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)') [ 0.945298] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 0.951591] pca953x 1-0020: supply vcc not found, using dummy regulator [ 0.958413] pca953x 1-0020: using no AI [ 0.985010] pca953x 1-0020: failed writing register [ 0.990059] pca953x: probe of 1-0020 failed with error -121 [ 0.995916] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.002723] pca953x 1-0022: using AI [ 1.006426] pca953x 1-0022: failed writing register [ 1.011460] pca953x: probe of 1-0022 failed with error -121 [ 1.017185] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz [ 1.023304] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz [ 1.030045] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz [ 1.036152] pca953x 4-0020: supply vcc not found, using dummy regulator [ 1.042978] pca953x 4-0020: using no AI [ 1.069009] pca953x 4-0020: failed writing register [ 1.074056] pca953x: probe of 4-0020 failed with error -121 [ 1.079926] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz [ 1.086048] pca953x 5-0020: supply vcc not found, using dummy regulator [ 1.092865] pca953x 5-0020: using no AI [ 1.117010] pca953x 5-0020: failed writing register [ 1.122054] pca953x: probe of 5-0020 failed with error -121 [ 1.127784] omap_i2c 2060000.i2c: bus 5 rev0.12 at 400 kHz [ 1.133559] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created [ 1.142090] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created [ 1.151414] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created [ 1.159994] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.175376] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.185269] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.192028] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.201067] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.211211] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.217969] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.225877] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 194, base_baud = 6000000) is a 8250 [ 1.235312] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 195, base_baud = 3000000) is a 8250 [ 1.244159] printk: console [ttyS2] enabled [ 1.244159] printk: console [ttyS2] enabled [ 1.252602] printk: bootconsole [ns16550a0] disabled [ 1.252602] printk: bootconsole [ns16550a0] disabled [ 1.262984] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 196, base_baud = 3000000) is a 8250 [ 1.271932] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 197, base_baud = 3000000) is a 8250 [ 1.280880] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 198, base_baud = 3000000) is a 8250 [ 1.290876] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.336970] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.345615] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.353887] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.366740] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.373948] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.380111] pps pps0: new PPS source ptp0 [ 1.384231] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 1.394462] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.403213] mmc0: CQHCI version 5.10 [ 1.447528] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.470870] vdd_ddr_1v1: Bringing 850000uV into 1100000-1100000uV [ 1.701129] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0 [ 1.707093] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock [ 1.977910] pca953x 2-0020: supply vcc not found, using dummy regulator [ 1.984583] pca953x 2-0020: using no AI [ 2.009012] pca953x 2-0020: failed writing register [ 2.013947] pca953x: probe of 2-0020 failed with error -121 [ 2.019847] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.026628] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.033405] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 2.040177] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 2.046927] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 2.060155] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 2.070728] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 2.084439] spi-nor: probe of spi0.0 failed with error -22 [ 2.091919] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 2.099151] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.144970] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.153632] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.161903] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 2.174762] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.181968] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.188109] pps pps0: new PPS source ptp1 [ 2.192219] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 2.202386] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.213901] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.229574] ALSA device list: [ 2.232536] No soundcards found. [ 2.236345] /dev/root: Can't open blockdev [ 2.240438] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6 [ 2.247901] Please append a correct "root=" boot option; here are the available partitions: [ 2.256240] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 2.264483] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.80-ti-g2e423244f8c0 #1 [ 2.271859] Hardware name: Texas Instruments J721e EVM (DT) [ 2.277414] Call trace: [ 2.279847] dump_backtrace.part.0+0xdc/0xf0 [ 2.284114] show_stack+0x18/0x30 [ 2.287417] dump_stack_lvl+0x68/0x84 [ 2.291069] dump_stack+0x18/0x34 [ 2.294370] panic+0x188/0x348 [ 2.297413] mount_block_root+0x188/0x23c [ 2.301410] mount_root+0x208/0x248 [ 2.304885] prepare_namespace+0x130/0x170 [ 2.308966] kernel_init_freeable+0x258/0x284 [ 2.313307] kernel_init+0x24/0x130 [ 2.316783] ret_from_fork+0x10/0x20 [ 2.320346] SMP: stopping secondary CPUs [ 2.324256] Kernel Offset: 0x80000 from 0xffff800008000000 [ 2.329723] PHYS_OFFSET: 0x80000000 [ 2.333198] CPU features: 0x40000,20128084,0000420b [ 2.338060] Memory Limit: none [ 2.341102] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
Please don't take into consideration the fact that I am trying to merge the two packages only, just can we focus on the problem that the A72 linux boot doesn't find the rootfs path.
Tamas
