Hello experts,
Please guide me, how can i boot from eMMC in TI AM625 at linux.
Please refer these logs.
U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:52:36 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') SPL initial stack usage: 13424 bytes Trying to boot from MMC1 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Loading Environment from MMC... OK init_env from device 9 not supported! Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 05:06:58, Feb 24 2023 U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') Trying to boot from MMC1 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -1 DRAM: 2 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -1 Net: Could not get PHY for ethernet@8000000port@1: addr 0 am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device SD/MMC found on device 0 Failed to load 'boot.scr' ** Unrecognized filesystem type ** 39154176 bytes read in 225 ms (166 MiB/s) 60014 bytes read in 5 ms (11.4 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.80-dirty (repl@repl-HP-EliteBook-840-G4) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Fri Aug 23 10:49:47 IST 2024 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xf7bd6a00-0xf7bd8fff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 21 pages/cpu s48040 r8192 d29784 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=00000000-01 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1828820K/2097152K available (17024K kernel code, 3804K rwdata, 9588K rodata, 7680K init, 625K bss, 137260K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.009682] Console: colour dummy device 80x25 [ 0.014325] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.025010] pid_max: default: 32768 minimum: 301 [ 0.029788] LSM: Security Framework initializing [ 0.034633] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.042217] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.052085] cblist_init_generic: Setting adjustable number of callback queues. [ 0.059532] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.065831] cblist_init_generic: Setting adjustable number of callback queues. [ 0.073229] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.079647] rcu: Hierarchical SRCU implementation. [ 0.084558] rcu: Max phase no-delay instances is 1000. [ 0.090153] Platform MSI: msi-controller@1820000 domain created [ 0.096454] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.105724] fsl-mc MSI: msi-controller@1820000 domain created [ 0.113675] EFI services will not be available. [ 0.118635] smp: Bringing up secondary CPUs ... [ 0.123955] Detected VIPT I-cache on CPU1 [ 0.124067] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.124085] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.124143] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.124887] Detected VIPT I-cache on CPU2 [ 0.124975] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.124990] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000 [ 0.125025] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.125659] Detected VIPT I-cache on CPU3 [ 0.125744] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.125757] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000 [ 0.125786] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.125859] smp: Brought up 1 node, 4 CPUs [ 0.205612] SMP: Total of 4 processors activated. [ 0.210425] CPU features: detected: 32-bit EL0 Support [ 0.215698] CPU features: detected: 32-bit EL1 Support [ 0.220959] CPU features: detected: CRC32 instructions [ 0.226292] CPU: All CPU(s) started at EL2 [ 0.230503] alternatives: applying system-wide alternatives [ 0.238599] devtmpfs: initialized [ 0.250845] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.260859] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.272925] pinctrl core: initialized pinctrl subsystem [ 0.280625] DMI not present or invalid. [ 0.285318] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.292580] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.300085] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.308146] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.316337] audit: initializing netlink subsys (disabled) [ 0.322043] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1 [ 0.323467] thermal_sys: Registered thermal governor 'step_wise' [ 0.329989] thermal_sys: Registered thermal governor 'power_allocator' [ 0.336214] cpuidle: using governor menu [ 0.347146] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.354192] ASID allocator initialised with 65536 entries [ 0.361578] Serial: AMBA PL011 UART driver [ 0.382769] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.395013] OF: /backlight: #pwm-cells = 3 found 2 [ 0.403562] KASLR disabled due to lack of seed [ 0.416555] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.423523] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.429976] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.436916] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.443325] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.450264] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.456672] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.463612] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.472007] ACPI: Interpreter disabled. [ 0.477996] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.489161] iommu: Default domain type: Translated [ 0.494188] iommu: DMA domain TLB invalidation policy: strict mode [ 0.500908] SCSI subsystem initialized [ 0.505130] usbcore: registered new interface driver usbfs [ 0.510778] usbcore: registered new interface driver hub [ 0.516232] usbcore: registered new device driver usb [ 0.522696] pps_core: LinuxPPS API ver. 1 registered [ 0.527782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.537133] PTP clock support registered [ 0.541275] EDAC MC: Ver: 3.0.0 [ 0.546757] FPGA manager framework [ 0.550368] Advanced Linux Sound Architecture Driver Initialized. [ 0.557604] vgaarb: loaded [ 0.560854] clocksource: Switched to clocksource arch_sys_counter [ 0.567360] VFS: Disk quotas dquot_6.6.0 [ 0.571419] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.578652] pnp: PnP ACPI: disabled [ 0.588010] NET: Registered PF_INET protocol family [ 0.593318] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.602590] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.611404] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.619343] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.627546] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.635541] TCP: Hash tables configured (established 16384 bind 16384) [ 0.642455] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.649384] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.656921] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.663209] RPC: Registered named UNIX socket transport module. [ 0.669292] RPC: Registered udp transport module. [ 0.674102] RPC: Registered tcp transport module. [ 0.678911] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.685504] NET: Registered PF_XDP protocol family [ 0.690419] PCI: CLS 0 bytes, default 64 [ 0.695317] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.704418] kvm [1]: IPA Size Limit: 40 bits [ 0.710440] kvm [1]: vgic-v2@100010000 [ 0.714293] kvm [1]: GIC system register CPU interface enabled [ 0.720365] kvm [1]: vgic interrupt IRQ9 [ 0.724459] kvm [1]: Hyp mode initialized successfully [ 0.731219] Initialise system trusted keyrings [ 0.736090] workingset: timestamp_bits=42 max_order=19 bucket_order=0 [ 0.748966] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.755594] NFS: Registering the id_resolver key type [ 0.760826] Key type id_resolver registered [ 0.765104] Key type id_legacy registered [ 0.769271] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.776127] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.783897] 9p: Installing v9fs 9p2000 file system support [ 0.824229] Key type asymmetric registered [ 0.828434] Asymmetric key parser 'x509' registered [ 0.833484] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.841225] io scheduler mq-deadline registered [ 0.845866] io scheduler kyber registered [ 0.859412] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.865976] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.873344] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.888122] EINJ: ACPI disabled. [ 0.917207] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.928950] SuperH (H)SCI(F) driver initialized [ 0.934333] msm_serial: driver initialized [ 0.946759] loop: module loaded [ 0.951962] megasas: 07.719.03.00-rc1 [ 0.963922] tun: Universal TUN/TAP device driver, 1.6 [ 0.970463] thunder_xcv, ver 1.0 [ 0.973839] thunder_bgx, ver 1.0 [ 0.977174] nicpf, ver 1.0 [ 0.981617] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.989021] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.994514] hclge is initializing [ 0.997931] e1000: Intel(R) PRO/1000 Network Driver [ 1.002917] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 1.008828] e1000e: Intel(R) PRO/1000 Network Driver [ 1.013909] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 1.020000] igb: Intel(R) Gigabit Ethernet Network Driver [ 1.025520] igb: Copyright (c) 2007-2014 Intel Corporation. [ 1.031319] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 1.037735] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 1.044369] sky2: driver version 1.30 [ 1.049993] VFIO - User Level meta-driver version: 0.3 [ 1.058245] usbcore: registered new interface driver usb-storage [ 1.068078] i2c_dev: i2c /dev entries driver [ 1.083672] sdhci: Secure Digital Host Controller Interface driver [ 1.090066] sdhci: Copyright(c) Pierre Ossman [ 1.095788] Synopsys Designware Multimedia Card Interface Driver [ 1.103281] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.111880] ledtrig-cpu: registered to indicate activity on CPUs [ 1.120294] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.127821] usbcore: registered new interface driver usbhid [ 1.133552] usbhid: USB HID core driver [ 1.143952] optee: probing for conduit method. [ 1.148571] optee: revision 3.20 (8e74d476) [ 1.148963] optee: dynamic shared memory is enabled [ 1.158494] optee: initialized driver [ 1.166676] Initializing XFRM netlink socket [ 1.171133] NET: Registered PF_PACKET protocol family [ 1.176449] 9pnet: Installing 9P2000 support [ 1.180910] Key type dns_resolver registered [ 1.185773] registered taskstats version 1 [ 1.190001] Loading compiled-in X.509 certificates [ 1.231404] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') [ 1.353427] rtc-m41t80 0-0068: HT bit was set! [ 1.358007] rtc-m41t80 0-0068: Power Down at 2024-08-23T07:15:15 [ 1.364999] rtc-m41t80 0-0068: registered as rtc0 [ 1.370264] rtc-m41t80 0-0068: setting system clock to 2024-08-23T07:15:26 UTC (1724397326) [ 1.378886] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.385405] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.395063] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.411167] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.419449] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.431816] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.442009] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.453889] printk: console [ttyS2] disabled [ 1.458353] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 236, base_baud = 3000000) is a 8250 [ 1.467241] printk: console [ttyS2] enabled [ 1.467241] printk: console [ttyS2] enabled [ 1.475698] printk: bootconsole [ns16550a0] disabled [ 1.475698] printk: bootconsole [ns16550a0] disabled [ 1.488613] 2820000.serial: ttyS3 at MMIO 0x2820000 (irq = 238, base_baud = 3000000) is a 8250 [ 1.502330] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.548867] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.559138] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.567249] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver SMSC LAN8710/LAN8720 [ 1.576242] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.589208] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.596338] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.603026] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0 [ 1.613414] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.629945] mmc0: CQHCI version 5.10 [ 1.637402] am65-cpsw-nuss 8000000.ethernet: Failed to create device link (0x180) with 601000.gpio [ 1.656275] mmc1: CQHCI version 5.10 [ 1.661645] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.669524] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.670924] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.696382] ALSA device list: [ 1.699417] No soundcards found. [ 1.757675] mmc0: Command Queue Engine enabled [ 1.762160] mmc0: new HS200 MMC card at address 0001 [ 1.768144] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.774743] mmcblk0: p1 [ 1.778000] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.784167] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.790071] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (511:0) [ 3.177358] sdhci-am654 fa00000.mmc: Power on failed [ 3.213501] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.239815] EXT4-fs (mmcblk0p1): recovery complete [ 3.246241] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none. [ 3.255329] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 3.261843] devtmpfs: mounted [ 3.270518] Freeing unused kernel memory: 7680K [ 3.275246] Run /sbin/init as init process [ 3.435043] NET: Registered PF_INET6 protocol family [ 3.441770] Segment Routing with IPv6 [ 3.445526] In-situ OAM (IOAM) with IPv6 [ 3.486307] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 3.518461] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 3.577684] systemd[1]: Hostname set to <am62xx-evm>. [ 3.678200] systemd-sysv-generator[153]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.966860] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.026728] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.098803] systemd[1]: Queued start job for default target Graphical Interface. [ 4.162332] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 4.188071] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 4.211969] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 4.235547] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.257506] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 4.281423] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 4.305548] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 4.325112] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.345146] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.365156] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.441580] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.465562] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.504115] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.525991] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.551121] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.574519] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.599838] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.625042] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.651985] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.675278] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.699602] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.761582] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.788454] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.841649] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.866319] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.880050] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway. [ 4.897735] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 4.933298] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 4.993973] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 5.028084] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 5.056740] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 5.077583] fuse: init (API version 7.37) [ 5.090161] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 5.158105] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 5.177467] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 5.204351] systemd[1]: Starting Journal Service... Starting Journal Service... [ 5.234093] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.255957] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network …ts from Kernel command line... [ 5.291188] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 5.320659] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 5.343950] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 5.357805] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [FAILED] Failed to mount Huge Pages File System. See 'systemctl status dev-hugepages.mount' for details. [FAILED] Failed to mount POSIX Message Queue File System. See 'systemctl status dev-mqueue.mount' for details. [FAILED] Failed to mount Kernel Debug File System. See 'systemctl status sys-kernel-debug.mount' for details. [FAILED] Failed to mount Temporary Directory /tmp. See 'systemctl status tmp.mount' for details. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [FAILED] Failed to start Remount Root and Kernel File Systems. See 'systemctl status systemd-remount-fs.service' for details. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 5.813519] systemd-journald[168]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [FAILED] Failed to mount FUSE Control File System. See 'systemctl status sys-fs-fuse-connections.mount' for details. [FAILED] Failed to mount Kernel Configuration File System. See 'systemctl status sys-kernel-config.mount' for details. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 6.087435] audit: type=1334 audit(1724397331.212:2): prog-id=5 op=LOAD [ 6.094148] audit: type=1334 audit(1724397331.220:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Finished Coldplug All udev Devices. [FAILED] Failed to mount /media/ram. See 'systemctl status media-ram.mount' for details. [DEPEND] Dependency failed for Local File Systems. [FAILED] Failed to mount /var/volatile. See 'systemctl status var-volatile.mount' for details. [DEPEND] Dependency failed for Bind mount volatile /srv. [DEPEND] Dependency failed for Bind mount volatile /var/lib. [DEPEND] Dependency failed for Bind mount volatile /var/spool. [DEPEND] Dependency failed for Bind mount volatile /var/cache. [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Stopped Dispatch Password …ts to Console Directory Watch. [ OK ] Stopped Forward Password R…uests to Wall Directory Watch. [ OK ] Reached target Timer Units. [ OK ] Reached target Preparation for Network. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Network Configuration... Starting Load/Save Random Seed... [ OK ] Reached target Socket Units. [ OK ] Started Emergency Shell. [ OK ] Reached target Emergency Mode. Starting Load Kernel Module fuse... Starting Create Volatile Files and Directories... [ OK ] Finished Load Kernel Module fuse. Mounting FUSE Control File System... [FAILED] Failed to mount FUSE Control File System. See 'systemctl status sys-fs-fuse-connections.mount' for details. [ OK ] Finished Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ 6.828269] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ OK ] Finished Record System Boot/Shutdown in UTMP. [ 6.863760] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.871196] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' Starting Record Runlevel Change in UTMP... [ OK ] Finished Synchronize System and HW clocks. [ OK ] Started Network Configuration. Starting Network Name Resolution... [ OK ] Finished Record Runlevel Change in UTMP. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. Starting Load Kernel Module configfs... [ OK ] Started Network Name Resolution. [ OK ] Finished Load Kernel Module configfs. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Nam[ 7.458315] pwm-backlight backlight: supply power not found, using dummy regulator e Lookups. [ 7.489883] panel-simple panel: supply power not found, using dummy regulator [ 7.499040] OF: /backlight: #pwm-cells = 3 found 2 [ 7.503933] of_pwm_get(): can't parse "pwms" property [ 7.509513] pwm-backlight backlight: unable to request PWM [ 7.516481] pwm-backlight: probe of backlight failed with error -22 Mounting Kernel Configuration File System... [ 7.568922] random: crng init done [ OK ] Started NFS status monitor for NFSv2/3 locking.. [ OK ] Finished Load/Save Random Seed. [FAILED] Failed to mount Kernel Configuration File System. See 'systemctl status sys-kernel-config.mount' for details. You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" oPress Enter for maintenance (or press Control-D to continue): [ 7.786006] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 7.796382] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 7.805210] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ 7.809757] rtc-ti-k3 2b1f0000.rtc: registered as rtc1 [ 7.814404] remoteproc remoteproc0: 5000000.m4fss is available [ 7.820074] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 7.848425] remoteproc remoteproc0: powering up 5000000.m4fss [ 7.848456] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016 [ 7.850574] k3-m4-rproc 5000000.m4fss: mbox_request_channel failed: -517 [ 7.850597] remoteproc remoteproc0: can't start rproc 5000000.m4fss: -16 [ 7.851220] Console: switching to colour frame buffer device 160x50 [ 7.858771] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: SoC supports only single core R5 but num_cores is set to 0 [ 7.976277] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device [ 8.045533] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [SMSC LAN8710/LAN8720] (irq=POLL) [ 8.056245] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rmii link mode [ 8.091792] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.101455] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 8.136570] pvrsrvkm: loading out-of-tree module taints kernel. [ 8.191704] PVR_K: 201: Device: fd00000.gpu [ 8.221566] PVR_K: 201: Read BVNC 33.15.11.3 from HW device registers [ 8.233165] PVR_K: 201: RGX Device registered with BVNC 33.15.11.3 [ 8.250629] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1 [ 8.672765] remoteproc remoteproc1: 30074000.pru is available [ 8.687244] remoteproc remoteproc2: 30078000.pru is available [ 8.728469] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 8.734351] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 8.742359] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports [ 8.748501] xhci-hcd xhci-hcd.1.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010 [ 8.758031] xhci-hcd xhci-hcd.1.auto: irq 420, io mem 0x31100000 [ 8.765247] hub 1-0:1.0: USB hub found [ 8.769191] hub 1-0:1.0: 1 port detected [ 9.028987] usb 1-1: new low-speed USB device number 2 using xhci-hcd [ 9.221983] input: Usb KeyBoard Usb KeyBoard as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:C0F4:04F5.0001/input/input0 [ 9.299034] hid-generic 0003:C0F4:04F5.0001: input: USB HID v1.10 Keyboard [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.1.auto-1/input0 [ 9.322134] input: Usb KeyBoard Usb KeyBoard Consumer Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:C0F4:04F5.0002/input/input1 [ 9.398036] input: Usb KeyBoard Usb KeyBoard System Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:C0F4:04F5.0002/input/input2 [ 9.415134] hid-generic 0003:C0F4:04F5.0002: input: USB HID v1.10 Device [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.1.auto-1/input1 sh-5.1# [ 18.862959] platform sound: deferred probe pending sh-5.1# journalctl -xb > a.txt sh-5.1# [ 50.533862] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 50.540364] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx sh-5.1# ifconfig eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 1c:63:49:1c:04:8c txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.60 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::1e63:49ff:fe1c:48c prefixlen 64 scopeid 0x20<link> ether 1c:63:49:1c:04:8c txqueuelen 1000 (Ethernet) RX packets 53 bytes 4296 (4.1 KiB) RX errors 0 dropped 15 overruns 0 frame 0 TX packets 20 bytes 2088 (2.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 2 bytes 140 (140.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 2 bytes 140 (140.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 sh-5.1# scp a.txt repl@192.168.1.164:/home/repl Host '192.168.1.164' is not in the trusted hosts file. (ssh-ed25519 fingerprint sha1!! 6b:57:4b:b4:77:d5:57:ee:6c:21:a7:a3:e5:ff:00:d3:c3:3b:51:b8) Do you want to continue connecting? (y/n) /usr/bin/dbclient: Connection to repl@192.168.1.164:22 exited: Didn't validate host key lost connection sh-5.1# scp a.txt repl@192.168.1.164:/home/repl Host '192.168.1.164' is not in the trusted hosts file. (ssh-ed25519 fingerprint sha1!! 6b:57:4b:b4:77:d5:57:ee:6c:21:a7:a3:e5:ff:00:d3:c3:3b:51:b8) Do you want to continue connecting? (y/n) y repl@192.168.1.164's password: a.txt 100% 95KB 95.3KB/s 00:00 sh-5.1# ls -l / total 72 drwxr-xr-x 2 weston weston 4096 Mar 9 2018 bin drwxr-xr-x 3 weston weston 4096 Aug 23 06:25 boot drwxr-xr-x 17 root root 3760 Aug 23 07:15 dev drwxr-xr-x 55 weston weston 4096 Aug 23 07:10 etc drwxr-xr-x 4 weston weston 4096 Mar 9 2018 home drwxr-xr-x 10 weston weston 4096 Mar 9 2018 lib lrwxrwxrwx 1 weston weston 19 Mar 9 2018 linuxrc -> /bin/busybox.nosuid drwx------ 2 root root 16384 Aug 23 04:52 lost+found drwxr-xr-x 3 weston weston 4096 Aug 23 07:10 media drwxr-xr-x 2 weston weston 4096 Mar 9 2018 mnt drwxr-xr-x 3 weston weston 4096 Mar 9 2018 opt dr-xr-xr-x 154 root root 0 Aug 23 07:15 proc drwxr-xr-x 11 root root 320 Aug 23 07:15 run drwxr-xr-x 2 weston weston 4096 Mar 9 2018 sbin drwxr-xr-x 2 weston weston 4096 Mar 9 2018 srv dr-xr-xr-x 13 root root 0 Aug 23 07:15 sys drwxrwxrwt 4 root root 4096 Aug 23 07:15 tmp drwxr-xr-x 12 weston weston 4096 Mar 9 2018 usr drwxr-xr-x 9 weston weston 4096 Aug 23 07:10 var drwxr-xr-x 3 weston weston 4096 Mar 9 2018 www sh-5.1#
Kind Regards,
Seema B
