Part Number: PROCESSOR-SDK-J721S2
I am working on edgeai-tiovx-apps and for multiple models inference, the application initializes a new dl_block for each model. Each dl_block->output_pad is connected to the output_block->input_pads list that will be later used by mosiac_node to display the results.
I am developing an application on top of edgeai-tiovx-apps in which I am running two models. In this application, I only want to show the output of one model on the display, while just using the inference results of other model. For this, I want to expose the output_pad of dl_block as graph parameter.
Hence, I would like to know how I can expose the dl_block->output_pad as graph parameter in the connect_blocks function in app.c?
Ahmed
