J721S2XSOMXEVM: Facing issue in launching debug session using Blackhawk XDS560v2-USB System Trace Emulator
Part Number: J721S2XSOMXEVM
Other Parts Discussed in Thread: TDA4VL
Hello, In J721S2-EVM I'm facing this error in opening a debug session using Blackhawk XDS560v2-USB System Trace Emulator in code composer studio. Do I need to change anything in launch.js file
    Could you please tell me if you are using TI DDR or custom DDR?
    Karthik
  • Hi, I'm using TI DDR
    It's seems like DDR issue ,Could you please validate any driver example using SD or eMMC Boot mode. and can you please share your launch.js file.
    Karthik
  • This the launch.js file I'm using
     * Copyright (c) 2018-2022, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    //File Name: launch_j721s2.js
    //Description:
    //   Launch the TIFS firmware and board configuration from R5F.
    //Usage:
    //From CCS Scripting console
    //  1. loadJSFile "C:\\ti\\launch_j721s2.js"
    //Note:
    //  1. Search for "edit this" to look at changes that need to be edited
    //     for your usage.
    //<!!!!!! EDIT THIS !!!!!>
    // Set this to 1, if using 'freertos'
    isFreertos = 1;
    // Set this to 1, if using 'SafeRTOS'
    isSafertos = 0;
    //PDK path. Edit this
    pdkPath = "/home/user/Documents/IFV721/rtos_sdk/ti-processor-sdk-rtos-j721s2-evm-09_00_00_02/pdk_j721s2_09_00_00_45";
    //path to board config elf
    pathSciclient = pdkPath+"/packages/ti/drv/sciclient/tools/ccsLoadDmsc/j721s2/"
    ccs_init_elf_file = pathSciclient+"sciclient_ccs_init_mcu1_0_release.xer5f";
    // Set this to 1, to clear 'Secure Claim' Bit in CLEC register
    clearCLECSecureClaimFlag = 1;
    loadSciserverFlag = 1;
    if(isFreertos == 1)
        //Path to FreeRTOS sciserver
        sciserver_elf_file = pathSciclient+"sciserver_testapp_freertos_mcu1_0_release.xer5f";
    else if(isSafertos == 1)
        //Path to SafeRTOS sciserver
        sciserver_elf_file = pathSciclient+"sciserver_testapp_safertos_mcu1_0_release.xer5f";
    //path to tifs bin
    tifs_bin = pdkPath+"/packages/ti/drv/sciclient/soc/sysfw/binaries/ti-fs-firmware-j721s2-gp.bin"
    // Import the DSS packages into our namespace to save on typing
    importPackage(Packages.com.ti.debug.engine.scripting)
    importPackage(Packages.com.ti.ccstudio.scripting.environment)
    importPackage(Packages.java.lang);
    importPackage(Packages.java.io);
    function updateScriptVars()
        //Open a debug session
        dsMCU1_0 = debugServer.openSession( ".*MCU_Cortex_R5_0" );
        dsMCU1_1 = debugServer.openSession( ".*MCU_Cortex_R5_1" );
        dsDMSC_0 = debugServer.openSession( ".*CORTEX_M4F_0" );
    function printVars()
        updateScriptVars();
    function connectTargets()
        /* Set timeout of 200 seconds */
        script.setScriptTimeout(2000000);
        updateScriptVars();
        sysResetVar=dsDMSC_0.target.getResetType(1);
        sysResetVar.issueReset();
        print("Connecting to Cortex_M4F_0!");
        // Connect targets
        dsDMSC_0.target.connect();
        print("Fill R5F ATCM memory...");
        dsDMSC_0.memory.fill(0x61000000, 0, 0x8000, 0);
        print("Writing While(1) for R5F")
        dsDMSC_0.memory.writeWord(0, 0x61000000, 0xE59FF004); /* ldr        pc, [pc, #4] */
        dsDMSC_0.memory.writeWord(0, 0x61000004, 0x38);       /* Address 0x38 */
        dsDMSC_0.memory.writeWord(0, 0x61000038, 0xEAFFFFFE) /* b          #0x38 */
        print("Loading TIFS Firmware ... " + tifs_bin);
        // Load the TIFS firmware
        dsDMSC_0.memory.loadRaw(0, 0x40000, tifs_bin, 32, false);
        print("TIFS Firmware Load Done...");
        // Set Stack pointer and Program Counter
        stackPointer = dsDMSC_0.memory.readWord(0, 0x40000);
        progCounter = dsDMSC_0.memory.readWord(0, 0x40004);
        dsDMSC_0.memory.writeRegister("SP", stackPointer);
        dsDMSC_0.memory.writeRegister("PC", progCounter);
        print( "TIFS Firmware run starting now...");
        // Run the TIFS firmware
        dsDMSC_0.target.runAsynch();
        /* Run the DDR Configuration */
        print("J721S2 Running the DDR configuration... Wait till it completes!");
        dsDMSC_0.target.halt();
    //    dsDMSC_0.expression.evaluate("J7_LPDDR4_Config_Late()");
        print("Connecting to MCU Cortex_R5_0!");
        // Connect the MCU R5F
        dsMCU1_0.target.connect();
        // This is done to support other boot modes. OSPI is the most stable.
        // MMC is not always stable.
        bootMode = dsMCU1_0.memory.readWord(0, 0x43000030) & 0xF8;
        print (" WKUP Boot Mode is " + bootMode);
        mainBootMode = dsMCU1_0.memory.readWord(0, 0x100030) & 0xFF;
        print (" Main Boot Mode is " + mainBootMode);
        if ((bootMode != 0x38) || (mainBootMode != 0x11))
            print("Disable MCU Timer for ROM clean up");
            dsMCU1_0.memory.writeWord(0, 0x40400010, 0x1); /* Write reset to MCU Timer 0. Left running by ROM */
            dsMCU1_0.memory.writeWord(0, 0x40F80430, 0xFFFFFFFF); /* Clear Pending Interrupts */
            dsMCU1_0.memory.writeWord(0, 0x40F80018, 0x0); /* Clear Pending Interrupts */
            // Reset the R5F to be in clean state.
            dsMCU1_0.target.reset();
            // Load the board configuration init file.
            dsMCU1_0.expression.evaluate('GEL_Load("'+ ccs_init_elf_file +'")');
            // Run Asynchronously
            dsMCU1_0.target.runAsynch();
            print ("Running Async");
            // Halt the R5F and re-run.
            dsMCU1_0.target.halt();
        // Reset the MCU R5F Core 1, to ensure the ATCM/BTCM config takes effect
        print("Connecting to MCU R5 1 0");
        dsMCU1_1.target.connect();
        print("Reset MCU R5 10, to ensure TCMs configurations take effect");
        dsMCU1_1.target.reset();
        print("Running the board configuration initialization from R5!");
        dsMCU1_0.memory.loadProgram(ccs_init_elf_file);
        // Run Synchronously for the executable to finish
        dsMCU1_0.target.run();
        dsMCU1_0.target.restart();
    function disconnectTargets()
        updateScriptVars();
        dsMCU1_1.target.disconnect();
        // Disconnect targets
        dsDMSC_0.target.disconnect();
    function sampleDDRCheck ()
        print("Running DDR Memory Checks....");
        dsMCU1_0.memory.fill (0x80000000, 0, 1024, 0xA5A5A5A5);
        ar = dsMCU1_0.memory.readWord(0, 0x80000000, 1024);
        fail = 0
        for (i = 0; i < ar.length; i++) {
                x = ar[i];
                if (x != 0xA5A5A5A5)
                    fail = 1;
        if (fail == 1)
            print ("0x80000000: DDR memory sample check failed !!");
        dsMCU1_0.memory.fill (0x81000000, 0, 1024, 0x5A5A5A5A);
        ar = dsMCU1_0.memory.readWord(0, 0x81000000, 1024);
        fail = 0
                x = ar[i];
                if (x != 0x5a5a5a5a)
                    fail = 1;
        if (fail == 1)
            print ("0x81000000: DDR memory sample check failed !!");
    function loadSciserver()
        updateScriptVars();
        print("######################################################################################");
        print("Loading Sciserver Application on MCU1_0. This will service RM/PM messages");
        print("If you do not want this to be loaded update the launch script to make loadSciserverFlag = 0");
        print("If you want to load and run other cores, please run the MCU1_0 core after Sciserver is loaded. ");
        dsMCU1_0.expression.evaluate('GEL_Load("'+ sciserver_elf_file +'")');
    function clearCLECSecureClaim()
        dsC7X1_0 = debugServer.openSession( ".*C71X_0" );
        dsC7X1_0.target.connect();
        c7x_binary = pdkPath+"/packages/ti/drv/sciclient/tools/clearClecSecureClaim/sciclient_clear_clec_secure_claim_c7x_1_release.xe71";
        dsC7X1_0.memory.loadProgram(c7x_binary);
        dsC7X1_0.target.runAsynch();
        // Halt and re-run since the startup code image doesn't have a main function.
        dsC7X1_0.target.halt();
        dsC7X1_0.target.disconnect();
    function doEverything()
        printVars();
        connectTargets();
        disconnectTargets();
        sampleDDRCheck ();
        if (clearCLECSecureClaimFlag == 1)
            print("Clearing CLEC Secure Claim...");
            clearCLECSecureClaim();
        if (loadSciserverFlag == 1)
            loadSciserver();
        print("Happy Debugging!!");
    var ds;
    var debugServer;
    var script;
    // Check to see if running from within CCSv4 Scripting Console
    var withinCCS = (ds !== undefined);
    // Create scripting environment and get debug server if running standalone
    if (!withinCCS)
        importPackage(Packages.com.ti.debug.engine.scripting);
        importPackage(Packages.com.ti.ccstudio.scripting.environment);
        // Create our scripting environment object - which is the main entry point into any script and
        // the factory for creating other Scriptable ervers and Sessions
        script = ScriptingEnvironment.instance();
        // Get the Debug Server and start a Debug Session
        debugServer = script.getServer("DebugServer.1");
    else // otherwise leverage existing scripting environment and debug server
        debugServer = ds;
        script = env;
    doEverything();
    please help me!
    it's seems like you are commanded below the line your launch.js file , is there any specific reason  for commanding that line. if no could you please try it once with uncommanding that line
    Karthik
  • dsDMSC_0.expression.evaluate("J7_LPDDR4_Config_Late()");
    If I uncomment this line it is throwing this error.
    If I comment this I'm facing this error
    I'm trying to open debug session on custom board of j721S2. I'm using J721S2_TDA4VL/J7AEP_SI.gel file for debugging. I have provided the launch file I'm using above
  • Hi, I'm facing issue in opening a debug session in J721S2 customized board(IFV720 A0 sample) in code composer studio using blackhawk xds560v2 USB system Trace Emulator. I have changed the pdkPath path according to my sdk installation path .I'm using IFV700_J721S2_TDA4VL/J7AEP_SI.gel file. The code composer studio version is 12.4.0. Then I'm facing this issue
    So as I'm using J7AEP_SI.gel file I commented the line dsDMSC_0.expression.evaluate("J7_LPDDR4_Config_Late()") ; (Line no. 130). I'm not sure whether it should be commented or not. After commenting the line dsDMSC_0.expression.evaluate("J7_LPDDR4_Config_Late()"); (line no.130). I' m facing this error
    Can you suggest how to proceed further and establish the debug session. This is the launch.js file I'm using
     * are met:
    //Description:
    //Usage:
    //Note:
    //     for your usage.
    isFreertos = 1;
    isSafertos = 0;
    if(isFreertos == 1)
    //path to tifs bin
        updateScriptVars();
        updateScriptVars();
        // Connect targets
        updateScriptVars();
        fail = 0
                x = ar[i];
                    fail = 1;
        if (fail == 1)
        fail = 0
                x = ar[i];
                    fail = 1;
        if (fail == 1)
        updateScriptVars();
        printVars();
        connectTargets();
        sampleDDRCheck ();
            loadSciserver();
    var ds;
    var debugServer;
    var script;
    if (!withinCCS)
        debugServer = ds;
        script = env;
    doEverything();
    Do we need to change anything in target configuration file  or gel file or launch.js  file to make it work?
    It's seems like DDR issue ,Could you please try this ? if you can able to run driver example in SD or eMMC boot mode then we come to know DDR is fine or not.
    Karthik
