Part Number: TDA4VM
ROCESSOR-SDK-RTOS-J721E/07.02.00.06
PROCESSOR-SDK-LINUX-J721E/07.02.00.07
I updated gpu to 1.15 based on this link:https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1316731/faq-tda4vl-q1-what-are-the-gpu-driver-bug-fixes-for-sdk-8-6-or-earlier
The probability of the issue recurring is very low..A GPU HWR occurred; the log is as follows:
Aug 31 15:04:31 buildroot kernel: [ 37.659106] PVR_K: 1340: RGX Firmware image 'rgx.fw.22.104.208.318.64k' loaded
Aug 31 15:04:31 buildroot kernel: [ 37.662403] PVR_K: 1340: Shader binary image 'rgx.sh.22.104.208.318' loaded
Aug 31 15:05:19 buildroot kernel: [ 85.808493] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.818313] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.828312] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.838325] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.848310] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.858316] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:19 buildroot kernel: [ 85.868503] virtio_rpmsg_bus virtio3: msg received with no recipient
Aug 31 15:05:33 buildroot kernel: [ 11.227104] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Aug 31 15:05:33 buildroot kernel: [ 11.227126] NFSD: Using legacy client tracking operations.
Aug 31 15:05:33 buildroot kernel: [ 11.227129] NFSD: starting 90-second grace period (net f0000041)
Aug 31 15:05:33 buildroot kernel: [ 11.383153] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
Aug 31 17:13:55 buildroot kernel: [ 11.335953] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Aug 31 17:13:55 buildroot kernel: [ 11.335973] NFSD: Using legacy client tracking operations.
Aug 31 17:13:55 buildroot kernel: [ 11.335976] NFSD: starting 90-second grace period (net f0000041)
Aug 31 17:13:55 buildroot kernel: [ 11.667788] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
Sep 3 13:48:41 buildroot kernel: [ 237.175899] PVR_K: 207: ------------[ PVR DBG: START (High) ]------------
Sep 3 13:48:41 buildroot kernel: [ 237.175904] PVR_K: 207: OS kernel info: Linux 5.4.74-ACU-10.0.66.1 #4 SMP PREEMPT Fri Jul 19 06:41:15 UTC 2024 aarch64
Sep 3 13:48:41 buildroot kernel: [ 237.175907] PVR_K: 207: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
Sep 3 13:48:41 buildroot kernel: [ 237.175909] PVR_K: 207: Time now: 237175908us
Sep 3 13:48:41 buildroot kernel: [ 237.175911] PVR_K: 207: Services State: OK
Sep 3 13:48:41 buildroot kernel: [ 237.175914] PVR_K: 207: Server Errors: 0
Sep 3 13:48:41 buildroot kernel: [ 237.175919] PVR_K: 207: Connections Device ID:0(128) P505-V505-T966-AVMExec
Sep 3 13:48:41 buildroot kernel: [ 237.175920] PVR_K: 207: ------[ Driver Info ]------
Sep 3 13:48:41 buildroot kernel: [ 237.175922] PVR_K: 207: Comparison of UM/KM components: MATCHING
Sep 3 13:48:41 buildroot kernel: [ 237.175924] PVR_K: 207: KM Arch: 64 Bit
Sep 3 13:48:41 buildroot kernel: [ 237.175926] PVR_K: 207: UM Connected Clients: 64 Bit
Sep 3 13:48:41 buildroot kernel: [ 237.175928] PVR_K: 207: UM info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:48:41 buildroot kernel: [ 237.175931] PVR_K: 207: KM info: 1.15 @ 6133109 (release) build options: 0x00000810
Sep 3 13:48:41 buildroot kernel: [ 237.175933] PVR_K: 207: Window system: wayland
Sep 3 13:48:41 buildroot kernel: [ 237.175936] PVR_K: 207: ------[ RGX Device ID:0 Start ]------
Sep 3 13:48:41 buildroot kernel: [ 237.175938] PVR_K: 207: ------[ RGX Info ]------
Sep 3 13:48:41 buildroot kernel: [ 237.175941] PVR_K: 207: Device Node (Info): 00000000c7b5bd8d (000000001ac6423b)
Sep 3 13:48:41 buildroot kernel: [ 237.175944] PVR_K: 207: RGX BVNC: 22.104.208.318 (rogue)
Sep 3 13:48:41 buildroot kernel: [ 237.175946] PVR_K: 207: RGX Device State: Active
Sep 3 13:48:41 buildroot kernel: [ 237.175948] PVR_K: 207: RGX Power State: ON
Sep 3 13:48:41 buildroot kernel: [ 237.175951] PVR_K: 207: FW info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:48:41 buildroot kernel: [ 237.175954] PVR_K: 207: BIF0 - OK
Sep 3 13:48:41 buildroot kernel: [ 237.175959] PVR_K: 207: RGX FW State: OK (HWRState 0x00000001: HWR OK;)
Sep 3 13:48:41 buildroot kernel: [ 237.175963] PVR_K: 207: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
Sep 3 13:48:41 buildroot kernel: [ 237.175967] PVR_K: 207: RGX DVFS: 0 frequency changes. Current frequency: 749.999 MHz (sampled at 228170734785 ns). FW frequency: 100.000 MHz.
Sep 3 13:48:41 buildroot kernel: [ 237.175970] PVR_K: 207: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
Sep 3 13:48:41 buildroot kernel: [ 237.175979] PVR_K: 207: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(0/0+0), 3D(1/1+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
Sep 3 13:48:41 buildroot kernel: [ 237.175981] PVR_K: 207: DM 0 (GP)
Sep 3 13:48:41 buildroot kernel: [ 237.175984] PVR_K: 207: DM 1 (HWRflags 0x00000000: working;)
Sep 3 13:48:41 buildroot kernel: [ 237.175986] PVR_K: 207: DM 2 (HWRflags 0x00000000: working;)
Sep 3 13:48:41 buildroot kernel: [ 237.175988] PVR_K: 207: DM 3 (HWRflags 0x00000000: working;)
Sep 3 13:48:41 buildroot kernel: [ 237.175992] PVR_K: 207: Recovery 1: PID = 505, frame = 0, HWRTData = 0xC00C1B40, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:48:41 buildroot kernel: [ 237.175995] PVR_K: 207: CRTimer = 0x00002928b03d, OSTimer = 237.171682829, CyclesElapsed = 45940992
Sep 3 13:48:41 buildroot kernel: [ 237.175998] PVR_K: 207: PreResetTimeInCycles = 38912, HWResetTimeInCycles = 18944, FreelistReconTimeInCycles = 239616, TotalRecoveryTimeInCycles = 297472
Sep 3 13:48:41 buildroot kernel: [ 237.176000] PVR_K: 207: DM 4 (HWRflags 0x00000000: working;)
Sep 3 13:48:41 buildroot kernel: [ 237.176002] PVR_K: 207: DM 5 (HWRflags 0x00000000: working;)
Sep 3 13:48:41 buildroot kernel: [ 237.176004] PVR_K: 207: RGX Kernel CCB WO:0x4B RO:0x4B
Sep 3 13:48:41 buildroot kernel: [ 237.176006] PVR_K: 207: RGX Firmware CCB WO:0xC RO:0xC
Sep 3 13:48:41 buildroot kernel: [ 237.176008] PVR_K: 207: RGX Kernel CCB commands executed = 112075
Sep 3 13:48:41 buildroot kernel: [ 237.176010] PVR_K: 207: RGX SLR: Forced UFO updates requested = 0
Sep 3 13:48:41 buildroot kernel: [ 237.176012] PVR_K: 207: RGX Errors: WGP:0, TRP:0
Sep 3 13:48:41 buildroot kernel: [ 237.176014] PVR_K: 207: Thread0: FW IRQ count = 140086
Sep 3 13:48:41 buildroot kernel: [ 237.176016] PVR_K: 207: Last sampled IRQ count in LISR = 140086
Sep 3 13:48:41 buildroot kernel: [ 237.176019] PVR_K: 207: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
Sep 3 13:48:41 buildroot kernel: [ 237.176023] PVR_K: 207: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
Sep 3 13:48:41 buildroot kernel: [ 237.176025] PVR_K: 207: ------[ RGX registers ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176027] PVR_K: 207: RGX Register Base Address (Linear): 0x00000000b4d0f7c8
Sep 3 13:48:41 buildroot kernel: [ 237.176029] PVR_K: 207: RGX Register Base Address (Physical): 0x4E20000000
Sep 3 13:48:41 buildroot kernel: [ 237.176033] PVR_K: 207: CORE_ID : 0x0000000008470000
Sep 3 13:48:41 buildroot kernel: [ 237.176036] PVR_K: 207: CORE_REVISION : 0x00D0013E
Sep 3 13:48:41 buildroot kernel: [ 237.176038] PVR_K: 207: DESIGNER_REV_FIELD1 : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176040] PVR_K: 207: DESIGNER_REV_FIELD2 : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176043] PVR_K: 207: CHANGESET_NUMBER : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176046] PVR_K: 207: CLK_CTRL : 0x0aaaaa002a2aaaaa
Sep 3 13:48:41 buildroot kernel: [ 237.176048] PVR_K: 207: CLK_STATUS : 0x0000000000600018
Sep 3 13:48:41 buildroot kernel: [ 237.176051] PVR_K: 207: CLK_CTRL2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176053] PVR_K: 207: CLK_STATUS2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176056] PVR_K: 207: EVENT_STATUS : 0x00000400
Sep 3 13:48:41 buildroot kernel: [ 237.176058] PVR_K: 207: TIMER : 0x000000002928b6ba
Sep 3 13:48:41 buildroot kernel: [ 237.176060] PVR_K: 207: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176063] PVR_K: 207: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176065] PVR_K: 207: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176068] PVR_K: 207: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176071] PVR_K: 207: BIF_MMU_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176073] PVR_K: 207: BIF_MMU_ENTRY : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176075] PVR_K: 207: BIF_MMU_ENTRY_STATUS : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176078] PVR_K: 207: BIF_STATUS_MMU : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176080] PVR_K: 207: BIF_READS_EXT_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176082] PVR_K: 207: BIF_READS_INT_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176085] PVR_K: 207: BIFPM_STATUS_MMU : 0x00000001
Sep 3 13:48:41 buildroot kernel: [ 237.176087] PVR_K: 207: BIFPM_READS_EXT_STATUS : 0x00000001
Sep 3 13:48:41 buildroot kernel: [ 237.176089] PVR_K: 207: BIFPM_READS_INT_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176092] PVR_K: 207: BIF_CAT_BASE_INDEX : 0x0000000000000101
Sep 3 13:48:41 buildroot kernel: [ 237.176095] PVR_K: 207: BIF_CAT_BASE0 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176098] PVR_K: 207: BIF_CAT_BASE1 : 0x00000008bd050000
Sep 3 13:48:41 buildroot kernel: [ 237.176101] PVR_K: 207: BIF_CAT_BASE2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176103] PVR_K: 207: BIF_CAT_BASE3 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176105] PVR_K: 207: BIF_CAT_BASE4 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176108] PVR_K: 207: BIF_CAT_BASE5 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176111] PVR_K: 207: BIF_CAT_BASE6 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176113] PVR_K: 207: BIF_CAT_BASE7 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176116] PVR_K: 207: BIF_CTRL_INVAL : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176118] PVR_K: 207: BIF_CTRL : 0x000000C0
Sep 3 13:48:41 buildroot kernel: [ 237.176121] PVR_K: 207: BIF_PM_CAT_BASE_VCE0 : 0x00000000fea8d001
Sep 3 13:48:41 buildroot kernel: [ 237.176123] PVR_K: 207: BIF_PM_CAT_BASE_TE0 : 0x00000000fea82001
Sep 3 13:48:41 buildroot kernel: [ 237.176126] PVR_K: 207: BIF_PM_CAT_BASE_ALIST0 : 0x00000000fea7d001
Sep 3 13:48:41 buildroot kernel: [ 237.176129] PVR_K: 207: BIF_PM_CAT_BASE_VCE1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176131] PVR_K: 207: BIF_PM_CAT_BASE_TE1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176134] PVR_K: 207: BIF_PM_CAT_BASE_ALIST1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176136] PVR_K: 207: PERF_TA_PHASE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176139] PVR_K: 207: PERF_TA_CYCLE : 0x00010A4A
Sep 3 13:48:41 buildroot kernel: [ 237.176141] PVR_K: 207: PERF_3D_PHASE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176143] PVR_K: 207: PERF_3D_CYCLE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176147] PVR_K: 207: PERF_TA_OR_3D_CYCLE : 0x0001201C
Sep 3 13:48:41 buildroot kernel: [ 237.176148] PVR_K: 207: PERF_TA_AND_3D_CYCLE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176151] PVR_K: 207: PERF_COMPUTE_PHASE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176153] PVR_K: 207: PERF_COMPUTE_CYCLE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176155] PVR_K: 207: PM_PARTIAL_RENDER_ENABLE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176157] PVR_K: 207: ISP_RENDER : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176160] PVR_K: 207: TLA_STATUS : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176163] PVR_K: 207: MCU_FENCE : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176165] PVR_K: 207: VDM_CONTEXT_STORE_STATUS : 0x00000001
Sep 3 13:48:41 buildroot kernel: [ 237.176168] PVR_K: 207: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176171] PVR_K: 207: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176173] PVR_K: 207: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176177] PVR_K: 207: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176179] PVR_K: 207: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176182] PVR_K: 207: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176184] PVR_K: 207: ISP_CTL : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176186] PVR_K: 207: ISP_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176189] PVR_K: 207: MTS_INTCTX : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176191] PVR_K: 207: MTS_BGCTX : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176193] PVR_K: 207: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176195] PVR_K: 207: MTS_SCHEDULE : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176198] PVR_K: 207: MTS_GPU_INT_STATUS : 0x00004550
Sep 3 13:48:41 buildroot kernel: [ 237.176200] PVR_K: 207: CDM_CONTEXT_STORE_STATUS : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176202] PVR_K: 207: CDM_CONTEXT_PDS0 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176205] PVR_K: 207: CDM_CONTEXT_PDS1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176208] PVR_K: 207: CDM_TERMINATE_PDS : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176211] PVR_K: 207: CDM_TERMINATE_PDS1 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176213] PVR_K: 207: SIDEKICK_IDLE : 0x0000007E
Sep 3 13:48:41 buildroot kernel: [ 237.176215] PVR_K: 207: SLC_IDLE : 0x0000001E
Sep 3 13:48:41 buildroot kernel: [ 237.176218] PVR_K: 207: SLC_STATUS0 : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176221] PVR_K: 207: SLC_STATUS1 : 0x0000000400010402
Sep 3 13:48:41 buildroot kernel: [ 237.176223] PVR_K: 207: SLC_STATUS2 : 0x0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.176225] PVR_K: 207: SLC_CTRL_BYPASS : 0x01000000
Sep 3 13:48:41 buildroot kernel: [ 237.176228] PVR_K: 207: SLC_CTRL_MISC : 0x0000000000200003
Sep 3 13:48:41 buildroot kernel: [ 237.176232] PVR_K: 207: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
Sep 3 13:48:41 buildroot kernel: [ 237.176234] PVR_K: 207: MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:48:41 buildroot kernel: [ 237.176237] PVR_K: 207: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
Sep 3 13:48:41 buildroot kernel: [ 237.176239] PVR_K: 207: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008bc8ee00c
Sep 3 13:48:41 buildroot kernel: [ 237.176241] PVR_K: 207: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
Sep 3 13:48:41 buildroot kernel: [ 237.176244] PVR_K: 207: MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008bc8dd00c
Sep 3 13:48:41 buildroot kernel: [ 237.176246] PVR_K: 207: MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
Sep 3 13:48:41 buildroot kernel: [ 237.176249] PVR_K: 207: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
Sep 3 13:48:41 buildroot kernel: [ 237.176251] PVR_K: 207: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
Sep 3 13:48:41 buildroot kernel: [ 237.176253] PVR_K: 207: MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:48:41 buildroot kernel: [ 237.176256] PVR_K: 207: MIPS_WRAPPER_CONFIG : 0x000000000001cf80
Sep 3 13:48:41 buildroot kernel: [ 237.176258] PVR_K: 207: MIPS_EXCEPTION_STATUS : 0x00000020
Sep 3 13:48:41 buildroot kernel: [ 237.176329] PVR_K: 207: ---- [ MIPS internal state ] ----
Sep 3 13:48:41 buildroot kernel: [ 237.176331] PVR_K: 207: PC : 0xC001711C
Sep 3 13:48:41 buildroot kernel: [ 237.176333] PVR_K: 207: STATUS_REGISTER : 0x00481C05
Sep 3 13:48:41 buildroot kernel: [ 237.176334] PVR_K: 207: CAUSE_REGISTER : 0x00800000
Sep 3 13:48:41 buildroot kernel: [ 237.176336] PVR_K: 207: BAD_REGISTER : 0xC00C005C
Sep 3 13:48:41 buildroot kernel: [ 237.176338] PVR_K: 207: EPC : 0xC0017118
Sep 3 13:48:41 buildroot kernel: [ 237.176340] PVR_K: 207: SP : 0xCF600FE0
Sep 3 13:48:41 buildroot kernel: [ 237.176342] PVR_K: 207: BAD_INSTRUCTION : 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176344] PVR_K: 207: TLB :
Sep 3 13:48:41 buildroot kernel: [ 237.176348] PVR_K: 207: 0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176351] PVR_K: 207: 1) VA 0xCF000000 ( 16k) -> PA0 0x8bc840000 DVGC, PA1 0x8bc844000 DVGC
Sep 3 13:48:41 buildroot kernel: [ 237.176354] PVR_K: 207: 2) VA 0xCF600000 ( 4k) -> PA0 0x8bc8ef000 DV C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176357] PVR_K: 207: 3) VA 0xF0060000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176360] PVR_K: 207: 4) VA 0xF0080000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176362] PVR_K: 207: 5) VA 0xC0140000 ( 64k) -> PA0 0x8839d0000 DVG , PA1 0xfce80000 DVG
Sep 3 13:48:41 buildroot kernel: [ 237.176365] PVR_K: 207: 6) VA 0xC0100000 ( 64k) -> PA0 0x8bd830000 DVGC, PA1 0x880ed0000 DVGC
Sep 3 13:48:41 buildroot kernel: [ 237.176368] PVR_K: 207: 7) VA 0xC0080000 ( 64k) -> PA0 0x8bc920000 DVG , PA1 0x8bc940000 DVG
Sep 3 13:48:41 buildroot kernel: [ 237.176370] PVR_K: 207: 8) VA 0xC0040000 ( 64k) -> PA0 0x8bc8e0000 DVGC, PA1 0x8bc8f0000 DVG
Sep 3 13:48:41 buildroot kernel: [ 237.176373] PVR_K: 207: 9) VA 0xC00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x8bd820000 DV C
Sep 3 13:48:41 buildroot kernel: [ 237.176375] PVR_K: 207: 10) VA 0xC0160000 ( 64k) -> PA0 0xfe220000 DV , PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176378] PVR_K: 207: 11) VA 0xC00C0000 ( 64k) -> PA0 0x8bd2a0000 DVGC, PA1 0x8bd810000 DVGC
Sep 3 13:48:41 buildroot kernel: [ 237.176381] PVR_K: 207: 12) VA 0xF0180000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176383] PVR_K: 207: 13) VA 0xC0000000 ( 64k) -> PA0 0x8bc8a0000 DVGC, PA1 0x8bc8b0000 DVGC
Sep 3 13:48:41 buildroot kernel: [ 237.176386] PVR_K: 207: 14) VA 0xF01C0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176388] PVR_K: 207: 15) VA 0xF01E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:48:41 buildroot kernel: [ 237.176392] PVR_K: 207: --------------------------------
Sep 3 13:48:41 buildroot kernel: [ 237.176394] PVR_K: 207: ------[ RGX FW Trace Info ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176396] PVR_K: 207: Debug log type: none
Sep 3 13:48:41 buildroot kernel: [ 237.176397] PVR_K: 207: RGX FW thread 0: Trace buffer not yet allocated
Sep 3 13:48:41 buildroot kernel: [ 237.176399] PVR_K: 207: ------[ Full CCB Status ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176406] PVR_K: 207: FWCtx 0xC00C0300 (TQ_3D-P505-T966-AVMExec)
Sep 3 13:48:41 buildroot kernel: [ 237.176409] PVR_K: 207: |--Waiting FENCE @ 53176 Int=111960 Ext=111960
Sep 3 13:48:41 buildroot kernel: [ 237.176412] PVR_K: 207: | `--Addr:0xc01401c9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176415] PVR_K: 207: |--Waiting TQ_3D @ 53224 Int=111960 Ext=111960
Sep 3 13:48:41 buildroot kernel: [ 237.176417] PVR_K: 207: |--Waiting UPDATE @ 53424 Int=111960 Ext=111960
Sep 3 13:48:41 buildroot kernel: [ 237.176419] PVR_K: 207: | |--Addr:0xc0130000 Val=0x00014810
Sep 3 13:48:41 buildroot kernel: [ 237.176421] PVR_K: 207: | `--Addr:0xc0140019 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176424] PVR_K: 207: |--Waiting TQ_3D @ 53480 Int=111961 Ext=111961
Sep 3 13:48:41 buildroot kernel: [ 237.176426] PVR_K: 207: |--Waiting UPDATE @ 53680 Int=111961 Ext=111961
Sep 3 13:48:41 buildroot kernel: [ 237.176428] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014811
Sep 3 13:48:41 buildroot kernel: [ 237.176431] PVR_K: 207: |--Waiting TQ_3D @ 53728 Int=111962 Ext=111962
Sep 3 13:48:41 buildroot kernel: [ 237.176433] PVR_K: 207: |--Waiting UPDATE @ 53928 Int=111962 Ext=111962
Sep 3 13:48:41 buildroot kernel: [ 237.176435] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014812
Sep 3 13:48:41 buildroot kernel: [ 237.176437] PVR_K: 207: |--Waiting TQ_3D @ 53976 Int=111963 Ext=111963
Sep 3 13:48:41 buildroot kernel: [ 237.176440] PVR_K: 207: |--Waiting UPDATE @ 54176 Int=111963 Ext=111963
Sep 3 13:48:41 buildroot kernel: [ 237.176442] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014813
Sep 3 13:48:41 buildroot kernel: [ 237.176444] PVR_K: 207: |--Waiting TQ_3D @ 54224 Int=111964 Ext=111964
Sep 3 13:48:41 buildroot kernel: [ 237.176446] PVR_K: 207: |--Waiting UPDATE @ 54424 Int=111964 Ext=111964
Sep 3 13:48:41 buildroot kernel: [ 237.176448] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014814
Sep 3 13:48:41 buildroot kernel: [ 237.176451] PVR_K: 207: |--Waiting TQ_3D @ 54472 Int=111965 Ext=111965
Sep 3 13:48:41 buildroot kernel: [ 237.176453] PVR_K: 207: |--Waiting UPDATE @ 54672 Int=111965 Ext=111965
Sep 3 13:48:41 buildroot kernel: [ 237.176455] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014815
Sep 3 13:48:41 buildroot kernel: [ 237.176457] PVR_K: 207: |--Waiting TQ_3D @ 54720 Int=111966 Ext=111966
Sep 3 13:48:41 buildroot kernel: [ 237.176460] PVR_K: 207: |--Waiting UPDATE @ 54920 Int=111966 Ext=111966
Sep 3 13:48:41 buildroot kernel: [ 237.176462] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014816
Sep 3 13:48:41 buildroot kernel: [ 237.176464] PVR_K: 207: |--Waiting TQ_3D @ 54968 Int=111967 Ext=111967
Sep 3 13:48:41 buildroot kernel: [ 237.176467] PVR_K: 207: |--Waiting UPDATE @ 55168 Int=111967 Ext=111967
Sep 3 13:48:41 buildroot kernel: [ 237.176469] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014817
Sep 3 13:48:41 buildroot kernel: [ 237.176471] PVR_K: 207: |--Waiting TQ_3D @ 55216 Int=111968 Ext=111968
Sep 3 13:48:41 buildroot kernel: [ 237.176474] PVR_K: 207: |--Waiting UPDATE @ 55416 Int=111968 Ext=111968
Sep 3 13:48:41 buildroot kernel: [ 237.176476] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014818
Sep 3 13:48:41 buildroot kernel: [ 237.176478] PVR_K: 207: |--Waiting TQ_3D @ 55464 Int=111969 Ext=111969
Sep 3 13:48:41 buildroot kernel: [ 237.176480] PVR_K: 207: |--Waiting UPDATE @ 55664 Int=111969 Ext=111969
Sep 3 13:48:41 buildroot kernel: [ 237.176482] PVR_K: 207: | `--Addr:0xc0130000 Val=0x00014819
Sep 3 13:48:41 buildroot kernel: [ 237.176484] PVR_K: 207: |--Waiting FENCE @ 55712 Int=111970 Ext=111970
Sep 3 13:48:41 buildroot kernel: [ 237.176486] PVR_K: 207: | `--Addr:0xc01401c9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176488] PVR_K: 207: |--Waiting TQ_3D @ 55760 Int=111970 Ext=111970
Sep 3 13:48:41 buildroot kernel: [ 237.176491] PVR_K: 207: |--Waiting UPDATE @ 55960 Int=111970 Ext=111970
Sep 3 13:48:41 buildroot kernel: [ 237.176493] PVR_K: 207: | |--Addr:0xc0130000 Val=0x0001481a
Sep 3 13:48:41 buildroot kernel: [ 237.176495] PVR_K: 207: | `--Addr:0xc0140241 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176497] PVR_K: 207: |--Waiting FENCE @ 56016 Int=111972 Ext=111972
Sep 3 13:48:41 buildroot kernel: [ 237.176499] PVR_K: 207: | `--Addr:0xc0140219 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176501] PVR_K: 207: |--Waiting TQ_3D @ 56064 Int=111972 Ext=111972
Sep 3 13:48:41 buildroot kernel: [ 237.176503] PVR_K: 207: |--Waiting UPDATE @ 56264 Int=111972 Ext=111972
Sep 3 13:48:41 buildroot kernel: [ 237.176505] PVR_K: 207: | |--Addr:0xc0130000 Val=0x0001481b
Sep 3 13:48:41 buildroot kernel: [ 237.176507] PVR_K: 207: | `--Addr:0xc0140209 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176510] PVR_K: 207: |--Waiting TQ_3D @ 56320 Int=111973 Ext=111973
Sep 3 13:48:41 buildroot kernel: [ 237.176512] PVR_K: 207: |--Waiting UPDATE @ 56520 Int=111973 Ext=111973
Sep 3 13:48:41 buildroot kernel: [ 237.176514] PVR_K: 207: | `--Addr:0xc0130000 Val=0x0001481c
Sep 3 13:48:41 buildroot kernel: [ 237.176516] PVR_K: 207: |--Waiting TQ_3D @ 56568 Int=111974 Ext=111974
Sep 3 13:48:41 buildroot kernel: [ 237.176519] PVR_K: 207: |--Waiting UPDATE @ 56768 Int=111974 Ext=111974
Sep 3 13:48:41 buildroot kernel: [ 237.176521] PVR_K: 207: | `--Addr:0xc0130000 Val=0x0001481d
Sep 3 13:48:41 buildroot kernel: [ 237.176523] PVR_K: 207: |--Waiting FENCE @ 56816 Int=111975 Ext=111975
Sep 3 13:48:41 buildroot kernel: [ 237.176525] PVR_K: 207: | `--Addr:0xc0140219 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176527] PVR_K: 207: |--Waiting TQ_3D @ 56864 Int=111975 Ext=111975
Sep 3 13:48:41 buildroot kernel: [ 237.176530] PVR_K: 207: `--Waiting UPDATE @ 57064 Int=111975 Ext=111975
Sep 3 13:48:41 buildroot kernel: [ 237.176532] PVR_K: 207: |--Addr:0xc0130000 Val=0x0001481e
Sep 3 13:48:41 buildroot kernel: [ 237.176534] PVR_K: 207: `--Addr:0xc0140229 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176537] PVR_K: 207: FWCtx 0xC00C0040 (TA-P505-T966-AVMExec)
Sep 3 13:48:41 buildroot kernel: [ 237.176539] PVR_K: 207: |--Ready TA @ 32520 Int=111958 Ext=111957
Sep 3 13:48:41 buildroot kernel: [ 237.176542] PVR_K: 207: |--Ready UPDATE @ 32632 Int=111958 Ext=111957
Sep 3 13:48:41 buildroot kernel: [ 237.176544] PVR_K: 207: | |--Addr:0xc0160054 Val=0x00000e51
Sep 3 13:48:41 buildroot kernel: [ 237.176546] PVR_K: 207: | `--Addr:0xc0140131 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176548] PVR_K: 207: |--Ready FENCE @ 32688 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176550] PVR_K: 207: | `--Addr:0xc0160018 Val=0x00000ae8
Sep 3 13:48:41 buildroot kernel: [ 237.176552] PVR_K: 207: |--Ready TA @ 32736 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176554] PVR_K: 207: |--Ready UPDATE @ 32848 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176556] PVR_K: 207: | |--Addr:0xc0160018 Val=0x00000ae9
Sep 3 13:48:41 buildroot kernel: [ 237.176558] PVR_K: 207: | `--Addr:0xc0140111 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176560] PVR_K: 207: |--Ready FENCE @ 32904 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176562] PVR_K: 207: | `--Addr:0xc0160034 Val=0x00000f7a
Sep 3 13:48:41 buildroot kernel: [ 237.176565] PVR_K: 207: |--Ready TA @ 32952 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176567] PVR_K: 207: |--Ready UPDATE @ 33064 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176569] PVR_K: 207: | |--Addr:0xc0160034 Val=0x00000f7b
Sep 3 13:48:41 buildroot kernel: [ 237.176571] PVR_K: 207: | `--Addr:0xc01400c1 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176573] PVR_K: 207: |--Waiting FENCE @ 33120 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176575] PVR_K: 207: | |--Addr:0xc016004c Val=0x00000abc
Sep 3 13:48:41 buildroot kernel: [ 237.176577] PVR_K: 207: | `--Addr:0xc01400f9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176579] PVR_K: 207: |--Waiting TA @ 33176 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176581] PVR_K: 207: `--Waiting UPDATE @ 33288 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176583] PVR_K: 207: |--Addr:0xc016004c Val=0x00000abd
Sep 3 13:48:41 buildroot kernel: [ 237.176585] PVR_K: 207: `--Addr:0xc01401a1 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176588] PVR_K: 207: FWCtx 0xC00C00E0 (3D-P505-T966-AVMExec)
Sep 3 13:48:41 buildroot kernel: [ 237.176590] PVR_K: 207: |--Ready 3D @ 49096 Int=111957 Ext=111938
Sep 3 13:48:41 buildroot kernel: [ 237.176592] PVR_K: 207: |--Ready UPDATE @ 49488 Int=111957 Ext=111938
Sep 3 13:48:41 buildroot kernel: [ 237.176594] PVR_K: 207: | |--Addr:0xc0160008 Val=0x00000eac
Sep 3 13:48:41 buildroot kernel: [ 237.176596] PVR_K: 207: | |--Addr:0xc0140141 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176598] PVR_K: 207: | `--Addr:0xc01400e9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176601] PVR_K: 207: |--Waiting FENCE_PR @ 49552 Int=111958 Ext=111957
Sep 3 13:48:41 buildroot kernel: [ 237.176603] PVR_K: 207: | `--Addr:0xc0160054 Val=0x00000e51
Sep 3 13:48:41 buildroot kernel: [ 237.176605] PVR_K: 207: |--Waiting 3D @ 49600 Int=111958 Ext=111957
Sep 3 13:48:41 buildroot kernel: [ 237.176607] PVR_K: 207: |--Waiting UPDATE @ 49992 Int=111958 Ext=111957
Sep 3 13:48:41 buildroot kernel: [ 237.176609] PVR_K: 207: | |--Addr:0xc0160054 Val=0x00000e52
Sep 3 13:48:41 buildroot kernel: [ 237.176611] PVR_K: 207: | |--Addr:0xc01400f9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176613] PVR_K: 207: | `--Addr:0xc0140081 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176615] PVR_K: 207: |--Waiting FENCE_PR @ 50056 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176618] PVR_K: 207: | `--Addr:0xc0160018 Val=0x00000ae9
Sep 3 13:48:41 buildroot kernel: [ 237.176620] PVR_K: 207: |--Waiting 3D @ 50104 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176622] PVR_K: 207: |--Waiting UPDATE @ 50496 Int=111959 Ext=111939
Sep 3 13:48:41 buildroot kernel: [ 237.176624] PVR_K: 207: | |--Addr:0xc0160018 Val=0x00000aea
Sep 3 13:48:41 buildroot kernel: [ 237.176626] PVR_K: 207: | |--Addr:0xc0140211 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176629] PVR_K: 207: | `--Addr:0xc01401c9 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176631] PVR_K: 207: |--Waiting FENCE @ 50560 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176633] PVR_K: 207: | `--Addr:0xc0140241 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176635] PVR_K: 207: |--Waiting FENCE_PR @ 50608 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176637] PVR_K: 207: | `--Addr:0xc0160034 Val=0x00000f7b
Sep 3 13:48:41 buildroot kernel: [ 237.176640] PVR_K: 207: |--Waiting 3D @ 50656 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176642] PVR_K: 207: |--Waiting UPDATE @ 51048 Int=111971 Ext=111951
Sep 3 13:48:41 buildroot kernel: [ 237.176644] PVR_K: 207: | |--Addr:0xc0160034 Val=0x00000f7c
Sep 3 13:48:41 buildroot kernel: [ 237.176646] PVR_K: 207: | `--Addr:0xc0140219 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176650] PVR_K: 207: |--Waiting FENCE @ 51104 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176652] PVR_K: 207: | `--Addr:0xc0140229 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176654] PVR_K: 207: |--Waiting FENCE_PR @ 51152 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176656] PVR_K: 207: | `--Addr:0xc016004c Val=0x00000abd
Sep 3 13:48:41 buildroot kernel: [ 237.176658] PVR_K: 207: |--Waiting 3D @ 51200 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176661] PVR_K: 207: `--Waiting UPDATE @ 51592 Int=111976 Ext=111956
Sep 3 13:48:41 buildroot kernel: [ 237.176663] PVR_K: 207: |--Addr:0xc016004c Val=0x00000abe
Sep 3 13:48:41 buildroot kernel: [ 237.176665] PVR_K: 207: |--Addr:0xc0140179 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176667] PVR_K: 207: `--Addr:0xc0140279 Val=0x00000519
Sep 3 13:48:41 buildroot kernel: [ 237.176670] PVR_K: 207: ------[ RGX Device ID:0 End ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176673] PVR_K: 207: ------[ System Summary Device ID:0 ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176675] PVR_K: 207: Device System Power State: ON
Sep 3 13:48:41 buildroot kernel: [ 237.176678] PVR_K: 207: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
Sep 3 13:48:41 buildroot kernel: [ 237.176680] PVR_K: 207: ------[ Server Thread Summary ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176684] PVR_K: 207: pvr_defer_free : Running
Sep 3 13:48:41 buildroot kernel: [ 237.176685] PVR_K: 207: Number of deferred cleanup items : 0
Sep 3 13:48:41 buildroot kernel: [ 237.176688] PVR_K: 207: pvr_device_wdg : Running
Sep 3 13:48:41 buildroot kernel: [ 237.176690] PVR_K: 207: pvr_cacheop : Running
Sep 3 13:48:41 buildroot kernel: [ 237.176695] PVR_K: 207: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes
Sep 3 13:48:41 buildroot kernel: [ 237.176697] PVR_K: 207: Pending deferred CacheOp entries : 0
Sep 3 13:48:41 buildroot kernel: [ 237.176699] PVR_K: 207: ------[ AppHint Settings ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176703] PVR_K: 207: Build Vars
Sep 3 13:48:41 buildroot kernel: [ 237.176708] PVR_K: 207: EnableTrustedDeviceAceConfig: N
Sep 3 13:48:41 buildroot kernel: [ 237.176711] PVR_K: 207: CleanupThreadPriority: 0x00000005
Sep 3 13:48:41 buildroot kernel: [ 237.176713] PVR_K: 207: CacheOpThreadPriority: 0x00000001
Sep 3 13:48:41 buildroot kernel: [ 237.176715] PVR_K: 207: WatchdogThreadPriority: 0x00000000
Sep 3 13:48:41 buildroot kernel: [ 237.176717] PVR_K: 207: HWPerfClientBufferSize: 0x000c0000
Sep 3 13:48:41 buildroot kernel: [ 237.176719] PVR_K: 207: Module Params
Sep 3 13:48:41 buildroot kernel: [ 237.176730] PVR_K: 207: none
Sep 3 13:48:41 buildroot kernel: [ 237.176732] PVR_K: 207: Debug Info Params
Sep 3 13:48:41 buildroot kernel: [ 237.176737] PVR_K: 207: CacheOpConfig: 0x0000000c
Sep 3 13:48:41 buildroot kernel: [ 237.176739] PVR_K: 207: CacheOpUMKMThresholdSize: 0xffffffff
Sep 3 13:48:41 buildroot kernel: [ 237.176742] PVR_K: 207: Debug Info Params Device ID: 0
Sep 3 13:48:41 buildroot kernel: [ 237.176747] PVR_K: 207: none
Sep 3 13:48:41 buildroot kernel: [ 237.176750] PVR_K: 207: ------[ HTB Log state: Off ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176753] PVR_K: 207: ------[ Active Sync Checkpoints ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176757] PVR_K: 207: - ID = 100738, FWAddr = 0xc0140278, r1:e1:f0: es3_DoKick3D_111956
Sep 3 13:48:41 buildroot kernel: [ 237.176760] PVR_K: 207: - ID = 100737, FWAddr = 0xc01401a0, r1:e1:f0: es3_DoKickTA_111956
Sep 3 13:48:41 buildroot kernel: [ 237.176762] PVR_K: 207: - ID = 100736, FWAddr = 0xc0140178, r1:e1:f0: update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176764] PVR_K: 207: - ID = 100735, FWAddr = 0xc0140228, r1:e2:f0: TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176767] PVR_K: 207: - ID = 100734, FWAddr = 0xc0140208, r1:e1:f0: TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176769] PVR_K: 207: - ID = 100733, FWAddr = 0xc0140218, r1:e3:f0: es3_DoKick3D_111951
Sep 3 13:48:41 buildroot kernel: [ 237.176771] PVR_K: 207: - ID = 100732, FWAddr = 0xc01400c0, r1:e1:f0: es3_DoKickTA_111951
Sep 3 13:48:41 buildroot kernel: [ 237.176774] PVR_K: 207: - ID = 100731, FWAddr = 0xc0140240, r1:e2:f0: TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176776] PVR_K: 207: - ID = 100730, FWAddr = 0xc0140018, r1:e1:f0: TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176778] PVR_K: 207: - ID = 100729, FWAddr = 0xc01401c8, r1:e3:f0: es3_DoKick3D_111939
Sep 3 13:48:41 buildroot kernel: [ 237.176780] PVR_K: 207: - ID = 100728, FWAddr = 0xc0140110, r1:e1:f0: es3_DoKickTA_111939
Sep 3 13:48:41 buildroot kernel: [ 237.176782] PVR_K: 207: - ID = 100727, FWAddr = 0xc0140210, r1:e1:f0: update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176785] PVR_K: 207: - ID = 100726, FWAddr = 0xc0140080, r1:e1:f0: es3_DoKick3D_111957
Sep 3 13:48:41 buildroot kernel: [ 237.176788] PVR_K: 207: - ID = 100724, FWAddr = 0xc01400f8, r1:e2:f0: update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176790] PVR_K: 207: - ID = 100723, FWAddr = 0xc01400e8, r1:e1:f0: es3_DoKick3D_111938
Sep 3 13:48:41 buildroot kernel: [ 237.176793] PVR_K: 207: - ID = 100721, FWAddr = 0xc0140140, r1:e1:f0: update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176798] ------[ Native Fence Sync: timelines ]------
Sep 3 13:48:41 buildroot kernel: [ 237.176802] foreign_sync: @0 ctx=1 refs=1
Sep 3 13:48:41 buildroot kernel: [ 237.176807] sw: RM_SWTimeline-eda-AVMExec-505 @0 cur=0
Sep 3 13:48:41 buildroot kernel: [ 237.176809] rogue-ta3d: @22340 ctx=3 refs=15
Sep 3 13:48:41 buildroot kernel: [ 237.176814] @22270: (++) refs=4 fwaddr=0xc0140121 enqueue=1 status=Signalled 22270-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176818] @22282: (++) refs=4 fwaddr=0xc0140001 enqueue=1 status=Signalled 22282-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176821] @22302: (++) refs=4 fwaddr=0xc01401e9 enqueue=1 status=Signalled 22302-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176824] @22314: (++) refs=4 fwaddr=0xc01400a9 enqueue=1 status=Signalled 22314-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176827] @22318: (++) refs=4 fwaddr=0xc0140259 enqueue=1 status=Signalled 22318-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176829] @22322: (++) refs=4 fwaddr=0xc0140021 enqueue=1 status=Signalled 22322-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176832] @22326: (++) refs=4 fwaddr=0xc0140079 enqueue=1 status=Signalled 22326-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176835] @22330: (++) refs=4 fwaddr=0xc01401f1 enqueue=1 status=Signalled 22330-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176838] @22332: (++) refs=1 fwaddr=0xc0140119 enqueue=1 status=Signalled 22332-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176840] @22334: (++) refs=4 fwaddr=0xc0140139 enqueue=1 status=Signalled 22334-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176843] @22336: (+-) refs=2 fwaddr=0xc0140141 enqueue=1 status=Active 22336-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176846] @22337: (+-) refs=1 fwaddr=0xc01400f9 enqueue=2 status=Active 22337-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176848] @22338: (+-) refs=5 fwaddr=0xc0140211 enqueue=1 status=Active 22338-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176851] @22339: (+-) refs=2 fwaddr=0xc0140179 enqueue=1 status=Active 22339-update fence
Sep 3 13:48:41 buildroot kernel: [ 237.176853] rogue-tq3d: @0 ctx=5 refs=1
Sep 3 13:48:41 buildroot kernel: [ 237.176855] QE-eda-AVMExec-505: @22449 ctx=6 refs=5
Sep 3 13:48:41 buildroot kernel: [ 237.176857] @22445: (+-) refs=2 fwaddr=0xc0140019 enqueue=1 status=Active 22445-TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176860] @22446: (+-) refs=2 fwaddr=0xc0140241 enqueue=2 status=Active 22446-TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176863] @22447: (+-) refs=2 fwaddr=0xc0140209 enqueue=1 status=Active 22447-TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176865] @22448: (+-) refs=2 fwaddr=0xc0140229 enqueue=2 status=Active 22448-TQM
Sep 3 13:48:41 buildroot kernel: [ 237.176868] V3-eda-AVMExec-505: @27978 ctx=7 refs=6
Sep 3 13:48:41 buildroot kernel: [ 237.176871] @27973: (++) refs=3 fwaddr=0xc01400d9 enqueue=1 status=Signalled 27973-es3_DoKickTA_111938
Sep 3 13:48:41 buildroot kernel: [ 237.176873] @27974: (++) refs=1 fwaddr=0xc0140131 enqueue=1 status=Signalled 27974-es3_DoKickTA_111957
Sep 3 13:48:41 buildroot kernel: [ 237.176876] @27975: (+-) refs=2 fwaddr=0xc0140111 enqueue=1 status=Active 27975-es3_DoKickTA_111939
Sep 3 13:48:41 buildroot kernel: [ 237.176879] @27976: (+-) refs=2 fwaddr=0xc01400c1 enqueue=1 status=Active 27976-es3_DoKickTA_111951
Sep 3 13:48:41 buildroot kernel: [ 237.176882] @27977: (+-) refs=2 fwaddr=0xc01401a1 enqueue=1 status=Active 27977-es3_DoKickTA_111956
Sep 3 13:48:41 buildroot kernel: [ 237.176884] P3-eda-AVMExec-505: @27972 ctx=8 refs=7
Sep 3 13:48:41 buildroot kernel: [ 237.176887] @27966: (++) refs=1 fwaddr=0xc01401a9 enqueue=1 status=Signalled 27966-es3_DoKick3D_111936
Sep 3 13:48:41 buildroot kernel: [ 237.176890] @27967: (+-) refs=4 fwaddr=0xc01400e9 enqueue=1 status=Active 27967-es3_DoKick3D_111938
Sep 3 13:48:41 buildroot kernel: [ 237.176893] @27968: (+-) refs=2 fwaddr=0xc0140081 enqueue=1 status=Active 27968-es3_DoKick3D_111957
Sep 3 13:48:41 buildroot kernel: [ 237.176896] @27969: (+-) refs=2 fwaddr=0xc01401c9 enqueue=3 status=Active 27969-es3_DoKick3D_111939
Sep 3 13:48:41 buildroot kernel: [ 237.176899] @27970: (+-) refs=2 fwaddr=0xc0140219 enqueue=3 status=Active 27970-es3_DoKick3D_111951
Sep 3 13:48:41 buildroot kernel: [ 237.176902] @27971: (+-) refs=2 fwaddr=0xc0140279 enqueue=1 status=Active 27971-es3_DoKick3D_111956
Sep 3 13:48:41 buildroot kernel: [ 237.176904] PVR_K: 207: ------------[ PVR DBG: END ]------------
Sep 3 13:48:41 buildroot kernel: [ 237.176962] ------------[ cut here ]------------
Sep 3 13:48:41 buildroot kernel: [ 237.177054] WARNING: CPU: 1 PID: 207 at /root/ONLINE_SERVICE/other/ferry/task_workspace/baidu/acu/single-tda4-psdkla/board-support/extra-drivers/ti-img-rogue-driver-1.10.5371573/binary_j721e_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177056] Modules linked in: iptable_filter xt_tcpudp 8021q garp stp mrp llc xhci_plat_hcd xhci_hcd usbcore cdns3 roles udc_core rpmsg_char usb_common virtio_rpmsg_bus crct10dif_ce ti_j721e_cpsw_virt_mac acu_timesync ti_k3_r5_remoteproc pvrsrvkm(O) sa2ul ti_k3_dsp_remoteproc cdns3_ti sha512_generic authenc sch_fq_codel rpmsg_kdrv_switch ip_tables x_tables ipv6
Sep 3 13:48:41 buildroot kernel: [ 237.177085] CPU: 1 PID: 207 Comm: pvr_device_wdg Tainted: G O 5.4.74-ACU-10.0.66.1 #4
Sep 3 13:48:41 buildroot kernel: [ 237.177086] Hardware name: Texas Instruments K3 J721E SoC (DT)
Sep 3 13:48:41 buildroot kernel: [ 237.177090] pstate: 80000005 (Nzcv daif -PAN -UAO)
Sep 3 13:48:41 buildroot kernel: [ 237.177132] pc : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177173] lr : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177174] sp : ffff8000137cfca0
Sep 3 13:48:41 buildroot kernel: [ 237.177175] x29: ffff8000137cfca0 x28: 0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.177178] x27: 0000000000000000 x26: ffff800008f4bae0
Sep 3 13:48:41 buildroot kernel: [ 237.177181] x25: ffff000849185300 x24: 0000000000000009
Sep 3 13:48:41 buildroot kernel: [ 237.177183] x23: 0000000000000002 x22: 0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.177185] x21: 0000000000000000 x20: ffff0008491853d8
Sep 3 13:48:41 buildroot kernel: [ 237.177188] x19: ffff000846a76aa0 x18: 0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.177190] x17: 0000000000006030 x16: 0000000000006018
Sep 3 13:48:41 buildroot kernel: [ 237.177192] x15: ffff80001112a000 x14: ffff8000111e74e2
Sep 3 13:48:41 buildroot kernel: [ 237.177194] x13: 0000000000000000 x12: ffff8000111e6000
Sep 3 13:48:41 buildroot kernel: [ 237.177196] x11: ffff80001112a000 x10: ffff8000111e6b30
Sep 3 13:48:41 buildroot kernel: [ 237.177198] x9 : 0000000000000000 x8 : 0000000000000000
Sep 3 13:48:41 buildroot kernel: [ 237.177200] x7 : 0000000000000000 x6 : 0000000000000468
Sep 3 13:48:41 buildroot kernel: [ 237.177203] x5 : ffff00087fa81848 x4 : 0000000000000001
Sep 3 13:48:41 buildroot kernel: [ 237.177205] x3 : 0000000000000000 x2 : ffffffffffffff00
Sep 3 13:48:41 buildroot kernel: [ 237.177207] x1 : 0000000000000000 x0 : ffff000846a77e00
Sep 3 13:48:41 buildroot kernel: [ 237.177209] Call trace:
Sep 3 13:48:41 buildroot kernel: [ 237.177251] PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177290] DevicesWatchdogThread_ForEachVaCb+0x100/0x150 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177332] List_PVRSRV_DEVICE_NODE_ForEach_va+0x74/0xb0 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177371] DevicesWatchdogThread+0x13c/0x208 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177409] OSThreadRun+0x20/0x58 [pvrsrvkm]
Sep 3 13:48:41 buildroot kernel: [ 237.177421] kthread+0x138/0x158
Sep 3 13:48:41 buildroot kernel: [ 237.177426] ret_from_fork+0x10/0x1c
Sep 3 13:48:41 buildroot kernel: [ 237.177427] ---[ end trace e33a221189b3f2bb ]---
Sep 3 13:56:01 buildroot kernel: [ 676.664282] PVR_K: 2824: User requested PVR debug info
Sep 3 13:56:01 buildroot kernel: [ 676.664288] PVR_K: 2824: ------------[ PVR DBG: START (High) ]------------
Sep 3 13:56:01 buildroot kernel: [ 676.664291] PVR_K: 2824: OS kernel info: Linux 5.4.74-ACU-10.0.66.1 #4 SMP PREEMPT Fri Jul 19 06:41:15 UTC 2024 aarch64
Sep 3 13:56:01 buildroot kernel: [ 676.664293] PVR_K: 2824: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
Sep 3 13:56:01 buildroot kernel: [ 676.664296] PVR_K: 2824: Time now: 676664294us
Sep 3 13:56:01 buildroot kernel: [ 676.664298] PVR_K: 2824: Services State: OK
Sep 3 13:56:01 buildroot kernel: [ 676.664300] PVR_K: 2824: Server Errors: 0
Sep 3 13:56:01 buildroot kernel: [ 676.664305] PVR_K: 2824: Connections Device ID:0(128) P505-V505-T966-AVMExec, P2824-V2824-T2824-pvrdebug
Sep 3 13:56:01 buildroot kernel: [ 676.664306] PVR_K: 2824: ------[ Driver Info ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664308] PVR_K: 2824: Comparison of UM/KM components: MATCHING
Sep 3 13:56:01 buildroot kernel: [ 676.664310] PVR_K: 2824: KM Arch: 64 Bit
Sep 3 13:56:01 buildroot kernel: [ 676.664312] PVR_K: 2824: UM Connected Clients: 64 Bit
Sep 3 13:56:01 buildroot kernel: [ 676.664314] PVR_K: 2824: UM info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:56:01 buildroot kernel: [ 676.664317] PVR_K: 2824: KM info: 1.15 @ 6133109 (release) build options: 0x00000810
Sep 3 13:56:01 buildroot kernel: [ 676.664319] PVR_K: 2824: Window system: wayland
Sep 3 13:56:01 buildroot kernel: [ 676.664322] PVR_K: 2824: ------[ RGX Device ID:0 Start ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664324] PVR_K: 2824: ------[ RGX Info ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664327] PVR_K: 2824: Device Node (Info): 00000000c7b5bd8d (000000001ac6423b)
Sep 3 13:56:01 buildroot kernel: [ 676.664329] PVR_K: 2824: RGX BVNC: 22.104.208.318 (rogue)
Sep 3 13:56:01 buildroot kernel: [ 676.664331] PVR_K: 2824: RGX Device State: Active
Sep 3 13:56:01 buildroot kernel: [ 676.664333] PVR_K: 2824: RGX Power State: ON
Sep 3 13:56:01 buildroot kernel: [ 676.664336] PVR_K: 2824: FW info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:56:01 buildroot kernel: [ 676.664340] PVR_K: 2824: BIF0 - OK
Sep 3 13:56:01 buildroot kernel: [ 676.664344] PVR_K: 2824: RGX FW State: OK (HWRState 0x00000001: HWR OK;)
Sep 3 13:56:01 buildroot kernel: [ 676.664348] PVR_K: 2824: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
Sep 3 13:56:01 buildroot kernel: [ 676.664352] PVR_K: 2824: RGX DVFS: 0 frequency changes. Current frequency: 749.999 MHz (sampled at 668270529055 ns). FW frequency: 100.000 MHz.
Sep 3 13:56:01 buildroot kernel: [ 676.664354] PVR_K: 2824: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
Sep 3 13:56:01 buildroot kernel: [ 676.664363] PVR_K: 2824: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(1/1+0), 3D(5/5+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
Sep 3 13:56:01 buildroot kernel: [ 676.664365] PVR_K: 2824: DM 0 (GP)
Sep 3 13:56:01 buildroot kernel: [ 676.664369] PVR_K: 2824: DM 1 (HWRflags 0x00000000: working;)
Sep 3 13:56:01 buildroot kernel: [ 676.664371] PVR_K: 2824: DM 2 (HWRflags 0x00000000: working;)
Sep 3 13:56:01 buildroot kernel: [ 676.664375] PVR_K: 2824: Recovery 3: PID = 505, frame = 0, HWRTData = 0xC00C0B00, EventStatus = 0x00000400, Innocent Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664378] PVR_K: 2824: CRTimer = 0x000043f6667a, OSTimer = 390.665579061, CyclesElapsed = 12707328
Sep 3 13:56:01 buildroot kernel: [ 676.664381] PVR_K: 2824: PreResetTimeInCycles = 3996691968, HWResetTimeInCycles = 22272, FreelistReconTimeInCycles = 391936, TotalRecoveryTimeInCycles = 3997106176
Sep 3 13:56:01 buildroot kernel: [ 676.664384] PVR_K: 2824: T0 polling set (reg:0x000003B0 mask:0x00000002 last:0x00000000)
Sep 3 13:56:01 buildroot kernel: [ 676.664387] PVR_K: 2824: DM 3 (HWRflags 0x00000000: working;)
Sep 3 13:56:01 buildroot kernel: [ 676.664390] PVR_K: 2824: Recovery 1: PID = 505, frame = 0, HWRTData = 0xC00C1B40, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664392] PVR_K: 2824: CRTimer = 0x00002928b03d, OSTimer = 237.171682829, CyclesElapsed = 45940992
Sep 3 13:56:01 buildroot kernel: [ 676.664395] PVR_K: 2824: PreResetTimeInCycles = 38912, HWResetTimeInCycles = 18944, FreelistReconTimeInCycles = 239616, TotalRecoveryTimeInCycles = 297472
Sep 3 13:56:01 buildroot kernel: [ 676.664398] PVR_K: 2824: Recovery 2: PID = 505, frame = 0, HWRTData = 0xC00C21C0, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664401] PVR_K: 2824: CRTimer = 0x000043f59890, OSTimer = 390.647586015, CyclesElapsed = 40149504
Sep 3 13:56:01 buildroot kernel: [ 676.664403] PVR_K: 2824: PreResetTimeInCycles = 40448, HWResetTimeInCycles = 19968, FreelistReconTimeInCycles = 245760, TotalRecoveryTimeInCycles = 306176
Sep 3 13:56:01 buildroot kernel: [ 676.664406] PVR_K: 2824: Recovery 3: PID = 505, frame = 0, HWRTData = 0xC00C1E80, EventStatus = 0x00000400, Innocent Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664409] PVR_K: 2824: CRTimer = 0x000043f666ee, OSTimer = 390.665618655, CyclesElapsed = 12677120
Sep 3 13:56:01 buildroot kernel: [ 676.664411] PVR_K: 2824: PreResetTimeInCycles = 3996662272, HWResetTimeInCycles = 22272, FreelistReconTimeInCycles = 391936, TotalRecoveryTimeInCycles = 3997076480
Sep 3 13:56:01 buildroot kernel: [ 676.664414] PVR_K: 2824: T0 polling set (reg:0x000003B0 mask:0x00000002 last:0x00000000)
Sep 3 13:56:01 buildroot kernel: [ 676.664417] PVR_K: 2824: Recovery 4: PID = 505, frame = 0, HWRTData = 0xC00C2B80, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664420] PVR_K: 2824: CRTimer = 0x00004da153ab, OSTimer = 446.028748212, CyclesElapsed = 47842048
Sep 3 13:56:01 buildroot kernel: [ 676.664422] PVR_K: 2824: PreResetTimeInCycles = 40192, HWResetTimeInCycles = 19200, FreelistReconTimeInCycles = 231680, TotalRecoveryTimeInCycles = 291072
Sep 3 13:56:01 buildroot kernel: [ 676.664425] PVR_K: 2824: Recovery 5: PID = 505, frame = 0, HWRTData = 0xC00C21C0, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:56:01 buildroot kernel: [ 676.664427] PVR_K: 2824: CRTimer = 0x00006cdb2e09, OSTimer = 624.848212866, CyclesElapsed = 39648000
Sep 3 13:56:01 buildroot kernel: [ 676.664430] PVR_K: 2824: PreResetTimeInCycles = 40192, HWResetTimeInCycles = 20480, FreelistReconTimeInCycles = 236544, TotalRecoveryTimeInCycles = 297216
Sep 3 13:56:01 buildroot kernel: [ 676.664432] PVR_K: 2824: DM 4 (HWRflags 0x00000000: working;)
Sep 3 13:56:01 buildroot kernel: [ 676.664434] PVR_K: 2824: DM 5 (HWRflags 0x00000000: working;)
Sep 3 13:56:01 buildroot kernel: [ 676.664437] PVR_K: 2824: RGX Kernel CCB WO:0x1A RO:0x1A
Sep 3 13:56:01 buildroot kernel: [ 676.664439] PVR_K: 2824: RGX Firmware CCB WO:0x15 RO:0x15
Sep 3 13:56:01 buildroot kernel: [ 676.664440] PVR_K: 2824: RGX Kernel CCB commands executed = 328474
Sep 3 13:56:01 buildroot kernel: [ 676.664442] PVR_K: 2824: RGX SLR: Forced UFO updates requested = 0
Sep 3 13:56:01 buildroot kernel: [ 676.664444] PVR_K: 2824: RGX Errors: WGP:0, TRP:0
Sep 3 13:56:01 buildroot kernel: [ 676.664446] PVR_K: 2824: Thread0: FW IRQ count = 411027
Sep 3 13:56:01 buildroot kernel: [ 676.664448] PVR_K: 2824: Last sampled IRQ count in LISR = 411027
Sep 3 13:56:01 buildroot kernel: [ 676.664452] PVR_K: 2824: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
Sep 3 13:56:01 buildroot kernel: [ 676.664454] PVR_K: 2824: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
Sep 3 13:56:01 buildroot kernel: [ 676.664457] PVR_K: 2824: ------[ RGX registers ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664459] PVR_K: 2824: RGX Register Base Address (Linear): 0x00000000b4d0f7c8
Sep 3 13:56:01 buildroot kernel: [ 676.664461] PVR_K: 2824: RGX Register Base Address (Physical): 0x4E20000000
Sep 3 13:56:01 buildroot kernel: [ 676.664464] PVR_K: 2824: CORE_ID : 0x0000000008470000
Sep 3 13:56:01 buildroot kernel: [ 676.664466] PVR_K: 2824: CORE_REVISION : 0x00D0013E
Sep 3 13:56:01 buildroot kernel: [ 676.664469] PVR_K: 2824: DESIGNER_REV_FIELD1 : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664471] PVR_K: 2824: DESIGNER_REV_FIELD2 : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664473] PVR_K: 2824: CHANGESET_NUMBER : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664476] PVR_K: 2824: CLK_CTRL : 0x0aaaaa002a2aaaaa
Sep 3 13:56:01 buildroot kernel: [ 676.664479] PVR_K: 2824: CLK_STATUS : 0x0000000000600000
Sep 3 13:56:01 buildroot kernel: [ 676.664481] PVR_K: 2824: CLK_CTRL2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664484] PVR_K: 2824: CLK_STATUS2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664486] PVR_K: 2824: EVENT_STATUS : 0x00000410
Sep 3 13:56:01 buildroot kernel: [ 676.664489] PVR_K: 2824: TIMER : 0x0000000075e760ab
Sep 3 13:56:01 buildroot kernel: [ 676.664491] PVR_K: 2824: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664494] PVR_K: 2824: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664496] PVR_K: 2824: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664498] PVR_K: 2824: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664508] PVR_K: 2824: BIF_MMU_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664510] PVR_K: 2824: BIF_MMU_ENTRY : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664513] PVR_K: 2824: BIF_MMU_ENTRY_STATUS : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664516] PVR_K: 2824: BIF_STATUS_MMU : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664518] PVR_K: 2824: BIF_READS_EXT_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664520] PVR_K: 2824: BIF_READS_INT_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664523] PVR_K: 2824: BIFPM_STATUS_MMU : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664525] PVR_K: 2824: BIFPM_READS_EXT_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664527] PVR_K: 2824: BIFPM_READS_INT_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664530] PVR_K: 2824: BIF_CAT_BASE_INDEX : 0x0000000000000101
Sep 3 13:56:01 buildroot kernel: [ 676.664533] PVR_K: 2824: BIF_CAT_BASE0 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664535] PVR_K: 2824: BIF_CAT_BASE1 : 0x00000008bd050000
Sep 3 13:56:01 buildroot kernel: [ 676.664538] PVR_K: 2824: BIF_CAT_BASE2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664540] PVR_K: 2824: BIF_CAT_BASE3 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664542] PVR_K: 2824: BIF_CAT_BASE4 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664545] PVR_K: 2824: BIF_CAT_BASE5 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664547] PVR_K: 2824: BIF_CAT_BASE6 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664550] PVR_K: 2824: BIF_CAT_BASE7 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664552] PVR_K: 2824: BIF_CTRL_INVAL : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664554] PVR_K: 2824: BIF_CTRL : 0x000000C0
Sep 3 13:56:01 buildroot kernel: [ 676.664557] PVR_K: 2824: BIF_PM_CAT_BASE_VCE0 : 0x00000000fcdfa001
Sep 3 13:56:01 buildroot kernel: [ 676.664560] PVR_K: 2824: BIF_PM_CAT_BASE_TE0 : 0x00000000fcdf7001
Sep 3 13:56:01 buildroot kernel: [ 676.664562] PVR_K: 2824: BIF_PM_CAT_BASE_ALIST0 : 0x000000008fbc7001
Sep 3 13:56:01 buildroot kernel: [ 676.664565] PVR_K: 2824: BIF_PM_CAT_BASE_VCE1 : 0x00000008f9f42001
Sep 3 13:56:01 buildroot kernel: [ 676.664567] PVR_K: 2824: BIF_PM_CAT_BASE_TE1 : 0x00000008b421f001
Sep 3 13:56:01 buildroot kernel: [ 676.664570] PVR_K: 2824: BIF_PM_CAT_BASE_ALIST1 : 0x00000008f9f47001
Sep 3 13:56:01 buildroot kernel: [ 676.664572] PVR_K: 2824: PERF_TA_PHASE : 0x0000192D
Sep 3 13:56:01 buildroot kernel: [ 676.664574] PVR_K: 2824: PERF_TA_CYCLE : 0x40A73483
Sep 3 13:56:01 buildroot kernel: [ 676.664576] PVR_K: 2824: PERF_3D_PHASE : 0x000064B4
Sep 3 13:56:01 buildroot kernel: [ 676.664578] PVR_K: 2824: PERF_3D_CYCLE : 0x41ED8966
Sep 3 13:56:01 buildroot kernel: [ 676.664581] PVR_K: 2824: PERF_TA_OR_3D_CYCLE : 0x682215A5
Sep 3 13:56:01 buildroot kernel: [ 676.664583] PVR_K: 2824: PERF_TA_AND_3D_CYCLE : 0x1A72A844
Sep 3 13:56:01 buildroot kernel: [ 676.664585] PVR_K: 2824: PERF_COMPUTE_PHASE : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664588] PVR_K: 2824: PERF_COMPUTE_CYCLE : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664590] PVR_K: 2824: PM_PARTIAL_RENDER_ENABLE : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664592] PVR_K: 2824: ISP_RENDER : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664594] PVR_K: 2824: TLA_STATUS : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664597] PVR_K: 2824: MCU_FENCE : 0x0000018000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664599] PVR_K: 2824: VDM_CONTEXT_STORE_STATUS : 0x00000001
Sep 3 13:56:01 buildroot kernel: [ 676.664602] PVR_K: 2824: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664604] PVR_K: 2824: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664607] PVR_K: 2824: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664609] PVR_K: 2824: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664612] PVR_K: 2824: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664614] PVR_K: 2824: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664617] PVR_K: 2824: ISP_CTL : 0x0003500F
Sep 3 13:56:01 buildroot kernel: [ 676.664619] PVR_K: 2824: ISP_STATUS : 0x00000003
Sep 3 13:56:01 buildroot kernel: [ 676.664621] PVR_K: 2824: MTS_INTCTX : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664623] PVR_K: 2824: MTS_BGCTX : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664625] PVR_K: 2824: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664627] PVR_K: 2824: MTS_SCHEDULE : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664629] PVR_K: 2824: MTS_GPU_INT_STATUS : 0x00004550
Sep 3 13:56:01 buildroot kernel: [ 676.664632] PVR_K: 2824: CDM_CONTEXT_STORE_STATUS : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664634] PVR_K: 2824: CDM_CONTEXT_PDS0 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664637] PVR_K: 2824: CDM_CONTEXT_PDS1 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664639] PVR_K: 2824: CDM_TERMINATE_PDS : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664642] PVR_K: 2824: CDM_TERMINATE_PDS1 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664644] PVR_K: 2824: SIDEKICK_IDLE : 0x0000007E
Sep 3 13:56:01 buildroot kernel: [ 676.664646] PVR_K: 2824: SLC_IDLE : 0x000000FF
Sep 3 13:56:01 buildroot kernel: [ 676.664648] PVR_K: 2824: SLC_STATUS0 : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664651] PVR_K: 2824: SLC_STATUS1 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664653] PVR_K: 2824: SLC_STATUS2 : 0x0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.664655] PVR_K: 2824: SLC_CTRL_BYPASS : 0x01000000
Sep 3 13:56:01 buildroot kernel: [ 676.664658] PVR_K: 2824: SLC_CTRL_MISC : 0x0000000000200003
Sep 3 13:56:01 buildroot kernel: [ 676.664661] PVR_K: 2824: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
Sep 3 13:56:01 buildroot kernel: [ 676.664663] PVR_K: 2824: MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:56:01 buildroot kernel: [ 676.664666] PVR_K: 2824: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
Sep 3 13:56:01 buildroot kernel: [ 676.664668] PVR_K: 2824: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008bc8ee00c
Sep 3 13:56:01 buildroot kernel: [ 676.664670] PVR_K: 2824: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
Sep 3 13:56:01 buildroot kernel: [ 676.664673] PVR_K: 2824: MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008bc8dd00c
Sep 3 13:56:01 buildroot kernel: [ 676.664675] PVR_K: 2824: MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
Sep 3 13:56:01 buildroot kernel: [ 676.664677] PVR_K: 2824: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
Sep 3 13:56:01 buildroot kernel: [ 676.664680] PVR_K: 2824: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
Sep 3 13:56:01 buildroot kernel: [ 676.664682] PVR_K: 2824: MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:56:01 buildroot kernel: [ 676.664685] PVR_K: 2824: MIPS_WRAPPER_CONFIG : 0x000000000001cf80
Sep 3 13:56:01 buildroot kernel: [ 676.664687] PVR_K: 2824: MIPS_EXCEPTION_STATUS : 0x00000020
Sep 3 13:56:01 buildroot kernel: [ 676.664754] PVR_K: 2824: ---- [ MIPS internal state ] ----
Sep 3 13:56:01 buildroot kernel: [ 676.664756] PVR_K: 2824: PC : 0xC0017118
Sep 3 13:56:01 buildroot kernel: [ 676.664758] PVR_K: 2824: STATUS_REGISTER : 0x00481C05
Sep 3 13:56:01 buildroot kernel: [ 676.664760] PVR_K: 2824: CAUSE_REGISTER : 0x00800000
Sep 3 13:56:01 buildroot kernel: [ 676.664762] PVR_K: 2824: BAD_REGISTER : 0xC0160058
Sep 3 13:56:01 buildroot kernel: [ 676.664764] PVR_K: 2824: EPC : 0xC001711C
Sep 3 13:56:01 buildroot kernel: [ 676.664765] PVR_K: 2824: SP : 0xCF600FE0
Sep 3 13:56:01 buildroot kernel: [ 676.664767] PVR_K: 2824: BAD_INSTRUCTION : 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664769] PVR_K: 2824: TLB :
Sep 3 13:56:01 buildroot kernel: [ 676.664773] PVR_K: 2824: 0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664776] PVR_K: 2824: 1) VA 0xCF000000 ( 16k) -> PA0 0x8bc840000 DVGC, PA1 0x8bc844000 DVGC
Sep 3 13:56:01 buildroot kernel: [ 676.664779] PVR_K: 2824: 2) VA 0xCF600000 ( 4k) -> PA0 0x8bc8ef000 DV C, PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664782] PVR_K: 2824: 3) VA 0xC0080000 ( 64k) -> PA0 0x8bc920000 DVG , PA1 0x8bc940000 DVG
Sep 3 13:56:01 buildroot kernel: [ 676.664785] PVR_K: 2824: 4) VA 0xF0080000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664787] PVR_K: 2824: 5) VA 0xC0120000 ( 64k) -> PA0 0x00000000 C, PA1 0x880ee0000 DV
Sep 3 13:56:01 buildroot kernel: [ 676.664790] PVR_K: 2824: 6) VA 0xC0000000 ( 64k) -> PA0 0x8bc8a0000 DVGC, PA1 0x8bc8b0000 DVGC
Sep 3 13:56:01 buildroot kernel: [ 676.664792] PVR_K: 2824: 7) VA 0xC0140000 ( 64k) -> PA0 0x8839d0000 DVG , PA1 0xfce80000 DVG
Sep 3 13:56:01 buildroot kernel: [ 676.664795] PVR_K: 2824: 8) VA 0xC0100000 ( 64k) -> PA0 0x8bd830000 DVGC, PA1 0x880ed0000 DVGC
Sep 3 13:56:01 buildroot kernel: [ 676.664798] PVR_K: 2824: 9) VA 0xF0120000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664800] PVR_K: 2824: 10) VA 0xC00C0000 ( 64k) -> PA0 0x8bd2a0000 DVGC, PA1 0x8bd810000 DVGC
Sep 3 13:56:01 buildroot kernel: [ 676.664803] PVR_K: 2824: 11) VA 0xF0160000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664805] PVR_K: 2824: 12) VA 0xC0040000 ( 64k) -> PA0 0x8bc8e0000 DVGC, PA1 0x8bc8f0000 DVG
Sep 3 13:56:01 buildroot kernel: [ 676.664808] PVR_K: 2824: 13) VA 0xC0060000 ( 64k) -> PA0 0x8bc900000 DVG , PA1 0x8bc910000 VGC
Sep 3 13:56:01 buildroot kernel: [ 676.664810] PVR_K: 2824: 14) VA 0xC00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x8bd820000 DV C
Sep 3 13:56:01 buildroot kernel: [ 676.664813] PVR_K: 2824: 15) VA 0xC0160000 ( 64k) -> PA0 0xfe220000 DV , PA1 0x00000000 C
Sep 3 13:56:01 buildroot kernel: [ 676.664817] PVR_K: 2824: --------------------------------
Sep 3 13:56:01 buildroot kernel: [ 676.664818] PVR_K: 2824: ------[ RGX FW Trace Info ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664820] PVR_K: 2824: Debug log type: none
Sep 3 13:56:01 buildroot kernel: [ 676.664822] PVR_K: 2824: RGX FW thread 0: Trace buffer not yet allocated
Sep 3 13:56:01 buildroot kernel: [ 676.664824] PVR_K: 2824: ------[ Full CCB Status ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664828] PVR_K: 2824: FWCtx 0xC00C0300 (TQ_3D-P505-T966-AVMExec)
Sep 3 13:56:01 buildroot kernel: [ 676.664829] PVR_K: 2824: `--<Empty>
Sep 3 13:56:01 buildroot kernel: [ 676.664832] PVR_K: 2824: FWCtx 0xC00C0040 (TA-P505-T966-AVMExec)
Sep 3 13:56:01 buildroot kernel: [ 676.664834] PVR_K: 2824: `--<Empty>
Sep 3 13:56:01 buildroot kernel: [ 676.664836] PVR_K: 2824: FWCtx 0xC00C00E0 (3D-P505-T966-AVMExec)
Sep 3 13:56:01 buildroot kernel: [ 676.664838] PVR_K: 2824: `--<Empty>
Sep 3 13:56:01 buildroot kernel: [ 676.664840] PVR_K: 2824: ------[ RGX Device ID:0 End ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664843] PVR_K: 2824: ------[ System Summary Device ID:0 ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664844] PVR_K: 2824: Device System Power State: ON
Sep 3 13:56:01 buildroot kernel: [ 676.664847] PVR_K: 2824: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
Sep 3 13:56:01 buildroot kernel: [ 676.664849] PVR_K: 2824: ------[ Server Thread Summary ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664851] PVR_K: 2824: pvr_defer_free : Running
Sep 3 13:56:01 buildroot kernel: [ 676.664853] PVR_K: 2824: Number of deferred cleanup items : 0
Sep 3 13:56:01 buildroot kernel: [ 676.664855] PVR_K: 2824: pvr_device_wdg : Running
Sep 3 13:56:01 buildroot kernel: [ 676.664857] PVR_K: 2824: pvr_cacheop : Running
Sep 3 13:56:01 buildroot kernel: [ 676.664860] PVR_K: 2824: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes
Sep 3 13:56:01 buildroot kernel: [ 676.664862] PVR_K: 2824: Pending deferred CacheOp entries : 0
Sep 3 13:56:01 buildroot kernel: [ 676.664864] PVR_K: 2824: ------[ AppHint Settings ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664866] PVR_K: 2824: Build Vars
Sep 3 13:56:01 buildroot kernel: [ 676.664870] PVR_K: 2824: EnableTrustedDeviceAceConfig: N
Sep 3 13:56:01 buildroot kernel: [ 676.664872] PVR_K: 2824: CleanupThreadPriority: 0x00000005
Sep 3 13:56:01 buildroot kernel: [ 676.664874] PVR_K: 2824: CacheOpThreadPriority: 0x00000001
Sep 3 13:56:01 buildroot kernel: [ 676.664876] PVR_K: 2824: WatchdogThreadPriority: 0x00000000
Sep 3 13:56:01 buildroot kernel: [ 676.664878] PVR_K: 2824: HWPerfClientBufferSize: 0x000c0000
Sep 3 13:56:01 buildroot kernel: [ 676.664879] PVR_K: 2824: Module Params
Sep 3 13:56:01 buildroot kernel: [ 676.664884] PVR_K: 2824: none
Sep 3 13:56:01 buildroot kernel: [ 676.664886] PVR_K: 2824: Debug Info Params
Sep 3 13:56:01 buildroot kernel: [ 676.664889] PVR_K: 2824: CacheOpConfig: 0x0000000c
Sep 3 13:56:01 buildroot kernel: [ 676.664891] PVR_K: 2824: CacheOpUMKMThresholdSize: 0xffffffff
Sep 3 13:56:01 buildroot kernel: [ 676.664894] PVR_K: 2824: Debug Info Params Device ID: 0
Sep 3 13:56:01 buildroot kernel: [ 676.664897] PVR_K: 2824: none
Sep 3 13:56:01 buildroot kernel: [ 676.664899] PVR_K: 2824: ------[ HTB Log state: Off ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664902] PVR_K: 2824: ------[ Active Sync Checkpoints ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664908] ------[ Native Fence Sync: timelines ]------
Sep 3 13:56:01 buildroot kernel: [ 676.664911] foreign_sync: @0 ctx=1 refs=1
Sep 3 13:56:01 buildroot kernel: [ 676.664914] sw: RM_SWTimeline-eda-AVMExec-505 @0 cur=0
Sep 3 13:56:01 buildroot kernel: [ 676.664916] rogue-ta3d: @65584 ctx=3 refs=14
Sep 3 13:56:01 buildroot kernel: [ 676.664920] @65530: (++) refs=4 fwaddr=0xc0140689 enqueue=1 status=Signalled 65530-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664923] @65546: (++) refs=4 fwaddr=0xc0140449 enqueue=1 status=Signalled 65546-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664926] @65550: (++) refs=4 fwaddr=0xc01402d9 enqueue=1 status=Signalled 65550-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664928] @65558: (++) refs=4 fwaddr=0xc0140389 enqueue=1 status=Signalled 65558-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664931] @65562: (++) refs=4 fwaddr=0xc01406a9 enqueue=1 status=Signalled 65562-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664934] @65566: (++) refs=4 fwaddr=0xc01404d9 enqueue=1 status=Signalled 65566-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664936] @65570: (++) refs=4 fwaddr=0xc0140481 enqueue=1 status=Signalled 65570-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664938] @65574: (++) refs=4 fwaddr=0xc0140369 enqueue=1 status=Signalled 65574-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664941] @65576: (++) refs=1 fwaddr=0xc0140261 enqueue=1 status=Signalled 65576-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664943] @65578: (++) refs=4 fwaddr=0xc0140639 enqueue=1 status=Signalled 65578-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664946] @65580: (++) refs=1 fwaddr=0xc0140659 enqueue=1 status=Signalled 65580-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664948] @65582: (++) refs=4 fwaddr=0xc0140519 enqueue=1 status=Signalled 65582-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664951] @65583: (++) refs=1 fwaddr=0xc01403f9 enqueue=1 status=Signalled 65583-update fence
Sep 3 13:56:01 buildroot kernel: [ 676.664953] rogue-tq3d: @0 ctx=5 refs=1
Sep 3 13:56:01 buildroot kernel: [ 676.664955] QE-eda-AVMExec-505: @65693 ctx=6 refs=5
Sep 3 13:56:01 buildroot kernel: [ 676.664957] @65689: (++) refs=1 fwaddr=0xc01405c9 enqueue=1 status=Signalled 65689-TQM
Sep 3 13:56:01 buildroot kernel: [ 676.664960] @65690: (++) refs=1 fwaddr=0xc0140679 enqueue=2 status=Signalled 65690-TQM
Sep 3 13:56:01 buildroot kernel: [ 676.664962] @65691: (++) refs=1 fwaddr=0xc01406c1 enqueue=1 status=Signalled 65691-TQM
Sep 3 13:56:01 buildroot kernel: [ 676.664965] @65692: (++) refs=1 fwaddr=0xc01406c9 enqueue=2 status=Signalled 65692-TQM
Sep 3 13:56:01 buildroot kernel: [ 676.664967] V3-eda-AVMExec-505: @82166 ctx=7 refs=2
Sep 3 13:56:01 buildroot kernel: [ 676.664969] @82165: (++) refs=1 fwaddr=0xc0140059 enqueue=1 status=Signalled 82165-es3_DoKickTA_328309
Sep 3 13:56:01 buildroot kernel: [ 676.664971] P3-eda-AVMExec-505: @82160 ctx=8 refs=4
Sep 3 13:56:01 buildroot kernel: [ 676.664974] @82157: (++) refs=1 fwaddr=0xc01400c9 enqueue=3 status=Signalled 82157-es3_DoKick3D_328292
Sep 3 13:56:01 buildroot kernel: [ 676.664976] @82158: (++) refs=1 fwaddr=0xc01401e1 enqueue=3 status=Signalled 82158-es3_DoKick3D_328304
Sep 3 13:56:01 buildroot kernel: [ 676.664979] @82159: (++) refs=1 fwaddr=0xc01402f9 enqueue=1 status=Signalled 82159-es3_DoKick3D_328309
Sep 3 13:56:01 buildroot kernel: [ 676.664980] PVR_K: 2824: ------------[ PVR DBG: END ]------------
Sep 3 13:56:01 buildroot kernel: [ 676.665010] ------------[ cut here ]------------
Sep 3 13:56:01 buildroot kernel: [ 676.665066] WARNING: CPU: 0 PID: 2824 at /root/ONLINE_SERVICE/other/ferry/task_workspace/baidu/acu/single-tda4-psdkla/board-support/extra-drivers/ti-img-rogue-driver-1.10.5371573/binary_j721e_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665068] Modules linked in: iptable_filter xt_tcpudp 8021q garp stp mrp llc xhci_plat_hcd xhci_hcd usbcore cdns3 roles udc_core rpmsg_char usb_common virtio_rpmsg_bus crct10dif_ce ti_j721e_cpsw_virt_mac acu_timesync ti_k3_r5_remoteproc pvrsrvkm(O) sa2ul ti_k3_dsp_remoteproc cdns3_ti sha512_generic authenc sch_fq_codel rpmsg_kdrv_switch ip_tables x_tables ipv6
Sep 3 13:56:01 buildroot kernel: [ 676.665090] CPU: 0 PID: 2824 Comm: pvrdebug Tainted: G W O 5.4.74-ACU-10.0.66.1 #4
Sep 3 13:56:01 buildroot kernel: [ 676.665091] Hardware name: Texas Instruments K3 J721E SoC (DT)
Sep 3 13:56:01 buildroot kernel: [ 676.665094] pstate: 80000005 (Nzcv daif -PAN -UAO)
Sep 3 13:56:01 buildroot kernel: [ 676.665135] pc : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665175] lr : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665177] sp : ffff800126f8fa70
Sep 3 13:56:01 buildroot kernel: [ 676.665178] x29: ffff800126f8fa70 x28: ffff000845086000
Sep 3 13:56:01 buildroot kernel: [ 676.665181] x27: 0000000000000008 x26: ffff800008f4bae0
Sep 3 13:56:01 buildroot kernel: [ 676.665183] x25: ffff000849185300 x24: 0000000000000009
Sep 3 13:56:01 buildroot kernel: [ 676.665185] x23: 0000000000000002 x22: 0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.665187] x21: 0000000000000000 x20: ffff0008491853d8
Sep 3 13:56:01 buildroot kernel: [ 676.665189] x19: ffff000846a76aa0 x18: 0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.665191] x17: 0000000000006030 x16: 0000000000006018
Sep 3 13:56:01 buildroot kernel: [ 676.665193] x15: ffff80001112a000 x14: ffff8000111e74e2
Sep 3 13:56:01 buildroot kernel: [ 676.665195] x13: 0000000000000000 x12: ffff8000111e6000
Sep 3 13:56:01 buildroot kernel: [ 676.665197] x11: ffff80001112a000 x10: ffff8000111e6b30
Sep 3 13:56:01 buildroot kernel: [ 676.665199] x9 : 0000000000000000 x8 : 0000000000000000
Sep 3 13:56:01 buildroot kernel: [ 676.665201] x7 : 0000000000000000 x6 : 0000000000000583
Sep 3 13:56:01 buildroot kernel: [ 676.665203] x5 : ffff00087fa61848 x4 : 0000000000000001
Sep 3 13:56:01 buildroot kernel: [ 676.665205] x3 : 0000000000000000 x2 : ffffffffffffff00
Sep 3 13:56:01 buildroot kernel: [ 676.665207] x1 : 0000000000000000 x0 : ffff000846a77e00
Sep 3 13:56:01 buildroot kernel: [ 676.665209] Call trace:
Sep 3 13:56:01 buildroot kernel: [ 676.665249] PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665289] PVRSRVDumpDebugInfoKM+0x3c/0x58 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665328] PVRSRVBridgeDumpDebugInfo+0x34/0x50 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665368] BridgedDispatchKM+0x14c/0x550 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665407] PVRSRV_BridgeDispatchKM+0xac/0x180 [pvrsrvkm]
Sep 3 13:56:01 buildroot kernel: [ 676.665416] drm_ioctl_kernel+0xb8/0x108
Sep 3 13:56:01 buildroot kernel: [ 676.665418] drm_ioctl+0x210/0x468
Sep 3 13:56:01 buildroot kernel: [ 676.665422] do_vfs_ioctl+0x964/0xb48
Sep 3 13:56:01 buildroot kernel: [ 676.665424] ksys_ioctl+0x78/0xa8
Sep 3 13:56:01 buildroot kernel: [ 676.665426] __arm64_sys_ioctl+0x1c/0xb8
Sep 3 13:56:01 buildroot kernel: [ 676.665429] el0_svc_common.constprop.0+0x68/0x160
Sep 3 13:56:01 buildroot kernel: [ 676.665432] el0_svc_handler+0x20/0x80
Sep 3 13:56:01 buildroot kernel: [ 676.665434] el0_svc+0x8/0x204
Sep 3 13:56:01 buildroot kernel: [ 676.665436] ---[ end trace e33a221189b3f2bc ]---
Sep 3 13:58:26 buildroot kernel: [ 821.839432] PVR_K: 4243: User requested PVR debug info
Sep 3 13:58:26 buildroot kernel: [ 821.839439] PVR_K: 4243: ------------[ PVR DBG: START (High) ]------------
Sep 3 13:58:26 buildroot kernel: [ 821.839443] PVR_K: 4243: OS kernel info: Linux 5.4.74-ACU-10.0.66.1 #4 SMP PREEMPT Fri Jul 19 06:41:15 UTC 2024 aarch64
Sep 3 13:58:26 buildroot kernel: [ 821.839445] PVR_K: 4243: DDK info: Rogue_DDK_Linux_WS rogueddk 1.15@6133109 (release) j721e_linux
Sep 3 13:58:26 buildroot kernel: [ 821.839448] PVR_K: 4243: Time now: 821839446us
Sep 3 13:58:26 buildroot kernel: [ 821.839450] PVR_K: 4243: Services State: OK
Sep 3 13:58:26 buildroot kernel: [ 821.839452] PVR_K: 4243: Server Errors: 0
Sep 3 13:58:26 buildroot kernel: [ 821.839457] PVR_K: 4243: Connections Device ID:0(128) P505-V505-T966-AVMExec, P4243-V4243-T4243-pvrdebug
Sep 3 13:58:26 buildroot kernel: [ 821.839460] PVR_K: 4243: ------[ Driver Info ]------
Sep 3 13:58:26 buildroot kernel: [ 821.839462] PVR_K: 4243: Comparison of UM/KM components: MATCHING
Sep 3 13:58:26 buildroot kernel: [ 821.839463] PVR_K: 4243: KM Arch: 64 Bit
Sep 3 13:58:26 buildroot kernel: [ 821.839465] PVR_K: 4243: UM Connected Clients: 64 Bit
Sep 3 13:58:26 buildroot kernel: [ 821.839468] PVR_K: 4243: UM info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:58:26 buildroot kernel: [ 821.839470] PVR_K: 4243: KM info: 1.15 @ 6133109 (release) build options: 0x00000810
Sep 3 13:58:26 buildroot kernel: [ 821.839472] PVR_K: 4243: Window system: wayland
Sep 3 13:58:26 buildroot kernel: [ 821.839476] PVR_K: 4243: ------[ RGX Device ID:0 Start ]------
Sep 3 13:58:26 buildroot kernel: [ 821.839478] PVR_K: 4243: ------[ RGX Info ]------
Sep 3 13:58:26 buildroot kernel: [ 821.839481] PVR_K: 4243: Device Node (Info): 00000000c7b5bd8d (000000001ac6423b)
Sep 3 13:58:26 buildroot kernel: [ 821.839483] PVR_K: 4243: RGX BVNC: 22.104.208.318 (rogue)
Sep 3 13:58:26 buildroot kernel: [ 821.839486] PVR_K: 4243: RGX Device State: Active
Sep 3 13:58:26 buildroot kernel: [ 821.839488] PVR_K: 4243: RGX Power State: ON
Sep 3 13:58:26 buildroot kernel: [ 821.839491] PVR_K: 4243: FW info: 1.15 @ 6133109 (release) build options: 0x80000810
Sep 3 13:58:26 buildroot kernel: [ 821.839495] PVR_K: 4243: BIF0 - OK
Sep 3 13:58:26 buildroot kernel: [ 821.839500] PVR_K: 4243: RGX FW State: OK (HWRState 0x00000011: HWR OK; DM running ok;)
Sep 3 13:58:26 buildroot kernel: [ 821.839505] PVR_K: 4243: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms)
Sep 3 13:58:26 buildroot kernel: [ 821.839509] PVR_K: 4243: RGX DVFS: 0 frequency changes. Current frequency: 749.999 MHz (sampled at 818320432735 ns). FW frequency: 100.000 MHz.
Sep 3 13:58:26 buildroot kernel: [ 821.839512] PVR_K: 4243: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; MTS on;
Sep 3 13:58:26 buildroot kernel: [ 821.839522] PVR_K: 4243: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(1/1+0), 3D(6/6+0), CDM(0/0+0), RAY(0/0+0), FALSE(0,0,0,0,0,0)
Sep 3 13:58:26 buildroot kernel: [ 821.839525] PVR_K: 4243: DM 0 (GP)
Sep 3 13:58:26 buildroot kernel: [ 821.839530] PVR_K: 4243: DM 1 (HWRflags 0x00000000: working;)
Sep 3 13:58:26 buildroot kernel: [ 821.839532] PVR_K: 4243: DM 2 (HWRflags 0x00000000: working;)
Sep 3 13:58:26 buildroot kernel: [ 821.839536] PVR_K: 4243: Recovery 3: PID = 505, frame = 0, HWRTData = 0xC00C0B00, EventStatus = 0x00000400, Innocent Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839539] PVR_K: 4243: CRTimer = 0x000043f6667a, OSTimer = 390.665579061, CyclesElapsed = 12707328
Sep 3 13:58:26 buildroot kernel: [ 821.839544] PVR_K: 4243: PreResetTimeInCycles = 3996691968, HWResetTimeInCycles = 22272, FreelistReconTimeInCycles = 391936, TotalRecoveryTimeInCycles = 3997106176
Sep 3 13:58:26 buildroot kernel: [ 821.839547] PVR_K: 4243: T0 polling set (reg:0x000003B0 mask:0x00000002 last:0x00000000)
Sep 3 13:58:26 buildroot kernel: [ 821.839550] PVR_K: 4243: DM 3 (HWRflags 0x00000000: working;)
Sep 3 13:58:26 buildroot kernel: [ 821.839553] PVR_K: 4243: Recovery 1: PID = 505, frame = 0, HWRTData = 0xC00C1B40, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839556] PVR_K: 4243: CRTimer = 0x00002928b03d, OSTimer = 237.171682829, CyclesElapsed = 45940992
Sep 3 13:58:26 buildroot kernel: [ 821.839559] PVR_K: 4243: PreResetTimeInCycles = 38912, HWResetTimeInCycles = 18944, FreelistReconTimeInCycles = 239616, TotalRecoveryTimeInCycles = 297472
Sep 3 13:58:26 buildroot kernel: [ 821.839562] PVR_K: 4243: Recovery 2: PID = 505, frame = 0, HWRTData = 0xC00C21C0, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839565] PVR_K: 4243: CRTimer = 0x000043f59890, OSTimer = 390.647586015, CyclesElapsed = 40149504
Sep 3 13:58:26 buildroot kernel: [ 821.839568] PVR_K: 4243: PreResetTimeInCycles = 40448, HWResetTimeInCycles = 19968, FreelistReconTimeInCycles = 245760, TotalRecoveryTimeInCycles = 306176
Sep 3 13:58:26 buildroot kernel: [ 821.839571] PVR_K: 4243: Recovery 3: PID = 505, frame = 0, HWRTData = 0xC00C1E80, EventStatus = 0x00000400, Innocent Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839574] PVR_K: 4243: CRTimer = 0x000043f666ee, OSTimer = 390.665618655, CyclesElapsed = 12677120
Sep 3 13:58:26 buildroot kernel: [ 821.839577] PVR_K: 4243: PreResetTimeInCycles = 3996662272, HWResetTimeInCycles = 22272, FreelistReconTimeInCycles = 391936, TotalRecoveryTimeInCycles = 3997076480
Sep 3 13:58:26 buildroot kernel: [ 821.839580] PVR_K: 4243: T0 polling set (reg:0x000003B0 mask:0x00000002 last:0x00000000)
Sep 3 13:58:26 buildroot kernel: [ 821.839582] PVR_K: 4243: Recovery 4: PID = 505, frame = 0, HWRTData = 0xC00C2B80, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839585] PVR_K: 4243: CRTimer = 0x00004da153ab, OSTimer = 446.028748212, CyclesElapsed = 47842048
Sep 3 13:58:26 buildroot kernel: [ 821.839587] PVR_K: 4243: PreResetTimeInCycles = 40192, HWResetTimeInCycles = 19200, FreelistReconTimeInCycles = 231680, TotalRecoveryTimeInCycles = 291072
Sep 3 13:58:26 buildroot kernel: [ 821.839590] PVR_K: 4243: Recovery 5: PID = 505, frame = 0, HWRTData = 0xC00C21C0, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839592] PVR_K: 4243: CRTimer = 0x00006cdb2e09, OSTimer = 624.848212866, CyclesElapsed = 39648000
Sep 3 13:58:26 buildroot kernel: [ 821.839595] PVR_K: 4243: PreResetTimeInCycles = 40192, HWResetTimeInCycles = 20480, FreelistReconTimeInCycles = 236544, TotalRecoveryTimeInCycles = 297216
Sep 3 13:58:26 buildroot kernel: [ 821.839598] PVR_K: 4243: Recovery 6: PID = 505, frame = 0, HWRTData = 0xC00C21C0, EventStatus = 0x00004410, Guilty Lockup
Sep 3 13:58:26 buildroot kernel: [ 821.839600] PVR_K: 4243: CRTimer = 0x00008eb71b95, OSTimer = 818.746478174, CyclesElapsed = 39298048
Sep 3 13:58:26 buildroot kernel: [ 821.839604] PVR_K: 4243: PreResetTimeInCycles = 38400, HWResetTimeInCycles = 19456, FreelistReconTimeInCycles = 228352, TotalRecoveryTimeInCycles = 286208
Sep 3 13:58:26 buildroot kernel: [ 821.839606] PVR_K: 4243: DM 4 (HWRflags 0x00000000: working;)
Sep 3 13:58:26 buildroot kernel: [ 821.839608] PVR_K: 4243: DM 5 (HWRflags 0x00000000: working;)
Sep 3 13:58:26 buildroot kernel: [ 821.839611] PVR_K: 4243: RGX Kernel CCB WO:0xF RO:0xF
Sep 3 13:58:26 buildroot kernel: [ 821.839613] PVR_K: 4243: RGX Firmware CCB WO:0x17 RO:0x17
Sep 3 13:58:26 buildroot kernel: [ 821.839616] PVR_K: 4243: RGX Kernel CCB commands executed = 400655
Sep 3 13:58:26 buildroot kernel: [ 821.839618] PVR_K: 4243: RGX SLR: Forced UFO updates requested = 0
Sep 3 13:58:26 buildroot kernel: [ 821.839621] PVR_K: 4243: RGX Errors: WGP:0, TRP:0
Sep 3 13:58:26 buildroot kernel: [ 821.839623] PVR_K: 4243: Thread0: FW IRQ count = 501463
Sep 3 13:58:26 buildroot kernel: [ 821.839625] PVR_K: 4243: Last sampled IRQ count in LISR = 501463
Sep 3 13:58:26 buildroot kernel: [ 821.839629] PVR_K: 4243: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile; VDM CS INDEX mode;)
Sep 3 13:58:26 buildroot kernel: [ 821.839632] PVR_K: 4243: FW OS config flags = 0x0000000F (Ctx switch: TDM; TA; 3D; CDM;)
Sep 3 13:58:26 buildroot kernel: [ 821.839634] PVR_K: 4243: ------[ RGX registers ]------
Sep 3 13:58:26 buildroot kernel: [ 821.839637] PVR_K: 4243: RGX Register Base Address (Linear): 0x00000000b4d0f7c8
Sep 3 13:58:26 buildroot kernel: [ 821.839638] PVR_K: 4243: RGX Register Base Address (Physical): 0x4E20000000
Sep 3 13:58:26 buildroot kernel: [ 821.839642] PVR_K: 4243: CORE_ID : 0x0000000008470000
Sep 3 13:58:26 buildroot kernel: [ 821.839645] PVR_K: 4243: CORE_REVISION : 0x00D0013E
Sep 3 13:58:26 buildroot kernel: [ 821.839647] PVR_K: 4243: DESIGNER_REV_FIELD1 : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839649] PVR_K: 4243: DESIGNER_REV_FIELD2 : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839652] PVR_K: 4243: CHANGESET_NUMBER : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839655] PVR_K: 4243: CLK_CTRL : 0x0aaaaa002a1aa9aa
Sep 3 13:58:26 buildroot kernel: [ 821.839657] PVR_K: 4243: CLK_STATUS : 0x000000001b703553
Sep 3 13:58:26 buildroot kernel: [ 821.839660] PVR_K: 4243: CLK_CTRL2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839662] PVR_K: 4243: CLK_STATUS2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839665] PVR_K: 4243: EVENT_STATUS : 0x00004410
Sep 3 13:58:26 buildroot kernel: [ 821.839668] PVR_K: 4243: TIMER : 0x800000008f4136be
Sep 3 13:58:26 buildroot kernel: [ 821.839670] PVR_K: 4243: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839672] PVR_K: 4243: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839675] PVR_K: 4243: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839678] PVR_K: 4243: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839680] PVR_K: 4243: BIF_MMU_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839682] PVR_K: 4243: BIF_MMU_ENTRY : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839684] PVR_K: 4243: BIF_MMU_ENTRY_STATUS : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839687] PVR_K: 4243: BIF_STATUS_MMU : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839689] PVR_K: 4243: BIF_READS_EXT_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839691] PVR_K: 4243: BIF_READS_INT_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839693] PVR_K: 4243: BIFPM_STATUS_MMU : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839695] PVR_K: 4243: BIFPM_READS_EXT_STATUS : 0x0000006D
Sep 3 13:58:26 buildroot kernel: [ 821.839697] PVR_K: 4243: BIFPM_READS_INT_STATUS : 0x0000001C
Sep 3 13:58:26 buildroot kernel: [ 821.839700] PVR_K: 4243: BIF_CAT_BASE_INDEX : 0x0000000000000101
Sep 3 13:58:26 buildroot kernel: [ 821.839703] PVR_K: 4243: BIF_CAT_BASE0 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839705] PVR_K: 4243: BIF_CAT_BASE1 : 0x00000008bd050000
Sep 3 13:58:26 buildroot kernel: [ 821.839708] PVR_K: 4243: BIF_CAT_BASE2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839711] PVR_K: 4243: BIF_CAT_BASE3 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839713] PVR_K: 4243: BIF_CAT_BASE4 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839716] PVR_K: 4243: BIF_CAT_BASE5 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839718] PVR_K: 4243: BIF_CAT_BASE6 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839721] PVR_K: 4243: BIF_CAT_BASE7 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839724] PVR_K: 4243: BIF_CTRL_INVAL : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839726] PVR_K: 4243: BIF_CTRL : 0x000000C0
Sep 3 13:58:26 buildroot kernel: [ 821.839728] PVR_K: 4243: BIF_PM_CAT_BASE_VCE0 : 0x000000008fbd9001
Sep 3 13:58:26 buildroot kernel: [ 821.839731] PVR_K: 4243: BIF_PM_CAT_BASE_TE0 : 0x000000008fbca001
Sep 3 13:58:26 buildroot kernel: [ 821.839733] PVR_K: 4243: BIF_PM_CAT_BASE_ALIST0 : 0x00000000fcdfa001
Sep 3 13:58:26 buildroot kernel: [ 821.839735] PVR_K: 4243: BIF_PM_CAT_BASE_VCE1 : 0x0000000080294001
Sep 3 13:58:26 buildroot kernel: [ 821.839738] PVR_K: 4243: BIF_PM_CAT_BASE_TE1 : 0x00000000802bf001
Sep 3 13:58:26 buildroot kernel: [ 821.839740] PVR_K: 4243: BIF_PM_CAT_BASE_ALIST1 : 0x00000000802b3001
Sep 3 13:58:26 buildroot kernel: [ 821.839743] PVR_K: 4243: PERF_TA_PHASE : 0x00000186
Sep 3 13:58:26 buildroot kernel: [ 821.839745] PVR_K: 4243: PERF_TA_CYCLE : 0x22518E27
Sep 3 13:58:26 buildroot kernel: [ 821.839747] PVR_K: 4243: PERF_3D_PHASE : 0x00000617
Sep 3 13:58:26 buildroot kernel: [ 821.839749] PVR_K: 4243: PERF_3D_CYCLE : 0x600F275F
Sep 3 13:58:26 buildroot kernel: [ 821.839752] PVR_K: 4243: PERF_TA_OR_3D_CYCLE : 0x625C39A4
Sep 3 13:58:26 buildroot kernel: [ 821.839754] PVR_K: 4243: PERF_TA_AND_3D_CYCLE : 0x20048392
Sep 3 13:58:26 buildroot kernel: [ 821.839756] PVR_K: 4243: PERF_COMPUTE_PHASE : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839758] PVR_K: 4243: PERF_COMPUTE_CYCLE : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839760] PVR_K: 4243: PM_PARTIAL_RENDER_ENABLE : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839763] PVR_K: 4243: ISP_RENDER : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839765] PVR_K: 4243: TLA_STATUS : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839768] PVR_K: 4243: MCU_FENCE : 0x0000018000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839770] PVR_K: 4243: VDM_CONTEXT_STORE_STATUS : 0x00000001
Sep 3 13:58:26 buildroot kernel: [ 821.839773] PVR_K: 4243: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839776] PVR_K: 4243: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839778] PVR_K: 4243: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839781] PVR_K: 4243: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839784] PVR_K: 4243: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839786] PVR_K: 4243: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839789] PVR_K: 4243: ISP_CTL : 0x0003500F
Sep 3 13:58:26 buildroot kernel: [ 821.839791] PVR_K: 4243: ISP_STATUS : 0x00000002
Sep 3 13:58:26 buildroot kernel: [ 821.839793] PVR_K: 4243: MTS_INTCTX : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839795] PVR_K: 4243: MTS_BGCTX : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839797] PVR_K: 4243: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839799] PVR_K: 4243: MTS_SCHEDULE : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839801] PVR_K: 4243: MTS_GPU_INT_STATUS : 0x00004550
Sep 3 13:58:26 buildroot kernel: [ 821.839803] PVR_K: 4243: CDM_CONTEXT_STORE_STATUS : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.839806] PVR_K: 4243: CDM_CONTEXT_PDS0 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.839809] PVR_K: 4243: CDM_CONTEXT_PDS1 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.841468] PVR_K: 4243: CDM_TERMINATE_PDS : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.841475] PVR_K: 4243: CDM_TERMINATE_PDS1 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.841478] PVR_K: 4243: SIDEKICK_IDLE : 0x0000001E
Sep 3 13:58:26 buildroot kernel: [ 821.841480] PVR_K: 4243: SLC_IDLE : 0x0000001E
Sep 3 13:58:26 buildroot kernel: [ 821.841482] PVR_K: 4243: SLC_STATUS0 : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.841485] PVR_K: 4243: SLC_STATUS1 : 0x0000000b001a040c
Sep 3 13:58:26 buildroot kernel: [ 821.841487] PVR_K: 4243: SLC_STATUS2 : 0x0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.841490] PVR_K: 4243: SLC_CTRL_BYPASS : 0x01000000
Sep 3 13:58:26 buildroot kernel: [ 821.841492] PVR_K: 4243: SLC_CTRL_MISC : 0x0000000000200003
Sep 3 13:58:26 buildroot kernel: [ 821.841496] PVR_K: 4243: MIPS_ADDR_REMAP1_CONFIG1 : 0x1FC00001
Sep 3 13:58:26 buildroot kernel: [ 821.841498] PVR_K: 4243: MIPS_ADDR_REMAP1_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:58:26 buildroot kernel: [ 821.841500] PVR_K: 4243: MIPS_ADDR_REMAP2_CONFIG1 : 0x1FC01001
Sep 3 13:58:26 buildroot kernel: [ 821.841503] PVR_K: 4243: MIPS_ADDR_REMAP2_CONFIG2 : 0x00000008bc8ee00c
Sep 3 13:58:26 buildroot kernel: [ 821.841506] PVR_K: 4243: MIPS_ADDR_REMAP3_CONFIG1 : 0x1FC02001
Sep 3 13:58:26 buildroot kernel: [ 821.841509] PVR_K: 4243: MIPS_ADDR_REMAP3_CONFIG2 : 0x00000008bc8dd00c
Sep 3 13:58:26 buildroot kernel: [ 821.841511] PVR_K: 4243: MIPS_ADDR_REMAP4_CONFIG1 : 0x1FC00000
Sep 3 13:58:26 buildroot kernel: [ 821.841513] PVR_K: 4243: MIPS_ADDR_REMAP4_CONFIG2 : 0x000000000000000c
Sep 3 13:58:26 buildroot kernel: [ 821.841515] PVR_K: 4243: MIPS_ADDR_REMAP5_CONFIG1 : 0x00000001
Sep 3 13:58:26 buildroot kernel: [ 821.841518] PVR_K: 4243: MIPS_ADDR_REMAP5_CONFIG2 : 0x00000008bc8df00c
Sep 3 13:58:26 buildroot kernel: [ 821.841520] PVR_K: 4243: MIPS_WRAPPER_CONFIG : 0x000000000001cf80
Sep 3 13:58:26 buildroot kernel: [ 821.841522] PVR_K: 4243: MIPS_EXCEPTION_STATUS : 0x00000020
Sep 3 13:58:26 buildroot kernel: [ 821.841649] PVR_K: 4243: ---- [ MIPS internal state ] ----
Sep 3 13:58:26 buildroot kernel: [ 821.841651] PVR_K: 4243: PC : 0xC0017118
Sep 3 13:58:26 buildroot kernel: [ 821.841652] PVR_K: 4243: STATUS_REGISTER : 0x00481C05
Sep 3 13:58:26 buildroot kernel: [ 821.841654] PVR_K: 4243: CAUSE_REGISTER : 0x00800000
Sep 3 13:58:26 buildroot kernel: [ 821.841657] PVR_K: 4243: BAD_REGISTER : 0xC0130000
Sep 3 13:58:26 buildroot kernel: [ 821.841658] PVR_K: 4243: EPC : 0xC001711C
Sep 3 13:58:26 buildroot kernel: [ 821.841660] PVR_K: 4243: SP : 0xCF600FE0
Sep 3 13:58:26 buildroot kernel: [ 821.841662] PVR_K: 4243: BAD_INSTRUCTION : 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.841664] PVR_K: 4243: TLB :
Sep 3 13:58:26 buildroot kernel: [ 821.841669] PVR_K: 4243: 0) VA 0xCF800000 ( 64k) -> PA0 0xe20000000 DV , PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841672] PVR_K: 4243: 1) VA 0xCF000000 ( 16k) -> PA0 0x8bc840000 DVGC, PA1 0x8bc844000 DVGC
Sep 3 13:58:26 buildroot kernel: [ 821.841675] PVR_K: 4243: 2) VA 0xCF600000 ( 4k) -> PA0 0x8bc8ef000 DV C, PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841678] PVR_K: 4243: 3) VA 0xC0000000 ( 64k) -> PA0 0x8bc8a0000 DVGC, PA1 0x8bc8b0000 DVGC
Sep 3 13:58:26 buildroot kernel: [ 821.841680] PVR_K: 4243: 4) VA 0xF0080000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841683] PVR_K: 4243: 5) VA 0xC0080000 ( 64k) -> PA0 0x8bc920000 DVG , PA1 0x8bc940000 DVG
Sep 3 13:58:26 buildroot kernel: [ 821.841686] PVR_K: 4243: 6) VA 0xC0160000 ( 64k) -> PA0 0xfe220000 DV , PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841688] PVR_K: 4243: 7) VA 0xF00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841690] PVR_K: 4243: 8) VA 0xC0040000 ( 64k) -> PA0 0x8bc8e0000 DVGC, PA1 0x8bc8f0000 DVG
Sep 3 13:58:26 buildroot kernel: [ 821.841693] PVR_K: 4243: 9) VA 0xC00E0000 ( 64k) -> PA0 0x00000000 C, PA1 0x8bd820000 DV C
Sep 3 13:58:26 buildroot kernel: [ 821.841695] PVR_K: 4243: 10) VA 0xF0140000 ( 64k) -> PA0 0x00000000 C, PA1 0x00000000 C
Sep 3 13:58:26 buildroot kernel: [ 821.841698] PVR_K: 4243: 11) VA 0xC0060000 ( 64k) -> PA0 0x8bc900000 DVG , PA1 0x8bc910000 VGC
Sep 3 13:58:26 buildroot kernel: [ 821.841700] PVR_K: 4243: 12) VA 0xC0120000 ( 64k) -> PA0 0x00000000 C, PA1 0x880ee0000 DV
Sep 3 13:58:26 buildroot kernel: [ 821.841703] PVR_K: 4243: 13) VA 0xC0140000 ( 64k) -> PA0 0x8839d0000 DVG , PA1 0xfce80000 DVG
Sep 3 13:58:26 buildroot kernel: [ 821.841705] PVR_K: 4243: 14) VA 0xC0100000 ( 64k) -> PA0 0x8bd830000 DVGC, PA1 0x880ed0000 DVGC
Sep 3 13:58:26 buildroot kernel: [ 821.841708] PVR_K: 4243: 15) VA 0xC00C0000 ( 64k) -> PA0 0x8bd2a0000 DVGC, PA1 0x8bd810000 DVGC
Sep 3 13:58:26 buildroot kernel: [ 821.841712] PVR_K: 4243: --------------------------------
Sep 3 13:58:26 buildroot kernel: [ 821.841714] PVR_K: 4243: ------[ RGX FW Trace Info ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841717] PVR_K: 4243: Debug log type: none
Sep 3 13:58:26 buildroot kernel: [ 821.841719] PVR_K: 4243: RGX FW thread 0: Trace buffer not yet allocated
Sep 3 13:58:26 buildroot kernel: [ 821.841722] PVR_K: 4243: ------[ Full CCB Status ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841729] PVR_K: 4243: FWCtx 0xC00C0300 (TQ_3D-P505-T966-AVMExec)
Sep 3 13:58:26 buildroot kernel: [ 821.841731] PVR_K: 4243: `--<Empty>
Sep 3 13:58:26 buildroot kernel: [ 821.841737] PVR_K: 4243: FWCtx 0xC00C0040 (TA-P505-T966-AVMExec)
Sep 3 13:58:26 buildroot kernel: [ 821.841739] PVR_K: 4243: `--<Empty>
Sep 3 13:58:26 buildroot kernel: [ 821.841742] PVR_K: 4243: FWCtx 0xC00C00E0 (3D-P505-T966-AVMExec)
Sep 3 13:58:26 buildroot kernel: [ 821.841746] PVR_K: 4243: |--Ready 3D @ 38064 Int=400509 Ext=400489
Sep 3 13:58:26 buildroot kernel: [ 821.841749] PVR_K: 4243: `--Ready UPDATE @ 38456 Int=400509 Ext=400489
Sep 3 13:58:26 buildroot kernel: [ 821.841752] PVR_K: 4243: |--Addr:0xc016004c Val=0x000026e6
Sep 3 13:58:26 buildroot kernel: [ 821.841754] PVR_K: 4243: |--Addr:0xc01405a9 Val=0x00000519
Sep 3 13:58:26 buildroot kernel: [ 821.841756] PVR_K: 4243: `--Addr:0xc01406c1 Val=0x00000519
Sep 3 13:58:26 buildroot kernel: [ 821.841760] PVR_K: 4243: ------[ RGX Device ID:0 End ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841765] PVR_K: 4243: ------[ System Summary Device ID:0 ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841766] PVR_K: 4243: Device System Power State: ON
Sep 3 13:58:26 buildroot kernel: [ 821.841769] PVR_K: 4243: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms)
Sep 3 13:58:26 buildroot kernel: [ 821.841771] PVR_K: 4243: ------[ Server Thread Summary ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841773] PVR_K: 4243: pvr_defer_free : Running
Sep 3 13:58:26 buildroot kernel: [ 821.841775] PVR_K: 4243: Number of deferred cleanup items : 0
Sep 3 13:58:26 buildroot kernel: [ 821.841777] PVR_K: 4243: pvr_device_wdg : Running
Sep 3 13:58:26 buildroot kernel: [ 821.841780] PVR_K: 4243: pvr_cacheop : Running
Sep 3 13:58:26 buildroot kernel: [ 821.841783] PVR_K: 4243: Configuration: QSZ: 16, UKT: -1, KDFT: 131072, LINESIZE: 64, PGSIZE: 65536, KDF: Yes, URBF: Yes
Sep 3 13:58:26 buildroot kernel: [ 821.841785] PVR_K: 4243: Pending deferred CacheOp entries : 0
Sep 3 13:58:26 buildroot kernel: [ 821.841788] PVR_K: 4243: ------[ AppHint Settings ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841790] PVR_K: 4243: Build Vars
Sep 3 13:58:26 buildroot kernel: [ 821.841794] PVR_K: 4243: EnableTrustedDeviceAceConfig: N
Sep 3 13:58:26 buildroot kernel: [ 821.841796] PVR_K: 4243: CleanupThreadPriority: 0x00000005
Sep 3 13:58:26 buildroot kernel: [ 821.841798] PVR_K: 4243: CacheOpThreadPriority: 0x00000001
Sep 3 13:58:26 buildroot kernel: [ 821.841800] PVR_K: 4243: WatchdogThreadPriority: 0x00000000
Sep 3 13:58:26 buildroot kernel: [ 821.841802] PVR_K: 4243: HWPerfClientBufferSize: 0x000c0000
Sep 3 13:58:26 buildroot kernel: [ 821.841804] PVR_K: 4243: Module Params
Sep 3 13:58:26 buildroot kernel: [ 821.841810] PVR_K: 4243: none
Sep 3 13:58:26 buildroot kernel: [ 821.841811] PVR_K: 4243: Debug Info Params
Sep 3 13:58:26 buildroot kernel: [ 821.841815] PVR_K: 4243: CacheOpConfig: 0x0000000c
Sep 3 13:58:26 buildroot kernel: [ 821.841817] PVR_K: 4243: CacheOpUMKMThresholdSize: 0xffffffff
Sep 3 13:58:26 buildroot kernel: [ 821.841820] PVR_K: 4243: Debug Info Params Device ID: 0
Sep 3 13:58:26 buildroot kernel: [ 821.841824] PVR_K: 4243: none
Sep 3 13:58:26 buildroot kernel: [ 821.841827] PVR_K: 4243: ------[ HTB Log state: Off ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841830] PVR_K: 4243: ------[ Active Sync Checkpoints ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841834] PVR_K: 4243: - ID = 360564, FWAddr = 0xc01406c0, r1:e1:f0: es3_DoKick3D_400489
Sep 3 13:58:26 buildroot kernel: [ 821.841838] PVR_K: 4243: - ID = 360562, FWAddr = 0xc01405a8, r1:e1:f0: update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841848] ------[ Native Fence Sync: timelines ]------
Sep 3 13:58:26 buildroot kernel: [ 821.841852] foreign_sync: @0 ctx=1 refs=1
Sep 3 13:58:26 buildroot kernel: [ 821.841857] sw: RM_SWTimeline-eda-AVMExec-505 @0 cur=0
Sep 3 13:58:26 buildroot kernel: [ 821.841859] rogue-ta3d: @80020 ctx=3 refs=14
Sep 3 13:58:26 buildroot kernel: [ 821.841865] @79966: (++) refs=4 fwaddr=0xc0140631 enqueue=1 status=Signalled 79966-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841869] @79986: (++) refs=4 fwaddr=0xc01403b9 enqueue=1 status=Signalled 79986-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841871] @79990: (++) refs=4 fwaddr=0xc01404a9 enqueue=1 status=Signalled 79990-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841874] @79994: (++) refs=4 fwaddr=0xc01403f1 enqueue=1 status=Signalled 79994-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841876] @79998: (++) refs=4 fwaddr=0xc01404d9 enqueue=1 status=Signalled 79998-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841879] @80002: (++) refs=4 fwaddr=0xc0140651 enqueue=1 status=Signalled 80002-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841882] @80006: (++) refs=4 fwaddr=0xc0140221 enqueue=1 status=Signalled 80006-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841884] @80010: (++) refs=4 fwaddr=0xc01405a1 enqueue=1 status=Signalled 80010-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841887] @80012: (++) refs=1 fwaddr=0xc0140519 enqueue=1 status=Signalled 80012-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841889] @80014: (++) refs=4 fwaddr=0xc0140299 enqueue=1 status=Signalled 80014-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841892] @80016: (++) refs=1 fwaddr=0xc0140059 enqueue=1 status=Signalled 80016-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841894] @80018: (++) refs=4 fwaddr=0xc01405c9 enqueue=1 status=Signalled 80018-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841897] @80019: (+-) refs=2 fwaddr=0xc01405a9 enqueue=1 status=Active 80019-update fence
Sep 3 13:58:26 buildroot kernel: [ 821.841899] rogue-tq3d: @0 ctx=5 refs=1
Sep 3 13:58:26 buildroot kernel: [ 821.841901] QE-eda-AVMExec-505: @80129 ctx=6 refs=5
Sep 3 13:58:26 buildroot kernel: [ 821.841903] @80125: (++) refs=1 fwaddr=0xc0140639 enqueue=1 status=Signalled 80125-TQM
Sep 3 13:58:26 buildroot kernel: [ 821.841906] @80126: (++) refs=1 fwaddr=0xc01406a9 enqueue=2 status=Signalled 80126-TQM
Sep 3 13:58:26 buildroot kernel: [ 821.841908] @80127: (++) refs=1 fwaddr=0xc0140419 enqueue=1 status=Signalled 80127-TQM
Sep 3 13:58:26 buildroot kernel: [ 821.841911] @80128: (++) refs=1 fwaddr=0xc0140481 enqueue=2 status=Signalled 80128-TQM
Sep 3 13:58:26 buildroot kernel: [ 821.841913] V3-eda-AVMExec-505: @100211 ctx=7 refs=3
Sep 3 13:58:26 buildroot kernel: [ 821.841915] @100201: (++) refs=1 fwaddr=0xc01400c1 enqueue=1 status=Signalled 100201-es3_DoKickTA_400451
Sep 3 13:58:26 buildroot kernel: [ 821.841918] @100210: (++) refs=1 fwaddr=0xc0140261 enqueue=1 status=Signalled 100210-es3_DoKickTA_400489
Sep 3 13:58:26 buildroot kernel: [ 821.841920] P3-eda-AVMExec-505: @100205 ctx=8 refs=5
Sep 3 13:58:26 buildroot kernel: [ 821.841923] @100195: (++) refs=1 fwaddr=0xc01400c9 enqueue=1 status=Signalled 100195-es3_DoKick3D_400451
Sep 3 13:58:26 buildroot kernel: [ 821.841925] @100202: (++) refs=1 fwaddr=0xc01402d9 enqueue=3 status=Signalled 100202-es3_DoKick3D_400472
Sep 3 13:58:26 buildroot kernel: [ 821.841928] @100203: (++) refs=1 fwaddr=0xc0140659 enqueue=3 status=Signalled 100203-es3_DoKick3D_400484
Sep 3 13:58:26 buildroot kernel: [ 821.841930] @100204: (+-) refs=2 fwaddr=0xc01406c1 enqueue=1 status=Active 100204-es3_DoKick3D_400489
Sep 3 13:58:26 buildroot kernel: [ 821.841932] PVR_K: 4243: ------------[ PVR DBG: END ]------------
Sep 3 13:58:26 buildroot kernel: [ 821.841979] ------------[ cut here ]------------
Sep 3 13:58:26 buildroot kernel: [ 821.842053] WARNING: CPU: 0 PID: 4243 at /root/ONLINE_SERVICE/other/ferry/task_workspace/baidu/acu/single-tda4-psdkla/board-support/extra-drivers/ti-img-rogue-driver-1.10.5371573/binary_j721e_linux_wayland_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:529 PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842056] Modules linked in: iptable_filter xt_tcpudp 8021q garp stp mrp llc xhci_plat_hcd xhci_hcd usbcore cdns3 roles udc_core rpmsg_char usb_common virtio_rpmsg_bus crct10dif_ce ti_j721e_cpsw_virt_mac acu_timesync ti_k3_r5_remoteproc pvrsrvkm(O) sa2ul ti_k3_dsp_remoteproc cdns3_ti sha512_generic authenc sch_fq_codel rpmsg_kdrv_switch ip_tables x_tables ipv6
Sep 3 13:58:26 buildroot kernel: [ 821.842087] CPU: 0 PID: 4243 Comm: pvrdebug Tainted: G W O 5.4.74-ACU-10.0.66.1 #4
Sep 3 13:58:26 buildroot kernel: [ 821.842089] Hardware name: Texas Instruments K3 J721E SoC (DT)
Sep 3 13:58:26 buildroot kernel: [ 821.842093] pstate: 80000005 (Nzcv daif -PAN -UAO)
Sep 3 13:58:26 buildroot kernel: [ 821.842140] pc : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842182] lr : PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842183] sp : ffff80012708fa70
Sep 3 13:58:26 buildroot kernel: [ 821.842185] x29: ffff80012708fa70 x28: ffff00084508e000
Sep 3 13:58:26 buildroot kernel: [ 821.842187] x27: 0000000000000008 x26: ffff800008f4bae0
Sep 3 13:58:26 buildroot kernel: [ 821.842190] x25: ffff000849185300 x24: 0000000000000009
Sep 3 13:58:26 buildroot kernel: [ 821.842192] x23: 0000000000000002 x22: 0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.842194] x21: 0000000000000000 x20: ffff0008491853d8
Sep 3 13:58:26 buildroot kernel: [ 821.842196] x19: ffff000846a76aa0 x18: 0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.842198] x17: 0000000000000000 x16: 0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.842199] x15: ffff80001112a000 x14: ffff8000111e74e2
Sep 3 13:58:26 buildroot kernel: [ 821.842202] x13: 0000000000003c0c x12: ffff8000111e6000
Sep 3 13:58:26 buildroot kernel: [ 821.842204] x11: ffff80001112a000 x10: ffff8000111e6b30
Sep 3 13:58:26 buildroot kernel: [ 821.842206] x9 : 0000000000000001 x8 : 0000000000000000
Sep 3 13:58:26 buildroot kernel: [ 821.842208] x7 : 0000000000000000 x6 : 00000000000006af
Sep 3 13:58:26 buildroot kernel: [ 821.842210] x5 : ffff00087fa61848 x4 : 0000000000000001
Sep 3 13:58:26 buildroot kernel: [ 821.842212] x3 : 0000000000000000 x2 : ffffffffffffff00
Sep 3 13:58:26 buildroot kernel: [ 821.842214] x1 : 0000000000000000 x0 : ffff000846a77e00
Sep 3 13:58:26 buildroot kernel: [ 821.842216] Call trace:
Sep 3 13:58:26 buildroot kernel: [ 821.842262] PVRSRVDebugRequest+0x4c4/0x650 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842305] PVRSRVDumpDebugInfoKM+0x3c/0x58 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842349] PVRSRVBridgeDumpDebugInfo+0x34/0x50 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842390] BridgedDispatchKM+0x14c/0x550 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842430] PVRSRV_BridgeDispatchKM+0xac/0x180 [pvrsrvkm]
Sep 3 13:58:26 buildroot kernel: [ 821.842440] drm_ioctl_kernel+0xb8/0x108
Sep 3 13:58:26 buildroot kernel: [ 821.842443] drm_ioctl+0x210/0x468
Sep 3 13:58:26 buildroot kernel: [ 821.842447] do_vfs_ioctl+0x964/0xb48
Sep 3 13:58:26 buildroot kernel: [ 821.842449] ksys_ioctl+0x78/0xa8
Sep 3 13:58:26 buildroot kernel: [ 821.842451] __arm64_sys_ioctl+0x1c/0xb8
Sep 3 13:58:26 buildroot kernel: [ 821.842456] el0_svc_common.constprop.0+0x68/0x160
Sep 3 13:58:26 buildroot kernel: [ 821.842458] el0_svc_handler+0x20/0x80
Sep 3 13:58:26 buildroot kernel: [ 821.842461] el0_svc+0x8/0x204
Sep 3 13:58:26 buildroot kernel: [ 821.842463] ---[ end trace e33a221189b3f2bd ]---
Sep 3 14:02:29 buildroot kernel: [ 1065.157738] virtio_rpmsg_bus virtio6: msg received with no recipient
Sep 3 14:02:29 buildroot kernel: [ 1065.157748] virtio_rpmsg_bus virtio6: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.858264] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.868276] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.878267] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.888260] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.898262] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:35 buildroot kernel: [ 1070.908280] virtio_rpmsg_bus virtio3: msg received with no recipient
Sep 3 14:02:49 buildroot kernel: [ 11.391793] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Sep 3 14:02:49 buildroot kernel: [ 11.391836] NFSD: Using legacy client tracking operations.
Sep 3 14:02:49 buildroot kernel: [ 11.391839] NFSD: starting 90-second grace period (net f0000041)
Sep 3 14:02:49 buildroot kernel: [ 11.548748] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
