My Environment
- QNX 7.1 & RTOS 9.2
- J721S2
- TIDL 9.2
Problem
- I’m encountering an issue with a deep learning model that takes 16-bit grayscale input.
- The model does not work as expected, as shown in the code below.
- Models with 8-bit grayscale and 16-bit RGB inputs work fine, but the 16-bit grayscale model does not.
Symptoms
- No error logs are generated.
- The system halts or freezes.
Error Occurrence
- The system runs without issues until a value is provided to the network input tensor.
- The system stops during the
vxProcessGraph
function call. - The
printf("Optimized conversion time: %.3f ms\n", optimized_time);
is executed, but nothing is printed after thevxProcessGraph
function.
#define KERNEL_ID_CUSTOM_IMAGE_TO_TENSOR_GREY 123459 #define KERNEL_ID_CUSTOM_IMAGE_TO_TENSOR_16bit 123460 #define KERNEL_ID_CUSTOM_IMAGE_TO_TENSOR_16bit_grey 123461 //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// vx_status VX_CALLBACK customImageToTensorValidator_16bit_grey(vx_node node, const vx_reference parameters[], vx_uint32 num, vx_meta_format metas[]) { if (num != 2) return VX_ERROR_INVALID_PARAMETERS; vx_image input = (vx_image)parameters[0]; vx_df_image df; vxQueryImage(input, VX_IMAGE_FORMAT, &df, sizeof(df)); if (df != VX_DF_IMAGE_U8) return VX_ERROR_INVALID_FORMAT; return VX_SUCCESS; } vx_status VX_CALLBACK customImageToTensorInitialize_16bit_grey(vx_node node, const vx_reference *parameters, vx_uint32 num) { return VX_SUCCESS; } vx_status VX_CALLBACK customImageToTensorDeinitialize_16bit_grey(vx_node node, const vx_reference *parameters, vx_uint32 num) { return VX_SUCCESS; } vx_status VX_CALLBACK customImageToTensorKernel_16bit_grey(vx_node node, const vx_reference *parameters, vx_uint32 num) { vx_image input = (vx_image)parameters[0]; vx_tensor output = (vx_tensor)parameters[1]; vx_uint32 rect_end_x, rect_end_y; vxQueryImage(input, VX_IMAGE_WIDTH, &rect_end_x, sizeof(vx_uint32)); vxQueryImage(input, VX_IMAGE_HEIGHT, &rect_end_y, sizeof(vx_uint32)); vx_rectangle_t rect; rect.start_x = 0; rect.start_y = 0; rect.end_x = rect_end_x; rect.end_y = rect_end_y; vx_imagepatch_addressing_t addr; vx_map_id map_id; vx_uint8* src_ptr; vxMapImagePatch(input, &rect, 0, &map_id, &addr, (void**)&src_ptr, VX_READ_ONLY, VX_MEMORY_TYPE_HOST, 0); vx_size stride[4]; vx_map_id map_id_tensor; vx_uint16* tensor_ptr; tivxMapTensorPatch(output, 3, NULL, NULL, &map_id_tensor, stride, (void**)&tensor_ptr, VX_WRITE_ONLY, VX_MEMORY_TYPE_HOST); vx_uint64 start_time = tivxPlatformGetTimeInUsecs(); printf(" [DIS_DL] [LM] Image to customImageToTensorKernel_16bit_grey\n"); printf("stride : %ld, %ld, %ld %ld \n",stride[0],stride[1],stride[2],stride[3]); printf("addr.stride_x : %d, addr.stride_y : %d\n",addr.stride_x,addr.stride_y); for (vx_size y = 0; y < rect.end_y; y++) { for (vx_size x = 0; x < rect.end_x; x++) { vx_uint8* src_pixel_addr = src_ptr + y * addr.stride_y + x * addr.stride_x; vx_uint8 src_pixel_value = *src_pixel_addr; vx_uint16* tensor_element = (vx_uint16*)((vx_uint8*)tensor_ptr + y * stride[1] + x * stride[0]); *tensor_element = src_pixel_value; } } vx_uint64 end_time = tivxPlatformGetTimeInUsecs(); vxUnmapImagePatch(input, map_id); tivxUnmapTensorPatch(output, map_id_tensor); float optimized_time = (end_time - start_time) / 1000.0f; printf("Optimized conversion time: %.3f ms\n", optimized_time); return VX_SUCCESS; } void registerImage2TensorKernel_16bit_grey(vx_context context) { vx_kernel kernel = vxAddUserKernel(context, "custom.image_to_tensor_16bit_grey", KERNEL_ID_CUSTOM_IMAGE_TO_TENSOR_16bit_grey, customImageToTensorKernel_16bit_grey, 2, customImageToTensorValidator_16bit_grey, customImageToTensorInitialize_16bit_grey, customImageToTensorDeinitialize_16bit_grey); vxAddParameterToKernel(kernel, 0, VX_INPUT, VX_TYPE_IMAGE, VX_PARAMETER_STATE_REQUIRED); vxAddParameterToKernel(kernel, 1, VX_OUTPUT, VX_TYPE_TENSOR, VX_PARAMETER_STATE_REQUIRED); vxFinalizeKernel(kernel); } vx_node vxCustomImage2TensorNode_16bit_grey(vx_graph graph, vx_image input, vx_tensor output) { vx_context context = vxGetContext((vx_reference)graph); vx_kernel kernel = vxGetKernelByEnum(context, KERNEL_ID_CUSTOM_IMAGE_TO_TENSOR_16bit_grey); vx_node node = vxCreateGenericNode(graph, kernel); printf("status : %d\n",status); vxSetParameterByIndex(node, 0, (vx_reference)input); vxSetParameterByIndex(node, 1, (vx_reference)output); return node; } ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
