Part Number: TDA4VEN-Q1
Hi :
We found that the GPU occasionally fails to initialize. The following is the log. Please help support us.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.162-g20d7f609c5b4 (root@f38b70c5b20e) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Tue Aug 27 14:23:05 CST 2024 [ 0.000000] Machine model: Texas Instruments J721S2 EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b0100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b6100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000f8000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@f8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 704 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x00000008ac000000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@8ac000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000f7ffffff] [ 0.000000] node 0: [mem 0x00000000f8000000-0x00000000fbffffff] [ 0.000000] node 0: [mem 0x00000000fc000000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008abffffff] [ 0.000000] node 0: [mem 0x00000008ac000000-0x00000008ffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffefff] [ 0.000000] On node 0 totalpages: 1048574 [ 0.000000] DMA zone: 8192 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 524287 pages, LIFO batch:63 [ 0.000000] Normal zone: 8192 pages used for memmap [ 0.000000] Normal zone: 524287 pages, LIFO batch:63 [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112 [ 0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032190 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),6m(ospi.tispl_a),6m(ospi.tispl_b),4m(ospi.u-boot_a),4m(ospi.u-boot_b),256k(ospi.update),256k(ospi.update_bkp),256k(ospi.carInfo),256k(ospi.profile),256k(ospi.sys),1M(ospi.tispl_bkp),2M(ospi.u-boot_bkp),256k(ospi.dtb_bkp),10M(ospi.kernel_bkp),28416k(ospi.rootfs_bkp),256k(ospi.phypattern);47034000.hyperbus:512k(ospi.tiboot3),6m(ospi.tispl_a),6m(ospi.tispl_b),4m(ospi.u-boot_a),4m(ospi.u-boot_b),256k(ospi.update),256k(ospi.update_bkp),256k(ospi.carInfo),256k(ospi.profile),256k(ospi.sys),1M(ospi.tispl_bkp),2M(ospi.u-boot_bkp),256k(ospi.dtb_bkp),10M(ospi.kernel_bkp),28416k(ospi.rootfs_bkp),256k(ospi.phypattern) root=PARTUUID=7458faf8-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB) [ 0.000000] Memory: 859776K/4194296K available (11456K kernel code, 1312K rwdata, 4616K rodata, 2176K init, 434K bss, 2417016K reserved, 917504K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8e4800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008e4030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008e4040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000216] Console: colour dummy device 80x25 [ 0.000254] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000262] pid_max: default: 32768 minimum: 301 [ 0.000318] LSM: Security Framework initializing [ 0.000369] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.000395] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001400] rcu: Hierarchical SRCU implementation. [ 0.001804] Platform MSI: msi-controller@1820000 domain created [ 0.001963] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.002014] EFI services will not be available. [ 0.002177] smp: Bringing up secondary CPUs ... [ 0.010697] Detected PIPT I-cache on CPU1 [ 0.010726] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.010739] GICv3: CPU1: using allocated LPI pending table @0x00000008e4050000 [ 0.010785] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.010869] smp: Brought up 1 node, 2 CPUs [ 0.010874] SMP: Total of 2 processors activated. [ 0.010878] CPU features: detected: 32-bit EL0 Support [ 0.010881] CPU features: detected: CRC32 instructions [ 0.020779] CPU: All CPU(s) started at EL2 [ 0.020802] alternatives: patching kernel code [ 0.021484] devtmpfs: initialized [ 0.026003] KASLR disabled due to lack of seed [ 0.026128] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.026138] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.038546] pinctrl core: initialized pinctrl subsystem [ 0.038911] DMI not present or invalid. [ 0.039297] NET: Registered protocol family 16 [ 0.040254] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.040317] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.040368] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.040643] thermal_sys: Registered thermal governor 'step_wise' [ 0.040646] thermal_sys: Registered thermal governor 'power_allocator' [ 0.041169] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.041228] ASID allocator initialised with 65536 entries [ 0.055793] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.055800] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.055803] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.055807] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.056581] cryptd: max_cpu_qlen set to 1000 [ 0.058424] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.058900] vsys_3v3: supplied by evm_12v0 [ 0.059115] vsys_5v0: supplied by evm_12v0 [ 0.059315] vdd_mmc1: supplied by vsys_3v3 [ 0.059847] iommu: Default domain type: Translated [ 0.060020] SCSI subsystem initialized [ 0.060327] mc: Linux media interface: v0.10 [ 0.060346] videodev: Linux video capture interface: v2.00 [ 0.060382] pps_core: LinuxPPS API ver. 1 registered [ 0.060385] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.060391] PTP clock support registered [ 0.060413] EDAC MC: Ver: 3.0.0 [ 0.061077] FPGA manager framework [ 0.061117] Advanced Linux Sound Architecture Driver Initialized. [ 0.061591] clocksource: Switched to clocksource arch_sys_counter [ 0.061712] VFS: Disk quotas dquot_6.6.0 [ 0.061744] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.064593] Carveout Heap: Exported 1024 MiB at 0x00000000b8000000 [ 0.064666] NET: Registered protocol family 2 [ 0.064964] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.066323] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.066357] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.066466] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.066719] TCP: Hash tables configured (established 32768 bind 32768) [ 0.066853] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.066902] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.067039] NET: Registered protocol family 1 [ 0.067423] RPC: Registered named UNIX socket transport module. [ 0.067427] RPC: Registered udp transport module. [ 0.067429] RPC: Registered tcp transport module. [ 0.067431] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.067438] NET: Registered protocol family 44 [ 0.067451] PCI: CLS 0 bytes, default 64 [ 0.067925] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.070400] Initialise system trusted keyrings [ 0.070508] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.072210] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.072518] NFS: Registering the id_resolver key type [ 0.072538] Key type id_resolver registered [ 0.072541] Key type id_legacy registered [ 0.072574] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.072579] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.072582] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.072744] 9p: Installing v9fs 9p2000 file system support [ 0.092104] Key type asymmetric registered [ 0.092111] Asymmetric key parser 'x509' registered [ 0.092141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.092146] io scheduler mq-deadline registered [ 0.092150] io scheduler kyber registered [ 0.093662] pinctrl-single 4301c000.pinctrl: 101 pins, size 404 [ 0.093838] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.098675] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.105329] brd: module loaded [ 0.109199] loop: module loaded [ 0.109969] megasas: 07.714.04.00-rc1 [ 0.112127] tun: Universal TUN/TAP device driver, 1.6 [ 0.112435] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.112437] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.112465] sky2: driver version 1.30 [ 0.113054] VFIO - User Level meta-driver version: 0.3 [ 0.113731] i2c /dev entries driver [ 0.114581] sdhci: Secure Digital Host Controller Interface driver [ 0.114584] sdhci: Copyright(c) Pierre Ossman [ 0.114904] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.115490] ledtrig-cpu: registered to indicate activity on CPUs [ 0.115722] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.116562] optee: probing for conduit method. [ 0.116582] optee: revision 3.20 (8e74d476) [ 0.133051] optee: dynamic shared memory is enabled [ 0.133285] optee: initialized driver [ 0.133502] gpio-mux: probe of mux-controller0 failed with error -2 [ 0.133520] gpio-mux: probe of mux-controller1 failed with error -2 [ 0.134786] NET: Registered protocol family 17 [ 0.134875] 9pnet: Installing 9P2000 support [ 0.134923] Key type dns_resolver registered [ 0.135062] Loading compiled-in X.509 certificates [ 0.143305] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar') [ 0.166934] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz [ 0.167458] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 0.167886] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz [ 0.168348] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.168798] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 0.169254] omap_i2c 2050000.i2c: bus 5 rev0.12 at 400 kHz [ 0.170146] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 0.170252] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 0.170338] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 0.170548] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 0.172555] ti-udma 311a0000.dma-controller: Number of rings: 48 [ 0.173203] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16) [ 0.174273] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 0.174280] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 0.174284] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.175762] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 0.175768] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 0.175771] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.176037] omap8250 40a00000.serial: failed to get alias [ 0.182466] printk: console [ttyS2] disabled [ 0.182507] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 27, base_baud = 3000000) is a 8250 [ 0.182546] printk: console [ttyS2] enabled [ 0.182549] printk: bootconsole [ns16550a0] disabled [ 0.184358] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available [ 0.191566] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 0.191591] 16 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 0.191594] Creating 16 MTD partitions on "47040000.spi.0": [ 0.191600] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 0.192262] 0x000000080000-0x000000680000 : "ospi.tispl_a" [ 0.192743] 0x000000680000-0x000000c80000 : "ospi.tispl_b" [ 0.193190] 0x000000c80000-0x000001080000 : "ospi.u-boot_a" [ 0.193658] 0x000001080000-0x000001480000 : "ospi.u-boot_b" [ 0.194100] 0x000001480000-0x0000014c0000 : "ospi.update" [ 0.194551] 0x0000014c0000-0x000001500000 : "ospi.update_bkp" [ 0.195012] 0x000001500000-0x000001540000 : "ospi.carInfo" [ 0.195437] 0x000001540000-0x000001580000 : "ospi.profile" [ 0.195869] 0x000001580000-0x0000015c0000 : "ospi.sys" [ 0.196328] 0x0000015c0000-0x0000016c0000 : "ospi.tispl_bkp" [ 0.196789] 0x0000016c0000-0x0000018c0000 : "ospi.u-boot_bkp" [ 0.197211] 0x0000018c0000-0x000001900000 : "ospi.dtb_bkp" [ 0.197689] 0x000001900000-0x000002300000 : "ospi.kernel_bkp" [ 0.198169] 0x000002300000-0x000003ec0000 : "ospi.rootfs_bkp" [ 0.198634] 0x000003ec0000-0x000003f00000 : "ospi.phypattern" [ 0.199797] cadence-qspi 47050000.spi: error -ENODEV: No Rx DMA available [ 0.210365] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode [ 0.210385] (null): mdiobus_register 1 [ 0.253601] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 0.253606] mdio_bus c200f00.mdio: mdiobus_register 0 [ 0.258652] mdio_bus c200f00.mdio: addr=0xf scanphys=0 [ 0.484832] davinci_mdio c200f00.mdio: phy[15]: device c200f00.mdio:0f, driver TI DP83TG720CS1.1 [ 0.484886] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 0.485024] am65-cpsw-nuss c200000.ethernet: Use random MAC address [ 0.491291] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4 [ 0.491294] am65-cpsw-nuss c200000.ethernet: ALE Table size 64 [ 0.491763] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 0.493560] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0 [ 0.595353] mmc0: CQHCI version 5.10 [ 0.596071] mmc1: CQHCI version 5.10 [ 0.599482] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 0.599832] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 0.600134] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 0.600433] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 0.601118] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 0.602768] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 0.605152] davinci_mdio c200f00.mdio: Configuring MDIO in manual mode [ 0.605173] (null): mdiobus_register 1 [ 0.636232] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 0.636236] mmc0: SDHCI controller on 4f80000.mmc end [ 0.636350] mmc_rescan [ 0.636356] mmc_rescan_try_freq start 0 [ 0.636359] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 0.641743] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 0.641748] mmc1: SDHCI controller on 4fb0000.mmc end [ 0.641870] mmc_rescan [ 0.641875] mmc_rescan_try_freq start 0 [ 0.641878] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz [ 0.642884] mmc0:mmc_attach_sdio end [ 0.644313] mmc_attach_sd mmc_send_app_op_cond err=-110 [ 0.644316] mmc0:mmc_attach_sd end [ 0.645606] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 0.645614] mdio_bus c200f00.mdio: mdiobus_register 0 [ 0.650677] mdio_bus c200f00.mdio: addr=0xf scanphys=0 [ 0.657278] mmc1:mmc_attach_sdio end [ 0.657876] mmc_attach_sd mmc_send_app_op_cond err=0 [ 0.657879] mmc_sd_init_card [ 0.669886] mmc_send_op_cond err=0 [ 0.682137] mmc1: new high speed SDXC card at address 59b4 [ 0.682564] mmcblk1: mmc1:59b4 USD00 58.9 GiB [ 0.876929] davinci_mdio c200f00.mdio: phy[15]: device c200f00.mdio:0f, driver TI DP83TG720CS1.1 [ 0.877001] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 0.877160] am65-cpsw-nuss c200000.ethernet: Use random MAC address [ 0.883433] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4 [ 0.883436] am65-cpsw-nuss c200000.ethernet: ALE Table size 64 [ 0.883603] mmc0: Command Queue Engine enabled [ 0.883613] mmc0: new high speed MMC card at address 0001 [ 0.884089] mmcblk0: mmc0:0001 BGUF4R 29.1 GiB [ 0.884197] mmcblk0boot0: mmc0:0001 BGUF4R partition 1 31.9 MiB [ 0.884307] mmcblk0boot1: mmc0:0001 BGUF4R partition 2 31.9 MiB [ 0.884451] mmcblk0rpmb: mmc0:0001 BGUF4R partition 3 4.00 MiB, chardev (237:0) [ 0.884953] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 0.885222] mmcblk1: p1 p2 [ 0.885754] mmc_rescan end [ 0.886520] mmc_rescan end [ 0.887283] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82 [ 0.890184] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present! [ 0.897506] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present! [ 0.905246] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present! [ 0.913157] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present! [ 0.925674] ALSA device list: [ 0.925680] No soundcards found. [ 1.056880] EXT4-fs (mmcblk1p2): recovery complete [ 1.057672] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.057723] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.058825] devtmpfs: mounted [ 1.059885] Freeing unused kernel memory: 2176K [ 1.060000] Run /sbin/init as init process [ 1.060005] with arguments: [ 1.060008] /sbin/init [ 1.060011] with environment: [ 1.060013] HOME=/ [ 1.060016] TERM=linux [ 1.245869] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 1.328870] random: crng init done [ 1.664138] NET: Registered protocol family 10 [ 1.664789] Segment Routing with IPv6 [ 1.695514] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 1.695728] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 1.696033] remoteproc remoteproc0: 41000000.r5f is available [ 1.696085] remoteproc remoteproc0: attaching to 41000000.r5f [ 1.696206] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 1.696251] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 1.696255] remoteproc remoteproc0: remote processor 41000000.r5f is now attached [ 1.698604] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 1.699173] remoteproc remoteproc1: 5c00000.r5f is available [ 1.699224] remoteproc remoteproc1: attaching to 5c00000.r5f [ 1.699328] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 1.699379] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 1.699382] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached [ 1.699579] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 1.700129] remoteproc remoteproc2: 5d00000.r5f is available [ 1.700157] remoteproc remoteproc2: attaching to 5d00000.r5f [ 1.700215] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 1.700249] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 1.700252] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached [ 1.702399] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 1.702704] remoteproc remoteproc3: 5e00000.r5f is available [ 1.702753] remoteproc remoteproc3: attaching to 5e00000.r5f [ 1.702854] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 1.702896] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 1.702899] remoteproc remoteproc3: remote processor 5e00000.r5f is now attached [ 1.703099] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 1.703387] remoteproc remoteproc4: 5f00000.r5f is available [ 1.703410] remoteproc remoteproc4: attaching to 5f00000.r5f [ 1.703469] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 1.703498] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 1.703502] remoteproc remoteproc4: remote processor 5f00000.r5f is now attached [ 1.711196] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b0000000 [ 1.712880] remoteproc remoteproc5: 64800000.dsp is available [ 1.712939] remoteproc remoteproc5: attaching to 64800000.dsp [ 1.712985] remoteproc remoteproc5: unsupported resource 65538 [ 1.713065] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b0000000 [ 1.713112] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 1.713115] remoteproc remoteproc5: remote processor 64800000.dsp is now attached [ 1.714246] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000 [ 1.714863] remoteproc remoteproc6: 65800000.dsp is available [ 1.714909] remoteproc remoteproc6: attaching to 65800000.dsp [ 1.714956] remoteproc remoteproc6: unsupported resource 65538 [ 1.715002] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b6000000 [ 1.715040] remoteproc6#vdev0buffer: registered virtio6 (type 7) [ 1.715043] remoteproc remoteproc6: remote processor 65800000.dsp is now attached [ 1.722820] virtio_rpmsg_bus virtio0: rpmsg host is online [ 1.723920] virtio_rpmsg_bus virtio1: rpmsg host is online [ 1.724742] virtio_rpmsg_bus virtio2: rpmsg host is online [ 1.725496] virtio_rpmsg_bus virtio3: rpmsg host is online [ 1.726397] virtio_rpmsg_bus virtio4: rpmsg host is online [ 1.727171] virtio_rpmsg_bus virtio5: rpmsg host is online [ 1.727893] virtio_rpmsg_bus virtio6: rpmsg host is online [ 1.731152] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 1.732412] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd [ 1.740068] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 1.741383] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 1.741570] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 1.742669] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 1.755439] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 1.756417] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 1.756638] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15 [ 1.756744] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 1.756904] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 1.757156] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 1.757296] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 1.757439] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 1.760114] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe [ 1.760699] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 1.763746] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 1.764600] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 1.783084] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 1.796247] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 1.823773] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 1.969458] pvrsrvkm: loading out-of-tree module taints kernel. [ 1.977359] PVR_K: 253: Read BVNC 36.53.104.796 from HW device registers [ 1.977372] PVR_K: 253: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 1.977787] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0 [ 2.488210] alloc_contig_range: [8ac100, 8ac400) PFNs busy [ 3.012525] am65-cpsw-nuss c200000.ethernet eth0: PHY [c200f00.mdio:0f] driver [TI DP83TG720CS1.1] (irq=POLL) [ 3.012541] am65-cpsw-nuss c200000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 3.867511] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 4.030082] am65-cpsw-nuss c200000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 4.030116] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 14.495327] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Profile | value: 0 [ 14.495339] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Level | value: 0 [ 14.495344] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Minimum QP Value | value: 8 [ 14.495349] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Maximum QP Value | value: 51 [ 14.495353] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC I-Frame QP Value | value: 30 [ 14.495357] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Loop Filter | value: 1 [ 14.495360] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Loop Filter Beta Offset | value: 0 [ 14.495364] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Loop Filter TC Offset | value: 0 [ 14.495368] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Refresh Type | value: 1 [ 14.495371] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Num of I-Frame b/w 2 IDR | value: 0 [ 14.495375] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Lossless Encoding | value: 0 [ 14.495378] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Constant Intra Prediction | value: 0 [ 14.495381] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Wavefront | value: 0 [ 14.495384] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Strong Intra Smoothing | value: 1 [ 14.495387] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC Max Num of Candidate MVs | value: 2 [ 14.495390] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: HEVC TMV Prediction | value: 1 [ 14.495394] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Profile | value: 0 [ 14.495397] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Level | value: 0 [ 14.495401] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Minimum QP Value | value: 8 [ 14.495404] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Maximum QP Value | value: 51 [ 14.495407] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 I-Frame QP Value | value: 30 [ 14.495410] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Loop Filter Mode | value: 0 [ 14.495413] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Loop Filter Alpha Offset | value: 0 [ 14.495417] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Loop Filter Beta Offset | value: 0 [ 14.495420] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 8x8 Transform Enable | value: 1 [ 14.495424] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Constrained Intra Pred | value: 0 [ 14.495428] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Chroma QP Index Offset | value: 0 [ 14.495431] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 I-Frame Period | value: 0 [ 14.495434] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Entropy Mode | value: 0 [ 14.495437] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Horizontal Flip | value: 0 [ 14.495441] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Vertical Flip | value: 0 [ 14.495444] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Rotate | value: 0 [ 14.495447] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: VBV Buffer Size | value: 3000 [ 14.495450] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Video Bitrate Mode | value: 1 [ 14.495454] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Video Bitrate | value: 0 [ 14.495457] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Video GOP Size | value: 0 [ 14.495460] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Slice Partitioning Method | value: 0 [ 14.495464] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Number of MBs in a Slice | value: 0 [ 14.495467] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Frame Level Rate Control Enable | value: 0 [ 14.495470] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 MB Level Rate Control | value: 0 [ 14.495512] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Video GOP Size | value: 30 [ 14.495517] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Video Bitrate | value: 30000000 [ 14.495520] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 I-Frame Period | value: 30 [ 14.495523] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Profile | value: 4 [ 14.495527] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: H264 Level | value: 9 [ 14.495530] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Frame Level Rate Control Enable | value: 1 [ 14.495540] vdec 4210000.video-codec: wave5_vpu_enc_s_parm: type: 10 [ 14.495543] vdec 4210000.video-codec: wave5_vpu_enc_s_parm: numerator: 1 | denominator: 30 [ 14.495553] vdec 4210000.video-codec: wave5_vpu_enc_s_fmt_out: fourcc: 842094158 width: 1792 height: 1024 num_planes: 1 field: 1 [ 14.495557] vdec 4210000.video-codec: wave5_vpu_enc_try_fmt_out: fourcc: 842094158 width: 1792 height: 1024 num_planes: 1 field: 1 [ 14.495564] vdec 4210000.video-codec: wave5_vpu_enc_s_fmt_cap: fourcc: 875967048 width: 1792 height: 1024 num_planes: 1 field: 1 [ 14.495567] vdec 4210000.video-codec: wave5_vpu_enc_try_fmt_cap: fourcc: 875967048 width: 1792 height: 1024 num_planes: 1 field: 1 [ 14.495579] vdec 4210000.video-codec: wave5_vpu_enc_queue_setup: num_buffers: 2 | num_planes: 0 | type: 10 [ 14.495583] vdec 4210000.video-codec: wave5_vpu_enc_queue_setup: size[0]: 2752512 [ 14.495586] vdec 4210000.video-codec: wave5_vpu_enc_queue_setup: size: 2752512 [ 14.495962] vdec 4210000.video-codec: wave5_bit_issue_command: cmd=0x8 [ 14.496323] vdec 4210000.video-codec: wave5_bit_issue_command: cmd=0x200 [ 14.497285] vdec 4210000.video-codec: wave5_bit_issue_command: cmd=0x4000 [ 14.497309] vdec 4210000.video-codec: wave5_vpu_enc_get_seq_info: init seq [ 14.497315] vdec 4210000.video-codec: wave5_vpu_enc_queue_setup: min_frame_buffer: 2 | min_source_buffer: 1 [ 14.497321] vdec 4210000.video-codec: wave5_vpu_enc_s_ctrl: name: Min Number of Output Buffers | value: 5 [ 14.502297] alloc_contig_range: [8ac100, 8ac139) PFNs busy [ 14.502528] alloc_contig_range: [8ac140, 8ac179) PFNs busy [ 14.502956] alloc_contig_range: [8ac180, 8ac1b9) PFNs busy [ 14.503491] alloc_contig_range: [8ac1c0, 8ac1f9) PFNs busy [ 14.508889] vdec 4210000.video-codec: wave5_bit_issue_command: cmd=0x80 [ 14.526408] vdec 4210000.video-codec: wave5_bit_issue_command: cmd=0x20 [ 14.526469] vdec 4210000.video-codec: wave5_vpu_enc_close: enc seq end timed out [ 14.560167] PVR_K: 676: RGX Firmware image 'rgx.fw.36.53.104.796' loaded [ 14.581719] PVR_K: 676: Shader binary image 'rgx.sh.36.53.104.796' loaded [ 15.924450] PVR_K:(Error): 67: RGXSafetyEventHandler: Safety Watchdog Trigger ! [358] [ 31.709614] vdd_mmc1: disabling
