Part Number: TDA4VH-Q1
Can TI Autonomous driving algorithm (TIADALG) run on TIOVX tutorial tests for PC Emulation mode ?
If possible, can you please share the procedure for it.
Yes, you are correct.
The TIADALG APIs are called from the OpenVX node (process callback) when running a vision_apps application.
For eg. The tivxImgPreProc node which is used in all the DL demos, uses the API tiadalg_image_preprocessing_c66() in it's process callback
Nikhil
