Part Number: TDA4VM
Hi TI,
We need to enable lockstep mode for SBL booting. Is it possible to boot the SBL in lockstep mode.
Is there any procedure for this?
Part Number: TDA4VM
Hi TI,
Please refer to below faq.
Brijesh
We have checked the above link, and it mentions enabling Lockstep after the SBL boot. However, we need to boot the SBL in Lockstep mode.
Is it possible to boot the SBL in Lockstep mode?
Are you using HS device? Then you could probably change it while signing SBL with x509Certificate.
Brijesh
Hi kanna,
Does you device support lockstep mode? After booting the SBL, can you please try reading control module register at the offset (0x45A5 0040)? Bit3 in this register tells lockstep capability of the device.
Brijesh
We don't have a debugger to read that register. Is there any other way to read the register?
Most likely, no, but can you try reading from Linux prompt?
Brijesh
