Part Number: AM625
Does the nTRST pin have to be explicitly pulled low, or will a pull up resistor be okay?
Thank you!
Part Number: AM625
Thank you!
Hello Owen Mears,
Thank you for the query.
Refer to the pin attributes table. A weak pull is internally enabled. Adding an external pullup will drive the IO to mid-supply.
Refer Pin connectivity requirements
Refer below E2E queries that could help
e2e.ti.com/.../am6442-for-jtag-connector-trst-and-tck-should-pull-up-or-pull-down
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1310299/am625-jtag-trst-signal-pull-down
Based on your query i created an FAQ that could be used by board designers
Please let me know if this helps.
Sreenivasa
