Part Number: TDA4VH-Q1
Hi Exbert
I want to use check the ds90ub960 test data on linux system with TDA4VH-Q1.
SW SDK: tda4vh-linux-sdk-j784s4-evm-09_00_01_01
1. I read the ds90ub960 datasheet(7.5.12) and refer the pattern generator sample code to implement "set_ds90ub960_pattern_mode" function and add it to the "ub960_probe" function in ds90ub960.c (driver/media/i2c/)., please see my modifications in ds90ub960.c ("set_ds90ub960_pattern_mode" and "ub960_probe" )ds90ub960.c
Media controller API version 6.1.46
Media device information
driver j721e-csi2rx
model TI-CSI2RX
serial
bus info platform:4520000.ticsi2rx
hw revision 0x1
driver version 6.1.46
Device topology
- entity 1: 4520000.ticsi2rx (5 pads, 0 link, 0 route)
type V4L2 subdev subtype Unknown flags 0
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
- entity 7: cdns_csi2rx.4524000.csi-bridge (5 pads, 0 link, 0 route)
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.46-dirty (root@UGC1BGLX7S3) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Tue Aug 6 11:23:23 CST 2024 [ 0.000000] Machine model: Texas Instruments J784S4 EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 47 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b7100000, size 47 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba100000, size 47 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bd000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bd000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000bd100000, size 47 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bd100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e0000000, size 80 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e5000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e5800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e5800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 2048 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 1792 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000fffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000bfffffff] [ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000dfffffff] [ 0.000000] node 0: [mem 0x00000000e0000000-0x00000000e6ffffff] [ 0.000000] node 0: [mem 0x00000000e7000000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] node 0: [mem 0x0000000900000000-0x0000000fffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824 [ 0.000000] pcpu-alloc: s38376 r8192 d31256 u77824 alloc=19*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8257534 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=b98cb854-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) [ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 27712180K/33554424K available (12480K kernel code, 1294K rwdata, 4360K rodata, 2176K init, 498K bss, 4007236K reserved, 1835008K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @920800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000920050000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000920060000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008426] Console: colour dummy device 80x25 [ 0.013000] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023672] pid_max: default: 32768 minimum: 301 [ 0.028413] LSM: Security Framework initializing [ 0.033239] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.041042] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.050235] cblist_init_generic: Setting adjustable number of callback queues. [ 0.057633] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.063900] cblist_init_generic: Setting adjustable number of callback queues. [ 0.071285] cblist_init_generic: Setting shift to 3 and lim to 1. [ 0.077598] rcu: Hierarchical SRCU implementation. [ 0.082496] rcu: Max phase no-delay instances is 1000. [ 0.087995] Platform MSI: msi-controller@1820000 domain created [ 0.094198] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.104004] EFI services will not be available. [ 0.108844] smp: Bringing up secondary CPUs ... [ 0.121935] Detected PIPT I-cache on CPU1 [ 0.121994] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.122009] GICv3: CPU1: using allocated LPI pending table @0x0000000920070000 [ 0.122042] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.130512] Detected PIPT I-cache on CPU2 [ 0.130559] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000 [ 0.130572] GICv3: CPU2: using allocated LPI pending table @0x0000000920080000 [ 0.130594] CPU2: Booted secondary processor 0x0000000002 [0x411fd080] [ 0.139020] Detected PIPT I-cache on CPU3 [ 0.139066] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000 [ 0.139079] GICv3: CPU3: using allocated LPI pending table @0x0000000920090000 [ 0.139102] CPU3: Booted secondary processor 0x0000000003 [0x411fd080] [ 0.147583] Detected PIPT I-cache on CPU4 [ 0.147665] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000 [ 0.147679] GICv3: CPU4: using allocated LPI pending table @0x00000009200a0000 [ 0.147711] CPU4: Booted secondary processor 0x0000000100 [0x411fd080] [ 0.156191] Detected PIPT I-cache on CPU5 [ 0.156245] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000 [ 0.156258] GICv3: CPU5: using allocated LPI pending table @0x00000009200b0000 [ 0.156283] CPU5: Booted secondary processor 0x0000000101 [0x411fd080] [ 0.164724] Detected PIPT I-cache on CPU6 [ 0.164778] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000 [ 0.164790] GICv3: CPU6: using allocated LPI pending table @0x00000009200c0000 [ 0.164814] CPU6: Booted secondary processor 0x0000000102 [0x411fd080] [ 0.173263] Detected PIPT I-cache on CPU7 [ 0.173317] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000 [ 0.173330] GICv3: CPU7: using allocated LPI pending table @0x00000009200d0000 [ 0.173353] CPU7: Booted secondary processor 0x0000000103 [0x411fd080] [ 0.173399] smp: Brought up 1 node, 8 CPUs [ 0.354381] SMP: Total of 8 processors activated. [ 0.359188] CPU features: detected: 32-bit EL0 Support [ 0.364444] CPU features: detected: CRC32 instructions [ 0.369743] CPU: All CPU(s) started at EL2 [ 0.373932] alternatives: applying system-wide alternatives [ 0.380701] devtmpfs: initialized [ 0.394386] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.404365] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.436771] pinctrl core: initialized pinctrl subsystem [ 0.442471] DMI not present or invalid. [ 0.446748] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.454137] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations [ 0.462170] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.470900] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.479134] audit: initializing netlink subsys (disabled) [ 0.484763] audit: type=2000 audit(0.344:1): state=initialized audit_enabled=0 res=1 [ 0.484980] thermal_sys: Registered thermal governor 'step_wise' [ 0.492683] thermal_sys: Registered thermal governor 'power_allocator' [ 0.498908] cpuidle: using governor menu [ 0.509657] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.516688] ASID allocator initialised with 65536 entries [ 0.532200] platform a000000.dp-bridge: Fixed dependency cycle(s) with /dp0-connector [ 0.540927] KASLR disabled due to lack of seed [ 0.548594] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.555544] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.561950] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.568885] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.575287] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.582222] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.588625] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.595559] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.602872] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected [ 0.612532] iommu: Default domain type: Translated [ 0.617518] iommu: DMA domain TLB invalidation policy: strict mode [ 0.624049] SCSI subsystem initialized [ 0.627946] libata version 3.00 loaded. [ 0.628040] usbcore: registered new interface driver usbfs [ 0.633660] usbcore: registered new interface driver hub [ 0.639101] usbcore: registered new device driver usb [ 0.644504] pps_core: LinuxPPS API ver. 1 registered [ 0.649575] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.658914] PTP clock support registered [ 0.662994] EDAC MC: Ver: 3.0.0 [ 0.666737] FPGA manager framework [ 0.670242] Advanced Linux Sound Architecture Driver Initialized. [ 0.676912] clocksource: Switched to clocksource arch_sys_counter [ 0.683258] VFS: Disk quotas dquot_6.6.0 [ 0.687286] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.697301] Carveout Heap: Exported 512 MiB at 0x0000000900000000 [ 0.703589] NET: Registered PF_INET protocol family [ 0.708943] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.721680] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) [ 0.730721] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.738655] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.747778] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.756238] TCP: Hash tables configured (established 262144 bind 65536) [ 0.763120] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.770470] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.778364] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.784462] RPC: Registered named UNIX socket transport module. [ 0.790523] RPC: Registered udp transport module. [ 0.795327] RPC: Registered tcp transport module. [ 0.800130] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.806720] NET: Registered PF_XDP protocol family [ 0.811623] PCI: CLS 0 bytes, default 64 [ 0.816357] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.825653] Initialise system trusted keyrings [ 0.830304] workingset: timestamp_bits=46 max_order=23 bucket_order=0 [ 0.839562] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.845817] NFS: Registering the id_resolver key type [ 0.850994] Key type id_resolver registered [ 0.855266] Key type id_legacy registered [ 0.859390] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.866239] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.873861] 9p: Installing v9fs 9p2000 file system support [ 0.898622] Key type asymmetric registered [ 0.902805] Asymmetric key parser 'x509' registered [ 0.907816] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.915446] io scheduler mq-deadline registered [ 0.920077] io scheduler kyber registered [ 0.926435] pinctrl-single 4301c000.pinctrl: 13 pins, size 52 [ 0.932392] pinctrl-single 4301c038.pinctrl: 11 pins, size 44 [ 0.938452] pinctrl-single 4301c068.pinctrl: 72 pins, size 288 [ 0.944490] pinctrl-single 4301c190.pinctrl: 1 pins, size 4 [ 0.950322] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.956566] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.966949] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.978296] loop: module loaded [ 0.982291] megasas: 07.719.03.00-rc1 [ 0.988210] tun: Universal TUN/TAP device driver, 1.6 [ 0.993705] thunder_xcv, ver 1.0 [ 0.997024] thunder_bgx, ver 1.0 [ 1.000327] nicpf, ver 1.0 [ 1.003351] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 1.010733] hns3: Copyright (c) 2017 Huawei Corporation. [ 1.016176] hclge is initializing [ 1.019569] e1000: Intel(R) PRO/1000 Network Driver [ 1.024550] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 1.030434] e1000e: Intel(R) PRO/1000 Network Driver [ 1.035503] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.041565] igb: Intel(R) Gigabit Ethernet Network Driver [ 1.047080] igb: Copyright (c) 2007-2014 Intel Corporation. [ 1.052782] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 1.059184] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 1.065305] sky2: driver version 1.30 [ 1.069459] VFIO - User Level meta-driver version: 0.3 [ 1.075078] usbcore: registered new interface driver usb-storage [ 1.081665] i2c_dev: i2c /dev entries driver [ 1.087050] sdhci: Secure Digital Host Controller Interface driver [ 1.093369] sdhci: Copyright(c) Pierre Ossman [ 1.098107] Synopsys Designware Multimedia Card Interface Driver [ 1.104519] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.110915] ledtrig-cpu: registered to indicate activity on CPUs [ 1.117151] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.123885] usbcore: registered new interface driver usbhid [ 1.129579] usbhid: USB HID core driver [ 1.134242] optee: probing for conduit method. [ 1.138800] optee: revision 4.0 (2a5b1d12) [ 1.155196] optee: dynamic shared memory is enabled [ 1.164587] optee: initialized driver [ 1.169448] Initializing XFRM netlink socket [ 1.173832] NET: Registered PF_PACKET protocol family [ 1.179062] 9pnet: Installing 9P2000 support [ 1.183452] Key type dns_resolver registered [ 1.187999] registered taskstats version 1 [ 1.192197] Loading compiled-in X.509 certificates [ 1.202568] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.2--v09.01.02 (Kool Koala)') [ 1.235177] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz [ 1.241483] pca953x 0-0020: supply vcc not found, using dummy regulator [ 1.248300] pca953x 0-0020: using no AI [ 1.273548] pca953x 0-0022: supply vcc not found, using dummy regulator [ 1.280352] pca953x 0-0022: using AI [ 1.284652] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.290674] i2c 2-0036: Fixed dependency cycle(s) with /bus@100000/ticsi2rx@4520000/csi-bridge@4524000 [ 1.300294] pca953x 2-0020: supply vcc not found, using dummy regulator [ 1.307116] pca953x 2-0020: using no AI [ 1.333760] omap_i2c 2050000.i2c: bus 2 rev0.12 at 100 kHz [ 1.339568] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created [ 1.348105] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created [ 1.357354] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created [ 1.366018] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created [ 1.378306] ti-udma 311a0000.dma-controller: Number of rings: 48 [ 1.385083] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16) [ 1.394265] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328 [ 1.404142] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.410901] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.419798] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315 [ 1.429944] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.436703] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.444635] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 215, base_baud = 6000000) is a 8250 [ 1.454101] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 216, base_baud = 3000000) is a 8250 [ 1.462954] printk: console [ttyS2] enabled [ 1.471398] printk: bootconsole [ns16550a0] disabled [ 1.520911] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.529826] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.538092] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.550953] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.558162] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.564312] pps pps0: new PPS source ptp0 [ 1.568447] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1 [ 1.616917] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.625587] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867 [ 1.633678] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.646423] am65-cpsw-nuss c200000.ethernet: Use random MAC address [ 1.652678] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4 [ 1.659796] am65-cpsw-nuss c200000.ethernet: ALE Table size 64 [ 1.665932] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0 [ 1.676126] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 1.785910] mmc0: CQHCI version 5.10 [ 1.830436] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.922060] mmc0: Command Queue Engine enabled [ 1.926504] mmc0: new HS200 MMC card at address 0001 [ 1.931843] mmcblk0: mmc0:0001 G1M15M 59.3 GiB [ 1.937518] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB [ 1.943166] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB [ 1.948704] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (240:0) [ 2.080706] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0 [ 2.086665] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock [ 2.094930] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 2.101715] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 2.108499] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 2.115276] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100 [ 2.122067] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 2.128850] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100 [ 2.137368] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8) [ 2.147353] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16) [ 2.159960] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 2.164955] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 2.171554] Creating 7 MTD partitions on "47040000.spi.0": [ 2.177034] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 2.183264] 0x000000080000-0x000000280000 : "ospi.tispl" [ 2.189204] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 2.195163] 0x000000680000-0x0000006c0000 : "ospi.env" [ 2.200875] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 2.207169] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 2.213146] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 2.221651] spi-nor spi1.0: mt25qu512a (65536 Kbytes) [ 2.226735] 7 fixed-partitions partitions found on MTD device 47050000.spi.0 [ 2.233769] Creating 7 MTD partitions on "47050000.spi.0": [ 2.239241] 0x000000000000-0x000000080000 : "qspi.tiboot3" [ 2.245339] 0x000000080000-0x000000280000 : "qspi.tispl" [ 2.251213] 0x000000280000-0x000000680000 : "qspi.u-boot" [ 2.257142] 0x000000680000-0x0000006c0000 : "qspi.env" [ 2.262805] 0x0000006c0000-0x000000700000 : "qspi.env.backup" [ 2.269117] 0x000000800000-0x000003fc0000 : "qspi.rootfs" [ 2.275053] 0x000003fc0000-0x000004000000 : "qspi.phypattern" [ 2.320924] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.329805] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.338073] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 2.350944] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.358152] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.364296] pps pps0: new PPS source ptp1 [ 2.368445] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1 [ 2.378375] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.424919] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.433628] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867 [ 2.441722] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 2.454475] am65-cpsw-nuss c200000.ethernet: Use random MAC address [ 2.460729] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4 [ 2.467847] am65-cpsw-nuss c200000.ethernet: ALE Table size 64 [ 2.473971] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.483774] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82 [ 2.491496] debugfs: Directory 'pd:74' with parent 'pm_genpd' already present! [ 2.491823] mmc1: CQHCI version 5.10 [ 2.498744] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present! [ 2.509550] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present! [ 2.517349] debugfs: Directory 'pd:335' with parent 'pm_genpd' already present! [ 2.524660] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present! [ 2.531976] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present! [ 2.543185] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.546773] ALSA device list: [ 2.553625] No soundcards found. [ 2.557231] Waiting for root device PARTUUID=b98cb854-02... [ 2.602338] mmc1: new ultra high speed SDR104 SDXC card at address aaaa [ 2.609364] mmcblk1: mmc1:aaaa SN256 238 GiB [ 2.615185] mmcblk1: p1 p2 [ 2.717298] EXT4-fs (mmcblk1p2): recovery complete [ 2.723212] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 2.731767] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.738937] devtmpfs: mounted [ 2.742837] Freeing unused kernel memory: 2176K [ 2.747484] Run /sbin/init as init process [ 2.751572] with arguments: [ 2.751574] /sbin/init [ 2.751576] with environment: [ 2.751578] HOME=/ [ 2.751580] TERM=linux [ 2.890217] systemd[1]: System time before build time, advancing clock. [ 2.926627] NET: Registered PF_INET6 protocol family [ 2.932264] Segment Routing with IPv6 [ 2.935942] In-situ OAM (IOAM) with IPv6 [ 2.962132] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 2.993620] systemd[1]: Detected architecture arm64. [ 3.065844] systemd[1]: Hostname set to <j784s4-evm>. [ 3.132261] systemd-sysv-generator[191]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.156546] systemd-sysv-generator[191]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.181864] systemd-sysv-generator[191]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.206773] systemd-sysv-generator[191]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.438493] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.490216] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.545838] systemd[1]: Queued start job for default target Graphical Interface. [ 3.597073] systemd[1]: Created slice Slice /system/getty. [ 3.618276] systemd[1]: Created slice Slice /system/modprobe. [ 3.642009] systemd[1]: Created slice Slice /system/serial-getty. [ 3.665812] systemd[1]: Created slice User and Session Slice. [ 3.689076] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 3.713012] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 3.737093] systemd[1]: Reached target Path Units. [ 3.752982] systemd[1]: Reached target Remote File Systems. [ 3.772958] systemd[1]: Reached target Slice Units. [ 3.788968] systemd[1]: Reached target Swaps. [ 3.834877] systemd[1]: Listening on RPCbind Server Activation Socket. [ 3.861034] systemd[1]: Reached target RPC Port Mapper. [ 3.884161] systemd[1]: Listening on Process Core Dump Socket. [ 3.905095] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 3.929220] systemd[1]: Listening on Journal Audit Socket. [ 3.949127] systemd[1]: Listening on Journal Socket (/dev/log). [ 3.969168] systemd[1]: Listening on Journal Socket. [ 3.985189] systemd[1]: Listening on Network Service Netlink Socket. [ 4.009188] systemd[1]: Listening on udev Control Socket. [ 4.029092] systemd[1]: Listening on udev Kernel Socket. [ 4.049121] systemd[1]: Listening on User Database Manager Socket. [ 4.085177] systemd[1]: Mounting Huge Pages File System... [ 4.103330] systemd[1]: Mounting POSIX Message Queue File System... [ 4.127159] systemd[1]: Mounting Kernel Debug File System... [ 4.145112] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.160931] systemd[1]: Mounting Temporary Directory /tmp... [ 4.179677] systemd[1]: Starting Create List of Static Device Nodes... [ 4.202958] systemd[1]: Starting Load Kernel Module configfs... [ 4.223011] systemd[1]: Starting Load Kernel Module drm... [ 4.239179] systemd[1]: Starting Load Kernel Module fuse... [ 4.249915] fuse: init (API version 7.37) [ 4.268804] systemd[1]: Starting Start psplash boot splash screen... [ 4.292597] systemd[1]: Starting RPC Bind... [ 4.309173] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 4.325095] systemd[1]: Starting Journal Service... [ 4.348597] systemd[1]: Starting Load Kernel Modules... [ 4.367830] systemd[1]: Starting Generate network units from Kernel command line... [ 4.395834] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.407939] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. [ 4.461375] systemd[1]: Starting Coldplug All udev Devices... [ 4.481651] systemd[1]: Started RPC Bind. [ 4.497347] systemd[1]: Started Journal Service. [ 4.800258] systemd-journald[211]: Received client request to flush runtime journal. [ 5.011276] audit: type=1334 audit(1651167747.120:2): prog-id=5 op=LOAD [ 5.017906] audit: type=1334 audit(1651167747.128:3): prog-id=6 op=LOAD [ 5.207253] random: crng init done [ 5.217709] CAN device driver interface [ 5.222883] mc: Linux media interface: v0.10 [ 5.231171] j721e-pcie-host 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 5.243993] j721e-pcie-host 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 5.252742] j721e-pcie-host 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 5.261312] j721e-pcie-host 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 5.273894] videodev: Linux video capture interface: v2.00 [ 5.314850] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000 [ 5.327340] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 5.343459] remoteproc remoteproc0: 64800000.dsp is available [ 5.349555] remoteproc remoteproc0: attaching to 64800000.dsp [ 5.363910] remoteproc remoteproc0: unsupported resource 65538 [ 5.370003] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 5.376686] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node vision-apps-c71-dma-memory@b4000000 [ 5.393818] ds90ub960 2-0036: supply vddio not found, using dummy regulator [ 5.407468] virtio_rpmsg_bus virtio0: rpmsg host is online [ 5.412227] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 5.434919] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7) [ 5.442637] remoteproc remoteproc0: remote processor 64800000.dsp is now attached [ 5.452616] ds90ub960 2-0036: 'links' node missing [ 5.484196] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7000000 [ 5.492006] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 5.498878] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode [ 5.511693] platform 41000000.r5f: configured R5F for IPC-only mode [ 5.514263] remoteproc remoteproc1: 65800000.dsp is available [ 5.519567] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 5.524560] remoteproc remoteproc1: attaching to 65800000.dsp [ 5.537529] remoteproc remoteproc2: 41000000.r5f is available [ 5.544627] remoteproc remoteproc1: unsupported resource 65538 [ 5.545124] remoteproc remoteproc2: attaching to 41000000.r5f [ 5.550995] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode [ 5.560629] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 5.563344] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b7000000 [ 5.570983] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 5.589025] virtio_rpmsg_bus virtio1: rpmsg host is online [ 5.592532] virtio_rpmsg_bus virtio2: rpmsg host is online [ 5.600206] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7) [ 5.601403] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 5.603812] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7) [ 5.603822] remoteproc remoteproc2: remote processor 41000000.r5f is now attached [ 5.608121] remoteproc remoteproc1: remote processor 65800000.dsp is now attached [ 5.629813] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba000000 [ 5.637504] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 5.654887] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode [ 5.655088] platform 5c00000.r5f: configured R5F for IPC-only mode [ 5.657306] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 5.658430] m_can_platform 40528000.can: m_can device registered (irq=595, version=32) [ 5.668562] m_can_platform 40568000.can: m_can device registered (irq=596, version=32) [ 5.675180] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 5.683544] remoteproc remoteproc3: 66800000.dsp is available [ 5.687682] m_can_platform 26a1000.can: m_can device registered (irq=597, version=32) [ 5.694745] remoteproc remoteproc4: 5c00000.r5f is available [ 5.700159] remoteproc remoteproc3: attaching to 66800000.dsp [ 5.705702] remoteproc remoteproc4: attaching to 5c00000.r5f [ 5.715890] remoteproc remoteproc3: unsupported resource 65538 [ 5.719860] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 5.725054] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode [ 5.730640] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 5.731225] virtio_rpmsg_bus virtio3: rpmsg host is online [ 5.736701] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@ba000000 [ 5.743215] rproc-virtio rproc-virtio.11.auto: registered virtio3 (type 7) [ 5.749914] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 5.754031] virtio_rpmsg_bus virtio4: rpmsg host is online [ 5.754689] rproc-virtio rproc-virtio.10.auto: registered virtio4 (type 7) [ 5.754696] remoteproc remoteproc3: remote processor 66800000.dsp is now attached [ 5.760983] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bd000000 [ 5.765170] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached [ 5.765861] platform 5d00000.r5f: configured R5F for IPC-only mode [ 5.766005] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 5.791237] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode [ 5.801743] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 5.837600] remoteproc remoteproc5: 67800000.dsp is available [ 5.846883] remoteproc remoteproc6: 5d00000.r5f is available [ 5.846944] remoteproc remoteproc6: attaching to 5d00000.r5f [ 5.856686] remoteproc remoteproc5: attaching to 67800000.dsp [ 5.862227] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 5.868094] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 5.868349] remoteproc remoteproc5: unsupported resource 65538 [ 5.868475] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode [ 5.868491] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@bd000000 [ 5.871272] virtio_rpmsg_bus virtio5: rpmsg host is online [ 5.871308] rproc-virtio rproc-virtio.13.auto: registered virtio5 (type 7) [ 5.871314] remoteproc remoteproc5: remote processor 67800000.dsp is now attached [ 5.873261] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 5.875564] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 5.881048] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 5.915450] virtio_rpmsg_bus virtio6: rpmsg host is online [ 5.916039] cdns-csi2rx 4524000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 5.920505] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 5.923162] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd [ 5.929981] rproc-virtio rproc-virtio.12.auto: registered virtio6 (type 7) [ 5.935711] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 5.948042] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached [ 5.952771] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 5.966426] platform 5e00000.r5f: configured R5F for IPC-only mode [ 6.035776] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 6.035968] scsi host0: ufshcd [ 6.051339] remoteproc remoteproc7: 5e00000.r5f is available [ 6.059932] remoteproc remoteproc7: attaching to 5e00000.r5f [ 6.066090] platform 5e00000.r5f: R5F core initialized in IPC-only mode [ 6.072723] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 6.083629] virtio_rpmsg_bus virtio7: rpmsg host is online [ 6.089191] rproc-virtio rproc-virtio.14.auto: registered virtio7 (type 7) [ 6.090920] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd [ 6.096083] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached [ 6.110616] platform 5f00000.r5f: configured R5F for IPC-only mode [ 6.117023] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 6.125318] scsi 0:0:0:49488: Well-known LUN MICRON MT128GASAO4U21 0202 PQ: 0 ANSI: 6 [ 6.131949] remoteproc remoteproc8: 5f00000.r5f is available [ 6.141942] scsi 0:0:0:49476: Well-known LUN MICRON MT128GASAO4U21 0202 PQ: 0 ANSI: 6 [ 6.146272] remoteproc remoteproc8: attaching to 5f00000.r5f [ 6.155630] scsi 0:0:0:49456: Well-known LUN MICRON MT128GASAO4U21 0202 PQ: 0 ANSI: 6 [ 6.160643] platform 5f00000.r5f: R5F core initialized in IPC-only mode [ 6.175363] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 6.186225] virtio_rpmsg_bus virtio8: rpmsg host is online [ 6.193212] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd [ 6.196781] rproc-virtio rproc-virtio.15.auto: registered virtio8 (type 7) [ 6.212149] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached [ 6.221465] platform 5900000.r5f: configured R5F for IPC-only mode [ 6.231617] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000 [ 6.241559] remoteproc remoteproc9: 5900000.r5f is available [ 6.247314] remoteproc remoteproc9: attaching to 5900000.r5f [ 6.253462] platform 5900000.r5f: R5F core initialized in IPC-only mode [ 6.265274] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000 [ 6.276635] virtio_rpmsg_bus virtio9: rpmsg host is online [ 6.282158] rproc-virtio rproc-virtio.16.auto: registered virtio9 (type 7) [ 6.283462] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd [ 6.289032] remoteproc remoteproc9: remote processor 5900000.r5f is now attached [ 6.301039] j721e-pcie-host 2900000.pcie: PCI host bridge to bus 0000:00 [ 6.303551] platform 5a00000.r5f: configured R5F for IPC-only mode [ 6.310274] pci_bus 0000:00: root bus resource [bus 00-ff] [ 6.316538] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000 [ 6.321809] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 6.321816] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 6.331559] remoteproc remoteproc10: 5a00000.r5f is available [ 6.340353] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 6.347225] remoteproc remoteproc10: attaching to 5a00000.r5f [ 6.352918] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 6.359227] platform 5a00000.r5f: R5F core initialized in IPC-only mode [ 6.364752] pci 0000:00:00.0: supports D1 [ 6.374282] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000 [ 6.380871] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 6.385341] virtio_rpmsg_bus virtio10: rpmsg host is online [ 6.391824] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd [ 6.392170] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 6.392386] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 6.392747] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 6.392968] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 6.393204] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15 [ 6.393283] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 6.393436] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15 [ 6.393792] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15 [ 6.393933] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15 [ 6.394226] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15 [ 6.394648] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 6.397873] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 6.400681] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe [ 6.400779] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe [ 6.400812] rproc-virtio rproc-virtio.17.auto: registered virtio10 (type 7) [ 6.400818] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached [ 6.406588] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 6.413593] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe [ 6.420613] pci 0000:00:00.0: PCI bridge to [bus 01] [ 6.427900] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe [ 6.435282] pcieport 0000:00:00.0: PME: Signaling with IRQ 608 [ 6.442078] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 6.449413] pcieport 0000:00:00.0: AER: enabled with IRQ 608 [ 6.456384] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 6.470650] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 6.478170] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 6.484896] j721e-pcie-host 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 6.492722] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe [ 6.500339] j721e-pcie-host 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 6.525517] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x1e [ 6.529719] j721e-pcie-host 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 6.540957] virtio_rpmsg_bus virtio3: creating channel rpmsg-kdrv addr 0x1a [ 6.646539] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 6.659359] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2 [ 6.670220] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 15/Sep/2023 SHA: [ 6.680283] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2 [ 6.690915] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 15/Sep/2023 SHA: [ 6.706226] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:114 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0 [ 6.729927] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: virt_cpsw_nuss mac loaded [ 6.740423] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:114 tx_psil_dst_id:4A00 mac_only:0 [ 6.754401] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1 [ 6.756942] j721e-pcie-host 2910000.pcie: Link up [ 6.766748] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:115 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1 [ 6.770554] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0001:00 [ 6.794967] pci_bus 0001:00: root bus resource [bus 00-ff] [ 6.800457] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 6.810155] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 6.822302] pci 0001:00:00.0: [104c:b013] type 01 class 0x060400 [ 6.823732] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded [ 6.828385] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 6.836232] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:115 tx_psil_dst_id:4A01 mac_only:1 [ 6.846025] pci 0001:00:00.0: supports D1 [ 6.858449] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2 [ 6.862448] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 6.879493] pci 0001:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 6.886362] pci 0001:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 6.898332] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 6.909762] pci 0001:01:00.0: [11ab:0b92] type 00 class 0x020000 [ 6.915836] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit] [ 6.922652] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit] [ 6.929843] pci 0001:01:00.0: supports D1 D2 [ 6.937944] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 6.944649] pci 0001:01:00.0: reg 0x20c: [mem 0x00000000-0x000fffff 64bit] [ 6.951511] pci 0001:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x006fffff 64bit] (contains BAR0 for 7 VFs) [ 6.961278] pci 0001:01:00.0: reg 0x214: [mem 0x00000000-0x00003fff 64bit] [ 6.968148] pci 0001:01:00.0: VF(n) BAR2 space: [mem 0x00000000-0x0001bfff 64bit] (contains BAR2 for 7 VFs) [ 7.417140] audit: type=1334 audit(1651232063.652:4): prog-id=7 op=LOAD [ 7.423836] audit: type=1334 audit(1651232063.656:5): prog-id=8 op=LOAD [ 7.560701] Bluetooth: Core ver 2.22 [ 7.564356] NET: Registered PF_BLUETOOTH protocol family [ 7.569709] Bluetooth: HCI device and connection manager initialized [ 7.576072] Bluetooth: HCI socket layer initialized [ 7.580950] Bluetooth: L2CAP socket layer initialized [ 7.586006] Bluetooth: SCO socket layer initialized [ 7.842479] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 7.854730] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 7.971214] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started [ 7.986240] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac0: virt_cpsw_nuss mac started [ 8.007421] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.016738] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode [ 8.039388] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.048868] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 8.105013] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 8.111666] pci 0001:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit] [ 8.118971] pci 0001:00:00.0: BAR 14: assigned [mem 0x19400000-0x19cfffff] [ 8.125837] pci 0001:01:00.0: BAR 0: assigned [mem 0x19400000-0x194fffff 64bit] [ 8.133162] pci 0001:01:00.0: BAR 7: assigned [mem 0x19500000-0x19bfffff 64bit] [ 8.140471] pci 0001:01:00.0: BAR 2: assigned [mem 0x19c00000-0x19c03fff 64bit] [ 8.147793] pci 0001:01:00.0: BAR 9: assigned [mem 0x19c04000-0x19c1ffff 64bit] [ 8.155102] pci 0001:00:00.0: PCI bridge to [bus 01] [ 8.160062] pci 0001:00:00.0: bridge window [mem 0x19400000-0x19cfffff] [ 8.167088] pcieport 0001:00:00.0: enabling device (0000 -> 0002) [ 8.173459] pcieport 0001:00:00.0: PME: Signaling with IRQ 616 [ 8.179503] pcieport 0001:00:00.0: AER: enabled with IRQ 616 [ 8.756145] audit: type=1334 audit(1651232064.988:6): prog-id=9 op=LOAD [ 8.762811] audit: type=1334 audit(1651232064.996:7): prog-id=10 op=LOAD [ 9.015163] audit: type=1006 audit(1651232065.248:8): pid=749 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 9.027718] audit: type=1300 audit(1651232065.248:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdcfce9c8 a2=4 a3=ffffa0582020 items=0 ppid=1 pid=749 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 9.054227] audit: type=1327 audit(1651232065.248:8): proctitle="(systemd)" [ 9.417185] audit: type=1006 audit(1651232065.652:9): pid=738 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 9.429558] audit: type=1300 audit(1651232065.652:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffdcfce9c8 a2=4 a3=ffffa0582020 items=0 ppid=1 pid=738 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 9.455776] audit: type=1327 audit(1651232065.652:9): proctitle="(weston)" [ 17.107952] audit: type=1006 audit(1651232073.340:10): pid=775 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 17.120337] audit: type=1300 audit(1651232073.340:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffdcfce9c8 a2=1 a3=ffffa0582020 items=0 ppid=1 pid=775 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 17.146636] audit: type=1327 audit(1651232073.340:10): proctitle="(systemd)" [ 17.153691] audit: type=1334 audit(1651232073.352:11): prog-id=11 op=LOAD [ 17.160492] audit: type=1300 audit(1651232073.352:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc64df210 a2=78 a3=0 items=0 ppid=1 pid=775 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 17.185860] audit: type=1327 audit(1651232073.352:11): proctitle="(systemd)" [ 17.192919] audit: type=1334 audit(1651232073.352:12): prog-id=11 op=UNLOAD [ 17.199904] audit: type=1334 audit(1651232073.352:13): prog-id=12 op=LOAD [ 17.206688] audit: type=1300 audit(1651232073.352:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc64df2b0 a2=78 a3=0 items=0 ppid=1 pid=775 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 17.232023] audit: type=1327 audit(1651232073.352:13): proctitle="(systemd)" [ 18.345494] platform a000000.dp-bridge: deferred probe pending [ 18.351335] platform dp0-connector: deferred probe pending [ 18.356814] platform regulator-dp0-prw: deferred probe pending [ 18.362640] platform regulator-dp1-prw: deferred probe pending
