hello teams:
sdk update from sdk805 to sdk902
target sdk version: 09.02.00.05
tisdk-tiny-image-j721s2-evm.tar.xz
ti-processor-sdk-linux-adas-j721s2-evm-09_02_00_05
The following printout shows that the card was stuck for nearly 6 seconds
[2024-08-12 19:39:40] See 'systemctl status sync-clocks.service' for details.
[2024-08-12 19:39:40] [ OK ] Started User Login Management.
[2024-08-12 19:39:46] _____ _____ _ _
[2024-08-12 19:39:46] | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
[2024-08-12 19:39:36] Welcome to Arago 2023.10! [2024-08-12 19:39:36] [2024-08-12 19:39:36] [ OK ] Created slice Slice /system/getty. [2024-08-12 19:39:38] [ OK ] Created slice Slice /system/modprobe. [2024-08-12 19:39:38] [ OK ] Created slice Slice /system/serial-getty. [2024-08-12 19:39:38] [ OK ] Created slice User and Session Slice. [2024-08-12 19:39:38] [ OK ] Started Dispatch Password ts to Console Directory Watch. [2024-08-12 19:39:38] [ OK ] Started Forward Password Ruests to Wall Directory Watch. [2024-08-12 19:39:38] [ OK ] Reached target Path Units. [2024-08-12 19:39:38] [ OK ] Reached target Remote File Systems. [2024-08-12 19:39:38] [ OK ] Reached target Slice Units. [2024-08-12 19:39:38] [ OK ] Reached target Swaps. [2024-08-12 19:39:38] [ OK ] Listening on Process Core Dump Socket. [2024-08-12 19:39:38] [ OK ] Listening on initctl Compatibility Named Pipe. [2024-08-12 19:39:38] [ OK ] Listening on Journal Audit Socket. [2024-08-12 19:39:38] [ OK ] Listening on Journal Socket (/dev/log). [2024-08-12 19:39:38] [ OK ] Listening on Journal Socket. [2024-08-12 19:39:38] [ OK ] Listening on Network Service Netlink Socket. [2024-08-12 19:39:38] [ OK ] Listening on udev Control Socket. [2024-08-12 19:39:38] [ OK ] Listening on udev Kernel Socket. [2024-08-12 19:39:38] [ OK ] Listening on User Database Manager Socket. [2024-08-12 19:39:38] Mounting Huge Pages File System... [2024-08-12 19:39:38] Mounting POSIX Message Queue File System... [2024-08-12 19:39:38] Mounting Kernel Debug File System... [2024-08-12 19:39:38] Mounting Temporary Directory /tmp... [2024-08-12 19:39:38] Starting Create List of Static Device Nodes... [2024-08-12 19:39:38] Starting Load Kernel Module configfs... [2024-08-12 19:39:38] Starting Load Kernel Module drm... [2024-08-12 19:39:38] Starting Load Kernel Module fuse... [2024-08-12 19:39:38] Starting Journal Service... [2024-08-12 19:39:38] Starting Generate network ts from Kernel command line... [2024-08-12 19:39:38] Starting Remount Root and Kernel File Systems... [2024-08-12 19:39:38] Starting Apply Kernel Variables... [2024-08-12 19:39:38] Starting Coldplug All udev Devices... [2024-08-12 19:39:38] [ OK ] Mounted Huge Pages File System. [2024-08-12 19:39:38] [ OK ] Mounted POSIX Message Queue File System. [2024-08-12 19:39:38] [ OK ] Mounted Kernel Debug File System. [2024-08-12 19:39:38] [ OK ] Mounted Temporary Directory /tmp. [2024-08-12 19:39:38] [ OK ] Finished Create List of Static Device Nodes. [2024-08-12 19:39:38] [ OK ] Finished Load Kernel Module configfs. [2024-08-12 19:39:38] [ OK ] Started Journal Service. [2024-08-12 19:39:38] [ OK ] Finished Load Kernel Module drm. [2024-08-12 19:39:39] [ OK ] Finished Load Kernel Module fuse. [2024-08-12 19:39:39] [ OK ] Finished Generate network units from Kernel command line. [2024-08-12 19:39:39] [ OK ] Finished Remount Root and Kernel File Systems. [2024-08-12 19:39:39] [ OK ] Finished Apply Kernel Variables. [2024-08-12 19:39:39] [ OK ] Reached target Preparation for Network. [2024-08-12 19:39:39] Mounting Kernel Configuration File System... [2024-08-12 19:39:39] Starting Flush Journal to Persistent Storage... [2024-08-12 19:39:39] Starting Create Static Device Nodes in /dev... [2024-08-12 19:39:39] [ OK ] Mounted Kernel Configuration File System. [2024-08-12 19:39:39] [ OK ] Finished Flush Journal to Persistent Storage. [2024-08-12 19:39:39] [ OK ] Finished Create Static Device Nodes in /dev. [2024-08-12 19:39:39] [ OK ] Reached target Preparation for Local File Systems. [2024-08-12 19:39:39] Mounting /media/ram... [2024-08-12 19:39:39] Mounting /var/volatile... [2024-08-12 19:39:39] Starting Rule-based Managefor Device Events and Files... [2024-08-12 19:39:39] [ OK ] Finished Coldplug All udev Devices. [2024-08-12 19:39:39] [ OK ] Mounted /media/ram. [2024-08-12 19:39:39] [ OK ] Mounted /var/volatile. [2024-08-12 19:39:39] Starting Load/Save Random Seed... [2024-08-12 19:39:39] [ OK ] Reached target Local File Systems. [2024-08-12 19:39:39] Starting Create Volatile Files and Directories... [2024-08-12 19:39:39] [ OK ] Finished Create Volatile Files and Directories. [2024-08-12 19:39:39] [ OK ] Started Rule-based Manager for Device Events and Files. [2024-08-12 19:39:39] Starting Network Configuration... [2024-08-12 19:39:39] Starting Network Time Synchronization... [2024-08-12 19:39:39] Starting Record System Boot/Shutdown in UTMP... [2024-08-12 19:39:39] [ OK ] Finished Record System Boot/Shutdown in UTMP. [2024-08-12 19:39:39] [ OK ] Started Network Configuration. [2024-08-12 19:39:40] Starting Network Name Resolution... [2024-08-12 19:39:40] [ OK ] Started Network Time Synchronization. [2024-08-12 19:39:40] [ OK ] Reached target System Initialization. [2024-08-12 19:39:40] [ OK ] Started Daily Cleanup of Temporary Directories. [2024-08-12 19:39:40] [ OK ] Reached target System Time Set. [2024-08-12 19:39:40] [ OK ] Reached target Timer Units. [2024-08-12 19:39:40] [ OK ] Listening on D-Bus System Message Bus Socket. [2024-08-12 19:39:40] [ OK ] Reached target Socket Units. [2024-08-12 19:39:40] [ OK ] Reached target Basic System. [2024-08-12 19:39:40] Starting D-Bus System Message Bus... [2024-08-12 19:39:40] Starting User Login Management... [2024-08-12 19:39:40] [ OK ] Started Network Name Resolution. [2024-08-12 19:39:40] [ OK ] Finished Load/Save Random Seed. [2024-08-12 19:39:40] [ OK ] Found device /dev/ttyS2. [2024-08-12 19:39:40] [ OK ] Reached target Network. [2024-08-12 19:39:40] [ OK ] Reached target Host and Network Name Lookups. [2024-08-12 19:39:40] Starting OpenSSH server daemon... [2024-08-12 19:39:40] Starting Permit User Sessions... [2024-08-12 19:39:40] [ OK ] Finished Permit User Sessions. [2024-08-12 19:39:40] [ OK ] Started Getty on tty1. [2024-08-12 19:39:40] [ OK ] Started Serial Getty on ttyS2. [2024-08-12 19:39:40] [ OK ] Reached target Login Prompts. [2024-08-12 19:39:40] Starting Synchronize System and HW clocks... [2024-08-12 19:39:40] [ OK ] Started D-Bus System Message Bus. [2024-08-12 19:39:40] [FAILED] Failed to start Synchronize System and HW clocks. [2024-08-12 19:39:40] See 'systemctl status sync-clocks.service' for details. [2024-08-12 19:39:40] [ OK ] Started User Login Management. [2024-08-12 19:39:40] [2024-08-12 19:39:46] _____ _____ _ _ [2024-08-12 19:39:46] | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ [2024-08-12 19:39:46] | | _| .'| . | . | | __| _| . | | | -_| _| _| [2024-08-12 19:39:46] |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| [2024-08-12 19:39:46] |___| |___| [2024-08-12 19:39:46] [2024-08-12 19:39:46] Arago Project j721s2-evm - [2024-08-12 19:39:46] [2024-08-12 19:39:46] Arago 2023.10 j721s2-evm - [2024-08-12 19:39:46] [2024-08-12 19:39:46] j721s2-evm login:
