The TDA4VM evm board unable to boot normally
Part Number: TDA4VM
        Recently,my TDA4VM  evm board suddenly can't boot properly. I use the boot-adas-j721e-evm.tar.gz and tisdk-adas-image-j721e-evm.tar.xz to make a SD card.But still can't boot properly.Below is log about boot
U-Boot SPL 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
I/TC:
I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
Detected: J7X-BASE-CPB rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2023.04-ti-gf9b966c67473 (Mar 19 2024 - 20:31:40 +0000)
SoC:   J721E SR1.0 GP
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E7
DRAM:  2 GiB (effective 4 GiB)
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus are properly configured
I/TC:
SoC:   J721E SR1.0 GP
I find the log in "dcu_processorsdk_linux_09_01_00_06_adc20_3.0/board-support/ti-u-boot-2023.04+gitAUTOINC+71b8c840ca-g71b8c840ca/drivers/i2c/omap24xx_i2c.c"
I don't know why this is happening.I haven't changed anything.Is my board broken?
