AM6422: How to install kernel module on emmc
Part Number: AM6422
if I have achieved booting Linux from an eMMC device, when my kernel changes, I recompile it and use Ethernet to transfer the generated image file to the boot path of the development board. At this time, how do I install the kernel module in the development board environment? Can you give me the specific operation? Thank you very much!
    You could follow the below steps to install the modules:
    ----------- Host PC -----------
    1) Assuming you are using the SDK top level makefile, you could first install the Linux Kernel, DTBs, and modules to a folder in your local filesystem. For example,
    ❯ make linux_install DESTDIR=/home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install
    mkdir -p /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/dtb/ti
    cp /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/u-boot-build/a53/tispl.bin /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/tispl.bin
    cp /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/u-boot-build/a53/u-boot.img /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/u-boot.img
    cp /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/u-boot-build/r5/tiboot3*.bin /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/
    cp /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/ti-linux-kernel*/arch/arm64/boot/Image /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images
    Installing the Linux Kernel DTBs
    install -d /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/boot/dtb/ti
    install /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/fitImage /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/boot
    install /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/built-images/Image /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/boot
    install /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/ti-linux-kernel*/vmlinux /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/boot
    install /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/ti-linux-kernel*/System.map /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/boot
    make -C /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/ti-linux-kernel* ARCH=arm64 CROSS_COMPILE=/home/p-shivhare/ti/psdk/am62x/09.02.01.10/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux- INSTALL_MOD_PATH=/home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install INSTALL_MOD_STRIP=1 modules_install
    make[1]: Entering directory '/home/p-shivhare/ti/cgit/ti-linux-kernel'
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/aes-neon-blk.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/aes-neon-blk.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/aes-neon-bs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/aes-neon-bs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/chacha-neon.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/chacha-neon.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/crct10dif-ce.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/crct10dif-ce.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha3-ce.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha3-ce.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha512-arm64.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha512-arm64.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha512-ce.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sha512-ce.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sm3-ce.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/crypto/sm3-ce.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/lib/xor-neon.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/arch/arm64/lib/xor-neon.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/af_alg.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/af_alg.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/algif_hash.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/algif_hash.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/algif_rng.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/algif_rng.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/blake2b_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/blake2b_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ccm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ccm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/cmac.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/cmac.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/crypto_engine.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/crypto_engine.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/curve25519-generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/curve25519-generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/des_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/des_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/dh_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/dh_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecb.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecb.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecdh_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/ecdh_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/md5.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/md5.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/michael_mic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/michael_mic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sha3_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sha3_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm3.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm3.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm3_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm3_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm4_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/sm4_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/tcrypt.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/tcrypt.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xor.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xor.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xts.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xts.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xxhash_generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/crypto/xxhash_generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/base/regmap/regmap-sdw.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/base/regmap/regmap-sdw.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/block/nbd.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/block/nbd.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btbcm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btbcm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btintel.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btintel.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btmrvl.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btmrvl.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btmrvl_sdio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btmrvl_sdio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btqca.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btqca.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btrtl.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btrtl.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btusb.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/btusb.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/hci_uart.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bluetooth/hci_uart.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bus/mhi/host/mhi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/bus/mhi/host/mhi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/omap-rng.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/omap-rng.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/optee-rng.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/optee-rng.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/rng-core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/hw_random/rng-core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_devintf.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_devintf.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_msghandler.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_msghandler.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_si.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/char/ipmi/ipmi_si.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/counter.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/counter.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/ti-ecap-capture.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/ti-ecap-capture.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/ti-eqep.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/counter/ti-eqep.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/cpufreq/cpufreq_conservative.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/cpufreq/cpufreq_conservative.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/cpufreq/cpufreq_powersave.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/cpufreq/cpufreq_powersave.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/amlogic/amlogic-gxl-crypto.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/amlogic/amlogic-gxl-crypto.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/ccree/ccree.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/ccree/ccree.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/sa2ul.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/sa2ul.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/ti/mcrc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/crypto/ti/mcrc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/devfreq/governor_userspace.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/devfreq/governor_userspace.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/dma/bcm-sba-raid.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/dma/bcm-sba-raid.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/extcon/extcon-ptn5150.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/extcon/extcon-ptn5150.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/altera-cvp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/altera-cvp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/altera-freeze-bridge.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/altera-freeze-bridge.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/fpga-bridge.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/fpga-bridge.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/fpga-region.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/fpga-region.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/of-fpga-region.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/fpga/of-fpga-region.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss-mtk.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss-mtk.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss-serial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss-serial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gnss/gnss.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpio/gpio-bd9571mwv.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpio/gpio-bd9571mwv.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/cadence/cdns-dsi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/cadence/cdns-dsi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/cadence/cdns-mhdp8546.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/display-connector.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/display-connector.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ite-it66121.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ite-it66121.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt8912b.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt8912b.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt9611.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt9611.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt9611uxc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/lontium-lt9611uxc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/nwl-dsi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/nwl-dsi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/parade-ps8640.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/parade-ps8640.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/sii902x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/sii902x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/simple-bridge.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/simple-bridge.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/tc358762.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/tc358762.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/thc63lvd1024.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/thc63lvd1024.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ti-sn65dsi86.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ti-sn65dsi86.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ti-tfp410.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/bridge/ti-tfp410.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/display/drm_display_helper.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/display/drm_display_helper.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/display/drm_dp_aux_bus.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/display/drm_dp_aux_bus.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_dma_helper.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_dma_helper.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_kms_helper.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_kms_helper.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_panel_orientation_quirks.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/drm_panel_orientation_quirks.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/ch7006.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/ch7006.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/sil164.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/sil164.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/tda998x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/i2c/tda998x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-boe-tv101wum-nl6.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-boe-tv101wum-nl6.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-edp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-edp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-ilitek-ili9881c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-ilitek-ili9881c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-lvds.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-lvds.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-mantix-mlaf057we51.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-mantix-mlaf057we51.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-raydium-rm67191.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-raydium-rm67191.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-simple.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-simple.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-sitronix-st7703.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-sitronix-st7703.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-truly-nt35597.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/panel/panel-truly-nt35597.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/tidss/tidss.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/gpu/drm/tidss/tidss.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/hid-multitouch.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/hid-multitouch.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/i2c-hid/i2c-hid-of.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/i2c-hid/i2c-hid-of.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/i2c-hid/i2c-hid.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hid/i2c-hid/i2c-hid.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/gpio-fan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/gpio-fan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/ina2xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/ina2xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/ina3221.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/ina3221.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/jc42.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/jc42.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/lm75.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/lm75.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/lm90.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/lm90.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/pwm-fan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwmon/pwm-fan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-catu.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-catu.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-cpu-debug.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-cpu-debug.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-cti.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-cti.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-etb10.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-etb10.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-funnel.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-funnel.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-replicator.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-replicator.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-stm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-stm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-tmc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-tmc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-tpiu.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight-tpiu.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/coresight/coresight.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/stm/stm_core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/hwtracing/stm/stm_core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/algos/i2c-algo-bit.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/algos/i2c-algo-bit.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/busses/i2c-gpio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/busses/i2c-gpio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/i2c-atr.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/i2c/i2c-atr.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/max9611.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/max9611.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/ti-ads1015.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/ti-ads1015.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/ti_am335x_adc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/adc/ti_am335x_adc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/buffer/industrialio-triggered-buffer.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/buffer/industrialio-triggered-buffer.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/buffer/kfifo_buf.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/buffer/kfifo_buf.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors_i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors_i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors_spi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/common/st_sensors/st_sensors_spi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx_i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx_i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx_spi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/imu/st_lsm6dsx/st_lsm6dsx_spi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/light/isl29018.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/light/isl29018.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/light/vcnl4000.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/light/vcnl4000.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn_i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn_i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn_spi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/magnetometer/st_magn_spi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/pressure/mpl3115.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/iio/pressure/mpl3115.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/ff-memless.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/ff-memless.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/keyboard/adc-keys.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/keyboard/adc-keys.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/pwm-beeper.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/pwm-beeper.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/pwm-vibra.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/pwm-vibra.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/tps65219-pwrbutton.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/misc/tps65219-pwrbutton.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/atmel_mxt_ts.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/atmel_mxt_ts.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/edt-ft5x06.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/edt-ft5x06.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/goodix_ts.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/goodix_ts.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/ili210x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/input/touchscreen/ili210x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/irqchip/irq-pruss-intc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/irqchip/irq-pruss-intc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/led-class-multicolor.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/led-class-multicolor.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/leds-lm3692x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/leds-lm3692x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/leds-pca9532.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/leds/leds-pca9532.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-bio-prison.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-bio-prison.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-bufio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-bufio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-log.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-log.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-mirror.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-mirror.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-mod.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-mod.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-region-hash.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-region-hash.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-thin-pool.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-thin-pool.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-zero.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/dm-zero.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/md-mod.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/md-mod.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/persistent-data/dm-persistent-data.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/md/persistent-data/dm-persistent-data.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-common.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-common.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-dma-contig.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-dma-contig.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-dma-sg.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-dma-sg.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-memops.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-memops.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-v4l2.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-v4l2.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-vmalloc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/common/videobuf2/videobuf2-vmalloc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/dvb-core/dvb-core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/dvb-core/dvb-core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ds90ub953.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ds90ub953.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ds90ub960.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ds90ub960.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/imx219.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/imx219.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/imx390.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/imx390.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov2312.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov2312.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov5640.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov5640.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov5645.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ov5645.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ox05b1s.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/i2c/ox05b1s.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/mc/mc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/mc/mc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/cadence/cdns-csi2rx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/cadence/cdns-csi2rx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/chips-media/wave5/wave5.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/chips-media/wave5/wave5.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/e5010/e5010_jpeg_enc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/e5010/e5010_jpeg_enc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/vxe-vxd/vxd-dec.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/vxe-vxd/vxd-dec.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/vxe-vxd/vxe-enc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/img/vxe-vxd/vxe-enc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/platform/ti/j721e-csi2rx/j721e-csi2rx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/usb/uvc/uvcvideo.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/usb/uvc/uvcvideo.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-async.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-async.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-dv-timings.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-fwnode.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-fwnode.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-mem2mem.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/v4l2-mem2mem.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/videodev.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/media/v4l2-core/videodev.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mfd/ti_am335x_tscadc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mfd/ti_am335x_tscadc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mfd/wm8994.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mfd/wm8994.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/eeprom/at24.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/eeprom/at24.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/eeprom/at25.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/eeprom/at25.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/pci_endpoint_test.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/pci_endpoint_test.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/uacce/uacce.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/misc/uacce/uacce.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/hyperbus/hbmc-am654.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/hyperbus/hbmc-am654.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/hyperbus/hyperbus-core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/hyperbus/hyperbus-core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_nandbiterrs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_nandbiterrs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_nandecctest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_nandecctest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_oobtest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_oobtest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_pagetest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_pagetest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_readtest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_readtest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_speedtest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_speedtest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_stresstest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_stresstest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_subpagetest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_subpagetest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_torturetest.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/mtd/tests/mtd_torturetest.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/dev/can-dev.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/dev/can-dev.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/m_can/m_can.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/m_can/m_can.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/m_can/m_can_platform.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/m_can/m_can_platform.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/spi/mcp251xfd/mcp251xfd.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/can/spi/mcp251xfd/mcp251xfd.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/dummy.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/dummy.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/atheros/atl1c/atl1c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/atheros/atl1c/atl1c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/realtek/r8169.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/realtek/r8169.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/icss_iep.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/icss_iep.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/icssg-prueth.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/icssg-prueth.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/ti-cpsw-proxy-client.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/ti-cpsw-proxy-client.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ethernet/ti/ti-j721e-cpsw-virt-mac.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ipvlan/ipvlan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/ipvlan/ipvlan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/macvlan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/macvlan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/macvtap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/macvtap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/mdio/mdio-bcm-unimac.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/mdio/mdio-bcm-unimac.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/mii.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/mii.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/ax88796b.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/ax88796b.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/bcm-phy-lib.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/bcm-phy-lib.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/bcm7xxx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/bcm7xxx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/marvell.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/marvell.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/marvell10g.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/marvell10g.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/microchip.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/microchip.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/smsc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/phy/smsc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/tap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/tap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/asix.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/asix.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/ax88179_178a.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/ax88179_178a.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_ether.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_ether.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_ncm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_ncm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_subset.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/cdc_subset.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/dm9601.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/dm9601.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/lan78xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/lan78xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/mcs7830.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/mcs7830.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/net1080.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/net1080.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/pegasus.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/pegasus.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/plusb.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/plusb.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/r8152.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/r8152.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/r8153_ecm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/r8153_ecm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/rtl8150.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/rtl8150.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/smsc75xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/smsc75xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/smsc95xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/smsc95xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/sr9800.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/sr9800.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/usbnet.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/usbnet.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/zaurus.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/usb/zaurus.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/veth.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/veth.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/vxlan/vxlan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/vxlan/vxlan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath10k/ath10k_core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k_ahb.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k_ahb.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k_pci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/ath11k/ath11k_pci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/wcn36xx/wcn36xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ath/wcn36xx/wcn36xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac/brcmfmac.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil/brcmutil.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/dvm/iwldvm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex_pcie.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex_sdio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/marvell/mwifiex/mwifiex_sdio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wl18xx/wl18xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wl18xx/wl18xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wlcore/wlcore.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wlcore/wlcore.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wlcore/wlcore_sdio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/net/wireless/ti/wlcore/wlcore_sdio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nfc/s3fwrn5/s3fwrn5.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nfc/s3fwrn5/s3fwrn5.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nfc/s3fwrn5/s3fwrn5_i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nfc/s3fwrn5/s3fwrn5_i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvme/host/nvme-core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvme/host/nvme-core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvme/host/nvme.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvme/host/nvme.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvmem/nvmem-rmem.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/nvmem/nvmem-rmem.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e-ep.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e-ep.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e-host.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e-host.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pci-j721e.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence-ep.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence-ep.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence-host.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence-host.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pci/controller/cadence/pcie-cadence.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-cci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-cci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-ccn.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-ccn.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-cmn.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm-cmn.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm_dsu_pmu.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm_dsu_pmu.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm_spe_pmu.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/perf/arm_spe_pmu.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/cadence/cdns-dphy-rx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/cadence/cdns-dphy-rx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/cadence/cdns-dphy.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/cadence/cdns-dphy.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/phy-can-transceiver.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/phy-can-transceiver.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/qualcomm/phy-qcom-usb-hs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/qualcomm/phy-qcom-usb-hs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/ti/phy-omap-usb2.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/phy/ti/phy-omap-usb2.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/bq25890_charger.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/bq25890_charger.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/bq25980_charger.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/bq25980_charger.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/max17042_battery.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/max17042_battery.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/mt6360_charger.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/mt6360_charger.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/sbs-battery.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/power/supply/sbs-battery.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-omap-dmtimer.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-omap-dmtimer.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-tiecap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-tiecap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-tiehrpwm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/pwm/pwm-tiehrpwm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/rpi-panel-attiny-regulator.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/rpi-panel-attiny-regulator.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/tps65132-regulator.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/tps65132-regulator.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/vctrl-regulator.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/regulator/vctrl-regulator.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/pru_rproc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/pru_rproc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_common.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_common.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_dsp_remoteproc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_dsp_remoteproc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_m4_remoteproc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_m4_remoteproc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_r5_remoteproc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/remoteproc/ti_k3_r5_remoteproc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_char.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_char.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_ctrl.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_ctrl.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_ns.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_ns.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_pru.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/rpmsg_pru.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/virtio_rpmsg_bus.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rpmsg/virtio_rpmsg_bus.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-bq32k.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-bq32k.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-ds1307.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-ds1307.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-hym8563.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-hym8563.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-m41t80.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-m41t80.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-mt6397.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-mt6397.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf2127.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf2127.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf85063.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf85063.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf85363.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-pcf85363.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rk808.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rk808.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rv3028.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rv3028.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rv8803.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rv8803.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rx8581.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-rx8581.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-ti-k3.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/rtc/rtc-ti-k3.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/scsi/mpt3sas/mpt3sas.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/scsi/mpt3sas/mpt3sas.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/scsi/raid_class.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/scsi/raid_class.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soc/qcom/qmi_helpers.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soc/qcom/qmi_helpers.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soc/ti/pruss.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soc/ti/pruss.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soundwire/soundwire-bus.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/soundwire/soundwire-bus.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/spi/spi-omap2-mcspi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/spi/spi-omap2-mcspi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/spi/spidev.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/spi/spidev.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/staging/media/max96712/max96712.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/staging/media/max96712/max96712.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/thermal/k3_bandgap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/thermal/k3_bandgap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/thermal/k3_j72xx_bandgap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/thermal/k3_j72xx_bandgap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/tty/serial/8250/8250_pruss.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/tty/serial/8250/8250_pruss.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/ufs/host/cdns-pltfrm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/ufs/host/cdns-pltfrm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/ufs/host/ti-j721e-ufs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/ufs/host/ti-j721e-ufs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns-usb-common.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns-usb-common.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns3-ti.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns3-ti.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns3.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/cdns3/cdns3.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/class/cdc-acm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/class/cdc-acm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-am62.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-am62.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-haps.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-haps.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-keystone.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-keystone.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-of-simple.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3-of-simple.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/dwc3/dwc3.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/u_ether.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/u_ether.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/u_serial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/u_serial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_acm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_acm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_eem.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_eem.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_fs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_fs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ncm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ncm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_obex.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_obex.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_serial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_serial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_cdc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_cdc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_ether.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_ether.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_mass_storage.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_mass_storage.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_multi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_multi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_ncm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_ncm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_serial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_serial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_zero.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/legacy/g_zero.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/libcomposite.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/gadget/libcomposite.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-pci-renesas.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-pci-renesas.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-pci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-pci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-plat-hcd.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/host/xhci-plat-hcd.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/cp210x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/cp210x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/ftdi_sio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/ftdi_sio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/option.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/option.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/usb_wwan.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/usb_wwan.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/usbserial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/usbserial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/xr_serial.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/serial/xr_serial.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/hd3ss3220.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/hd3ss3220.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/fusb302.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/fusb302.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/tcpci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/tcpci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/tcpm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tcpm/tcpm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tipd/tps6598x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/tipd/tps6598x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/typec.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/usb/typec/typec.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/backlight/lp855x_bl.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/backlight/lp855x_bl.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/backlight/pwm_bl.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/backlight/pwm_bl.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/fb_sys_fops.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/fb_sys_fops.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/syscopyarea.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/syscopyarea.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/sysfillrect.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/sysfillrect.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/sysimgblt.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/video/fbdev/core/sysimgblt.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/watchdog/rti_wdt.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/drivers/watchdog/rti_wdt.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/btrfs/btrfs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/btrfs/btrfs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/fuse/cuse.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/fuse/cuse.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/fuse/fuse.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/fuse/fuse.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/nfs/blocklayout/blocklayoutdriver.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/nfs/blocklayout/blocklayoutdriver.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/overlayfs/overlay.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/fs/overlayfs/overlay.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crc-ccitt.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crc-ccitt.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libarc4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libarc4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libchacha.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libchacha.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libcurve25519-generic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libcurve25519-generic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libdes.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/crypto/libdes.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/libcrc32c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/libcrc32c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/raid6/raid6_pq.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/raid6/raid6_pq.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_bm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_bm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_fsm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_fsm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_kmp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/lib/ts_kmp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/garp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/garp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/mrp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/mrp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/p8022.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/p8022.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/psnap.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/psnap.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/stp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/802/stp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/8021q/8021q.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/8021q/8021q.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bluetooth/bluetooth.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bluetooth/bluetooth.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bluetooth/hidp/hidp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bluetooth/hidp/hidp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bridge/br_netfilter.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bridge/br_netfilter.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bridge/bridge.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/bridge/bridge.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-bcm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-bcm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-gw.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-gw.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-raw.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can-raw.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/can/can.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/dsa_core.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/dsa_core.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_brcm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_brcm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_ocelot.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_ocelot.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_ocelot_8021q.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/dsa/tag_ocelot_8021q.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/hsr/hsr.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/hsr/hsr.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/ip_tunnel.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/ip_tunnel.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/ip_tables.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/ip_tables.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/ipt_REJECT.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/ipt_REJECT.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_filter.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_filter.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_mangle.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_mangle.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_nat.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/iptable_nat.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/nf_defrag_ipv4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/nf_defrag_ipv4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/nf_reject_ipv4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/netfilter/nf_reject_ipv4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/tunnel4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/tunnel4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/udp_tunnel.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv4/udp_tunnel.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/ip6_udp_tunnel.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/ip6_udp_tunnel.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/ipv6.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/ipv6.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6_tables.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6_tables.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6t_REJECT.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6t_REJECT.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_filter.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_filter.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_mangle.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_mangle.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_nat.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/ip6table_nat.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/sit.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/ipv6/sit.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/llc/llc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/llc/llc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/mac80211/mac80211.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/mac80211/mac80211.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/ipvs/ip_vs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/ipvs/ip_vs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/ipvs/ip_vs_rr.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/ipvs/ip_vs_rr.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack_ftp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack_ftp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack_tftp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_conntrack_tftp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_log_syslog.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_log_syslog.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat_ftp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat_ftp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat_tftp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/nf_nat_tftp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/x_tables.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/x_tables.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_CHECKSUM.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_CHECKSUM.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_LOG.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_LOG.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_MASQUERADE.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_MASQUERADE.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_REDIRECT.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_REDIRECT.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_addrtype.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_addrtype.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_conntrack.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_conntrack.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_ipvs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_ipvs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_mark.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_mark.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_nat.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_nat.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_tcpudp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/netfilter/xt_tcpudp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/nfc/nci/nci.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/nfc/nci/nci.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/nfc/nfc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/nfc/nfc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-mhi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-mhi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-smd.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-smd.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-tun.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr-tun.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/qrtr/qrtr.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/rfkill/rfkill.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/rfkill/rfkill.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_csum.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_csum.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_gact.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_gact.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_gate.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_gate.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_ipt.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_ipt.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_mirred.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_mirred.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_nat.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_nat.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_pedit.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_pedit.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_police.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_police.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_simple.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_simple.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_skbedit.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/act_skbedit.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_basic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_basic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_cgroup.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_cgroup.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_flow.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_flow.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_flower.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_flower.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_fw.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_fw.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_route.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_route.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_u32.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/cls_u32.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_cmp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_cmp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_meta.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_meta.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_nbyte.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_nbyte.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_text.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_text.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_u32.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/em_u32.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_cbs.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_cbs.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_etf.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_etf.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_ingress.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_ingress.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_mqprio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_mqprio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_taprio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/sched/sch_taprio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/wireless/cfg80211.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/net/wireless/cfg80211.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/samples/rpmsg/rpmsg_client_sample.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/samples/rpmsg/rpmsg_client_sample.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/core/snd-hwdep.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/core/snd-hwdep.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/core/snd-rawmidi.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/core/snd-rawmidi.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-adau7002.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-adau7002.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-dmic.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-dmic.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-gtm601.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-gtm601.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-hdmi-codec.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-hdmi-codec.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-macro-common.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-macro-common.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-rx-macro.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-rx-macro.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-tx-macro.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-tx-macro.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-va-macro.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-va-macro.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-wsa-macro.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-lpass-wsa-macro.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-max98357a.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-max98357a.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-max98927.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-max98927.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-msm8916-digital.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-msm8916-digital.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-nau8822.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-nau8822.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-pcm3168a-i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-pcm3168a-i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-pcm3168a.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-pcm3168a.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-rl6231.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-rl6231.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-rt5659.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-rt5659.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-sgtl5000.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-sgtl5000.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-simple-amplifier.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-simple-amplifier.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-simple-mux.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-simple-mux.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-spdif-rx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-spdif-rx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-spdif-tx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-spdif-tx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic31xx.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic31xx.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic32x4-i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic32x4-i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic32x4.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic32x4.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic3x-i2c.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic3x-i2c.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic3x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-tlv320aic3x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd-mbhc.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd-mbhc.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd938x-sdw.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd938x-sdw.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd938x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wcd938x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8524.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8524.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8904.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8904.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8960.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8960.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8962.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8962.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8978.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wm8978.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wsa881x.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/codecs/snd-soc-wsa881x.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-audio-graph-card.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-audio-graph-card.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-audio-graph-card2.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-audio-graph-card2.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-simple-card-utils.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-simple-card-utils.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-simple-card.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/generic/snd-soc-simple-card.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-davinci-mcasp.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-davinci-mcasp.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-j721e-evm.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-j721e-evm.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-edma.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-edma.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-sdma.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-sdma.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-udma.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/soc/ti/snd-soc-ti-udma.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/usb/snd-usb-audio.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/usb/snd-usb-audio.ko
      INSTALL /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/usb/snd-usbmidi-lib.ko
      STRIP   /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027/kernel/sound/usb/snd-usbmidi-lib.ko
      DEPMOD  /home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install/lib/modules/6.1.83-00001-g187795a28027
    make[1]: Leaving directory '/home/p-shivhare/ti/cgit/ti-linux-kernel'
    2) Go to the DESTDIR & create a tar archive.
    ❯ cd board-support/linux-install
    ❯ tar -cf linux-install.tar *
    ❯ ls -l
    drwxr-xr-x    - p-shivhare boot/
    drwxr-xr-x    - p-shivhare lib/
    .rw-r--r-- 147M p-shivhare linux-install.tar
    3) Transfer this archive to the development board.
    ----------- EVM -----------
    1) Extract the received tar archive with the following command
    tar -xvf linux-install.tar -C / && sync
    Prashant
    Thank you very much for writing so detailed, I understand the process now, I think I will try it tomorrow.
    I have another question, how can I boot the Linux system from emmc through the SD card, and complete the boot automatically after the configuration is completed instead of entering the command every time. The SDK version I use is SDK8.06.
  • instead of entering the command every time.
    May I know what exact commands you are talking about here?
    I followed the instructions to boot Linux from eMMC. When I completed the settings and entered the boot command, the following error was returned:
    https://dev.ti.com/tirex/explore/node?node=A__Acd0nQTgfZUAAJJCnbWdKQ__AM64-ACADEMY__WI1KRXP__LATEST
    U-Boot 2021.01-00001-g7e12ed6f28-dirty (Aug 06 2024 - 14:20:12 +0800)
    SoC: AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 EVM
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -1
    DRAM: 2 GiB
    NAND: 0 MiB
    MMC: mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from FAT... *** Warning - bad CRC, using default environment
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Net: eth0: ethernet@8000000port@1
    Hit any key to stop autoboot: 0
    => setenv mmcdev 0
    => setenv bootpart 0
    => saveenv
    Saving Environment to FAT... Error: no space left: 131072
    Error: writing contents
    At this time, I can start it normally by entering the command, but I need to enter it every time, not automatically start.
    => setenv mmcdev 0
    => setenv bootpart 0:1
    => boot
    I tested it according to your method and found that the version I was using was SDK8.06, which was inconsistent with yours. An error was reported when installing the kernel module. What command should I use to install the kernel module in version 8.06? How to use the specific command content?
    make -C /home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-5.10.168+gitAUTOINC+2c23e6c538-g2c23e6c538 ARCH=arm64 CROSS_COMPILE=/home/byf/ti/ ti-processor-sdk-linux-am64xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux- INSTALL_MOD_PATH=/home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-install INSTALL_MOD_STRIP=1 modules_install
    make: 进入目录“/home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-5.10.168+gitAUTOINC+2c23e6c538-g2c23e6c538”
    arch/arm64/Makefile:25: ld does not support --fix-cortex-a53-843419; kernel may be susceptible to erratum
    make: /home/byf/ti/gcc: Command not found
    SYNC include/config/auto.conf.cmd
    scripts/Kconfig.include:39: compiler '/home/byf/ti/gcc' not found
    scripts/kconfig/Makefile:71: recipe for target 'syncconfig' failed
    make[2]: *** [syncconfig] Error 1
    Makefile:606: recipe for target 'syncconfig' failed
    make[1]: *** [syncconfig] Error 2
    Makefile:723: recipe for target 'include/config/auto.conf.cmd' failed
    make: *** [include/config/auto.conf.cmd] Error 2
    make: 离开目录“/home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-5.10.168+gitAUTOINC+2c23e6c538-g2c23e6c538”
    byf@byf-virtual-machine:~/ti/t
  • CROSS_COMPILE=/home/byf/ti/ ti-processor-sdk-linux-am64xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-
    You have a space here after "/home/byf/ti/". Please give the correct path & it should then run successfully.
    Thank you for your tip. I changed the path, but the error still occurs after running. I think it may be due to the inconsistency of your SDK version.
  • The Kernel configuration probably got corrupted because of the previous incorrect command. Please rebuild the Linux & then try installing the module.
    I recompiled and reinstalled and found the same error as before,I founed "x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux- INSTALL_MOD_PATH" have two  aarch64-oe-linux.Is there a problem here?
  • What command you are using to build Linux Kernel?
  • I use "make linux " on sdk top path.Is it correct?
  • Then, use the "make linux_install" on sdk top path like I suggested in my first post.
    make linux_install DESTDIR=/home/p-shivhare/ti/psdk/am62x/09.02.01.10/board-support/linux-install
  • Using make linux_install can succeed, but the error still occurs when executing modules_install at the end.
  • Behind the scenes, the "make linux_install" calls the "modules_install" only from the kernel directory. The reason for the failure of "modules_install" on your end is mostly because of the incorrect path to the compiler given to CROSS_COMPILE.
    If in doubt, you may look at the output of "make linux_install" & see the command it runs to install the modules.
    I look at the output of "make linux_install" and  see the command it runs to install the modules,found that the path is wrong, it is fine after modification.
    make -C /home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-5.10.168+gitAUTOINC+2c23e6c538-g2c23e6c538 ARCH=arm64 CROSS_COMPILE=/home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-none-linux-gnu- INSTALL_MOD_PATH=/home/byf/ti/ti-processor-sdk-linux-am64xx-evm-08.06.00.42/board-support/linux-install INSTALL_MOD_STRIP=1 modules_install
    There is also a problem with booting from emmc,like
    DRAM: 2 GiB
    NAND: 0 MiB
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    => setenv mmcdev 0
    => saveenv
    => setenv mmcdev 0
    => boot
    Can you give me some advice?
    It seems like the `saveenv` is trying to save the environment into something that doesn't exist (a FAT partition on eMMC). You would need to reformat your eMMC to have the first partition formatted as FAT & then any number of partitions for your rootfs.
    OR
    You could apply the following patch to save the environment in the eMMC BOOT0 partition at the location 0x3800 according to the eMMC layout desribed in the documentation.
    diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig
    index dc9daa61bb1..ce6c769707b 100644
    --- a/configs/am64x_evm_a53_defconfig
    +++ b/configs/am64x_evm_a53_defconfig
    @@ -84,8 +84,8 @@ CONFIG_OF_LIST="k3-am642-evm k3-am642-sk"
     CONFIG_MULTI_DTB_FIT=y
     CONFIG_SPL_MULTI_DTB_FIT=y
     CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
    -CONFIG_ENV_IS_IN_FAT=y
    -CONFIG_ENV_FAT_DEVICE_AND_PART="1:1"
    +CONFIG_ENV_OFFSET=0x700000
    +CONFIG_ENV_IS_IN_MMC=y
     CONFIG_SPL_ENV_IS_NOWHERE=y
     CONFIG_NET_RANDOM_ETHADDR=y
     CONFIG_DM=y
    Let me tell you my operation process:
    1、ls /dev/mmcblk*
    /dev/mmcblk0  /dev/mmcblk0boot0  /dev/mmcblk0boot1  /dev/mmcblk0rpmb  /dev/mmcblk1  /dev/mmcblk1p1  /dev/mmcblk1p2
    2、echo 0 > /sys/block/mmcblk0boot0/force_ro
    dd if=/media/mmcblk1p1/tiboot3.bin of=/dev/mmcblk0boot0 seek=0
    dd if=/media/mmcblk1p1/tispl.bin of=/dev/mmcblk0boot0 seek=2048
    dd if=/media/mmcblk1p1/u-boot.img of=/dev/mmcblk0boot0 seek=6144
    At this time, I used the SD card to boot, and copied the file from the SD card path to emmc.
    3、
    fdisk /dev/mmcblk0
    The command used is:p d n y w
    4、
     ls -l /dev/mmcblk0*
    brw-rw---- 1 root disk 179, 32 Nov 16 02:02 /dev/mmcblk0
    brw-rw---- 1 root disk 179, 64 Nov 16 02:01 /dev/mmcblk0boot0
    brw-rw---- 1 root disk 179, 96 Nov 16 01:44 /dev/mmcblk0boot1
    brw-rw---- 1 root disk 179, 33 Nov 16 02:02 /dev/mmcblk0p1
    crw------- 1 root root 237,  0 Nov 16 01:44 /dev/mmcblk0rpmb
    5、
    mkfs.ext4 /dev/mmcblk0p1
    mkdir -p /mnt/temp
    mount -t ext4 /dev/mmcblk0p1 /mnt/temp
     cd /mnt/temp
    tar xf  /home/tisdk-default-image-am64xx-evm.tar.xz
    cd ..
    umount temp
    tisdk-default-image-am64xx-evm.tar.xz  has been saved in advance to the SD card.
    6、Enter the uboot command line after reboot
    mmc partconf 0 1 1 1
    mmc bootbus 0 2 0 0
    change switch from SD to emmc
    7、reboot and Enter the uboot command
    setenv mmcdev 0
    setenv bootpart 0
    saveenv
    At this point, the message should Successful saving of environment , but no such message is displayed.Display Saving Environment to FAT... Error: no space left: 131072
    Do you see anything wrong with my process?Can you elaborate on the two methods you mentioned? How do they work?
  • Following are the configs related to the location & size of the A53 U-Boot environment
    ❯ grep CONFIG_ENV -- configs/am64x_evm_a53_defconfig
    CONFIG_ENV_SIZE=0x20000
    This says that the A53 U-Boot environment is in the SD card 1st partition formatted as FAT. In case you do not have SD card inserted at the time of booting from eMMC, the A53 U-Boot & saveenv command will have trouble loading & saving the environment respectively.
    To overcome the issue, the suggestion is to change the location of the environment to the eMMC Boot0 partition according to the default eMMC layout as described in the documentation.
  • I modified the am64x_evm_a53_defconfig file in the uboot path as you said, as follows:
    Then I recompiled uboot using the command make u-boot.
    I overwrote the newly generated u-boot.img, tispl.bin, and tiboot3.bin to the SD card, then connected the development board and started it in SD card mode, and executed the command
    Follow steps 6 and 7 again, and it prompts that the environment is saved to the file successfully, but when I pull out the SD card, I still cannot automatically enter the Linux system
  • Could you please share the boot logs?
  • The following is the log I just run
    3034.编辑2.C
  • DRAM: 2 GiB
    NAND: 0 MiB
    Loading Environment from FAT... MMC: no card present
    Above snap of the logs suggests the environment is not loaded correctly which is the cause of the failure.
    The U-Boot is still trying to load the environment from the FAT partition on SD card, this means you haven't correctly applied the patch. Could you share the am64x_evm_a53_defconfig file?
  • CONFIG_ARM=y
    CONFIG_ARCH_K3=y
    CONFIG_TI_SECURE_DEVICE=y
    CONFIG_TI_COMMON_CMD_OPTIONS=y
    CONFIG_SPL_GPIO_SUPPORT=y
    CONFIG_SPL_LIBCOMMON_SUPPORT=y
    CONFIG_SPL_LIBGENERIC_SUPPORT=y
    CONFIG_SYS_MALLOC_F_LEN=0x8000
    CONFIG_NR_DRAM_BANKS=2
    CONFIG_SOC_K3_AM642=y
    CONFIG_K3_ATF_LOAD_ADDR=0x701c0000
    CONFIG_TARGET_AM642_A53_EVM=y
    CONFIG_SYS_SPI_U_BOOT_OFFS=0x300000
    CONFIG_DM_GPIO=y
    CONFIG_SPL_DM_SPI=y
    CONFIG_SPL_TEXT_BASE=0x80080000
    CONFIG_SPL_MMC_SUPPORT=y
    CONFIG_SPL_SERIAL_SUPPORT=y
    CONFIG_SPL_DRIVERS_MISC_SUPPORT=y
    CONFIG_SPL_STACK_R_ADDR=0x82000000
    CONFIG_SPL_FS_FAT=y
    CONFIG_SPL_LIBDISK_SUPPORT=y
    CONFIG_SPL_SPI_FLASH_SUPPORT=y
    CONFIG_SPL_SPI_SUPPORT=y
    CONFIG_DEFAULT_DEVICE_TREE="k3-am642-evm"
    CONFIG_DISTRO_DEFAULTS=y
    # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
    CONFIG_FIT_IMAGE_POST_PROCESS=y
    CONFIG_SPL_LOAD_FIT=y
    CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000
    CONFIG_SPL_LOAD_FIT_APPLY_OVERLAY=y
    CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y
    CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;"
    CONFIG_BOARD_LATE_INIT=y
    CONFIG_SPL_BOARD_INIT=y
    CONFIG_SPL_SYS_MALLOC_SIMPLE=y
    CONFIG_SPL_STACK_R=y
    CONFIG_SPL_SEPARATE_BSS=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800
    CONFIG_SPL_DMA=y
    CONFIG_SPL_ENV_SUPPORT=y
    CONFIG_SPL_ETH_SUPPORT=y
    CONFIG_SPL_I2C_SUPPORT=y
    CONFIG_SPL_DM_MAILBOX=y
    CONFIG_SPL_MTD_SUPPORT=y
    CONFIG_SPL_NAND_SUPPORT=y
    CONFIG_SPL_NAND_DRIVERS=y
    CONFIG_SPL_NAND_ECC=y
    CONFIG_SPL_NAND_BASE=y
    CONFIG_SPL_NAND_IDENT=y
    CONFIG_SPL_DM_SPI_FLASH=y
    CONFIG_SPL_NET_SUPPORT=y
    CONFIG_SPL_NET_VCI_STRING="AM64X U-Boot A53 SPL"
    CONFIG_SPL_POWER_DOMAIN=y
    CONFIG_SPL_RAM_SUPPORT=y
    CONFIG_SPL_RAM_DEVICE=y
    # CONFIG_SPL_SPI_FLASH_TINY is not set
    CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y
    CONFIG_SPL_SPI_LOAD=y
    CONFIG_SPL_THERMAL=y
    CONFIG_SPL_USB_HOST_SUPPORT=y
    CONFIG_SPL_USB_STORAGE=y
    CONFIG_SPL_USB_GADGET=y
    CONFIG_SPL_DFU=y
    CONFIG_SPL_YMODEM_SUPPORT=y
    # CONFIG_CMD_BOOTZ is not set
    # CONFIG_CMD_EEPROM is not set
    CONFIG_CMD_DM=y
    # CONFIG_CMD_GPIO is not set
    CONFIG_CMD_MTD=y
    CONFIG_CMD_NAND=y
    # CONFIG_CMD_SPI is not set
    CONFIG_CMD_DDRSS=y
    # CONFIG_CMD_EXT4_WRITE is not set
    CONFIG_CMD_MTDPARTS=y
    CONFIG_MTDIDS_DEFAULT="nor0=fc40000.spi.0,nand0=omap2-nand.0"
    CONFIG_MTDPARTS_DEFAULT="mtdparts=fc40000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system)"
    CONFIG_CMD_UBI=y
    CONFIG_OF_CONTROL=y
    CONFIG_SPL_OF_CONTROL=y
    CONFIG_DM=y
    CONFIG_SPL_DM=y
    CONFIG_SPL_DM_SEQ_ALIAS=y
    CONFIG_REGMAP=y
    CONFIG_SPL_REGMAP=y
    CONFIG_SYSCON=y
    CONFIG_SPL_OF_TRANSLATE=y
    CONFIG_CLK=y
    CONFIG_SPL_CLK=y
    CONFIG_CLK_CCF=y
    CONFIG_CLK_TI_SCI=y
    CONFIG_DFU_MMC=y
    CONFIG_DFU_RAM=y
    CONFIG_DFU_SF=y
    CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000
    CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000
    CONFIG_DMA_CHANNELS=y
    CONFIG_TI_K3_NAVSS_UDMA=y
    CONFIG_TI_SCI_PROTOCOL=y
    CONFIG_DM_PCA953X=y
    CONFIG_SPL_DM_PCA953X=y
    CONFIG_DM_I2C=y
    CONFIG_I2C_SET_DEFAULT_BUS_NUM=y
    CONFIG_DM_I2C_GPIO=y
    CONFIG_SYS_I2C_OMAP24XX=y
    CONFIG_DM_MAILBOX=y
    CONFIG_K3_SEC_PROXY=y
    CONFIG_TI_GPMC=y
    CONFIG_DM_MMC=y
    CONFIG_SUPPORT_EMMC_BOOT=y
    CONFIG_MMC_HS400_SUPPORT=y
    CONFIG_SPL_MMC_HS400_SUPPORT=y
    CONFIG_MMC_SDHCI=y
    CONFIG_MMC_SDHCI_ADMA=y
    CONFIG_SPL_MMC_SDHCI_ADMA=y
    CONFIG_MMC_SDHCI_AM654=y
    CONFIG_MTD=y
    CONFIG_DM_MTD=y
    CONFIG_MTD_RAW_NAND=y
    CONFIG_NAND_OMAP_GPMC=y
    CONFIG_NAND_OMAP_ELM=y
    # CONFIG_SPL_NAND_AM33XX_BCH is not set
    CONFIG_DM_SPI_FLASH=y
    CONFIG_SF_DEFAULT_MODE=0
    CONFIG_SPI_FLASH_SFDP_SUPPORT=y
    CONFIG_SPI_FLASH_SOFT_RESET=y
    CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y
    CONFIG_SPI_FLASH_SPANSION=y
    CONFIG_SPI_FLASH_S28HS512T=y
    CONFIG_SPI_FLASH_STMICRO=y
    CONFIG_SPI_FLASH_MT35XU=y
    # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set
    CONFIG_SPI_FLASH_MTD=y
    CONFIG_MULTIPLEXER=y
    CONFIG_MUX_MMIO=y
    CONFIG_PHY_TI_DP83867=y
    CONFIG_PHY_FIXED=y
    CONFIG_DM_ETH=y
    CONFIG_TI_AM65_CPSW_NUSS=y
    CONFIG_PHY=y
    CONFIG_SPL_PHY=y
    CONFIG_PHY_CADENCE_SIERRA=y
    CONFIG_PHY_CADENCE_TORRENT=y
    CONFIG_PHY_J721E_WIZ=y
    CONFIG_PINCTRL=y
    CONFIG_SPL_PINCTRL=y
    CONFIG_PINCTRL_SINGLE=y
    CONFIG_POWER_DOMAIN=y
    CONFIG_TI_SCI_POWER_DOMAIN=y
    CONFIG_K3_SYSTEM_CONTROLLER=y
    CONFIG_REMOTEPROC_TI_K3_ARM64=y
    CONFIG_DM_RESET=y
    CONFIG_RESET_TI_SCI=y
    CONFIG_DM_SERIAL=y
    CONFIG_SOC_DEVICE=y
    CONFIG_SOC_DEVICE_TI_K3=y
    CONFIG_SOC_TI=y
    CONFIG_SPI=y
    CONFIG_DM_SPI=y
    CONFIG_CADENCE_QSPI=y
    CONFIG_CADENCE_QSPI_PHY=y
    CONFIG_SYSRESET=y
    CONFIG_SPL_SYSRESET=y
    CONFIG_SYSRESET_TI_SCI=y
    CONFIG_DM_THERMAL=y
    CONFIG_USB=y
    CONFIG_DM_USB=y
    CONFIG_DM_USB_GADGET=y
    CONFIG_SPL_DM_USB_GADGET=y
    CONFIG_USB_XHCI_HCD=y
    CONFIG_USB_CDNS3=y
    CONFIG_USB_CDNS3_GADGET=y
    CONFIG_USB_CDNS3_HOST=y
    CONFIG_SPL_USB_CDNS3_GADGET=y
    CONFIG_SPL_USB_CDNS3_HOST=y
    CONFIG_USB_GADGET=y
    CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments"
    CONFIG_USB_GADGET_VENDOR_NUM=0x0451
    CONFIG_USB_GADGET_PRODUCT_NUM=0x6165
    CONFIG_USB_GADGET_DOWNLOAD=y
    CONFIG_USB_FUNCTION_MASS_STORAGE=y
    CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
    CONFIG_HEXDUMP=y
    The CONFIG_ENV changes looks okay but it seems the changes are not reflecting either because the u-boot image is not built or flashed correctly. Can you commit the changes, rebuild, and flash the images.
    Do you then see the commit id in the U-Boot logs? This should at least confirm the built image is getting flashed correctly.
    I recompiled it according to what you said, and after executing it, I can realize the function of self-booting from emmc. Your answer solved a big problem for us, thank you very much!
  • Thanks for the confirmation. Always happy to help!!
