PROCESSOR-SDK-J784S4: CddIpc gCslR5MpuCfg Configuration for 1 GB DDR
Part Number: PROCESSOR-SDK-J784S4
Hello TI forum,
I was successfully tested on EVM the CddIPC provided by this example: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1356059/faq-tda4ah-q1-cdd-ipc-app-example-running-on-mcu1_0-communicating-with-another-r5-core. Now, the problem that we have is that on our board we have only a 1GB DDR instead of 4GB as EVM, mapped starting with address 0x80000000. How can I configure the Regions from CddIpcR5Mpu.c ? Where can I find the documentation to explain the Regions defined in gCslR5MpuCfg?
Thank you !
Calin Harangus
  • Thanks for pointing to the example, we will loop in the author of the mentioned thread.
    Kevin
    Even if you change the DDR size the starting address will not be changed from 0x80000000.
    For IPC , what cores you want to communicate with and not ,based on that you can change the reserved memory regions. This will be custom specific and mpu configuration need to done according to freeRTOS standards if you are using freeRTOS OS.
    Tarun Mukesh
  • Hello Tarun,
    I want the IPC for cores mcu1_0 and mcu2_0. Yes, we are using freeRTOS. Anyway, de default configuration that you provided in the example mentioned above, has the IPC Shared Memory at address 0xAC000000 with size CSL_ARM_R5_MPU_REGION_SIZE_32MB. This should fit in our 1 GB. Still the application doesn't start with this configuration. It goes directly to HwiP_prefetch_abort_handler(). Maybe we didn't configured properly our lds file.
    Do you have a hint for us where should we look? Or maybe an example of 1 GB lds file configuration?
    Thank you very much!
    Calin
  • Hello Calin,
    Can you provide me the call stack from where it is going to  HwiP_prefetch_abort_handler().
    We don't have any 1 GB lds file configuration.
    Tarun Mukesh
  • Hi Tarun,
    Here is a snapshot from the callstack:
    Thank you!
    Calin Harangus
  • Hello Calin,
    Thanks for sharing the information.
    It appears to be an issue in the MPU configuration itself and resulting in abort.Is it possible to share your MPU configuration.
    Tarun Mukesh
  • Hi Tarun,
    Here is my CddIpcMpu.c:
    * Copyright (c) 2024 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
     *  \file     CddIpcR5Mpu.c
     *  \brief    This file defines R5 MPU configurations
    /*                             Include Files                                  */
    #include <stdlib.h>
    #include <stdint.h>
    #include <hw_include/arch/lld_arch.h>
    /*                           Macros & Typedefs                                */
    /*                            Global Variables                                */
    /** \brief The CSL startup code, uses gCslR5MpuCfg to define MPU configurations
     *          In cases where default configurations requires and override,
     *          applications could define this variable with required configuration
     *          In this application, we would require to mark the shared area as
     *          non-cacheable and shared. Defined in regionId 7
    #if defined (BUILD_MCU1_0)
    const CSL_ArmR5MpuRegionCfg gCslR5MpuCfg[CSL_ARM_R5F_MPU_REGIONS_MAX]
    __attribute__((section(".CDD_IPC_MPU_CFG_OCMRAM"))) =
    #else
    /* const CSL_ArmR5MpuRegionCfg gCslR5MpuCfg[CSL_ARM_R5F_MPU_REGIONS_MAX] __attribute__ ((section(".CDD_IPC_MPU_CFG_OCMRAM"))) =  No support for other
        cores/compilers at this point */
    const CSL_ArmR5MpuRegionCfg gCslR5MpuCfg[CSL_ARM_R5F_MPU_REGIONS_MAX] =
    #endif
            /* Region 0 configuration: complete 32 bit address space = 4Gbits */
            .regionId         = 0U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_4GB,
            .subRegionEnable  = CSL_ARM_R5_MPU_SUB_REGION_ENABLE_ALL,
            .exeNeverControl  = 1U,
            .accessPermission = CSL_ARM_R5_ACC_PERM_PRIV_USR_RD_WR,
            .shareable        = 0U,
            .cacheable        = (uint32_t)FALSE,
            .cachePolicy      = 0U,
            .memAttr          = 0U,
            /* Region 1 configuration: 128 bytes memory for exception vector execution */
            .regionId         = 1U,
            .enable           = 1U,
            .baseAddr         = 0x0U,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_128B,
            .exeNeverControl  = 0U,
            .shareable        = 0U,
            .cacheable        = (uint32_t)TRUE,
            .cachePolicy      = CSL_ARM_R5_CACHE_POLICY_WB_WA,
            .memAttr          = 0U,
            /* Region 2 configuration: 512 KB OCMS RAM */
            .regionId         = 2U,
            .enable           = 1U,
            .baseAddr         = 0x41C00000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_512KB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 3 configuration: 2 MB MCMS3 RAM */
            .regionId         = 3U,
            .enable           = 1U,
            .baseAddr         = 0x70000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_8MB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 4 configuration: 2 GB DDR RAM */
            .regionId         = 4U,
            .enable           = 1U,
            .baseAddr         = 0x80000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_1GB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 5 configuration: 64 KB BTCM */
            .regionId         = 5U,
            .enable           = 1U,
            .baseAddr         = 0x41010000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_64KB,
            .shareable        = 0U,
            .cachePolicy      = CSL_ARM_R5_CACHE_POLICY_NON_CACHEABLE,
            .memAttr          = 0U,
            /* Region 6 configuration: 128 MB FSS DAT */
            .regionId         = 6U,
            .enable           = 1U,
            .baseAddr         = 0x50000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_128MB,
            .shareable        = 0U,
            .memAttr          = 0U,
            /* Region 7 configuration: 32 MB for IPC Shared memory */
            .regionId         = 7U,
            .enable           = 1U,
            .baseAddr         = 0xAC000000,
            .size             = CSL_ARM_R5_MPU_REGION_SIZE_32MB,
            .shareable        = 1U,
            .memAttr          = 0U,
    /*EoF*/
    And following is the linker file with MCU1_0 and MCU2_0 configuration:
    /*     Linker Settings     */
    --retain="*(.bootCode)"
    --retain="*(.startupCode)"
    --retain="*(.startupData)"
    --retain="*(.irqStack)"
    --retain="*(.fiqStack)"
    --retain="*(.abortStack)"
    --retain="*(.undStack)"
    --retain="*(.svcStack)"
    --fill_value=0
    --stack_size=0x4000
    --heap_size=0x8000
    --entry_point=_freertosresetvectors
    -stack  0x4000  /* SOFTWARE STACK SIZE */
    -heap   0x8000  /* HEAP AREA SIZE      */
    --define FILL_PATTERN=0xFEAA55EF
    --define FILL_LENGTH=0x100
    __IRQ_STACK_SIZE   = 0x1000;  /* IRQ stack size */
    __FIQ_STACK_SIZE   = 0x0100;  /* FIQ stack size */
    __ABORT_STACK_SIZE = 0x0100;  /* Abort stack size */
    __UND_STACK_SIZE   = 0x0100;  /* Undefined instruction mode stack size */
    __SVC_STACK_SIZE   = 0x0100;  /* Supervisor mode stack size */
    /* DDR memory map */
    #define CONCAT(a, b)                a##b
    #define DDR0_ALLOCATED_START        (0x80000000)
    #define MCU1_0_DDR_SIZE             (0x10000000) /* 256MB */
    #define MCU2_0_DDR_SIZE             (0x10000000) /* 256MB */
    #define DSP0_DDR_SIZE               (0x01000000) /* 16MB */
    #define DSP1_DDR_SIZE               (0x01000000) /* 16MB */
    #define WAKEUP_SIZE                 (0x10000000) /* 256MB */
    #define MCU1_0_DDR_SPACE_START      (DDR0_ALLOCATED_START)
    #define MCU1_0_DDR_SPACE_END        (MCU1_0_DDR_SPACE_START + MCU1_0_DDR_SIZE)
    #define MCU2_0_DDR_SPACE_START      (MCU1_0_DDR_SPACE_END)
    #define MCU2_0_DDR_SPACE_END        (MCU2_0_DDR_SPACE_START + MCU2_0_DDR_SIZE)
    #define DSP0_DDR_SPACE_START        (MCU2_0_DDR_SPACE_END)
    #define DSP0_DDR_SPACE_END          (DSP0_DDR_SPACE_START + DSP0_DDR_SIZE)
    #define DSP1_DDR_SPACE_START        (DSP0_DDR_SPACE_END)
    #define DSP1_DDR_SPACE_END          (DSP1_DDR_SPACE_START + DSP1_DDR_SIZE)
    #define WAKEUP_DDR_SPACE_START      (DSP1_DDR_SPACE_END)
    #define WAKEUP_DDR_SPACE_END        (WAKEUP_DDR_SPACE_START + WAKEUP_SIZE)
    #define MCU_DDR_SIZE(mcu)           CONCAT(mcu, _DDR_SIZE)
    #define MCU_DDR_SPACE_START(mcu)    CONCAT(mcu, _DDR_SPACE_START)
    #define MCU_DDR_SPACE_END(mcu)      CONCAT(mcu, _DDR_SPACE_END)
    MEMORY
        /* MCU R5F TCM Local View */
        MCU_R5F_TCMA_VECS       (X) : ORIGIN = 0x00000000 LENGTH = 0x00000040
        MCU_R5F_TCMA            (X) : ORIGIN = 0x00000040 LENGTH = 0x00007FC0
        MCU_R5F_TCMB_VECS       (X) : ORIGIN = 0x41010000 LENGTH = 0x00000040
        MCU_R5F_TCMB            (X) : ORIGIN = 0x41010040 LENGTH = 0x00007FC0
        /*- Refer user guide for details on persistence of these sections -*/
        OCMC_RAM_BOARD_CFG   (RWIX) : ORIGIN = 0x41C80000 LENGTH = 0x00002000
        OCMC_RAM_SCISERVER   (RWIX) : ORIGIN = 0x41C82000 LENGTH = 0x00060000
        OCMC_RAM             (RWIX) : ORIGIN = 0x41CE3100 LENGTH = 0x0001AA00
        OCMC_RAM_X509_HEADER (RWIX) : ORIGIN = 0x41CFDB00 LENGTH = 0x00000500
        /*========================J784S4 MCMS3 LOCATIONS ===================*/
        /*---------- J784S4 Reserved Memory for ARM Trusted Firmware -------*/
        MSMC3_ARM_FW  (RWIX)        : ORIGIN = 0x70000000 LENGTH = 0x00020000   /* 128KB */
        MSMC3         (RWIX)        : ORIGIN = 0x70020000 LENGTH = 0x007D0000   /* 8MB - 192KB */
        /*------------- J784S4 Reserved Memory for DMSC Firmware -----------*/
        MSMC3_DMSC_FW (RWIX)        : ORIGIN = 0x707F0000 LENGTH = 0x00010000   /* 64KB */
        /*======================= J784S4 DDR LOCATION =======================*/
        MCU1_0_DDR (RWIX)          : ORIGIN = MCU_DDR_SPACE_START(MCU1_0) LENGTH = MCU_DDR_SIZE(MCU1_0)
        MCU2_0_DDR (RWIX)          : ORIGIN = MCU_DDR_SPACE_START(MCU2_0) LENGTH = MCU_DDR_SIZE(MCU2_0)
        DSP0_DDR (RWIX)            : ORIGIN = MCU_DDR_SPACE_START(DSP0) LENGTH = MCU_DDR_SIZE(DSP0)
        DSP1_DDR (RWIX)            : ORIGIN = MCU_DDR_SPACE_START(DSP1) LENGTH = MCU_DDR_SIZE(DSP1)
        WAKEUP_DDR (RWIX)          : ORIGIN = MCU_DDR_SPACE_START(WAKEUP) LENGTH = WAKEUP_SIZE
    #define MCU_DDR(mcu)           CONCAT(mcu, _DDR)
    /* Section Definitions */
    SECTIONS
        .freertosrstvectors     : {} palign(8)                      > MCU_R5F_TCMA_VECS
        .bootCode               : {} palign(8)                      > MCU_R5F_TCMA
        .startupCode            : {} palign(8)                      > MCU_R5F_TCMA
        .startupData            : {} palign(8)                      > MCU_R5F_TCMA, type = NOINIT
        .text                   : {} palign(8)                      > MCU_DDR(CURRENT_MCU)
        GROUP {
            .text.hwi           : palign(8)
            .text.cache         : palign(8)
            .text.mpu           : palign(8)
            .text.boot          : palign(8)
        }                                                           > MCU_DDR(CURRENT_MCU)
        .const                  : {} palign(8)                      > MCU_DDR(CURRENT_MCU)
        .rodata                 : {} palign(8)                      > MCU_DDR(CURRENT_MCU)
        .cinit                  : {} palign(8)                      > MCU_DDR(CURRENT_MCU)
        .bss                    : {} align(4)                       > MCU_DDR(CURRENT_MCU)
        .far                    : {} align(4)                       > MCU_DDR(CURRENT_MCU)
        .data                   : {} palign(128)                    > MCU_DDR(CURRENT_MCU)
        .sysmem                 : {}                                > MCU_DDR(CURRENT_MCU)
        .data_buffer            : {} palign(128)                    > MCU_DDR(CURRENT_MCU)
        .bss.devgroup           : {*(.bss.devgroup*)} align(4)      > MCU_DDR(CURRENT_MCU)
        .const.devgroup         : {*(.const.devgroup*)} align(4)    > MCU_DDR(CURRENT_MCU)
        .boardcfg_data          : {} align(4)                       > MCU_DDR(CURRENT_MCU)
        /* USB or any other LLD buffer for benchmarking */
        .benchmark_buffer (NOLOAD) {} ALIGN (8)                     > MCU_DDR(CURRENT_MCU)
        .stack      : {} align(4)                                   > MCU_DDR(CURRENT_MCU)  (HIGH)
        .irqStack   : {. = . + __IRQ_STACK_SIZE;} align(4)          > MCU_DDR(CURRENT_MCU)  (HIGH)
        RUN_START(__IRQ_STACK_START)
        RUN_END(__IRQ_STACK_END)
        .fiqStack   : {. = . + __FIQ_STACK_SIZE;} align(4)          > MCU_DDR(CURRENT_MCU)  (HIGH)
        RUN_START(__FIQ_STACK_START)
        RUN_END(__FIQ_STACK_END)
        .abortStack : {. = . + __ABORT_STACK_SIZE;} align(4)        > MCU_DDR(CURRENT_MCU)  (HIGH)
        RUN_START(__ABORT_STACK_START)
        RUN_END(__ABORT_STACK_END)
        .undStack   : {. = . + __UND_STACK_SIZE;} align(4)          > MCU_DDR(CURRENT_MCU)  (HIGH)
        RUN_START(__UND_STACK_START)
        RUN_END(__UND_STACK_END)
        .svcStack   : {. = . + __SVC_STACK_SIZE;} align(4)          > MCU_DDR(CURRENT_MCU)  (HIGH)
        RUN_START(__SVC_STACK_START)
        RUN_END(__SVC_STACK_END)
        /* Additional sections settings     */
            McalTextSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR
                .=align(4);
                __linker_spi_text_start = .;
                . += FILL_LENGTH;
                *(SPI_TEXT_SECTION)
                *(SPI_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_spi_text_end = .;
                .=align(4);
                __linker_gpt_text_start = .;
                . += FILL_LENGTH;
                *(GPT_TEXT_SECTION)
                *(GPT_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_gpt_text_end = .;
                .=align(4);
                __linker_dio_text_start = .;
                . += FILL_LENGTH;
                *(DIO_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_dio_text_end = .;
                .=align(4);
                __linker_eth_text_start = .;
                . += FILL_LENGTH;
                *(ETH_TEXT_SECTION)
                *(ETH_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_eth_text_end = .;
                .=align(4);
                __linker_ethtrcv_text_start = .;
                . += FILL_LENGTH;
                *(ETHTRCV_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_ethtrcv_text_end = .;
                .=align(4);
                __linker_can_text_start = .;
                . += FILL_LENGTH;
                *(CAN_TEXT_SECTION)
                *(CAN_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_can_text_end = .;
                .=align(4);
                __linker_wdg_text_start = .;
                . += FILL_LENGTH;
                *(WDG_TEXT_SECTION)
                *(WDG_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_wdg_text_end = .;
                .=align(4);
                __linker_pwm_text_start = .;
                . += FILL_LENGTH;
                *(PWM_TEXT_SECTION)
                *(PWM_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_pwm_text_end = .;
                __linker_adc_text_start = .;
                . += FILL_LENGTH;
                *(ADC_TEXT_SECTION)
                *(ADC_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_adc_text_end = .;
                .=align(4);
                __linker_cdd_ipc_text_start = .;
                . += FILL_LENGTH;
                *(CDD_IPC_TEXT_SECTION)
                *(CDD_IPC_ISR_TEXT_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_cdd_ipc_text_end = .;
            McalConstSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR
                .=align(4);
                __linker_spi_const_start = .;
                . += FILL_LENGTH;
                *(SPI_CONST_32_SECTION)
                *(SPI_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_spi_const_end = .;
                .=align(4);
                __linker_gpt_const_start = .;
                . += FILL_LENGTH;
                *(GPT_CONST_32_SECTION)
                *(GPT_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_gpt_const_end = .;
                .=align(4);
                __linker_dio_const_start = .;
                . += FILL_LENGTH;
                *(DIO_CONST_32_SECTION)
                *(DIO_CONST_UNSPECIFIED_SECTION)
                *(DIO_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_dio_const_end = .;
                .=align(4);
                __linker_can_const_start = .;
                . += FILL_LENGTH;
                *(CAN_CONST_8_SECTION)
                *(CAN_CONST_32_SECTION)
                *(CAN_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_can_const_end = .;
                .=align(4);
                __linker_eth_const_start = .;
                . += FILL_LENGTH;
                *(ETH_CONST_32_SECTION)
                *(ETH_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_eth_const_end = .;
                .=align(4);
                __linker_ethtrcv_const_start = .;
                . += FILL_LENGTH;
                *(ETHTRCV_CONST_32_SECTION)
                *(ETHTRCV_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_ethtrcv_const_end = .;
                .=align(4);
                __linker_wdg_const_start = .;
                . += FILL_LENGTH;
                *(WDG_CONST_32_SECTION)
                *(WDG_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_wdg_const_end = .;
                .=align(4);
                __linker_pwm_const_start = .;
                . += FILL_LENGTH;
                *(PWM_CONST_32_SECTION)
                *(PWM_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_pwm_const_end = .;
                .=align(4);
                __linker_adc_const_start = .;
                . += FILL_LENGTH;
                *(ADC_CONST_32_SECTION)
                *(ADC_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_adc_const_end = .;
                .=align(4);
                __linker_cdd_ipc_const_start = .;
                . += FILL_LENGTH;
                *(CDD_IPC_CONST_32_SECTION)
                *(CDD_IPC_CONFIG_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_cdd_ipc_const_end = .;
            McalInitSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR
                .=align(4);
                __linker_spi_init_start = .;
                . += FILL_LENGTH;
                *(SPI_DATA_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_spi_init_end = .;
                .=align(4);
                __linker_gpt_init_start = .;
                . += FILL_LENGTH;
                *(GPT_DATA_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_gpt_init_end = .;
                .=align(4);
                __linker_pwm_init_start = .;
                . += FILL_LENGTH;
                *(PWM_DATA_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_pwm_init_end = .;
                .=align(4);
                __linker_dio_init_start = .;
                . += FILL_LENGTH;
                *(DIO_DATA_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_dio_init_end = .;
                .=align(4);
                __linker_eth_init_start = .;
                . += FILL_LENGTH;
                *(ETH_DATA_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_eth_init_end = .;
                .=align(4);
                __linker_ethtrcv_init_start = .;
                . += FILL_LENGTH;
                *(ETHTRCV_DATA_INIT_UNSPECIFIED_SECTION)
                *(ETHTRCV_DATA_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_ethtrcv_init_end = .;
                .=align(4);
                __linker_can_init_start = .;
                . += FILL_LENGTH;
                *(CAN_DATA_INIT_8_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_can_init_end = .;
                .=align(4);
                __linker_wdg_init_start = .;
                . += FILL_LENGTH;
                *(WDG_DATA_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_wdg_init_end = .;
                .=align(4);
                __linker_adc_init_start = .;
                . += FILL_LENGTH;
                *(ADC_DATA_INIT_UNSPECIFIED_SECTION)
                *(ADC_DATA_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_adc_init_end = .;
                .=align(4);
                __linker_cdd_ipc_init_start = .;
                . += FILL_LENGTH;
                *(CDD_IPC_DATA_INIT_UNSPECIFIED_SECTION)
                *(CDD_IPC_DATA_INIT_32_SECTION)
                *(CDD_IPC_DATA_INIT_8_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_cdd_ipc_init_end = .;
            McalNoInitSection : fill=FILL_PATTERN, align=4, load > MCU1_0_DDR, type = NOINIT
                .=align(4);
                __linker_spi_no_init_start = .;
                . += FILL_LENGTH;
                *(SPI_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_spi_no_init_end = .;
                .=align(4);
                __linker_gpt_no_init_start = .;
                . += FILL_LENGTH;
                *(GPT_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_gpt_no_init_end = .;
                .=align(4);
                __linker_dio_no_init_start = .;
                . += FILL_LENGTH;
                *(DIO_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_dio_no_init_end = .;
                .=align(4);
                __linker_eth_no_init_start = .;
                . += FILL_LENGTH;
                *(ETH_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_eth_no_init_end = .;
                .=align(4);
                __linker_ethtrcv_no_init_start = .;
                . += FILL_LENGTH;
                *(ETHTRCV_DATA_NO_INIT_UNSPECIFIED_SECTION)
                *(ETHTRCV_DATA_NO_INIT_16_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_ethtrcv_no_init_end = .;
                .=align(4);
                __linker_can_no_init_start = .;
                . += FILL_LENGTH;
                *(CAN_DATA_NO_INIT_UNSPECIFIED_SECTION)
                *(CAN_DATA_NO_INIT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_can_no_init_end = .;
                .=align(4);
                __linker_wdg_no_init_start = .;
                . += FILL_LENGTH;
                *(WDG_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_wdg_no_init_end = .;
                .=align(4);
                __linker_pwm_no_init_start = .;
                . += FILL_LENGTH;
                *(PWM_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_pwm_no_init_end = .;
                __linker_adc_no_init_start = .;
                . += FILL_LENGTH;
                *(ADC_DATA_NO_INIT_UNSPECIFIED_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_adc_no_init_end = .;
                __linker_cdd_ipc_no_init_start = .;
                . += FILL_LENGTH;
                *(CDD_IPC_DATA_NO_INIT_UNSPECIFIED_SECTION)
                *(CDD_IPC_DATA_NO_INIT_8_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_cdd_ipc_no_init_end = .;
            /* Example Utility specifics */
            VariablesAlignedNoInitSection : align=8, load > MCU1_0_DDR, type = NOINIT
                .=align(8);
                __linker_cdd_ipc_no_init_align_8b_start = .;
                . += FILL_LENGTH;
                *(CDD_IPC_DATA_NO_INIT_8_ALIGN_8B_SECTION)
                .=align(8);
                . += FILL_LENGTH;
                __linker_cdd_ipc_no_init_align_8b_end = .;
            UtilityNoInitSection : align=4, load > MCU1_0_DDR, type = NOINIT
                .=align(4);
                __linker_utility_no_init_start = .;
                . += FILL_LENGTH;
                *(EG_TEST_RESULT_32_SECTION)
                .=align(4);
                . += FILL_LENGTH;
                __linker_utility_no_init_end = .;
            SciClientBoardCfgSection : align=128, load > MCU1_0_DDR, type = NOINIT
                .=align(128);
                __linker_boardcfg_data_start = .;
                . += FILL_LENGTH;
                *(.boardcfg_data)
                .=align(128);
                . += FILL_LENGTH;
                __linker_boardcfg_data_end = .;
            /* This section is used for descs and ring mems. It's best to have
             * it in OCMRAM or MSMC3 */
            McalUdmaSection : fill=FILL_PATTERN, align=128, load > MSMC3
                .=align(128);
                __linker_eth_udma_desc_start = .;
                . += FILL_LENGTH;
                *(ETH_UDMA_DESC_SECTION)
                .=align(128);
                . += FILL_LENGTH;
                __linker_eth_udma_desc_end = .;
                .=align(128);
                __linker_eth_udma_ring_start = .;
                . += FILL_LENGTH;
                *(ETH_UDMA_RING_SECTION)
                .=align(128);
                . += FILL_LENGTH;
                __linker_eth_udma_ring_end = .;
            McalTxDataSection : fill=FILL_PATTERN, align=128, load > MCU1_0_DDR, type = NOINIT
                .=align(128);
                __linker_eth_tx_data_start = .;
                . += FILL_LENGTH;
                *(ETH_TX_DATA_SECTION)
                .=align(128);
                . += FILL_LENGTH;
                __linker_eth_tx_data_end = .;
            McalRxDataSection : fill=FILL_PATTERN, align=128, load > MCU1_0_DDR, type = NOINIT
                .=align(128);
                __linker_eth_rx_data_start = .;
                . += FILL_LENGTH;
                *(ETH_RX_DATA_SECTION)
                .=align(128);
                . += FILL_LENGTH;
                __linker_eth_rx_data_end = .;
    Calin Harangus
