Hi expert
I'm getting the following error:
undefined first referenced
symbol in file
gBoardSerdesInfo /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
gCaptPinCfg /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
read16BitReg /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
read8BitReg /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
ti_des960_get_linklock /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
write16BitReg /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
write8BitReg /home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/app_utils/lib/J784S4/C7120/FREERTOS/release/app_utils_ipc.lib<app_ipc_rtos_echo_test.obj>
error: unresolved symbols remain
error: errors encountered during linking;
"/home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/vision_apps/ou
t/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_4.out" not built
symbol in file
make[2]: [/home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/vision_apps/out/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_4.out] Error 1 (ignored)
symbol in file
t/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_3.out" not built
make[2]: [/home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/vision_apps/out/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_3.out] Error 1 (ignored)
t/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_1.out" not built
make[2]: [/home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/vision_apps/out/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_1.out] Error 1 (ignored)
symbol in file
t/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_2.out" not built
make[2]: [/home/data/xuefei.yuan/shockwave_a_0902/rtos-sdk-0902-j784s4/vision_apps/out/J784S4/C7120/FREERTOS/release/vx_app_rtos_linux_c7x_2.out] Error 1 (ignored)
Currently I have canceled the compilation of c7x_1~4, which can be compiled.
I'd like to ask how to compile the app_ipc_rtos_echo_test.c driver only in the mcu2_0
Thank you.
