hello everybody,
I'm really appreciate if you help me to fix this: I'm using OpenJDK Zero VM (build 14.0-b16, mixed mode)
for a board using ARMv5 (400MHz) processor.. and i have a lot of Alignment Traps errors (see example below) from the dmesg command.
Do you have any ideas to resolve this problem? I'm not VM expert but i guess there are un-alignment memory access in Openjdk VM and this only supports by the x86 machine?
Thank you very much,
Thanh Le
Alignment trap: java (8338) PC=0x40472f00 Instr=0xe59a5000 Address=0x404f98bd FSR 0x001
Alignment trap: java (8338) PC=0x40472f04 Instr=0xe58a3000 Address=0x404f98bd FSR 0x801
Alignment trap: java (8338) PC=0x40472f0c Instr=0xe58a5000 Address=0x404f98bd FSR 0x801
