I have an application using the TMS320C6748 where:
-I/O banks A and C are powered by 3.3VDC
-I/O banks B, and the 1.8 VCC input are powerewd by 1.8VDC
-Core is powered by 1.2VDC
Individual load switches are used on each of the three supplies. Outputs of the load switches are connected only to the processor and, in the case of the 1.8V supply, to the LPDDR memory that connects to the memory controller in the processor.
The power up sequence turns on the 1.2V first, the 1.8VDC 2nd and the 3.3VDC last.
When the 1.2VDC is turned on, the 1.2V bus at the processor goes to 1.2V correctly
When the 1.8VDC is turned on, the 1.8V bus at the processor goes to 1.8V correctly,
However, when the 3.3VDC is turned on, the 3.3VDC bus at the processor goes to 3.3V correctly, BUT the 1.8V bus at the processor now goes UP to 2.2VDC. Turning off the 3.3V brings the 1.8V bus back to 1.8V.
I have confirmed that none of the external pull-up resistors, on the I/O pins, are connected to the wrong voltage. I have tested two, newly bult (First Article) boards and both have the same problem.
Need your help to find out the cause of this problem.
