AM625: AM6254- stuck while booting from SD card
Part Number: AM625
Other Parts Discussed in Thread: BEAGL-PLAY-SBC
I was trying to boot the AM6254 processor with SD card as I removed the EMMC permanently. The board I am refering to the beagleplay board as mentioned in thread AM6254 issue with the power up sequence using TPS6521903RHBR.
I select the boot process from SD card while selecting the bootmode as 3-SD Card Debug, the Image I flashed is of beagleplay available on their website https://www.beagleboard.org/distros/beagleplay-debian-12-6-2024-07-04-xfce.
the error is coming out this,
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p3 does not exist. Dropping to a shell!
(initramfs)
I got this while having the console from UART debug pins,
Mohit Sharma
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
3bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[   15.332199] remoteproc remoteproc0: 30074000.pru is available
[   15.339481] remoteproc remoteproc1: 30078000.pru is available
[   15.350603] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[   15.359123] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[   15.368294] platform regulator-5: deferred probe pending
[   15.373656] i2c 2-004c: deferred probe pending
[   15.378114] platform fa00000.mmc: deferred probe pending
[   15.383421] platform 2b300050.target-module: deferred probe pending
[   15.389680] platform 30200000.dss: deferred probe pending
Begin: Running /scripts/local-block ... done.
done.
(initramfs)
                                          done.
(initramfs) sh: 2: done.: not found
(initramfs) Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running sh: 3: Begin:: not found
(initramfs) /scripts/local-premount ... Scanning for Btrfs filesystems
done.
sh: 4: Begin:: not found
(initramfs) sh: 5: done.: not found
(initramfs) Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
Begin: Running /scripts/losh: 6: Begin:: not found
(initramfs) cal-block ... done.
Begin: Running /scripts/local-block ... donesh: 7: Begin:: not found
(initramfs) .
Begin: Running sh: 8: Begin:: not found
(initramfs) /scripts/local-block ... done.
Begin: Running /ssh: 9: Begin:: not found
(initramfs) cripts/local-block ... done.
Begin: Running /scripts/local-blocksh: 10: Begin:: not found
(initramfs)  ... done.
Beginsh: 11: Begin:: not found
(initramfs) : Running /scripts/local-block ... done.
Begin: sh: 12: Begin:: not found
(initramfs) Running /scripts/local-block ... done.
Begin: Running /scripts/losh: 13: Begin:: not found
[   15.314149] OF: graph: no port node foundsh: 14: Begin:: not found
(initramfs)  in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[   15.322602sh: 15: [: missing ]
(initramfs) ] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[   15.332199] remoteproc remoteproc0: 30074000sh: 16: [: missing ]
(initramfs) .pru is available
[   15.339481] remoteproc remoteproc1: 3007800sh: 17: [: missing ]
(initramfs) 0.pru is available
[   15.350603] OF: graph: no port node found ish: 18: [: missing ]
(initramfs) n /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[   15.359123] sh: 19: [: missing ]
(initramfs) OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[sh: 20: [: missing ]
(initramfs)    15.368294] platform regulator-5: deferred probe pending
[   1sh: 21: [: missing ]
(initramfs) 5.373656] i2c 2-004c: deferred probe pending
[  sh: 22: [: missing ]
(initramfs)  15.378114] platform fa00000.mmc: deferred probe pending
[   15.3sh: 23: [: missing ]
(initramfs) 83421] platform 2b300050.target-module: deferred probe pending
[sh: 24: [: missing ]
(initramfs)    15.389680] platform 30200000.dss: deferred probe pending
Begish: 25: [: missing ]
(initramfs) n: Running /scripts/local-block ... done.
Begin: Running /scriptssh: 26: Begin:: not found
(initramfs) /local-block ... done.
Begin: Running /scripts/local-block ... dsh: 27: Begin:: not found
(initramfs) one.
Begin: Runnsh: 28: Begin:: not found
(initramfs) ing /scripts/local-block ... done.
Begin: Runninsh: 29: Begin:: not found
(initramfs) g /scripts/local-block ... done.
Begin: Running /scripts/local-blsh: 30: Begin:: not found
(initramfs) ock ... done.
Besh: 31: Begin:: not found
(initramfs) gin: Running /scripts/local-block ... done.
Begish: 32: Begin:: not found
Begin: Running /scriptsh: 33: Begin:: not found
(initramfs) s/local-block ... done.
Begin: Running /scripts/local-block ... dsh: 34: Begin:: not found
(initramfs) one.
Begin: Runnsh: 35: Begin:: not found
Begin: Runninsh: 36: Begin:: not found
Begin: Running /scripts/local-bsh: 37: Begin:: not found
(initramfs) lock ... done.
Besh: 38: Begin:: not found
Begish: 39: Begin:: not found
Begin: Running /scriptsh: 40: Begin:: not found
Begin: Running /scripts/local-block ... sh: 41: Begin:: not found
(initramfs) done.
Begin: Runnsh: 42: Begin:: not found
Begin: Runninsh: 43: Begin:: not found
Begin: Running /scripts/local-bsh: 44: Begin:: not found
Bsh: 45: Begin:: not found
(initramfs) egin: Running /scripts/local-block ... done.
Begsh: 46: Begin:: not found
(initramfs) in: Running /scripts/local-block ... done.
done.
Gave up waiting sh: 47: Begin:: not found
(initramfs) sh: 48: done.: not found
(initramfs) for root file system device.  Common problems:
 - Boot args (catsh: 49: Gave: not found
(initramfs)  /proc/cmdline)
sh: 50: Syntax error: "(" unexpected
(initramfs)    - Check rootdelay= (did the system wait long enough?)
 - Missish: 50: Syntax error: "(" unexpected
(initramfs) ng modules (cat /proc/modules; ls /dev)
ALERT!  sh: 50: Syntax error: "(" unexpected
(initramfs) /dev/mmcblk1p3 does not exist.  Dropping to a shell!
(initramfs)sh: 50: ALERT!: not found
(initramfs)
sh: 51: initramfs: not found
(initramfs)
                                          done.
(initramfs) sh: 53: done.: not found
Beg(initramfs) in: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premsh: 54: Begin:: not found
(initramfs) ount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for sh: 55: Begin:: not found
(initramfs) sh: 56: done.: not found
(initramfs) root file system ... Begin: Running /scripts/local-block ... done.
Begin: Runninsh: 57: Begin:: not found
Begin: Running sh: 58: Begin:: not found
Begin: Running /scripts/local-blocsh: 59: Begin:: not found
(initramfs) k ... done.
Begish: 60: Begin:: not found
Begin:sh: 61: Begin:: not found
Begin: Running /scripts/sh: 62: Begin:: not found
(initramfs) local-block ... done.
Begin: Running /scripts/local-block ... donsh: 63: Begin:: not found
(initramfs) e.
Begin: Runninsh: 64: Begin:: not found
[   15.314149] sh: 65: Begin:: not found
(initramfs) OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[sh: 66: [: missing ]
(initramfs)    15.322602] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[   15.332199] remsh: 67: [: missing ]
(initramfs) oteproc remoteproc0: 30074000.pru is available
[   15.339481] resh: 68: [: missing ]
(initramfs) moteproc remoteproc1: 30078000.pru is available
[   15.350603] OFsh: 69: [: missing ]
(initramfs) : graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[ sh: 70: [: missing ]
(initramfs)   15.359123] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[   15.368294] platfsh: 71: [: missing ]
(initramfs) orm regulator-5: deferred probe pending
[   15.373656] i2c 2-004sh: 72: [: missing ]
(initramfs) c: deferred probe pending
[   15.378114] platform fa00000.mmc: dsh: 73: [: missing ]
(initramfs) eferred probe pending
[   15.383421] platform 2b300050.target-modsh: 74: [: missing ]
(initramfs) ule: deferred probe pending
[   15.389680] platform 30200000.dsssh: 75: [: missing ]
(initramfs) : deferred probe pending
Begin: Running /scripts/local-block ...sh: 76: [: missing ]
(initramfs)  done.
Begin: Runsh: 77: Begin:: not found
(initramfs) ning /scripts/local-block ... done.
Begin: Runnish: 78: Begin:: not found
(initramfs) ng /scripts/local-block ... done.
Begin: Running /scripts/local-sh: 79: Begin:: not found
(initramfs) block ... done.
sh: 80: Begin:: not found
(initramfs) Begin: Running /scripts/local-block ... done.
Besh: 81: Begin:: not found
Begin: Running /scripsh: 82: Begin:: not found
(initramfs) ts/local-block ... done.
Begin: Running /scripts/local-block ...sh: 83: Begin:: not found
(initramfs)  done.
Begin: Rush: 84: Begin:: not found
(initramfs) nning /scripts/local-block ... done.
Begin: Runnsh: 85: Begin:: not found
Begin: Running /scripts/local-sh: 86: Begin:: not found
sh: 87: Begin:: not found
Besh: 88: Begin:: not found
Begin: Running /scrish: 89: Begin:: not found
(initramfs) pts/local-block ... done.
Begin: Running /scripts/local-block ...sh: 90: Begin:: not found
(initramfs)  done.
Begin: Rush: 91: Begin:: not found
Begin: Runnsh: 92: Begin:: not found
Begin: Running /scripts/localsh: 93: Begin:: not found
(initramfs) -block ... done.
sh: 94: Begin:: not found
Besh: 95: Begin:: not found
Begin: Running /scrish: 96: Begin:: not found
Begin: Running /scripts/local-block ..sh: 97: Begin:: not found
(initramfs) . done.
done.
Gavsh: 98: Begin:: not found
(initramfs) sh: 99: done.: not found
(initramfs) e up waiting for root file system device.  Common problems:
 - Bsh: 100: Gave: not found
(initramfs) oot args (cat /proc/cmdline)
   - Check rootdelash: 101: Syntax error: "(" unexpected
(initramfs) y= (did the system wait long enough?)
 - Missing modules (cat /psh: 101: Syntax error: "(" unexpected
(initramfs) roc/modules; ls /dev)
ALERT!  /dev/mmcblk1p3 does not exist.  Drosh: 101: Syntax error: "(" unexpected
(initramfs) pping to a shell!
(initramfs)
sh: 101: ALERT!: not found
(initramfs) sh: 102: initramfs: not found
(initramfs)
                                          done.
(initramfs) sh: 104: done.: not found
Begin: Running /scripts/local-premsh: 105: Begin:: not found
done.
Begin: Waiting forsh: 106: Begin:: not found
(initramfs) sh: 107: done.: not found
Begin: Runninsh: 108: Begin:: not found
Begin: Running sh: 109: Begin:: not found
Begin: Running /scripts/local-blosh: 110: Begin:: not found
(initramfs) ck ... done.
Begish: 111: Begin:: not found
Begin:sh: 112: Begin:: not found
Begin: Running /scripts/sh: 113: Begin:: not found
Begin: Running /scripts/local-block ... donsh: 114: Begin:: not found
(initramfs) e.
Begin: Runninsh: 115: Begin:: not found
[   15.314149] sh: 116: Begin:: not found
[sh: 117: [: missing ]
[   15.332199] remsh: 118: [: missing ]
[   15.339481] resh: 119: [: missing ]
[   15.350603] OFsh: 120: [: missing ]
[ sh: 121: [: missing ]
[   15.368294] platfsh: 122: [: missing ]
[   15.373656] i2c 2-004sh: 123: [: missing ]
[   15.378114] platform fa00000.mmc: dsh: 124: [: missing ]
[   15.383421] platform 2b300050.target-modsh: 125: [: missing ]
[   15.389680] platform 30200000.dsssh: 126: [: missing ]
Begin: Running /scripts/local-block ...sh: 127: [: missing ]
(initramfs)  done.
Begin: Runsh: 128: Begin:: not found
Begin: Runnish: 129: Begin:: not found
Begin: Running /scripts/local-sh: 130: Begin:: not found
sh: 131: Begin:: not found
Besh: 132: Begin:: not found
Begin: Running /scripsh: 133: Begin:: not found
Begin: Running /scripts/local-block ...sh: 134: Begin:: not found
(initramfs)  done.
Begin: Rush: 135: Begin:: not found
Begin: Runnsh: 136: Begin:: not found
Begin: Running /scripts/local-sh: 137: Begin:: not found
sh: 138: Begin:: not found
Besh: 139: Begin:: not found
Begin: Running /scrish: 140: Begin:: not found
Begin: Running /scripts/local-block ...sh: 141: Begin:: not found
(initramfs)  done.
Begin: Rush: 142: Begin:: not found
Begin: Runnsh: 143: Begin:: not found
Begin: Running /scripts/localsh: 144: Begin:: not found
sh: 145: Begin:: not found
Besh: 146: Begin:: not found
Begin: Running /scrish: 147: Begin:: not found
Begin: Running /scripts/local-block ..sh: 148: Begin:: not found
(initramfs) . done.
done.
Gavsh: 149: Begin:: not found
(initramfs) sh: 150: done.: not found
 - Bsh: 151: Gave: not found
   - Check rootdelash: 152: Syntax error: "(" unexpected
 - Missing modules (cat /psh: 152: Syntax error: "(" unexpected
ALERT!  /dev/mmcblk1p3 does not exist.  Drosh: 152: Syntax error: "(" unexpected
(initramfs)
sh: 152: ALERT!: not found
(initramfs) sh: 153: initramfs: not found
(initramfs) (initramfs) pts/local-block ... done.
Begin: Runnsh: 154: Syntax error: word unexpected
(initramfs) ing /scripts/local-block ..sh: 148: Begin:: not found
(initramfs) . done.
done.
Gavsh: 149: Begish: 154: Begin:: not found
(initramfs) sh: 155: Syntax error: word unexpected
(initramfs) sh: 155: done.: not found
(initramfs) n:: not found
(ish: 156: Gavsh:: not found
(initramfs) sh: 157: Syntax error: word unexpected
(initramfs) nitramfs) e up waiting for root file system device.  Common problems:
 - Bsh: 151sh: 157: Syntax error: word unexpected
(initramfs) : Gave: not found
(initramfs) oot args (cat /prosh: 157: -: not found
(initramfs) c/cmdline)
   - sh: 158: Syntax error: word unexpected
(initramfs) Check rootdelash: 152: Syntax error: "(" unexpected
(initramfs) ysh: 158: -: not found
(initramfs) = (did the system wait long enough?)
 - Missing sh: 159: Syntax error: word unexpected
(initramfs) modules (cat /psh: 152: Syntax error: "(" unexpected
(initramfs)sh: 159: Syntax error: "(" unexpected
ALERT!  /dev/mmcblk1p3 does not exist.  Dsh: 159: Syntax error: word unexpected
(initramfs) rosh: 152: Syntax error: "(" unexpected
(initramfs) pping to a shsh: 159: ALERT!: not found
(initramfs) ell!
(initramfs)sh: 160: Syntax error: word unexpected
(initramfs)
(initramfs) sh: 153:sh: 160: initramfs: not found
(initramfs) sh: 161: sh:: not found
(initramfs)  initramfs: not found
(initramfs)
sh: 162: Syntax error: word unexpected
(initramfs) sh: 162: initramfs: not found
(initramfs) ^C
  • For future readers, Mohit is NOT using a TI EVM, or a beaglebone EVM for this output. They are using a custom board.
    Hello Mohit,
    First, to set support expectations: TI does not design the beaglebone boards, or release the beaglebone software. If you have questions about Beaglebone hardware or software, you need to reach out to the beaglebone community, not TI. We have not tested the beaglebone software that you are using, so we cannot comment on how it works.
    Second, you have attached the terminal output starting 15 seconds after boot begins. Please attach the full boot log.
    Nick
  • Hello Nick,
    I will be using a BEAGL-PLAY-SBC(https://www.ti.com/tool/BEAGL-PLAY-SBC) as a reference as my board is a copy of it.
    I will be attaching the full log of my SBC please review it.
    Additionally, I have removed the EMMC and booting the board from SD card by pressing the USR button on beagleplay.
    Thanks and Regards
    Mohit
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.08.20 11:03:14 =~=~=~=~=~=~=~=~=~=~=~=
    U-Boot SPL 2024.07-rc5-00001-gc53b3444 (Jun 25 2024 - 20:52:00 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    Changed A53 CPU frequency to 1250000000Hz (T grade) in DT
    SPL initial stack usage: 13400 bytes
    Trying to boot from MMC2
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.11.0(release):d1c75f1
    NOTICE:  BL31: Built : 20:52:00, Jun 25 2024
    I/TC:
    I/TC: OP-TEE version: 4.2.0 (gcc version 12.2.0 (Debian 12.2.0-14)) #1 Tue Jun 25 20:52:00 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    SPL initial stack usage: 1760 bytes
    U-Boot 2024.07-rc5-00001-gc53b3444 (Jun 25 2024 - 20:52:00 +0000)
    SoC:   AM62X SR1.0 GP
    Model: BeagleBoard.org BeaglePlay
    DRAM:  2 GiB
    Core:  99 devices, 28 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
    am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
    No ethernet found.
    Press SPACE to abort autoboot in 2 seconds
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'uEnv.txt'
    Scanning for bootflows in all bootdevs
    Seq  Method       State   Uclass    Part  Name                      Filename
    Scanning bootdev 'mmc@fa00000.bootdev':
      0  extlinux     ready   mmc          1  mmc@fa00000.bootdev.part_ /extlinux/extlinux.conf
    ** Booting bootflow 'mmc@fa00000.bootdev.part_1' with extlinux
    BeaglePlay microSD (extlinux.conf) (swap enabled)
    1:	microSD disable BCFSERIAL
    2:	copy microSD to eMMC
    3:	microSD (debug)
    4:	microSD (default)
    Enter choice: 4:	microSD (default)
    Retrieving file: /Image
    Retrieving file: /initrd.img
    append: root=/dev/mmcblk1p3 ro rootfstype=ext4 resume=/dev/mmcblk1p2 rootwait net.ifnames=0 quiet
    Retrieving file: /ti/k3-am625-beagleplay.dtb
    Working FDT set to 88000000
       Loading Ramdisk to 8e999000, end 8ffff451 ... OK
       Loading Device Tree to 000000008e987000, end 000000008e998c3d ... OK
    Working FDT set to 8e987000
    Starting kernel ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.143016] omap-mailbox 29000000.mailbox: no available mbox devices found
    [    2.346210] tps65219 0-0030: Failed to read device ID: -121
    [    2.389630] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.398138] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.480151] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.529931] mikrobus mikrobus-0: failed to get w1_bus_master
    [    2.538281] bq32k 0-0068: hctosys: unable to read the hardware clock
    [    2.546329] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.554754] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.771881] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.780307] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.791237] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.799654] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.814515] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.822917] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [-1;-1f[   13.023199] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [   13.031666] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    Gave up waiting for suspend/resume device
    (initramfs)
  • Hello Mohit,
    I am not sure what to make of your terminal output. I am passing your thread to a team member more familiar with Debian. Feel free to ping the thread if you do not get a response within a couple of business days.
    Nick
  • Hi Mohit,
    While I went through your previous e2e thread and this one, I understand you copied the BeaglePlay design but had power problem on eMMC, so now the eMMC device is removed from your board.
    As Nick said, we only provide support based on TI Processor SDK, won't be able to support the open source community software. But from the console log you provided, I think this is what happens:
    The log line 106: ALERT!  /dev/mmcblk1p3 does not exist.  Dropping to a shell!
    and log line 63: append: root=/dev/mmcblk1p3 ro rootfstype=ext4 resume=/dev/mmcblk1p2 rootwait net.ifnames=0 quiet
    This configures the root filesystem on the SD card (/dev/mmcblk1). However now since the eMMC is removed, the SD card device name is no longer "/dev/mmcblk1", it should be "/dev/mmcblk0" now. Then Linux is unable to find and mount the root filesystem.
    I don't use the open source software on BeaglePlay, but I think this is how to resolve the issue:
    If you attach the SD card to a PC (Linux PC is preferred), the SD card first partition should have a file called /extlinux/extlinux.conf.
    Open this file, it should have a line as below (or similar).
        APPEND root=/dev/mmcblk1p3 ro rootfstype=ext4 resume=/dev/mmcblk1p2
    Modify the word "mmcblk1" to "mmcblk0" (change "1" to "0") in all instances. Then save the file and try to boot it on your board to see if it resolves the problem.
  • Hi Bin Liu,
    thanks for the feedback will try this.
    Additionally just wanted to provide you some information that when it drops to the shell at (initramfs) I have tried multiple things like
    (initramfs) ls /dev/mmc*,   but i am not able to see the directory related to this and when I tried
    (initramfs) ls /dev,     there is no content related to the mmcblk
    (initramfs) mmc info, no directory found
    When I tried to boot the beagleplay without pressing boot button it shows me the AM62xDFU maybe because there is no emmc on board.
    Please let me know if you have some OS image to flash with SD card only on Beagleplay board.
    thanks & Regards
    Mohit
  • Hi Mohit,
    Typically initramfs is very minimal, it doesn't provide kernel drivers to enable most peripherals. So it is normal that you don't see mmcblk nodes here.
    I guess so, it is up to how the board bootmode is configured.
    Let's do the extlinux.conf fix first, since it is a simple step. If it doesn't fix the boot issue, I will point you to the TI Processor SDK.
  • hi Bin Liu,
    I tested by modifying the extlinux.config file but the output remains same. I will be attaching the extlinux.comfig file and the current log after modifying.
    menu title BeaglePlay microSD (extlinux.conf) (swap enabled)
    timeout 50
    default microSD (default)
    label microSD disable BCFSERIAL
        kernel /Image
        append root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0
        fdtdir /
        fdtoverlays /overlays/k3-am625-beagleplay-bcfserial-no-firmware.dtbo
        initrd /initrd.img
    label copy microSD to eMMC
        kernel /Image
        append root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0 init=/usr/sbin/init-beagle-flasher
        fdtdir /
        initrd /initrd.img
    label microSD (debug)
        kernel /Image
        append console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0
        fdtdir /
        #fdtoverlays /overlays/<file>.dtbo
        initrd /initrd.img
    label microSD (default)
        kernel /Image
        append root=/dev/mmcblk0p3 ro rootfstype=ext4 resume=/dev/mmcblk0p2 rootwait net.ifnames=0 quiet
        fdtdir /
        initrd /initrd.img
    I/TC:
    SoC:   AM62X SR1.0 GP
    DRAM:  2 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    No ethernet found.
    3:	microSD (debug)
    Enter choice: 4
    append: root=/dev/mmcblk0p3 ro rootfstype=ext4 resume=/dev/mmcblk0p2 rootwait net.ifnames=0 quiet
    Starting kernel ...
    [    0.142640] omap-mailbox 29000000.mailbox: no available mbox devices found
    [    2.345799] tps65219 0-0030: Failed to read device ID: -121
    [    2.389069] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.397564] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.479624] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.529017] mikrobus mikrobus-0: failed to get w1_bus_master
    [    2.537396] bq32k 0-0068: hctosys: unable to read the hardware clock
    [    2.545335] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.553782] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.771290] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.779723] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.790829] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.799270] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.810338] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.818744] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.829817] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.838278] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [-1;-1f[   13.024089] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [   13.032530] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    ALERT!  /dev/mmcblk0p3 does not exist.  Dropping to a shell!
    (initramfs)
    For your reference below will be attaching the log which is of market purchased beagleplay.
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.08.20 11:07:46 =~=~=~=~=~=~=~=~=~=~=~=
    I/TC:
    SoC:   AM62X SR1.0 GP
    DRAM:  2 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    No ethernet found.
    3:	microSD (debug)
    Enter choice: 4
    Starting kernel ...
    [    2.390587] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.399085] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.479436] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.529015] mikrobus mikrobus-0: failed to get w1_bus_master
    [    2.537479] bq32k 0-0068: hctosys: unable to read the hardware clock
    [    2.599846] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.608276] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [-1;-1ftrap: EXIT: bad trap
    [  OK  ] Finished console-setup.service - Set console font and keymap.
    [  OK  ] Finished ufw.service - Uncomplicated firewall.
    [  OK  ] Reached target network-pre.target - Preparation for Network.
             Starting systemd-networkd.service - Network Configuration...
             Mounting proc-sys-fs-binfmt_misc.m…cutable File Formats File System...
    [  OK  ] Mounted proc-sys-fs-binfmt_misc.mo…xecutable File Formats File System.
    [  OK  ] Finished systemd-binfmt.service - Set Up Additional Binary Formats.
    [  OK  ] Finished systemd-tmpfiles-setup.se…ate Volatile Files and Directories.
             Starting systemd-resolved.service - Network Name Resolution...
             Starting systemd-timesyncd.service - Network Time Synchronization...
             Starting systemd-update-utmp.servi…ord System Boot/Shutdown in UTMP...
    [  OK  ] Finished apparmor.service - Load AppArmor profiles.
             Starting networking.service - Raise network interfaces...
    [  OK  ] Finished systemd-update-utmp.servi…ecord System Boot/Shutdown in UTMP.
    [  OK  ] Started systemd-networkd.service - Network Configuration.
    [  OK  ] Started systemd-timesyncd.service - Network Time Synchronization.
    [  OK  ] Reached target time-set.target - System Time Set.
    [  OK  ] Finished networking.service - Raise network interfaces.
    [  OK  ] Reached target usb-gadget.target - Hardware activated USB gadget.
    [  OK  ] Listening on systemd-rfkill.socket…ll Switch Status /dev/rfkill Watch.
    (K[  OK  ] Started systemd-resolved.service - Network Name Resolution.
    [  OK  ] Reached target nss-lookup.target - Host and Network Name Lookups.
    [  OK  ] Reached target sysinit.target - System Initialization.
    [  OK  ] Started apt-daily.timer - Daily apt download activities.
    [  OK  ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities.
    [  OK  ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
    [  OK  ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems.
    [  OK  ] Started fstrim.timer - Discard unused blocks once a week.
    [  OK  ] Started logrotate.timer - Daily rotation of log files.
    [  OK  ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
    [  OK  ] Reached target timers.target - Timer Units.
    [  OK  ] Listening on avahi-daemon.socket -…DNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on dbus.socket - D-Bus System Message Bus Socket.
             Starting docker.socket - Docker Socket for the API...
    [  OK  ] Listening on gpsd.socket - GPS (Gl…Positioning System) Daemon Sockets.
    [  OK  ] Listening on docker.socket - Docker Socket for the API.
    [  OK  ] Reached target sockets.target - Socket Units.
    [  OK  ] Reached target basic.target - Basic System.
             Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack...
             Starting bb-symlinks.service - BeagleBoard Generate Symlinks...
             Starting bb-usb-gadgets.service - BeagleBoard.org USB gadgets...
             Starting bbbio-set-sysconf.service…oard Set up system configuration...
             Starting beagle-camera-setup.service - BeagleBoard Camera Setup...
    [  OK  ] Started cron.service - Regular background program processing daemon.
             Starting dbus.service - D-Bus System Message Bus...
             Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots...
             Starting iwd.service - Wireless service...
    [  OK  ] Started mender-client.service - Mender OTA update service.
             Starting systemd-logind.service - User Login Management...
             Starting udisks2.service - Disk Manager...
    [  OK  ] Finished bb-symlinks.service - BeagleBoard Generate Symlinks.
    [  OK  ] Finished beagle-camera-setup.service - BeagleBoard Camera Setup.
             Starting alsa-restore.service - Save/Restore Sound Card State...
    [  OK  ] Finished alsa-restore.service - Save/Restore Sound Card State.
    [  OK  ] Reached target sound.target - Sound Card.
    [  OK  ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots.
    [  OK  ] Found device dev-ttyGS0.device - /dev/ttyGS0.
    [  OK  ] Started dbus.service - D-Bus System Message Bus.
    [  OK  ] Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
             Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
    [  OK  ] Started systemd-logind.service - User Login Management.
    [  OK  ] Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
    [  OK  ] Started iwd.service - Wireless service.
    [  OK  ] Reached target network.target - Network.
    [  OK  ] Reached target network-online.target - Network is Online.
    [   12.769454] bbbio-set-sysconf[651]: Reading the system configuration settings from /boot/firmware/sysconf.txt
             Starting code-server@debian.service - code-server...
             Starting containerd.service - containerd container runtime...
             Starting nginx.service - A high pe…erver and a reverse proxy server...
             Starting ssh.service - OpenBSD Secure Shell server...
             Starting systemd-user-sessions.service - Permit User Sessions...
    [  OK  ] Started unattended-upgrades.service - Unattended Upgrades Shutdown.
    [  OK  ] Finished bbbio-set-sysconf.service…eBoard Set up system configuration.
    [  OK  ] Finished systemd-user-sessions.service - Permit User Sessions.
             Starting plymouth-quit-wait.servic…d until boot process finishes up...
             Starting plymouth-quit.service - Terminate Plymouth Boot Screen...
             Starting polkit.service - Authorization Manager...
    Debian GNU/Linux 12 BeaglePlay ttyS2
    BeagleBoard.org Debian Bookworm Xfce Image 2024-06-25
    Support: https://bbb.io/debian
    default username is [debian] with a one time password of [temppwd]
    BeaglePlay login:
    Thanks and Regards
    Mohit
  • Hi Bin,
    Additionally I will be attaching the microSD card Debug logs.
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.08.22 15:08:04 =~=~=~=~=~=~=~=~=~=~=~=
    I/TC:
    SoC:   AM62X SR1.0 GP
    DRAM:  2 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    No ethernet found.
    3:	microSD (debug)
    Enter choice: 3
    3:	microSD (debug)
    append: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.32-ti-arm64-r5 (voodoo@rpi5b8g-65) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Mon Jun 24 23:05:35 UTC 2024
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: BeagleBoard.org BeaglePlay
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x000000009ca00000..0x000000009cafffff (1024 KiB) map non-reusable ramoops@9ca00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-dma-memory@9db00000
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009dafffff]
    [    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 144 MiB at 0x00000000f4a00000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 31 pages/cpu s87848 r8192 d30936 u126976
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait net.ifnames=0
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000f0800000-0x00000000f4800000] (64MB)
    [    0.000000] Memory: 95376K/2097152K available (18944K kernel code, 2936K rwdata, 5528K rodata, 6784K init, 870K bss, 203684K reserved, 147456K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 59186 entries in 232 pages
    [    0.000000] ftrace: allocated 232 pages with 4 groups
    [    0.000000] trace event string verifier disabled
    [    0.000000] Dynamic Preempt: voluntary
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Rude variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080620000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080630000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008783] Console: colour dummy device 80x25
    [    0.013387] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.024071] pid_max: default: 32768 minimum: 301
    [    0.031780] LSM: initializing lsm=capability,landlock,yama,apparmor,tomoyo,bpf,integrity
    [    0.040949] landlock: Up and running.
    [    0.044691] Yama: becoming mindful.
    [    0.048374] AppArmor: AppArmor initialized
    [    0.052567] TOMOYO Linux initialized
    [    0.056237] LSM support for eBPF active
    [    0.061168] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.068756] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.081533] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.088874] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.096615] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.104664] rcu: Hierarchical SRCU implementation.
    [    0.109568] rcu: 	Max phase no-delay instances is 1000.
    [    0.116254] Platform MSI: msi-controller@1820000 domain created
    [    0.122660] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.132114] EFI services will not be available.
    [    0.137231] smp: Bringing up secondary CPUs ...
    [    0.150776] Detected VIPT I-cache on CPU1
    [    0.150876] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.150894] GICv3: CPU1: using allocated LPI pending table @0x0000000080640000
    [    0.150956] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.159962] Detected VIPT I-cache on CPU2
    [    0.160033] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.160049] GICv3: CPU2: using allocated LPI pending table @0x0000000080650000
    [    0.160091] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.169020] Detected VIPT I-cache on CPU3
    [    0.169090] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.169105] GICv3: CPU3: using allocated LPI pending table @0x0000000080660000
    [    0.169145] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.169248] smp: Brought up 1 node, 4 CPUs
    [    0.248965] SMP: Total of 4 processors activated.
    [    0.253775] CPU features: detected: 32-bit EL0 Support
    [    0.259027] CPU features: detected: 32-bit EL1 Support
    [    0.264281] CPU features: detected: CRC32 instructions
    [    0.269620] CPU: All CPU(s) started at EL2
    [    0.273837] alternatives: applying system-wide alternatives
    [    0.325421] node 0 deferred pages initialised in 44ms
    [    0.332703] devtmpfs: initialized
    [    0.347045] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.357117] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.369995] pinctrl core: initialized pinctrl subsystem
    [    0.376019] DMI not present or invalid.
    [    0.381224] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.389517] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.397032] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.405349] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.414442] audit: initializing netlink subsys (disabled)
    [    0.420260] audit: type=2000 audit(0.284:1): state=initialized audit_enabled=0 res=1
    [    0.420890] thermal_sys: Registered thermal governor 'fair_share'
    [    0.428198] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.434429] thermal_sys: Registered thermal governor 'step_wise'
    [    0.440569] thermal_sys: Registered thermal governor 'user_space'
    [    0.446709] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.453217] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.466953] ASID allocator initialised with 65536 entries
    [    0.487470] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-hdmi@4c
    [    0.500794] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-hdmi@4c
    [    0.511744] Modules: 23952 pages in range for non-PLT usage
    [    0.511756] Modules: 515472 pages in range for PLT usage
    [    0.518943] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.531365] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.537778] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.544718] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.551127] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.558066] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.564475] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.571415] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.580896] raid6: skipped pq benchmark and selected neonx8
    [    0.586647] raid6: using neon recovery algorithm
    [    0.592103] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.602586] iommu: Default domain type: Translated
    [    0.607519] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.614796] SCSI subsystem initialized
    [    0.619148] usbcore: registered new interface driver usbfs
    [    0.624795] usbcore: registered new interface driver hub
    [    0.630278] usbcore: registered new device driver usb
    [    0.636077] pps_core: LinuxPPS API ver. 1 registered
    [    0.641157] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.650508] PTP clock support registered
    [    0.654683] scmi_core: SCMI protocol bus registered
    [    0.659898] omap-mailbox 29000000.mailbox: no available mbox devices found
    [    0.668539] NetLabel: Initializing
    [    0.672058] NetLabel:  domain hash size = 128
    [    0.676512] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
    [    0.682373] NetLabel:  unlabeled traffic allowed by default
    [    0.688690] vgaarb: loaded
    [    0.694997] clocksource: Switched to clocksource arch_sys_counter
    [    0.703432] VFS: Disk quotas dquot_6.6.0
    [    0.707588] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.714951] FS-Cache: Loaded
    [    0.718680] CacheFiles: Loaded
    [    0.722460] AppArmor: AppArmor Filesystem Enabled
    [    0.736546] NET: Registered PF_INET protocol family
    [    0.741849] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.752297] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.761191] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.769260] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.777723] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.785710] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.793085] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
    [    0.800911] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.807834] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.815678] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.822388] RPC: Registered named UNIX socket transport module.
    [    0.828476] RPC: Registered udp transport module.
    [    0.833285] RPC: Registered tcp transport module.
    [    0.838093] RPC: Registered tcp-with-tls transport module.
    [    0.843714] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.850330] NET: Registered PF_XDP protocol family
    [    0.855256] PCI: CLS 0 bytes, default 64
    [    0.859695] Trying to unpack rootfs image as initramfs...
    [    0.867548] kvm [1]: IPA Size Limit: 40 bits
    [    0.873414] kvm [1]: vgic-v2@100010000
    [    0.877349] kvm [1]: GIC system register CPU interface enabled
    [    0.883405] kvm [1]: vgic interrupt IRQ9
    [    0.887522] kvm [1]: Hyp mode initialized successfully
    [    1.369795] Initialise system trusted keyrings
    [    1.375183] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    1.382080] zbud: loaded
    [    1.393823] NFS: Registering the id_resolver key type
    [    1.399216] Key type id_resolver registered
    [    1.403542] Key type id_legacy registered
    [    1.407914] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.414862] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.423084] fuse: init (API version 7.39)
    [    1.464035] NET: Registered PF_ALG protocol family
    [    1.469080] xor: measuring software checksum speed
    [    1.477834]    8regs           :  2627 MB/sec
    [    1.486118]    32regs          :  2627 MB/sec
    [    1.494686]    arm64_neon      :  2436 MB/sec
    [    1.499174] xor: using function: 32regs (2627 MB/sec)
    [    1.504411] Key type asymmetric registered
    [    1.508647] Asymmetric key parser 'x509' registered
    [    1.513684] Asymmetric key parser 'pkcs8' registered
    [    1.519167] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    1.527465] io scheduler mq-deadline registered
    [    1.539786] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    1.547347] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    1.561985] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.581522] SPI driver tps6594 has no spi_device_id for ti,tps6594-q1
    [    1.588274] SPI driver tps6594 has no spi_device_id for ti,tps6593-q1
    [    1.595031] SPI driver tps6594 has no spi_device_id for ti,lp8764-q1
    [    1.602958] megasas: 07.725.01.00-rc1
    [    1.615785] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    1.622315] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.628566] sky2: driver version 1.30
    [    1.634860] VFIO - User Level meta-driver version: 0.3
    [    1.641949] usbcore: registered new device driver onboard-usb-hub
    [    1.651854] i2c_dev: i2c /dev entries driver
    [    1.657028] Driver for 1-wire Dallas network protocol.
    [    1.665613] sdhci: Secure Digital Host Controller Interface driver
    [    1.672031] sdhci: Copyright(c) Pierre Ossman
    [    1.677282] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.687122] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.694508] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.702536] hid: raw HID events driver (C) Jiri Kosina
    [    1.708578] usbcore: registered new interface driver usbhid
    [    1.714430] usbhid: USB HID core driver
    [    1.721864] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    1.731815] optee: probing for conduit method.
    [    1.736505] optee: revision 4.2 (12d7c4ee)
    [    1.752956] watchdog: Delayed init of the lockup detector failed: -19
    [    1.753606] optee: dynamic shared memory is enabled
    [    1.757250] watchdog: Hard watchdog permanently disabled
    [    1.764253] optee: initialized driver
    [    1.780402] NET: Registered PF_INET6 protocol family
    [    2.024422] Freeing initrd memory: 22936K
    [    2.080525] Segment Routing with IPv6
    [    2.084414] In-situ OAM (IOAM) with IPv6
    [    2.088682] mip6: Mobile IPv6
    [    2.091792] NET: Registered PF_PACKET protocol family
    [    2.097334] Key type dns_resolver registered
    [    2.101714] mpls_gso: MPLS GSO support
    [    2.116571] registered taskstats version 1
    [    2.121061] Loading compiled-in X.509 certificates
    [    2.138715] Key type .fscrypt registered
    [    2.144125] Key type fscrypt-provisioning registered
    [    2.154768] Btrfs loaded, zoned=yes, fsverity=yes
    [    2.159808] Key type encrypted registered
    [    2.163930] AppArmor: AppArmor sha1 policy hashing enabled
    [    2.169586] ima: No TPM chip found, activating TPM-bypass!
    [    2.175221] ima: Allocated hash algorithm: sha256
    [    2.180082] ima: No architecture policies found
    [    2.184819] evm: Initialising EVM extended attributes:
    [    2.190073] evm: security.selinux
    [    2.193462] evm: security.SMACK64 (disabled)
    [    2.197825] evm: security.SMACK64EXEC (disabled)
    [    2.202545] evm: security.SMACK64TRANSMUTE (disabled)
    [    2.207709] evm: security.SMACK64MMAP (disabled)
    [    2.212427] evm: security.apparmor
    [    2.215903] evm: security.ima
    [    2.218929] evm: security.capability
    [    2.222581] evm: HMAC attrs: 0x1
    [    2.233938] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    [    2.320596] omap_i2c 4900000.i2c: bus 5 rev0.12 at 100 kHz
    [    2.328341] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    2.359050] tps65219 0-0030: Failed to read device ID: -121
    [    2.364922] tps65219: probe of 0-0030 failed with error -121
    [    2.370938] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    2.378203] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    2.385335] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/bridge-hdmi@4c
    [    2.395269] i2c 2-004c: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    2.403008] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    2.410107] omap_i2c 20030000.i2c: bus 3 rev0.12 at 400 kHz
    [    2.416142] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    2.424525] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    2.433807] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    2.444625] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    2.454023] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    2.466320] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    2.478525] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    2.489774] printk: console [ttyS2] disabled
    [    2.494727] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 241, base_baud = 3000000) is a 8250
    [    2.503745] printk: console [ttyS2] enabled
    [    2.512227] printk: bootconsole [ns16550a0] disabled
    [    2.524356] 2850000.serial: ttyS0 at MMIO 0x2850000 (irq = 242, base_baud = 3000000) is a 8250
    [    2.533090] serial serial0: tty port ttyS0 registered
    [    2.538856] omap8250 2860000.serial: PM domain pd:158 will not be powered off
    [    2.546818] 2860000.serial: ttyS1 at MMIO 0x2860000 (irq = 243, base_baud = 3000000) is a 8250
    [    2.555784] serial serial1: tty port ttyS1 registered
    [    2.561971] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.570372] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.582356] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.627006] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.664215] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    2.677376] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.683670] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    2.690798] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    2.697742] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    2.716157] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    2.734186] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    2.739757] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    2.747573] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    2.753580] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
    [    2.763038] xhci-hcd xhci-hcd.0.auto: irq 256, io mem 0x31100000
    [    2.769374] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
    [    2.777645] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.784909] usb usb1: Product: xHCI Host Controller
    [    2.789783] usb usb1: Manufacturer: Linux 6.6.32-ti-arm64-r5 xhci-hcd
    [    2.796215] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    2.801746] hub 1-0:1.0: USB hub found
    [    2.805541] hub 1-0:1.0: 1 port detected
    [    2.812504] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [    2.820975] mmc0: CQHCI version 5.10
    [    2.834313] mikrobus mikrobus-0: registering port mikrobus-0
    [    2.840265] mikrobus mikrobus-0: mikrobus port 0 eeprom empty probing default eeprom
    [    2.848043] mikrobus mikrobus-0: adding lookup table : w1-gpio.0, key: 601000.gpio, hwnum: 13
    [    2.856830] mikrobus mikrobus-0: failed to get w1_bus_master
    [    2.863757] bq32k 0-0068: Oscillator Failure. Check RTC battery.
    [    2.865676] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.870379] bq32k 0-0068: registered as rtc0
    [    2.881873] bq32k 0-0068: hctosys: unable to read the hardware clock
    [    2.889800] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    2.898202] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    2.907922] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.955004] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.128307] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver RTL8211F Gigabit Ethernet
    [    3.137747] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83TD510E
    [    3.148684] mmc2: CQHCI version 5.10
    [    3.150039] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    3.160666] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    3.171859] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    3.180269] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    3.191061] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    3.193628] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    3.206376] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    3.206950] clk: Disabling unused clocks
    [    3.214778] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    3.227495] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
    [    3.229639] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    3.244014] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    3.257037] mmc2: new high speed SDIO card at address 0001
    [    3.261322] Freeing unused kernel memory: 6784K
    [    3.295714] Checked W+X mappings: passed, no W+X pages found
    [    3.301437] Run /init as init process
    Loading, please wait...
    Starting systemd-udevd version 254.5-1~bpo12+3bbbio0~bookworm+20240506
    Begin: Loading essential drivers ... done.
    Begin: Running /scripts/init-premount ... [-1;-1fdone.
    done.
    [   13.241323] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [   13.249782] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [   13.259075] platform fa00000.mmc: deferred probe pending
    [   13.264410] platform regulator-5: deferred probe pending
    [   13.269717] i2c 2-004c: deferred probe pending
    [   13.274157] platform 2b300050.target-module: deferred probe pending
    [   13.280415] platform 30200000.dss: deferred probe pending
    done.
    ALERT!  /dev/mmcblk0p3 does not exist.  Drop^[x		to a shell!
    (initramfs)
    Thanks and regards
    Mohit
  • Hi Mohit,
    The last SD card debug log (SD_debug.txt) shows the SD card is not detected and not enumerated.
    Can please provide the same SD card debug from the unmodified BeaglePlay board for comparison?
  • Hi Bin,
    Below attached is the log for the original beagleplay unmodified.
    SD_log_beagleplay.txt
    Mohit
  • Hi Bin, I got an update its due to RTC I2C lines was not connected with the PMIC which causing the SD card not to detect.
    Now its working thanks for your Help.
  • Hi Mohit,
    Glad the issue is resolved. Thanks for the update.
