Part Number: PROCESSOR-SDK-AM57X
the recipe gstreamer1.0-plugins-hevc [1] and gstreamer1.0-plugins-vpe [2] in meta-arago cannot fetch the submodule "common". See the following example of a local clone.
$ git clone https://git.ti.com/git/processor-sdk/gst-plugin-hevc.git --recurse-submodules Cloning into 'gst-plugin-hevc'... remote: Enumerating objects: 56, done. remote: Counting objects: 100% (56/56), done. remote: Compressing objects: 100% (45/45), done. remote: Total 56 (delta 20), reused 0 (delta 0), pack-reused 0 Receiving objects: 100% (56/56), 38.43 KiB | 96.00 KiB/s, done. Resolving deltas: 100% (20/20), done. Submodule 'common' (git://anongit.freedesktop.org/gstreamer/common) registered for path 'common' Cloning into '/home/daniel/work/phytec/git/gst-plugin-hevc/common'...
If I try to clone gstreamer common directly, I get the following error message:
$ git clone git://anongit.freedesktop.org/gstreamer/common Cloning into 'common'... fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists.
It looks like this Git server doesn't work properly. However, there is a mirror in Github which can be used.
Do you mind changing the git submodule in [3] to github like my following patch?
From d85ca8e83ea0537fd74d8bea3c358a3edddb87ac Mon Sep 17 00:00:00 2001 From: Daniel Schultz <d.schultz@phytec.de> Date: Tue, 6 Aug 2024 11:26:55 +0200 Subject: [PATCH] Switch submodule common to github The freedesktop.org URL is currently not available. Therefore, this plugin won't build. Use the official GStreamer mirror on GitHub. Signed-off-by: Daniel Schultz <d.schultz@phytec.de> --- .gitmodules | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/.gitmodules b/.gitmodules index a6b1eda..80ffbc5 100644 --- a/.gitmodules +++ b/.gitmodules @@ -1,3 +1,3 @@ [submodule "common"] path = common - url = git://anongit.freedesktop.org/gstreamer/common + url = https://github.com/GStreamer/common -- 2.34.1
Daniel
