Hello I have a question about changes in PRU FW between SDK Linux RT version 8.2 and 9.1.
When I connect IDK PRU ICSSG port to NIC which starts sending frames after linkUp. There is different behavior between mentioned versions. See attached log for that.
- with SDK Linux RT 8.2 - PRU ICSSG receive all sent frames (10 for each of 5 link changes)
- with SDK Linux RT 9.1 - PRU ICSSG receive only 1 frame only in 1 of 5 link changes (overall only 1 of 50 frames)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.09.04 08:11:29 =~=~=~=~=~=~=~=~=~=~=~= U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 06:00:43 +0000) SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') SPL initial stack usage: 1416 bytes Trying to boot from MMC2 spl_load_fit_image: Skip load 'dm': image size is 0! Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.01.00.006-dirty NOTICE: BL31: Built : 05:29:41, Mar 24 2022 U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 05:30:44 +0000) SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Detected: Silicon SR2.0 i2c_omap i2c@42120000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 Detected: AM6-IDKAPPEVM rev A Detected: SER-PCIE2LEVM rev A Trying to boot from MMC2 U-Boot 2021.01-g44a87e3ab8 (Mar 24 2022 - 05:30:44 +0000) SoC: AM65X SR2.0 Model: Texas Instruments AM654 Base Board Board: AM6-COMPROCEVM rev A DRAM: 4 GiB MMC: sdhci@4f80000: 0, sdhci@4fa0000: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: Silicon SR2.0 Detected: AM6-IDKAPPEVM rev A Detected: SER-PCIE2LEVM rev A Net: eth1: icssg2-eth, eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1011 bytes read in 4 ms (246.1 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... Using board_name = am65x 18231808 bytes read in 757 ms (23 MiB/s) 64207 bytes read in 8 ms (7.7 MiB/s) 11268 bytes read in 5 ms (2.1 MiB/s) 2333 bytes read in 5 ms (455.1 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.100-rt62-g204ec708dc (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Thu Mar 24 05:32:52 UTC 2022 [ 0.000000] Machine model: Texas Instruments AM654 Base Board [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a20fffff] [ 0.000000] node 0: [mem 0x00000000a2100000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] On node 0 totalpages: 1048576 [ 0.000000] DMA zone: 8192 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 524288 pages, LIFO batch:63 [ 0.000000] Normal zone: 8192 pages used for memmap [ 0.000000] Normal zone: 524288 pages, LIFO batch:63 [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe800000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728 [ 0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),57216k@8m(ospi.rootfs),128k(ospi.phypattern) root=PARTUUID=422b5712-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fa800000-0x00000000fe800000] (64MB) [ 0.000000] Memory: 3946716K/4194304K available (10624K kernel code, 1164K rwdata, 4148K rodata, 1728K init, 438K bss, 223012K reserved, 24576K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008697] Console: colour dummy device 80x25 [ 0.013315] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.024037] pid_max: default: 32768 minimum: 301 [ 0.028899] LSM: Security Framework initializing [ 0.033715] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.041331] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.051541] rcu: Hierarchical SRCU implementation. [ 0.057149] Platform MSI: msi-controller@1820000 domain created [ 0.063565] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.073019] EFI services will not be available. [ 0.078020] smp: Bringing up secondary CPUs ... [ 0.083983] Detected VIPT I-cache on CPU1 [ 0.088132] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.095198] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.102660] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.110929] Detected VIPT I-cache on CPU2 [ 0.115095] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000 [ 0.122341] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.129813] CPU2: Booted secondary processor 0x0000000100 [0x410fd034] [ 0.137979] Detected VIPT I-cache on CPU3 [ 0.142121] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000 [ 0.149359] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.156806] CPU3: Booted secondary processor 0x0000000101 [0x410fd034] [ 0.163690] smp: Brought up 1 node, 4 CPUs [ 0.167932] SMP: Total of 4 processors activated. [ 0.172781] CPU features: detected: 32-bit EL0 Support [ 0.178072] CPU features: detected: CRC32 instructions [ 0.198405] CPU: All CPU(s) started at EL2 [ 0.202654] alternatives: patching kernel code [ 0.208831] devtmpfs: initialized [ 0.225967] KASLR disabled due to lack of seed [ 0.230794] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.240816] futex hash table entries: 1024 (order: 5, 131072 bytes, linear) [ 0.249287] pinctrl core: initialized pinctrl subsystem [ 0.255326] DMI not present or invalid. [ 0.259899] NET: Registered protocol family 16 [ 0.266749] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.274266] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.282650] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.291557] thermal_sys: Registered thermal governor 'step_wise' [ 0.292354] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.305637] ASID allocator initialised with 65536 entries [ 0.362626] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.369588] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.376502] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.383404] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.391994] cryptd: max_cpu_qlen set to 1000 [ 0.401365] k3-chipinfo 43000014.chipid: Family:AM65X rev:SR2.0 JTAGID[0x1bb5a02f] Detected [ 0.410829] vcc3v3_io: supplied by evm_12v0 [ 0.416733] iommu: Default domain type: Translated [ 0.422305] SCSI subsystem initialized [ 0.426978] mc: Linux media interface: v0.10 [ 0.431503] videodev: Linux video capture interface: v2.00 [ 0.437263] pps_core: LinuxPPS API ver. 1 registered [ 0.442433] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.451844] PTP clock support registered [ 0.455972] EDAC MC: Ver: 3.0.0 [ 0.460697] FPGA manager framework [ 0.464341] Advanced Linux Sound Architecture Driver Initialized. [ 0.471854] clocksource: Switched to clocksource arch_sys_counter [ 0.478407] VFS: Disk quotas dquot_6.6.0 [ 0.482512] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.498478] NET: Registered protocol family 2 [ 0.503369] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.513713] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.522811] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.531389] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 0.541383] TCP: Hash tables configured (established 32768 bind 32768) [ 0.548417] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.555804] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.563915] NET: Registered protocol family 1 [ 0.569465] RPC: Registered named UNIX socket transport module. [ 0.575670] RPC: Registered udp transport module. [ 0.580507] RPC: Registered tcp transport module. [ 0.585337] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.591959] PCI: CLS 0 bytes, default 64 [ 0.597237] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.612057] Initialise system trusted keyrings [ 0.616911] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.630552] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.637406] NFS: Registering the id_resolver key type [ 0.642674] Key type id_resolver registered [ 0.646987] Key type id_legacy registered [ 0.651207] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.658095] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.665963] 9p: Installing v9fs 9p2000 file system support [ 0.725457] Key type asymmetric registered [ 0.729718] Asymmetric key parser 'x509' registered [ 0.734795] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.742425] io scheduler mq-deadline registered [ 0.747097] io scheduler kyber registered [ 0.754627] pinctrl-single 4301c000.pinctrl: 70 pins, size 280 [ 0.761399] pinctrl-single 11c000.pinctrl: 185 pins, size 740 [ 0.767521] pinctrl-single 11c2e8.pinctrl: 9 pins, size 36 [ 0.781352] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.787749] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.799424] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.828638] brd: module loaded [ 0.843457] loop: module loaded [ 0.847934] megasas: 07.714.04.00-rc1 [ 0.858065] tun: Universal TUN/TAP device driver, 1.6 [ 0.864326] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.870779] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.876956] sky2: driver version 1.30 [ 0.882303] VFIO - User Level meta-driver version: 0.3 [ 0.888898] i2c /dev entries driver [ 0.894338] sdhci: Secure Digital Host Controller Interface driver [ 0.900709] sdhci: Copyright(c) Pierre Ossman [ 0.906014] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.913702] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource [ 0.921408] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.929811] optee: probing for conduit method. [ 0.934446] optee: revision 3.12 (3d47a131) [ 0.935045] optee: initialized driver [ 0.946064] NET: Registered protocol family 17 [ 0.950898] 9pnet: Installing 9P2000 support [ 0.955386] Key type dns_resolver registered [ 0.960262] printk: bootconsole [ns16550a0]: printing thread started [ 0.960343] Loading compiled-in X.509 certificates [ 0.973706] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.974036] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.981930] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource [ 0.982440] ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') [ 1.056842] random: fast init done [ 1.078666] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 1.080193] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 1.082466] pca953x 2-0021: supply vcc not found, using dummy regulator [ 1.082652] pca953x 2-0021: using no AI [ 1.104703] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.105935] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz [ 1.107098] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.108266] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz [ 1.109702] ti-sci-intr bus@100000:bus@28380000:bus@42040000:interrupt-controller2: Interrupt Router 156 domain created [ 1.109981] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 100 domain created [ 1.110245] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 182 domain created [ 1.110687] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created [ 1.126079] keystone-pcie 5500000.pcie: host bridge /bus@100000/pcie@5500000 ranges: [ 1.126120] OF: /bus@100000/pcie@5500000: Missing device_type [ 1.126156] keystone-pcie 5500000.pcie: IO 0x0010020000..0x001002ffff -> 0x0000000000 [ 1.126189] keystone-pcie 5500000.pcie: MEM 0x0010030000..0x0017ffffff -> 0x0010030000 [ 2.126911] keystone-pcie 5500000.pcie: Phy link never came up [ 2.127118] keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00 [ 2.127131] pci_bus 0000:00: root bus resource [bus 00-ff] [ .127143] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 2.127153] pci_bus 0000:00: root bus resource [mem 0x10030000-0x17ffffff] [ 2.152719] printk: console [ttyS2]: printing thread started [ 2.127234] pci 0000:00:00.0: [104c:b00c] type 01 class 0x060400 [ 2.152747] printk: console [ttyS2] enabled [ 2.152753] printk: bootconsole [ns16550a0] disabled [ 2.171711] printk: bootconsole [ns16550a0]: printing thread stopped [ 2.173086] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 30, base_baud = 3000000) is a 8250 [ 2.174154] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 31, base_baud = 3000000) is a 8250 [ 2.231893] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.234458] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.234589] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000 [ 2.237850] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.242239] mmc0: CQHCI version 5.10 [ 2.257764] pca953x 0-0039: supply vcc not found, using dummy regulator [ 2.257971] pca953x 0-0039: using no AI [ 2.281773] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.282375] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.284555] ti-udma 285c0000.dma-controller: Channels: 28 (tchan: 14, rchan: 14, gp-rflow: 16) [ 2.285113] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.293998] ti-udma 31150000.dma-controller: Channels: 119 (tchan: 53, rchan: 66, gp-rflow: 64) [ 2.308430] spi-nor spi7.0: mt35xu512aba (65536 Kbytes) [ 2.308485] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 2.308493] Creating 8 MTD partitions on "47040000.spi.0": [ 2.308501] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 2.310297] 0x000000080000-0x000000280000 : "ospi.tispl" [ 2.311937] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 2.313479] 0x000000680000-0x0000006a0000 : "ospi.env" [ 2.315103] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 2.316681] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 2.318213] 0x000000800000-0x000003fe0000 : "ospi.rootfs" [ 2.319767] 0x000003fe0000-0x000004000000 : "ospi.phypattern" [ 2.333054] spi-nor spi9.0: n25q128a13 (16384 Kbytes) [ 2.372391] mmc0: Command Queue Engine enabled [ 2.372416] mmc0: new HS200 MMC card at address 0001 [ 2.373222] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 2.373475] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 2.373739] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 2.374018] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [ 2.375944] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.378853] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.379468] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000 [ 2.381224] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.382154] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.382165] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.383376] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.387299] vdd_mmc1_sd: supplied by vcc3v3_io [ 2.388284] mmc1: CQHCI version 5.10 [ 2.389391] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present! [ 2.389456] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present! [ 2.393408] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.415616] ALSA device list: [ 2.415629] No soundcards found. [ 3.305526] mmc1: SDHCI controller on 4fa0000.mmc [4fa0000.mmc] using ADMA 64-bit [ 3.306449] Waiting for root device PARTUUID=422b5712-02... [ 3.363556] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 3.364467] mmcblk1: mmc1:aaaa SA08G 7.40 GiB [ 3.366619] mmcblk1: p1 p2 [ 3.393602] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.393701] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.396767] devtmpfs: mounted [ 3.398217] Freeing unused kernel memory: 1728K [ 3.415996] Run /sbin/init as init process [ 3.562377] systemd[1]: System time before build time, advancing clock. [ 3.611475] NET: Registered protocol family 10 [ 3.612910] Segment Routing with IPv6 [ 3.632598] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.633272] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 3.681879] systemd[1]: Set hostname to <am65xx-evm>. [ 3.685485] random: systemd: uninitialized urandom read (16 bytes read) [ 3.685540] systemd[1]: Initializing machine ID from random generator. [ 4.080428] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock /run/docker.sock; please update the unit file accordingly. [ 4.207378] random: systemd: uninitialized urandom read (16 bytes read) [ 4.207716] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 4.207736] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 4.212875] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ OK ] Created slice system-serial\x2dgett[ 4.256117] random: systemd: uninitialized urandom read (16 bytes read) [ 4.258585] systemd[1]: Created slice system-serial\x2dgetty.slice. y.slice. [ OK ] Created slice User and Session Slic[ 4.290273] systemd[1]: Created slice User and Session Slice. e. [ OK ] Started Dispatch Password ts to [ 4.312444] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. Console Directory Watch. [ OK ] Started Forward Password Ruests [ 4.336277] systemd[1]: Started Forward Password Requests to Wall Directory Watch. to Wall Directory Watch. [ OK ] Reached target Paths. [ 4.360213] systemd[1]: Reached target Paths. [ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems. [0m. [ OK ] Reached target Slices. [ 4.392052] systemd[1]: Reached target Slices. [ OK ] Reached target Swap.[ 4.404044] systemd[1]: Reached target Swap. [ OK ] Listening on RPCbind Server Activat[ 4.429338] systemd[1]: Listening on RPCbind Server Activation Socket. ion Socket. [ OK ] Reached target RPC Port Mapper.[ 4.452134] systemd[1]: Reached target RPC Port Mapper. [ 4.479820] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ OK ] Listening on initctl Compatibility [ 4.500417] systemd[1]: Listening on initctl Compatibility Named Pipe. Named Pipe. [ OK ] Listening on Journal Socket (/dev/l[ 4.534585] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 4.535502] systemd[1]: Listening on Journal Socket (/dev/log). og). [ OK ] Listening on Journal Socket.[ 4.564821] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Network Service Netlin[ 4.588909] systemd[1]: Listening on Network Service Netlink Socket. k Socket. [ OK ] Listening on udev Control Socket 4.612594] systemd[1]: Listening on udev Control Socket. m. [ OK ] Listening on udev Kernel Socket[ 4.632430] systemd[1]: Listening on udev Kernel Socket. . Mounting Huge Pages File System... [ 4.658815] systemd[1]: Mounting Huge Pages File System... Mounting POSIX Message Queue File System..[ 4.676723] systemd[1]: Mounting POSIX Message Queue File System... . Mounting Kernel Debug File System... [ 4.706690] systemd[1]: Mounting Kernel Debug File System... Mounting Temporary Directory (/tmp)... [ 4.726206] systemd[1]: Mounting Temporary Directory (/tmp)... Starting Create list of stodes for the curr[ 4.745124] systemd[1]: Starting Create list of static device nodes for the current kernel... ent kernel... Starting Start psplash boot splash screen.[ 4.774149] systemd[1]: Starting Start psplash boot splash screen... .. Starting RPC Bind...[ 4.803388] systemd[1]: Starting RPC Bind... [ 4.824420] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.833254] systemd[1]: Starting Journal Service... Starting Journal Service... Starting Load Kernel Modules... [ 4.864240] systemd[1]: Starting Load Kernel Modules... Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.888848] cryptodev: loading out-of-tree module taints kernel. [0m... [ 4.892690] cryptodev: driver 1.10 loaded. [ 4.911789] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) Starting udev Coldplug all Devices... [ 4.929690] systemd[1]: Starting udev Coldplug all Devices... [ OK ] Started RPC Bind. [ 4.951131] systemd[1]: Started RPC Bind. [ OK ] Mounted Huge Pages File System.[ 4.961085] systemd[1]: Mounted Huge Pages File System. [ OK ] Started Journal Service.[ 4.985139] systemd[1]: Started Journal Service. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta nodes for the current kernel. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Starprogress communication helper. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... [ 5.236472] systemd-journald[222]: Received client request to flush runtime journal. Starting Create System Users... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create System Users. Starting Create Static Device Nodes in /dev... [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Dynamic Linker Cache... Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. Starting Run pending postinsts... Starting Rebuild Journal Catalog... Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Rebuild Journal Catalog. [ OK ] Started Update UTMP about System Boot/Shutdown. [ 7.851976] random: crng init done [ 7.851996] random: 7 urandom warning(s) missed due to ratelimiting [ OK ] Started udev Coldplug all Devices. [ OK ] Started Load/Save Random Seed. [ OK ] Started Rebuild Dynamic Linker Cache. Starting udev Wait for Complete Device Initialization... Starting Update is Completed... [ 9.172493] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0 [ OK ] Started Update is Completed. [ 9.347121] CAN device driver interface [ 9.514397] cal 6f03000.cal: Neither port is configured, no point in staying up [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ 9.698789] m_can_platform 40528000.mcan: m_can device registered (irq=23, version=32) [ 9.987523] platform 41000000.r5f: configured R5F for remoteproc mode [ 9.996749] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 10.048200] remoteproc remoteproc0: 41000000.r5f is available [ 10.054349] remoteproc remoteproc0: powering up 41000000.r5f [ 10.054381] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 82412 [ 10.068588] remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000 [ 10.076342] m_can_platform 40568000.mcan: m_can device registered (irq=25, version=32) [ 10.121710] virtio_rpmsg_bus virtio0: rpmsg host is online [ 10.128750] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 10.153791] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 10.243089] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 10.243119] remoteproc remoteproc0: remote processor 41000000.r5f is now up [ 10.655965] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 10.740385] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867 [ 10.740411] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867 [ OK ] Started Run pending postinsts. [ 11.267971] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 11.339465] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867 [ 11.339490] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867 [ 12.035953] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 12.071133] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867 [ 12.071162] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867 [ 12.083180] remoteproc remoteproc1: b034000.pru is available [ 12.084390] remoteproc remoteproc2: b004000.rtu is available [ 12.087660] remoteproc remoteproc3: b00a000.txpru is available [ 12.089565] remoteproc remoteproc4: b038000.pru is available [ 12.090153] remoteproc remoteproc5: b006000.rtu is available [ 12.090633] remoteproc remoteproc6: b00c000.txpru is available [ 12.091064] remoteproc remoteproc7: b134000.pru is available [ 12.091574] remoteproc remoteproc8: b104000.rtu is available [ 12.101093] remoteproc remoteproc9: b10a000.txpru is available [ 12.101793] remoteproc remoteproc10: b138000.pru is available [ 12.102541] remoteproc remoteproc11: b106000.rtu is available [ 12.103237] remoteproc remoteproc12: b10c000.txpru is available [ 12.103824] remoteproc remoteproc13: b234000.pru is available [ 12.119549] remoteproc remoteproc14: b204000.rtu is available [ 12.123695] remoteproc remoteproc15: b20a000.txpru is available [ 12.124922] remoteproc remoteproc16: b238000.pru is available [ 12.140734] remoteproc remoteproc17: b206000.rtu is available [ 12.141401] remoteproc remoteproc18: b20c000.txpru is available [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ 13.736070] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 13.921179] OF: graph: no port node found in /bus@100000/phy@4110000 [ 14.274041] icssg-prueth icssg0-eth: TI PRU ethernet driver initialized: dual EMAC mode [ OK ] Reached target Hardware activated USB gadget. [ 14.465376] usbcore: registered new interface driver usbfs [ 14.475692] usbcore: registered new interface driver hub [ 14.481929] usbcore: registered new device driver usb [ 14.521778] icssg-prueth icssg2-eth: TI PRU ethernet driver initialized: dual EMAC mode [ 14.616218] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 14.619344] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 14.619532] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010 [ 14.620198] xhci-hcd xhci-hcd.2.auto: irq 594, io mem 0x04010000 [ 14.620888] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 14.620905] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 14.620915] usb usb1: Product: xHCI Host Controller [ 14.620923] usb usb1: Manufacturer: Linux 5.10.100-rt62-g204ec708dc xhci-hcd [ 14.620931] usb usb1: SerialNumber: xhci-hcd.2.auto [ 14.756762] hub 1-0:1.0: USB hub found [ 14.756857] hub 1-0:1.0: 1 port detected [ 14.842564] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 14.842613] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 14.842643] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 14.842797] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 14.842973] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 14.842987] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 14.842996] usb usb2: Product: xHCI Host Controller [ 14.843004] usb usb2: Manufacturer: Linux 5.10.100-rt62-g204ec708dc xhci-hcd [ 14.843012] usb usb2: SerialNumber: xhci-hcd.2.auto [ OK ] Started File System Check on /dev/mmcblk1p1. [ 14.970892] hub 2-0:1.0: USB hub found [ 14.970991] hub 2-0:1.0: 1 port detected [ 15.019317] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: dual EMAC mode Mounting /run/media/mmcblk1p1... [ OK ] Mounted /run/media/mmcblk1p1. [ OK ] Started udev Wait for Complete Device Initialization. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API. [ OK ] Listening on dropbear.socket. Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting rc.pvr.service... Starting Login Service... [ OK ] Started TEE Supplicant. [ 15.832334] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Reached target Network (Pre). Starting Network Service... [ OK ] Started Telephony service. [ OK ] Started rc.pvr.service. Starting weston.service... [ OK ] Listening on Load/Save RF itch Status /dev/rfkill Watch. [ 16.007558] Bluetooth: Core ver 2.22 [ 16.011598] NET: Registered protocol family 31 [ 16.011611] Bluetooth: HCI device and connection manager initialized [ 16.011640] Bluetooth: HCI socket layer initialized [ 16.011655] Bluetooth: L2CAP socket layer initialized [ 16.011696] Bluetooth: SCO socket layer initialized [ OK ] Started weston.service. Starting telnetd.service... [ OK ] Started telnetd.service. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 16.516589] remoteproc remoteproc10: powering up b138000.pru [ 16.518573] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 37540 [ 16.518610] remoteproc remoteproc10: unsupported resource 5 [ 16.518643] remoteproc remoteproc10: remote processor b138000.pru is now up [ 16.518686] remoteproc remoteproc11: powering up b106000.rtu [ 16.524005] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30088 [ 16.524067] remoteproc remoteproc11: remote processor b106000.rtu is now up [ 16.524114] remoteproc remoteproc12: powering up b10c000.txpru [ 16.527995] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35264 [ 16.528053] remoteproc remoteproc12: remote processor b10c000.txpru is now up [ 16.533390] icssg-prueth icssg1-eth: settime timeout [ 16.533726] pps pps0: new PPS source ptp2 [ 16.548687] TI DP83867 b132400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:03, irq=POLL) [ 16.548982] net eth6: started [ 16.652585] remoteproc remoteproc7: powering up b134000.pru [ 16.654161] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 37264 [ 16.654197] remoteproc remoteproc7: unsupported resource 5 [ 16.654229] remoteproc remoteproc7: remote processor b134000.pru is now up [ 16.654272] remoteproc remoteproc8: powering up b104000.rtu [ 16.655591] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30832 [ 16.655635] remoteproc remoteproc8: remote processor b104000.rtu is now up [ 16.655671] remoteproc remoteproc9: powering up b10a000.txpru [ 16.661679] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36656 [ 16.661744] remoteproc remoteproc9: remote processor b10a000.txpru is now up [ 16.693289] TI DP83867 b132400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b132400.mdio:00, irq=POLL) [ 16.693574] net eth5: started [ 16.748645] remoteproc remoteproc16: powering up b238000.pru [ 16.748930] remoteproc remoteproc16: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 37540 [ 16.748963] remoteproc remoteproc16: unsupported resource 5 [ 16.748994] remoteproc remoteproc16: remote processor b238000.pru is now up [ 16.749037] remoteproc remoteproc17: powering up b206000.rtu [ 16.749216] remoteproc remoteproc17: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30088 [ 16.749252] remoteproc remoteproc17: remote processor b206000.rtu is now up [ 16.749279] remoteproc remoteproc18: powering up b20c000.txpru [ 16.749431] remoteproc remoteproc18: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35264 [ 16.749469] remoteproc remoteproc18: remote processor b20c000.txpru is now up [ 16.758098] icssg-prueth icssg2-eth: settime timeout [ 16.758500] pps pps1: new PPS source ptp3 [ 16.788935] TI DP83867 b232400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:03, irq=POLL) [ 16.789226] net eth4: started [ 16.880532] remoteproc remoteproc13: powering up b234000.pru [ 16.880823] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 37264 [ 16.880855] remoteproc remoteproc13: unsupported resource 5 [ 16.880887] remoteproc remoteproc13: remote processor b234000.pru is now up [ 16.880928] remoteproc remoteproc14: powering up b204000.rtu [ 16.881112] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30832 [ 16.881149] remoteproc remoteproc14: remote processor b204000.rtu is now up [ 16.881175] remoteproc remoteproc15: powering up b20a000.txpru [ 16.881323] remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36656 [ 16.881363] remoteproc remoteproc15: remote processor b20a000.txpru is now up [ 16.904423] TI DP83867 b232400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b232400.mdio:00, irq=POLL) [ 16.904714] net eth3: started [ 16.976279] remoteproc remoteproc4: powering up b038000.pru [ 16.976574] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 37540 [ 16.976605] remoteproc remoteproc4: unsupported resource 5 [ 16.976637] remoteproc remoteproc4: remote processor b038000.pru is now up [ 16.976676] remoteproc remoteproc5: powering up b006000.rtu [ 16.976826] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30088 [ 16.976863] remoteproc remoteproc5: remote processor b006000.rtu is now up [ 16.976890] remoteproc remoteproc6: powering up b00c000.txpru [ 16.977028] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35264 [ 16.977068] remoteproc remoteproc6: remote processor b00c000.txpru is now up [ 16.982503] icssg-prueth icssg0-eth: settime timeout [ 16.982898] pps pps2: new PPS source ptp4 [ 17.001145] TI DP83867 b032400.mdio:03: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:03, irq=POLL) [ 17.001432] net eth2: started [ 17.080671] remoteproc remoteproc1: powering up b034000.pru [ 17.080947] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 37264 [ 17.080980] remoteproc remoteproc1: unsupported resource 5 [ 17.081012] remoteproc remoteproc1: remote processor b034000.pru is now up [ 17.081049] remoteproc remoteproc2: powering up b004000.rtu [ 17.081206] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30832 [ 17.081242] remoteproc remoteproc2: remote processor b004000.rtu is now up [ 17.081267] remoteproc remoteproc3: powering up b00a000.txpru [ 17.081406] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36656 [ 17.081444] remoteproc remoteproc3: remote processor b00a000.txpru is now up [ 17.102610] TI DP83867 b032400.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=b032400.mdio:00, irq=POLL) [ 17.102891] net eth1: started [ 17.176207] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL) [ 17.182889] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down [ OK ] Started Login Service. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Maent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Getty on tty4. [ OK ] Started Serial Getty on ttyS1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Avahi mDNS/DNS-SD Stack. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Started Simple Network Manement Protocol (SNMP) Daemon.. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav-dev gstreamer1.0-libav gzip less libasm1 libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libidn2-0 libidn2-dev libmpc3 libmpfr6 libreadline-dev libreadline8 libunistring-dev libunistring2 m4-dev m4 make nettle-dev nettle parted pdm-anomaly-detection python3-rfc3987 python3-strict-rfc3339 tar which zeromq If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ 21.197509] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off [ 21.197600] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am65xx-evm ttyS2 Arago 2021.09 am65xx-evm ttyS2 am65xx-evm login: root root@am65xx-evm:~# cat ti run.sh #!/bin/sh IF=$1 ROLE=$2 gcc sendRec.c -o sendRec systemctl stop systemd-networkd.socket systemctl stop systemd-networkd.service ip a flush $IF ip -6 a flush $IF ./sendRec $IF $ROLE root@am65xx-evm:~# ./run.sh eth1 -r [ 51.688209] device eth1 entered promiscuous mode [ 52.172146] Initializing XFRM netlink socket [ 54.845524] process 'docker/tmp/qemu-check854655822/check' started with executable stack [ 57.037091] icssg-prueth icssg0-eth eth1: Link is Down Received frame len 60 with ID 0 HW 1648099160.935130040 Received frame len 60 with ID 1 HW 1648099160.945377404 Received frame len 60 with ID 2 HW 1648099160.955628700 Received frame len 60 with ID 3 HW 1648099160.965860840 Received frame len 60 with ID 4 HW 1648099160.976098976 Received frame len 60 with ID 5 HW 1648099160.986341036 Received frame len 60 with ID 6 HW 1648099160.996581112 Received frame len 60 with ID 7 HW 1648099161.6820376 Received frame len 60 with ID 8 HW 1648099161.17057772 Received frame len 60 with ID 9 HW 1648099161.27296404 [ 61.133534] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off [ 63.181087] icssg-prueth icssg0-eth eth1: Link is Down Received frame len 60 with ID 0 HW 1648099167.431032248 Received frame len 60 with ID 1 HW 1648099167.441227972 Received frame len 60 with ID 2 HW 1648099167.451456508 Received frame len 60 with ID 3 HW 1648099167.461684944 Received frame len 60 with ID 4 HW 1648099167.471922476 Received frame len 60 with ID 5 HW 1648099167.482160320 Received frame len 60 with ID 6 HW 1648099167.492393784 Received frame len 60 with ID 7 HW 1648099167.502629236 Received frame len 60 with ID 8 HW 1648099167.512867944 Received frame len 60 with ID 9 HW 1648099167.523109948 [ 67.277540] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off [ 69.325116] icssg-prueth icssg0-eth eth1: Link is Down Received frame len 60 with ID 0 HW 1648099173.162697092 Received frame len 60 with ID 1 HW 1648099173.172903776 Received frame len 60 with ID 2 HW 1648099173.183110832 Received frame len 60 with ID 3 HW 1648099173.193315060 Received frame len 60 with ID 4 HW 1648099173.203519192 Received frame len 60 with ID 5 HW 1648099173.213724080 Received frame len 60 with ID 6 HW 1648099173.223930500 Received frame len 60 with ID 7 HW 1648099173.234136884 Received frame len 60 with ID 8 HW 1648099173.244347672 Received frame len 60 with ID 9 HW 1648099173.254558816 [ 73.421553] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off [ 75.469064] icssg-prueth icssg0-eth eth1: Link is Down Received frame len 60 with ID 0 HW 1648099180.550543576 Received frame len 60 with ID 1 HW 1648099180.560748140 Received frame len 60 with ID 2 HW 1648099180.570952940 Received frame len 60 with ID 3 HW 1648099180.581157208 Received frame len 60 with ID 4 HW 1648099180.591362756 Received frame len 60 with ID 5 HW 1648099180.601572104 Received frame len 60 with ID 6 HW 1648099180.611779372 Received frame len 60 with ID 7 HW 1648099180.621985808 Received frame len 60 with ID 8 HW 1648099180.632196244 Received frame len 60 with ID 9 HW 1648099180.642406208 [ 80.589512] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off [ 83.661065] icssg-prueth icssg0-eth eth1: Link is Down Received frame len 60 with ID 0 HW 1648099188.910224604 Received frame len 60 with ID 1 HW 1648099188.920394012 Received frame len 60 with ID 2 HW 1648099188.930603524 Received frame len 60 with ID 3 HW 1648099188.940803776 Received frame len 60 with ID 4 HW 1648099188.951026924 Received frame len 60 with ID 5 HW 1648099188.961235544 Received frame len 60 with ID 6 HW 1648099188.971446736 Received frame len 60 with ID 7 HW 1648099188.981656740 Received frame len 60 with ID 8 HW 1648099188.991869640 Received frame len 60 with ID 9 HW 1648099189.2079332 [ 88.781526] icssg-prueth icssg0-eth eth1: Link is Up - 1Gbps/Full - flow control off ^C[ 89.837243] device eth1 left promiscuous mode root@am65xx-evm:~#
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.09.04 08:13:56 =~=~=~=~=~=~=~=~=~=~=~= U-Boot SPL 2023.04-gc1c2bdf272 (Nov 30 2023 - 18:17:44 +0000) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') SPL initial stack usage: 1424 bytes Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Starting ATF on ARM64 core... NOTICE: BL31: v2.9(release):v2.9.0-614-gd7a7135d32-dirty NOTICE: BL31: Built : 09:34:15, Aug 24 2023 I/TC: I/TC: OP-TEE version: 4.0.0 (gcc version 11.4.0 (GCC)) #1 Fri Oct 20 18:29:31 UTC 2023 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2023.04-gc1c2bdf272 (Nov 30 2023 - 18:17:44 +0000) SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2023.04-gc1c2bdf272 (Nov 30 2023 - 18:17:44 +0000) SoC: AM65X SR2.0 GP Model: Texas Instruments AM654 Base Board Board: AM6-COMPROCEVM rev A DRAM: 4 GiB Core: 119 devices, 31 uclasses, devicetree: separate MMC: mmc@4f80000: 0, mmc@4fa0000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Detected: AM6-IDKAPPEVM rev A Detected: SER-PCIE2LEVM rev A Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 2 1 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 574 bytes read in 27 ms (20.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... ## Error: "main_cpsw0_qsgmii_phyinit" not defined 19241472 bytes read in 787 ms (23.3 MiB/s) 66697 bytes read in 31 ms (2.1 MiB/s) Working FDT set to 88000000 11685 bytes read in 29 ms (392.6 KiB/s) 2333 bytes read in 28 ms (81.1 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK Working FDT set to 8feec000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.46-rt13-gb4f1767f9e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT_RT Thu Nov 30 22:21:00 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM654 Base Board [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a20fffff] [ 0.000000] node 0: [mem 0x00000000a2100000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 19 pages/cpu s37696 r8192 d31936 u77824 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=06f70d59-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB) [ 0.000000] Memory: 3945104K/4194304K available (11584K kernel code, 1254K rwdata, 3944K rodata, 1856K init, 461K bss, 216432K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: Offload RCU callbacks from CPUs: 0-3. [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000477] Console: colour dummy device 80x25 [ 0.457669] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000) [ 0.457683] pid_max: default: 32768 minimum: 301 [ 0.457768] LSM: Security Framework initializing [ 0.457936] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.457969] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.460427] cblist_init_generic: Setting adjustable number of callback queues. [ 0.503626] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.509993] cblist_init_generic: Setting adjustable number of callback queues. [ 0.517416] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.524146] rcu: Hierarchical SRCU implementation. [ 0.524150] rcu: Max phase no-delay instances is 400. [ 0.524234] printk: bootconsole [ns16550a0] printing thread started [ 0.541694] Platform MSI: msi-controller@1820000 domain created [ 0.541967] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.542396] EFI services will not be available. [ 0.542822] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.577148] Detected VIPT I-cache on CPU1 [ 0.577288] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.577308] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.577364] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot [ 0.612674] Detected VIPT I-cache on CPU2 [ 0.612904] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000 [ 0.612924] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.612984] CPU2: Booted secondary processor 0x0000000100 [0x410fd034] I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot [ 0.648278] Detected VIPT I-cache on CPU3 [ 0.648380] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000 [ 0.648396] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.648431] CPU3: Booted secondary processor 0x0000000101 [0x410fd034] [ 0.648598] smp: Brought up 1 node, 4 CPUs [ 0.678249] SMP: Total of 4 processors activated. [ 0.678258] CPU features: detected: 32-bit EL0 Support [ 0.678264] CPU features: detected: CRC32 instructions [ 0.678341] CPU: All CPU(s) started at EL2 [ 0.678344] alternatives: applying system-wide alternatives [ 0.680732] devtmpfs: initialized [ 0.700422] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.700449] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.701867] pinctrl core: initialized pinctrl subsystem [ 0.702619] DMI not present or invalid. [ 0.703469] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.717507] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.718051] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.718394] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.718529] audit: initializing netlink subsys (disabled) [ 0.718780] audit: type=2000 audit(0.713:1): state=initialized audit_enabled=0 res=1 [ 0.719463] thermal_sys: Registered thermal governor 'step_wise' [ 0.719720] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.757353] ASID allocator initialised with 65536 entries [ 0.772897] platform 900000.serdes: Fixed dependency cycle(s) with /bus@100000/serdes@910000 [ 0.785133] KASLR disabled due to lack of seed [ 0.799186] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.799195] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.799203] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.799207] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.799213] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.799217] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.799223] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.799227] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.806720] k3-chipinfo 43000014.chipid: Family:AM65X rev:SR2.0 JTAGID[0x1bb5a02f] Detected [ 0.808453] iommu: Default domain type: Translated [ 0.808462] iommu: DMA domain TLB invalidation policy: strict mode [ 0.808974] SCSI subsystem initialized [ 0.809499] usbcore: registered new interface driver usbfs [ 0.809556] usbcore: registered new interface driver hub [ 0.809603] usbcore: registered new device driver usb [ 0.810375] pps_core: LinuxPPS API ver. 1 registered [ 0.810380] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.810401] PTP clock support registered [ 0.810615] EDAC MC: Ver: 3.0.0 [ 0.811947] FPGA manager framework [ 0.812084] Advanced Linux Sound Architecture Driver Initialized. [ 0.813446] clocksource: Switched to clocksource arch_sys_counter [ 0.813780] VFS: Disk quotas dquot_6.6.0 [ 0.813876] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.824143] NET: Registered PF_INET protocol family [ 0.824589] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.829229] tcp_lIi/sTCt:e nR_epsoerrtvaeddd rs_hhaasrhe dh masehm otrayb lies eennatbrlieeds : 2I/0T4C8: ( Doryndeamr:ic 4 s,h a81re92d 0 mebmyotersy, ilsi neenaarbl) ed [ I/ T0.C8:2 9N3o2rm3a]l T aWborlled-p evritruturbal hizasath iotnab sleup epnotrrti eiss: d6is5a5b3l6 e(do r deIr/:T C:6 ,A s2y6n2c1h4r4o bnyoutess n, oltiinfiecarat) i on[s ar 0e. d8i29sa34b6l]ed T CP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.829983] TCP bind hash table entries: 32768 (order: 9, 2621440 bytes, linear) [ 0.833150] TCP: Hash tables configured (established 32768 bind 32768) [ 0.833406] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear) [ 0.833685] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear) [ 0.834167] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.834973] RPC: Registered named UNIX socket transport module. [ 0.834981] RPC: Registered udp transport module. [ 0.834985] RPC: Registered tcp transport module. [ 0.834989] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.835001] NET: Registered PF_XDP protocol family [ 0.835021] PCI: CLS 0 bytes, default 64 [ 0.836609] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.839022] Initialise system trusted keyrings [ 0.839341] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.849566] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.850331] NFS: Registering the id_resolver key type [ 0.850371] Key type id_resolver registered [ 0.850375] Key type id_legacy registered [ 0.850524] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.850531] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.905170] Key type asymmetric registered [ 0.905178] Asymmetric key parser 'x509' registered [ 0.905250] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.905466] io scheduler mq-deadline registered [ 0.905473] io scheduler kyber registered [ 0.911637] pinctrl-single 4301c000.pinctrl: 70 pins, size 280 [ 0.912524] pinctrl-single 11c000.pinctrl: 185 pins, size 740 [ 0.912766] pinctrl-single 11c2e8.pinctrl: 9 pins, size 36 [ 0.923724] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.951783] loop: module loaded [ 0.953586] megasas: 07.719.03.00-rc1 [ 0.959015] tun: Universal TUN/TAP device driver, 1.6 [ 0.960111] thunder_xcv, ver 1.0 [ 0.960174] thunder_bgx, ver 1.0 [ 0.960230] nicpf, ver 1.0 [ 0.960512] e1000: Intel(R) PRO/1000 Network Driver [ 0.960517] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.960589] e1000e: Intel(R) PRO/1000 Network Driver [ 0.960592] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.960649] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.960653] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.960696] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.960700] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.960896] sky2: driver version 1.30 [ 0.962112] VFIO - User Level meta-driver version: 0.3 [ 0.963209] usbcore: registered new interface driver usb-storage [ 0.964153] i2c_dev: i2c /dev entries driver [ 0.965062] sdhci: Secure Digital Host Controller Interface driver [ 0.965066] sdhci: Copyright(c) Pierre Ossman [ 0.965469] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.966550] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.967025] usbcore: registered new interface driver usbhid [ 0.967030] usbhid: USB HID core driver [ 0.968492] optee: probing for conduit method. [ 0.968525] optee: revision 4.0 (2a5b1d12) [ 1.001323] optee: dynamic shared memory is enabled [ 1.001908] optee: initialized driver [ 1.004622] Initializing XFRM netlink socket [ 1.004667] NET: Registered PF_PACKET protocol family [ 1.004787] Key type dns_resolver registered [ 1.005105] registered taskstats version 1 [ 1.005139] Loading compiled-in X.509 certificates [ 1.021994] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)') [ 1.096582] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 1.098016] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 1.099412] pca953x 2-0021: supply vcc not found, using dummy regulator [ 1.099597] pca953x 2-0021: using no AI [ 1.112290] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.113480] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz [ 1.114554] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.114948] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 156 domain created [ 1.115216] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 100 domain created [ 1.115474] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 182 domain created [ 1.115957] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created [ 1.126219] OF: /bus@100000/pcie@5500000: phandle pcie-mode@4060 needs 1, found 0 [ 1.126655] keystone-pcie 5500000.pcie: host bridge /bus@100000/pcie@5500000 ranges: [ 1.126719] keystone-pcie 5500000.pcie: IO 0x0010020000..0x001002ffff -> 0x0000000000 [ 1.126748] keystone-pcie 5500000.pcie: MEM 0x0010030000..0x0017ffffff -> 0x0010030000 [ 1.127091] OF: /bus@100000/pcie@5500000: phandle pcie-devid@210 needs 1, found 0 [ 1.127147] keystone-pcie 5500000.pcie: iATU unroll: enabled [ 1.127155] keystone-pcie 5500000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 4G [ 2.127491] keystone-pcie 5500000.pcie: Phy link never came up [ 2.127677] keystone-pcie 5500000.pcie: PCI host bridge to bus 0000:00 [ 2.127689] pci_bus 0000:0Lroot bus resource [bus 00-ff] [ [ 2.147216] printk: console [ttyS2] printing thread started 2.127701] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 2.147239] printk: console [ttyS2] enabled [ 2.147248] printk: bootconsole [ns16550a0] disabled [ 2.159232] printk: bootconsole [ns16550a0] printing thread stopped [ 2.166227] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.200473] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.202221] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.202282] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000 [ 2.202506] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.202516] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.203921] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.208183] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.210043] mmc0: CQHCI version 5.10 [ 2.224594] pca953x 0-0039: supply vcc not found, using dummy regulator [ 2.224784] pca953x 0-0039: using no AI [ 2.238222] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 2.238780] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 2.241143] ti-udma 285c0000.dma-controller: Channels: 28 (tchan: 14, rchan: 14, gp-rflow: 16) [ 2.250024] ti-udma 31150000.dma-controller: Channels: 119 (tchan: 53, rchan: 66, gp-rflow: 64) [ 2.252082] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 2.266301] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 2.266460] 8 fixed-partitions partitions found on MTD device 47040000.spi.0 [ 2.266475] Creating 8 MTD partitions on "47040000.spi.0": [ 2.266484] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 2.268598] 0x000000080000-0x000000280000 : "ospi.tispl" [ 2.270389] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 2.272273] 0x000000680000-0x0000006a0000 : "ospi.env" [ 2.274009] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 2.275777] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 2.277541] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 2.279279] 0x000003fe0000-0x000004000000 : "ospi.phypattern" [ 2.287366] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.321492] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.323243] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.323304] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00102, cpsw version 0x6BA80102 Ports: 2 quirks:00000000 [ 2.323530] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.323539] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.324675] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 2.346357] mmc0: Command Queue Engine enabled [ 2.346377] mmc0: new HS200 MMC card at address 0001 [ 2.347309] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 2.349999] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 2.351681] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.351954] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 2.353625] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0) [ 2.368581] debugfs: Directory 'pd:121' with parent 'pm_genpd' already present! [ 2.368656] debugfs: Directory 'pd:120' with parent 'pm_genpd' already present! [ 2.368872] mmc1: CQHCI version 5.10 [ 2.372237] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.393749] ALSA device list: [ 2.393759] No soundcards found. [ 2.410631] mmc1: SDHCI controller on 4fa0000.mmc [4fa0000.mmc] using ADMA 64-bit [ 2.506975] Waiting for root device PARTUUID=06f70d59-02... [ 2.532281] mmc1: new high speed SDHC card at address aaaa [ 2.533237] mmcblk1: mmc1:aaaa SM16G 14.8 GiB [ 2.536173] mmcblk1: p1 p2 [ 2.553387] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 2.553517] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.554227] devtmpfs: mounted [ 2.555647] Freeing unused kernel memory: 1856K [ 2.555795] Run /sbin/init as init process [ 2.942693] systemd[1]: System time before build time, advancing clock. [ 3.020900] NET: Registered PF_INET6 protocol family [ 3.022732] Segment Routing with IPv6 [ 3.022781] In-situ OAM (IOAM) with IPv6 [ 3.069003] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 3.069861] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 3.162536] systemd[1]: Hostname set to <am65xx-evm>. [ 3.174589] systemd[1]: Initializing machine ID from random generator. [ 3.308669] systemd-sysv-generator[203]: SysV service '/etc/init.d/netopeer2-server' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.310554] systemd-sysv-generator[203]: SysV service '/etc/init.d/sysrepo' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.310811] systemd-sysv-generator[203]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.681954] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.754720] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.842359] systemd[1]: Queued start job for default target Graphical Interface. [ OK ] Created slice Slice /system/getty 4.008800] systemd[1]: Created slice Slice /system/getty. 0m. [ OK ] Created slice Slice /system/modprob[ 4.028039] systemd[1]: Created slice Slice /system/modprobe. e. [ OK ] Created slice Slice /system/serial-[ 4.046880] systemd[1]: Created slice Slice /system/serial-getty. getty. [ OK ] Created slice User and Session Slic[ 4.065100] systemd[1]: Created slice User and Session Slice. e. [ OK ] Started Dispatch Password ts to [ 4.080048] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. Console Directory Watch. [ OK ] Started Forward Password Ruests [ 4.096933] systemd[1]: Started Forward Password Requests to Wall Directory Watch. to Wall Directory Watch. [ 4.116215] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems. [0m. [ OK ] Reached target Slice Units. [ 4.143691] systemd[1]: Reached target Slice Units. [ 4.154408] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ OK ] Listening on RPCbind Server Activat[ 4.223615] systemd[1]: Listening on RPCbind Server Activation Socket. ion Socket. [ OK ] Reached target RPC Port Mapper.[ 4.238868] systemd[1]: Reached target RPC Port Mapper. [ OK ] Listening on Process Core Dump Sock[ 4.264133] systemd[1]: Listening on Process Core Dump Socket. et. [ OK ] Listening on initctl Compatibility [ 4.279189] systemd[1]: Listening on initctl Compatibility Named Pipe. Named Pipe. [ OK ] Listening on Journal Audit Socket 4.295687] systemd[1]: Listening on Journal Audit Socket. 0m. [ 4.310295] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket. [ 4.325535] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Network Service Netlin[ 4.337487] systemd[1]: Listening on Network Service Netlink Socket. k Socket. [ OK ] Listening on udev Control Socket 4.353628] systemd[1]: Listening on udev Control Socket. m. [ OK ] Listening on udev Kernel Socket[ 4.368208] systemd[1]: Listening on udev Kernel Socket. . [ OK ] Listening on User Database Manager [ 4.382198] systemd[1]: Listening on User Database Manager Socket. Socket. [ 4.426178] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... Mounting POSIX Message Queue File System..[ 4.446901] systemd[1]: Mounting POSIX Message Queue File System... . Mounting Kernel Debug File System... [ 4.469043] systemd[1]: Mounting Kernel Debug File System... [ 4.481288] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.491612] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... Starting Create List of Static Device Nodes 4.516959] systemd[1]: Starting Create List of Static Device Nodes... m... Starting Load Kernel Module configfs... [ 4.539467] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module drm... [ 4.558125] systemd[1]: Starting Load Kernel Module drm... [ 4.576369] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 4.628161] fuse: init (API version 7.37) Starting Start psplash boot splash screen.[ 4.641734] systemd[1]: Starting Start psplash boot splash screen... .. Starting RPC Bind... [ 4.671661] systemd[1]: Starting RPC Bind... [ 4.680888] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 4.692307] systemd[1]: Starting Journal Service... Starting Journal Service... Starting Load Kernel Modules...[ 4.751902] systemd[1]: Starting Load Kernel Modules... Starting Generate network ts from Kernel co[ 4.773761] systemd[1]: Starting Generate network units from Kernel command line... mmand line... [ 4.783995] cryptodev: loading out-of-tree module taints kernel. [ 4.786321] cryptodev: driver 1.12 loaded. [ 4.804365] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 4.833200] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ OK ] Started RPC Bind. [ 4.860763] systemd[1]: Started RPC Bind. [ 4.861701] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. [ 4.875626] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File Sy[ 4.893883] systemd[1]: Mounted POSIX Message Queue File System. stem. [ OK ] Mounted Kernel Debug File System 4.909522] systemd[1]: Mounted Kernel Debug File System. m. [ OK ] Started Journal Service. [ 4.923094] systemd[1]: Started Journal Service. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Starprogress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... [ 5.166320] systemd-journald[221]: Received client request to flush runtime journal. Starting Create System Users... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create System Users. Starting Create Static Device Nodes in /dev... [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 5.459710] audit: type=1334 audit(1651167747.521:2): prog-id=5 op=LOAD Starting Rule-based Managefor Device Events[ 5.459960] audit: type=1334 audit(1651167747.521:3): prog-id=6 op=LOAD and Files... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Dynamic Linker Cache... Starting Create Volatile Files and Directories... [ OK ] Finished Create Volatile Files and Directories. Starting Rebuild Journal Catalog... Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Record System Boot/Shutdown in UTMP. [ 5.865470] random: crng init done [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Finished Load/Save Random Seed. [ OK ] Finished Rebuild Journal Catalog. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Found device /dev/ttyS2. [ 6.512171] davinci_mdio b032400.mdio: Configuring MDIO in manual mode [ 6.532216] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0 [ 6.546513] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 6.570652] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867 [ 6.570677] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867 [ 6.599866] spi-nor spi2.0: n25q128a13 (16384 Kbytes) [ 6.700966] CAN device driver interface [ 6.761286] m_can_platform 40528000.mcan: m_can device registered (irq=585, version=32) [ 6.765002] m_can_platform 40568000.mcan: m_can device registered (irq=586, version=32) [ 6.791053] davinci_mdio b132400.mdio: Configuring MDIO in manual mode [ 6.838537] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 6.877494] platform 41000000.r5f: configured R5F for remoteproc mode [ 6.886956] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 6.896796] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867 [ 6.896819] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867 [ 6.912280] remoteproc remoteproc0: 41000000.r5f is available [ 6.963056] davinci_mdio b232400.mdio: Configuring MDIO in manual mode [ 6.966333] remoteproc remoteproc0: powering up 41000000.r5f [ 6.966359] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 82412 [ 6.988796] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@a0000000 [ 6.989847] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.989912] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7) [ 6.989923] remoteproc remoteproc0: remote processor 41000000.r5f is now up [ 7.009527] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 7.009873] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 7.025522] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 7.075472] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867 [ 7.075495] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867 [ 7.125008] remoteproc remoteproc1: b00a000.txpru is available [ 7.130540] remoteproc remoteproc2: b00c000.txpru is available [ 7.131312] remoteproc remoteproc3: b10a000.txpru is available [ 7.135416] remoteproc remoteproc4: b10c000.txpru is available [ 7.136118] remoteproc remoteproc5: b20a000.txpru is available [ 7.140675] remoteproc remoteproc6: b20c000.txpru is available [ 7.893210] remoteproc remoteproc7: b034000.pru is available [ 7.897287] remoteproc remoteproc8: b004000.rtu is available [ 7.904160] remoteproc remoteproc9: b138000.pru is available [ 7.906580] remoteproc remoteproc10: b106000.rtu is available [ 7.907572] remoteproc remoteproc11: b134000.pru is available [ 7.908492] remoteproc remoteproc12: b104000.rtu is available [ 7.909522] remoteproc remoteproc13: b234000.pru is available [ 7.911752] remoteproc remoteproc14: b204000.rtu is available [ 7.913536] remoteproc remoteproc15: b038000.pru is available [ 7.914419] remoteproc remoteproc16: b006000.rtu is available [ 7.919681] remoteproc remoteproc17: b238000.pru is available [ 7.920307] remoteproc remoteproc18: b206000.rtu is available [ 8.078895] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ 8.413055] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 8.413115] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 8.413287] xhci-hcd xhci-hcd.3.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010 [ 8.437702] xhci-hcd xhci-hcd.3.auto: irq 587, io mem 0x04010000 [ 8.438145] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 8.438175] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 [ 8.438203] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ OK ] Reached target Hardware activated U[ 8.448142] hub 1-0:1.0: USB hub found [ 8.450277] hub 1-0:1.0: 1 port detected SB gadget. [ 8.498729] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 8.501376] hub 2-0:1.0: USB hub found [ 8.501517] hub 2-0:1.0: 1 port detected [ OK ] Finished Rebuild Dynamic Linker Cache. Starting Update is Completed... [ OK ] Finished Update is Completed. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. Starting Weston socket... Starting Console System Startup Logging... Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Listening on Weston socket. [ OK ] Finished Console System Startup Logging. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Reached target Socket Units. [ OK ] Created slice Slice /system/systemd-fsck. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... [ OK ] Started strongSwan IPsec IIKEv2 daemon using ipsec.conf. [ 10.252240] audit: type=1334 audit(1651167752.313:4): prog-id=7 op=LOAD [ 10.253516] audit: type=1334 audit(1651167752.314:5): prog-id=8 op=LOAD Starting User Login Management... [ OK ] Started TEE Supplicant. Starting Telnet Server... [FAILED] Failed to start Print notice about GPLv3 packages. See 'systemctl status gplv3-notice.service' for details. [ OK ] Finished File System Check on /dev/mmcblk1p1. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Reached target Preparation for Network. Mounting /run/media/boot-mmcblk1p1... Starting Network Configuration... [ OK ] Started Telephony service. [ OK ] Mounted /run/media/boot-mmcblk1p1. [ OK ] Listening on Load/Save RF itch Status /dev/rfkill Watch. [ 10.543508] Bluetooth: Core ver 2.22 [ 10.543672] NET: Registered PF_BLUETOOTH protocol family [ 10.543678] Bluetooth: HCI device and connection manager initialized [ 10.543701] Bluetooth: HCI socket layer initialized [ 10.543716] Bluetooth: L2CAP socket layer initialized [ 10.543740] Bluetooth: SCO socket layer initialized [ OK ] Started User Login Management. [ 10.851341] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 10.866556] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ OK ] Started Network Configuration. Starting Network Name Resolution... [ 11.021115] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 11.021150] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... Starting containerd container runtime... [ OK ] Started Netperf Benchmark Server. [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Maent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [FAILED] Failed to start Enable andfigure wl18xx bluetooth stack. See 'systemctl status bt-enable.service' for details. [ OK ] Finished Permit User Sessions. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Weston, a Waylandositor, as a system service... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ 12.334926] audit: type=1334 audit(1651167754.396:6): prog-id=9 op=LOAD [ 12.335146] audit: type=1334 audit(1651167754.396:7): prog-id=10 op=LOAD Starting User Database Manager... [ OK ] Started User Database Manager. [ OK ] Created slice User Slice of UID 1000. Starting User Runtime Directory /run/user/1000... [ OK ] Finished User Runtime Directory /run/user/1000. Starting User Manager for UID 1000... [ 13.080666] audit: type=1006 audit(1651167755.142:8): pid=692 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 13.080698] audit: type=1300 audit(1651167755.142:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd20c5c78 a2=4 a3=ffff824d6020 items=0 ppid=1 pid=692 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 13.080719] audit: type=1327 audit(1651167755.142:8): proctitle="(systemd)" [ OK ] Started Simple Network Manement Protocol (SNMP) Daemon.. [ OK ] Started User Manager for UID 1000. [ OK ] Started Session c1 of User weston. [ 14.215873] audit: type=1006 audit(1651167756.277:9): pid=681 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 14.215911] audit: type=1300 audit(1651167756.277:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd20c5c78 a2=4 a3=ffff824d6020 items=0 ppid=1 pid=681 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 14.215932] audit: type=1327 audit(1651167756.277:9): proctitle="(weston)" [FAILED] Failed to start Weston, a mpositor, as a system service. See 'systemctl status weston.service' for details. [ OK ] Started containerd container runtime. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Record Runlevel Change in UTMP... [ OK ] Finished Record Runlevel Change in UTMP. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am65xx-evm - Arago 2023.10 am65xx-evm - am65xx-evm login: [ 18.935619] TI DP83867 b132400.mdio:00: attached PHY driver (mii_bus:phy_addr=b132400.mdio:00, irq=POLL) [ 18.954207] TI DP83867 b132400.mdio:03: attached PHY driver (mii_bus:phy_addr=b132400.mdio:03, irq=POLL) [ 18.954255] icssg-prueth icssg1-eth: TI PRU ethernet driver initialized: dual EMAC mode [ 18.977060] TI DP83867 b032400.mdio:00: attached PHY driver (mii_bus:phy_addr=b032400.mdio:00, irq=POLL) [ 18.985305] TI DP83867 b032400.mdio:03: attached PHY driver (mii_bus:phy_addr=b032400.mdio:03, irq=POLL) [ 18.985349] icssg-prueth icssg0-eth: TI PRU ethernet driver initialized: dual EMAC mode [ 19.016101] TI DP83867 b232400.mdio:00: attached PHY driver (mii_bus:phy_addr=b232400.mdio:00, irq=419) [ 19.044145] TI DP83867 b232400.mdio:03: attached PHY driver (mii_bus:phy_addr=b232400.mdio:03, irq=419) [ 19.058920] icssg-prueth icssg2-eth: TI PRU ethernet driver initialized: dual EMAC mode [ 19.151010] remoteproc remoteproc11: powering up b134000.pru [ 19.161114] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 40936 [ 19.161158] remoteproc remoteproc11: unsupported resource 5 [ 19.161195] remoteproc remoteproc11: remote processor b134000.pru is now up [ 19.161247] remoteproc remoteproc12: powering up b104000.rtu [ 19.191401] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30884 [ 19.191515] remoteproc remoteproc12: remote processor b104000.rtu is now up [ 19.191570] remoteproc remoteproc3: powering up b10a000.txpru [ 19.196841] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36672 [ 19.196912] remoteproc remoteproc3: remote processor b10a000.txpru is now up [ 19.197329] remoteproc remoteproc9: powering up b138000.pru [ 19.200294] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 41208 [ 19.200337] remoteproc remoteproc9: unsupported resource 5 [ 19.200372] remoteproc remoteproc9: remote processor b138000.pru is now up [ 19.200424] remoteproc remoteproc10: powering up b106000.rtu [ 19.202741] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30124 [ 19.202793] remoteproc remoteproc10: remote processor b106000.rtu is now up [ 19.202839] remoteproc remoteproc4: powering up b10c000.txpru [ 19.205201] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35184 [ 19.205258] remoteproc remoteproc4: remote processor b10c000.txpru is now up [ 19.206886] pps pps0: new PPS source ptp2 [ 19.325162] remoteproc remoteproc7: powering up b034000.pru [ 19.325396] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 40936 [ 19.325423] remoteproc remoteproc7: unsupported resource 5 [ 19.325567] remoteproc remoteproc7: remote processor b034000.pru is now up [ 19.325607] remoteproc remoteproc8: powering up b004000.rtu [ 19.325779] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30884 [ 19.325812] remoteproc remoteproc8: remote processor b004000.rtu is now up [ 19.325841] remoteproc remoteproc1: powering up b00a000.txpru [ 19.325970] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36672 [ 19.326011] remoteproc remoteproc1: remote processor b00a000.txpru is now up [ 19.326353] remoteproc remoteproc15: powering up b038000.pru [ 19.326570] remoteproc remoteproc15: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 41208 [ 19.326593] remoteproc remoteproc15: unsupported resource 5 [ 19.326622] remoteproc remoteproc15: remote processor b038000.pru is now up [ 19.326650] remoteproc remoteproc16: powering up b006000.rtu [ 19.326794] remoteproc remoteproc16: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30124 [ 19.326829] remoteproc remoteproc16: remote processor b006000.rtu is now up [ 19.326854] remoteproc remoteproc2: powering up b00c000.txpru [ 19.326982] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35184 [ 19.327020] remoteproc remoteproc2: remote processor b00c000.txpru is now up [ 19.328507] pps pps1: new PPS source ptp3 [ 19.491487] remoteproc remoteproc13: powering up b234000.pru [ 19.491713] remoteproc remoteproc13: Booting fw image ti-pruss/am65x-sr2-pru0-prueth-fw.elf, size 40936 [ 19.491743] remoteproc remoteproc13: unsupported resource 5 [ 19.491776] remoteproc remoteproc13: remote processor b234000.pru is now up [ 19.491813] remoteproc remoteproc14: powering up b204000.rtu [ 19.491927] remoteproc remoteproc14: Booting fw image ti-pruss/am65x-sr2-rtu0-prueth-fw.elf, size 30884 [ 19.491960] remoteproc remoteproc14: remote processor b204000.rtu is now up [ 19.491984] remoteproc remoteproc5: powering up b20a000.txpru [ 19.492105] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-sr2-txpru0-prueth-fw.elf, size 36672 [ 19.492142] remoteproc remoteproc5: remote processor b20a000.txpru is now up [ 19.492602] remoteproc remoteproc17: powering up b238000.pru [ 19.492731] remoteproc remoteproc17: Booting fw image ti-pruss/am65x-sr2-pru1-prueth-fw.elf, size 41208 [ 19.492754] remoteproc remoteproc17: unsupported resource 5 [ 19.492783] remoteproc remoteproc17: remote processor b238000.pru is now up [ 19.492811] remoteproc remoteproc18: powering up b206000.rtu [ 19.492923] remoteproc remoteproc18: Booting fw image ti-pruss/am65x-sr2-rtu1-prueth-fw.elf, size 30124 [ 19.492956] remoteproc remoteproc18: remote processor b206000.rtu is now up [ 19.493024] remoteproc remoteproc6: powering up b20c000.txpru [ 19.493149] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-sr2-txpru1-prueth-fw.elf, size 35184 [ 19.493185] remoteproc remoteproc6: remote processor b20c000.txpru is now up [ 19.494836] pps pps2: new PPS source ptp4 [ 23.463416] IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready [ 23.463880] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off cat t ru am65xx-evm login: root [ 39.393496] audit: type=1006 audit(1651167781.454:10): pid=798 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 39.393530] audit: type=1300 audit(1651167781.454:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd20c5c78 a2=1 a3=ffff824d6020 items=0 ppid=1 pid=798 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 39.393548] audit: type=1327 audit(1651167781.454:10): proctitle="(systemd)" [ 39.426327] audit: type=1334 audit(1651167781.487:11): prog-id=11 op=LOAD [ 39.426359] audit: type=1300 audit(1651167781.487:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff3880050 a2=78 a3=0 items=0 ppid=1 pid=798 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 39.426381] audit: type=1327 audit(1651167781.487:11): proctitle="(systemd)" [ 39.426402] audit: type=1334 audit(1651167781.487:12): prog-id=11 op=UNLOAD [ 39.426671] audit: type=1334 audit(1651167781.487:13): prog-id=12 op=LOAD [ 39.426712] audit: type=1300 audit(1651167781.487:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=fffff38800f0 a2=78 a3=0 items=0 ppid=1 pid=798 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null) [ 39.426734] audit: type=1327 audit(1651167781.487:13): proctitle="(systemd)" root@am65xx-evm:~# cat run.sh #!/bin/sh IF=$1 ROLE=$2 gcc sendRec.c -o sendRec systemctl stop systemd-networkd.socket systemctl stop systemd-networkd.service ip a flush $IF ip -6 a flush $IF ./sendRec $IF $ROLE root@am65xx-evm:~# ./run.sh eth3 -r [ 51.254734] device eth3 entered promiscuous mode [ 51.254870] kauditd_printk_skb: 1 callbacks suppressed [ 51.254890] audit: type=1700 audit(1651167793.316:15): dev=eth3 prom=256 old_prom=0 auid=4294967295 uid=0 gid=0 ses=4294967295 [ 51.255322] audit: type=1300 audit(1651167793.316:15): arch=c00000b7 syscall=208 success=yes exit=0 a0=3 a1=107 a2=1 a3=ffffdc10c068 items=0 ppid=819 pid=831 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS2 ses=4294967295 comm="sendRec" exe="/home/root/sendRec" key=(null) [ 51.255351] audit: type=1327 audit(1651167793.316:15): proctitle=2E2F73656E645265630065746833002D72 [ 54.183124] icssg-prueth icssg0-eth eth3: Link is Down [ 58.279608] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off [ 60.327144] icssg-prueth icssg0-eth eth3: Link is Down [ 64.423630] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off [ 67.495122] icssg-prueth icssg0-eth eth3: Link is Down [ 71.591666] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off [ 73.639136] icssg-prueth icssg0-eth eth3: Link is Down [ 77.735608] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off [ 80.807137] icssg-prueth icssg0-eth eth3: Link is Down [ 85.927814] icssg-prueth icssg0-eth eth3: Link is Up - 1Gbps/Full - flow control off Received frame len 60 with ID 9 HW 1651167827.991204160 ^C[ 89.292843] device eth3 left promiscuous mode [ 89.292957] audit: type=1700 audit(1651167831.354:16): dev=eth3 prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295 root@am65xx-evm:~#
HW setup
IDK - PRU ICSSG <---> PC - I217-LM
SW setup - default system images
- PROCESSOR-SDK-LINUX-RT-AM65X - Version: 09.01.00.01
- PROCESSOR-SDK-LINUX-RT-AM65X - Version: 08.02.00.01
- attached sources 6433.source.zip
Test description
Sender role
1. Sender is listening netlink messages for link state changes.
2. Immediately after LinkUp sends 10 frames with period 10ms with frame ID 0-9.
3. For each sent frame is reported HW Tx Timestamp.
4. Whole sequence is repeated with link state change.
Receiver role
1. Receiver is polling on socket FD and reports all received frames with their ID.
Reproduction steps
1. Prepare SD card - default image with attached script and application
2. Switch on IDK
3. Start receiver on IDK e.g.
$ ./run.sh eth1 -r
4. Start sender on PC - use the same script and application e.g.
$ ./run.sh enp0s25 -s
5. Unplug ang plug back the ethernet cable
6. Wait for successful send after link up and check received frames
7. Repeat 5 and 6 to get more data
My questions
Why is there different behavior, what was change in firmware?
And why the sent frames are not received?
Thank you for support.
Best regards
Lukas Libal
