hello,
now , I use the iar and jlink to develop my project, but i only debug program with iram debug option, I can't use the ddr debug option. in ccs, we can use the gel file to init ddr,nor,nand. but how to do it in IAR IDE system?
Thanks.
Token
hello,
Thanks.
Token
You could load a small program into IRAM that does the DDR initialization (just copy the code from the GEL) and then start debugging yoru actual application. However every time you reset the device you will need to rerun that initialization program. That is essentially what a GEL file does anyway.
Jeff
