TDA4VH-Q1: Adding IPC to DSP FW
Expert 4676 points
Part Number: TDA4VH-Q1
Hi Champs,
I have received some questions from customer. Would like to seek your help to address them.
I am currently building C66X DSP firmware using the yocto build system.
I have successfully built the DSP firmware without IPC. Now, I need your help to include IPC in our DSP firmware .
I am trying to build ‘ti-ipc-rtos_git.bb’ ( in meta-ti/meta-ti-extras/recipes-ti/ipc), but it uses source files “git://git.ti.com/git/ipc/ipc-examples.git” and ipc metadata form “git://git.ti.com/git/ipc-metadata.git” which does not support the ‘j721e-evm’ target.
Could you please assist me in obtaining the correct IPC example source files for remote cores and guide me through the build procedure?
Similarly, when I tried to build IPC for ARM A72 (which runs Linux) ,
meta-ti/meta-ti-bsp/recipes-ti/ipc/ti-ipc_git.bb
If I set PLATFORM:j721e = “j721e”  , I encountered an error : “configuration: error: PLATFORM is set to ‘j721e’
However, the build completes successfully when set PLATFORM:dra8xx = ‘dra8xx’.   Is this acceptable?
Kien Nguyen
