CCSTUDIO: Tools
Part Number: CCSTUDIO
ccs_setup_12.8.0.00012 installation fails in Ubuntu 22.04 with following error
Error from installation log
Unpacking /home/sreenathv/ti/ccs1280/ccs/scripting/docs/interfaces/Types.NumericRange.html
Unpacking /home/sreenathv/ti/ccs1280/ccs/scripting/docs/interfaces/Types.CoreList.html
Unpacking /home/sreenathv/ti/ccs1280/ccs/scripting/docs/interfaces/Types.LocationBreakpointProperty.html
Unpacking /home/sreenathv/ti/ccs1280/ccs/scripting/docs/modules/Types.html
Unpacking /home/sreenathv/ti/ccs1280/ccs/scripting/docs/.nojekyll
[21:27:59] deletelist = common/bin/liblldb_ccs.dll
[21:27:59] Start runProgram here. Variables: /home/sreenathv/ti/ccs1280/ccs/eclipse/eclipse true  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash
[21:27:59] check if base plugin exists
[21:27:59] running eclipse commands; plugin exists = false
[21:27:59] 1 0
Executing /home/sreenathv/ti/ccs1280/ccs/eclipse/eclipse  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash
Script exit code: 13
Script output:
 Preparing to commit the provisioning operation.
Committing the provisioning operation.
Installing com.ti.ccstudio.base.feature.group 12.8.0.03471.
Downloading com.ti.ccstudio.base
An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
Installation failed.
Script stderr:
 SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See www.slf4j.org/codes.html for further details.
An error occurred during the org.eclipse.equinox.internal.p2.engine.phases.CheckTrust phase.
 session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.CheckTrust, operand=, action=).
 Error reading signed content.
Caused by:  java.util.zip.ZipException: invalid stored block lengths
Application failed, log file location: /home/sreenathv/ti/ccs1280/ccs/eclipse/configuration/1725983880157.log
Error running /home/sreenathv/ti/ccs1280/ccs/eclipse/eclipse  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash: SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
[21:28:04] Rerunning  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash exitcode 13
[21:28:14] 13 1
Script output:
Script stderr:
Application failed, log file location: /home/sreenathv/ti/ccs1280/ccs/eclipse/configuration/1725983894873.log
[21:28:18] Rerunning  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash exitcode 13
[21:28:28] 13 2
Script output:
Script stderr:
Application failed, log file location: /home/sreenathv/ti/ccs1280/ccs/eclipse/configuration/1725983909239.log
[21:28:34] Rerunning  -application com.ti.ccstudio.p2app -installiu com.ti.ccstudio.base.feature.group -repository "file://home/sreenathv/ti/ccs1280/ccs/ccs_base/dsbuildrepo" -destination "/home/sreenathv/ti/ccs1280/ccs/eclipse" -nosplash exitcode 13
[21:28:44] 13 3
[21:28:44] copying properties file
Executing chmod -R 666 "/tmp/installbuilder_installer_6713.log"
Script exit code: 0
Script output:
    Can you provide all your logs? Basically everything in the /install_logs folder.
    ki
  • How to attach files here?
  • Logs from ~/ti/ccs/install_logs/20240910212522/ccs_install_12.8.0.00012.log
    Log started 09/10/2024 at 21:25:22 Preferred installation mode : unattended Trying to init installer in mode unattended Mode unattended successfully initialized [21:25:22] CCS_INFO: Installer timestamp 20240910212522 [21:25:22] Installer arguments --prefix /home/sreenathv/ti --mode unattended [21:25:22] CCS_INFO: Initialization sets components_download_url to software-dl.ti.com/.../components [21:25:22] createshortcuts set to true [21:25:22] CCS_INFO: Temporary folder set to /tmp/ccs_c0b85246-0e0b-4d7a-5a95-04d23ee0ea63 [21:25:23] CCS_INFO: Product families available: PF_MSP430,PF_MSP432,PF_MSPM0,PF_WCONN,PF_C28,PF_TM4C,PF_HERCULES,PF_SITARA,PF_SITARA_MCU,PF_OMAPL,PF_DAVINCI,PF_OMAP,PF_TDA_DRA,PF_C55,PF_C6000SC,PF_C66AK_KEYSTONE,PF_MMWAVE,PF_C64MC,PF_DIGITAL_POWER,PF_PGA [21:25:23] CCS_INFO: Components available: ARM_CGT_HELP,C2000_CGT_HELP,C6000_CGT_HELP,CCS_DOC,CCS_LAUNCHER,CCS_UTILS,CGT_DEFAULTLIBS_C2800,CGT_DEFAULTLIBS_C6000_V8P,CGT_DEFAULTLIBS_MSP430,CGT_DEFAULTLIBS_TMS470,CLOUDAGENT,DEV_SUPPORT_AUTOMOTIVE,DEV_SUPPORT_C55XX,DEV_SUPPORT_C6000,DEV_SUPPORT_CC2538,DEV_SUPPORT_CC26XX,DEV_SUPPORT_CC3220,DEV_SUPPORT_CC3230,DEV_SUPPORT_CC32XX,DEV_SUPPORT_CC32XX_COMMON,DEV_SUPPORT_DAVINCI,DEV_SUPPORT_INTEGRA,DEV_SUPPORT_MMWAVE,DEV_SUPPORT_OMAP,DEV_SUPPORT_PGA,DEV_SUPPORT_SHARED,DEV_SUPPORT_SITARA,DEV_SUPPORT_SITARA_MCU,DEV_SUPPORT_UCD31XX,DMED,DS,DS_FLASH,DVT,ECLIPSE,EMU_BH,EMU_C2000,EMU_C2000_FLASH,EMU_HERCULES,EMU_TI,IDE,IDE_CHROME,IDE_GC,IDE_TOOLS_COMMON,INSTALLER,JRE,KEYSTONE2,MSP430_BUILD_DEBUG,MSP430_CGT_HELP,MSP430_GCC_SUPPORT,MSP432_BUILD_DEBUG,MSPM0,NODEJS,P2APP,P2TOOLS,SEGGER_J_LINK,SYSCONFIG,TARGETDB_DEF_PROPS,TARGET_CONTENT_CORE,TIREX,TIREX4,TIVA_STELLARIS_DRIVERS,TIVA_TM4C,TIVA_TM4E,TI_ARM_CLANG,USERGUIDE,core [21:25:23] PFsToBeInstalled: [21:25:23] Running in unattended mode, must validate system. Executing /tmp/ccs_c0b85246-0e0b-4d7a-5a95-04d23ee0ea63/util/dependency-checker/check_depends.sh Script exit code: 0 Script output: Installed versions of glibc and glibcxx: 2.35, N/A Required versions of glibc and glibcxx: 2.18, GLIBCXX_3.4.29 GLIBC_INSTALLED: 2.35 GLIBC_REQUIRED: 2.18 Checking availability of libraries in ext-depends.txt ... Done. Script stderr: [21:25:24] CCS_INFO:GLIBC installed: 2.35 [21:25:24] CCS_INFO: GLIBC required: 2.18 [21:25:24] CCS_INFO: Missing dependencies: [] [21:25:24] CCS_WARNING: OK Executing /tmp/ccs_c0b85246-0e0b-4d7a-5a95-04d23ee0ea63/util/dependency-checker/ldcheck Script exit code: 0 Script output: Script stderr: [21:25:24] CCS_INFO: Running in unattended mode, must validate installdir /home/sreenathv/ti. [21:25:25] Logdir = /home/sreenathv/ti/ccs/install_logs/20240910212522 [21:25:25] CCS_INFO: CCStudio set to /home/sreenathv/ti/ccs/eclipse/ccstudio [21:25:25] installedProductFamilies = [21:25:25] CCS_INFO: Running fresh install in unattended mode, must select all components. [21:25:25] CCS_INFO: In selectAllComponents.xml PFList = PF_MSP430,PF_MSP432,PF_MSPM0,PF_WCONN,PF_C28,PF_TM4C,PF_HERCULES,PF_SITARA,PF_SITARA_MCU,PF_OMAPL,PF_DAVINCI,PF_OMAP,PF_TDA_DRA,PF_C55,PF_C6000SC,PF_C66AK_KEYSTONE,PF_MMWAVE,PF_C64MC,PF_DIGITAL_POWER,PF_PGA [21:25:25] PF_MSP430 selected: 1 [21:25:25] MSP430_BUILD_DEBUG selected: 1 [21:25:25] MSP430_BUILD_DEBUG: Installed Version: NOTSET Current Version: 11.1.0.20211104 [21:25:25] MSP430_GCC_SUPPORT selected: 1 [21:25:25] MSP430_GCC_SUPPORT: Installed Version: NOTSET Current Version: 11.1.0.20211104 [21:25:25] MSP430_CGT_HELP selected: 1 [21:25:25] MSP430_CGT_HELP: Installed Version: NOTSET Current Version: 18.1.0.20181119 [21:25:26] CGT_DEFAULTLIBS_MSP430 selected: 1 [21:25:26] CGT_DEFAULTLIBS_MSP430: Installed Version: NOTSET Current Version: 21.6.1.LTS [21:25:26] DMED selected: 1 [21:25:26] DMED: Installed Version: NOTSET Current Version: 1.1.6 [21:25:26] PF_MSP432 selected: 1 [21:25:26] MSP432_BUILD_DEBUG selected: 1 [21:25:26] MSP432_BUILD_DEBUG: Installed Version: NOTSET Current Version: 11.1.0.20211104 [21:25:26] ARM_CGT_HELP selected: 1 [21:25:26] ARM_CGT_HELP: Installed Version: NOTSET Current Version: 18.1.0.20181119 [21:25:26] CGT_DEFAULTLIBS_TMS470 selected: 1 [21:25:26] CGT_DEFAULTLIBS_TMS470: Installed Version: NOTSET Current Version: 20.2.7.LTS [21:25:26] TI_ARM_CLANG selected: 1 [21:25:26] TI_ARM_CLANG: Installed Version: NOTSET Current Version: 3.2.2.LTS [21:25:27] EMU_TI selected: 1 [21:25:27] EMU_TI: Installed Version: NOTSET Current Version: 12.8.0.00189 [21:25:27] PF_MSPM0 selected: 1 [21:25:27] MSPM0 selected: 1 [21:25:27] MSPM0: Installed Version: NOTSET Current Version: 1.10.00.06 [21:25:27] PF_WCONN selected: 1 [21:25:27] DEV_SUPPORT_CC26XX selected: 1 [21:25:27] DEV_SUPPORT_CC26XX: Installed Version: NOTSET Current Version: 3.20.01.32 [21:25:28] TIVA_STELLARIS_DRIVERS selected: 1 [21:25:28] TIVA_STELLARIS_DRIVERS: Installed Version: NOTSET Current Version: 2.1.3.15 [21:25:28] DEV_SUPPORT_CC32XX selected: 1 [21:25:28] DEV_SUPPORT_CC32XX: Installed Version: NOTSET Current Version: 1.0.8 [21:25:28] DEV_SUPPORT_CC3220 selected: 1 [21:25:28] DEV_SUPPORT_CC3220: Installed Version: NOTSET Current Version: 1.0.5 [21:25:28] DEV_SUPPORT_CC32XX_COMMON selected: 1 [21:25:28] DEV_SUPPORT_CC32XX_COMMON: Installed Version: NOTSET Current Version: 1.0.8 [21:25:28] DEV_SUPPORT_CC3230 selected: 1 [21:25:28] DEV_SUPPORT_CC3230: Installed Version: NOTSET Current Version: 1.0.5 [21:25:28] DEV_SUPPORT_CC2538 selected: 1 [21:25:28] DEV_SUPPORT_CC2538: Installed Version: NOTSET Current Version: 2.0.4.11 [21:25:29] PF_C28 selected: 1 [21:25:29] EMU_C2000_FLASH selected: 1 [21:25:29] EMU_C2000_FLASH: Installed Version: NOTSET Current Version: 1.0.0.5 [21:25:29] EMU_C2000 selected: 1 [21:25:29] EMU_C2000: Installed Version: NOTSET Current Version: 6.21.0.0 [21:25:29] C2000_CGT_HELP selected: 1 [21:25:29] C2000_CGT_HELP: Installed Version: NOTSET Current Version: 18.1.0.20180221 [21:25:29] CGT_DEFAULTLIBS_C2800 selected: 1 [21:25:29] CGT_DEFAULTLIBS_C2800: Installed Version: NOTSET Current Version: 22.6.1.LTS [21:25:30] PF_TM4C selected: 1 [21:25:30] TIVA_TM4C selected: 1 [21:25:30] TIVA_TM4C: Installed Version: NOTSET Current Version: 2.1.1.15071 [21:25:30] TIVA_TM4E selected: 1 [21:25:30] TIVA_TM4E: Installed Version: NOTSET Current Version: 2.1.1.15071 [21:25:30] PF_HERCULES selected: 1 [21:25:31] EMU_HERCULES selected: 1 [21:25:31] EMU_HERCULES: Installed Version: NOTSET Current Version: 6.0.9 [21:25:31] PF_SITARA selected: 1 [21:25:31] DEV_SUPPORT_SITARA selected: 1 [21:25:31] DEV_SUPPORT_SITARA: Installed Version: NOTSET Current Version: 1.6.7 [21:25:31] DEV_SUPPORT_SHARED selected: 1 [21:25:31] DEV_SUPPORT_SHARED: Installed Version: NOTSET Current Version: 1.1.7 [21:25:32] C6000_CGT_HELP selected: 1 [21:25:32] C6000_CGT_HELP: Installed Version: NOTSET Current Version: 7.4.0.20150713 [21:25:32] CGT_DEFAULTLIBS_C6000_V8P selected: 1 [21:25:32] CGT_DEFAULTLIBS_C6000_V8P: Installed Version: NOTSET Current Version: 8.3.12 [21:25:32] PF_SITARA_MCU selected: 1 [21:25:32] DEV_SUPPORT_SITARA_MCU selected: 1 [21:25:32] DEV_SUPPORT_SITARA_MCU: Installed Version: NOTSET Current Version: 1.3.5 [21:25:32] PF_OMAPL selected: 1 [21:25:32] DEV_SUPPORT_INTEGRA selected: 1 [21:25:32] DEV_SUPPORT_INTEGRA: Installed Version: NOTSET Current Version: 1.1.2 [21:25:33] PF_DAVINCI selected: 1 [21:25:33] DEV_SUPPORT_DAVINCI selected: 1 [21:25:33] DEV_SUPPORT_DAVINCI: Installed Version: NOTSET Current Version: 1.1.6 [21:25:34] PF_OMAP selected: 1 [21:25:34] DEV_SUPPORT_OMAP selected: 1 [21:25:34] DEV_SUPPORT_OMAP: Installed Version: NOTSET Current Version: 1.1.0 [21:25:34] PF_TDA_DRA selected: 1 [21:25:35] DEV_SUPPORT_AUTOMOTIVE selected: 1 [21:25:35] DEV_SUPPORT_AUTOMOTIVE: Installed Version: NOTSET Current Version: 1.1.16 [21:25:35] PF_C55 selected: 1 [21:25:35] DEV_SUPPORT_C55XX selected: 1 [21:25:35] DEV_SUPPORT_C55XX: Installed Version: NOTSET Current Version: 1.2.1 [21:25:35] PF_C6000SC selected: 1 [21:25:36] DEV_SUPPORT_C6000 selected: 1 [21:25:36] DEV_SUPPORT_C6000: Installed Version: NOTSET Current Version: 1.1.7 [21:25:36] PF_C66AK_KEYSTONE selected: 1 [21:25:36] KEYSTONE2 selected: 1 [21:25:36] KEYSTONE2: Installed Version: NOTSET Current Version: 1.2.4 [21:25:37] PF_MMWAVE selected: 1 [21:25:37] DEV_SUPPORT_MMWAVE selected: 1 [21:25:37] DEV_SUPPORT_MMWAVE: Installed Version: NOTSET Current Version: 1.7.12 [21:25:37] PF_C64MC selected: 1 [21:25:38] PF_DIGITAL_POWER selected: 1 [21:25:38] DEV_SUPPORT_UCD31XX selected: 1 [21:25:38] DEV_SUPPORT_UCD31XX: Installed Version: NOTSET Current Version: 1.1.5 [21:25:38] PF_PGA selected: 1 [21:25:38] DEV_SUPPORT_PGA selected: 1 [21:25:38] DEV_SUPPORT_PGA: Installed Version: NOTSET Current Version: 1.0.2 [21:25:39] CCS_INFO: setting project.component(ALL).component(core).selected to 1 [21:25:39] CCS_INFO: setting project.component(ALL).component(IDE).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(DVT).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(JRE).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(IDE_GC).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(IDE_CHROME).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(IDE_TOOLS_COMMON).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(P2APP).selected to 0 [21:25:39] CCS_INFO: setting project.component(ALL).component(P2TOOLS).selected to 0 [21:25:39] CCS_DOC NOTSET 12.8.0.00012 [21:25:39] CCS_DOC selected: 1 [21:25:39] CCS_DOC: Installed Version: NOTSET Current Version: 12.8.0.00012 [21:25:39] CCS_UTILS NOTSET 1.0.0.20221028 [21:25:39] CCS_UTILS selected: 1 [21:25:39] CCS_UTILS: Installed Version: NOTSET Current Version: 1.0.0.20221028 [21:25:39] CCS_LAUNCHER NOTSET 12.0.0.20220603 [21:25:39] CCS_LAUNCHER selected: 1 [21:25:39] CCS_LAUNCHER: Installed Version: NOTSET Current Version: 12.0.0.20220603 [21:25:39] TARGETDB_DEF_PROPS NOTSET 12.8.0.N202407141830 [21:25:39] TARGETDB_DEF_PROPS selected: 1 [21:25:39] TARGETDB_DEF_PROPS: Installed Version: NOTSET Current Version: 12.8.0.N202407141830 [21:25:39] INSTALLER NOTSET 12.8.0.00012 [21:25:39] INSTALLER selected: 1 [21:25:39] INSTALLER: Installed Version: NOTSET Current Version: 12.8.0.00012 [21:25:40] TARGET_CONTENT_CORE NOTSET 3.62.1.16 [21:25:40] TARGET_CONTENT_CORE selected: 1 [21:25:40] TARGET_CONTENT_CORE: Installed Version: NOTSET Current Version: 3.62.1.16 [21:25:40] TIREX NOTSET 3.8.0.201911142334 [21:25:40] TIREX selected: 1 [21:25:40] TIREX: Installed Version: NOTSET Current Version: 3.8.0.201911142334 [21:25:40] TIREX4 NOTSET 4.15.0.202309151451 [21:25:40] TIREX4 selected: 1 [21:25:40] TIREX4: Installed Version: NOTSET Current Version: 4.15.0.202309151451 [21:25:40] NODEJS NOTSET 18.16.0 [21:25:40] NODEJS selected: 1 [21:25:40] NODEJS: Installed Version: NOTSET Current Version: 18.16.0 [21:25:40] DS NOTSET 12.8.0.3471 [21:25:40] DS selected: 1 [21:25:40] DS: Installed Version: NOTSET Current Version: 12.8.0.3471 [21:25:40] DS_FLASH NOTSET 12.8.0.3471 [21:25:40] DS_FLASH selected: 1 [21:25:40] DS_FLASH: Installed Version: NOTSET Current Version: 12.8.0.3471 [21:25:40] CLOUDAGENT NOTSET 0.5.4870 [21:25:40] CLOUDAGENT selected: 1 [21:25:40] CLOUDAGENT: Installed Version: NOTSET Current Version: 0.5.4870 [21:25:40] SYSCONFIG NOTSET 1.21.0.3721 [21:25:41] SYSCONFIG selected: 1 [21:25:41] SYSCONFIG: Installed Version: NOTSET Current Version: 1.21.0.3721 [21:25:41] USERGUIDE NOTSET 12.8.0.202407301400 [21:25:41] USERGUIDE selected: 1 [21:25:41] USERGUIDE: Installed Version: NOTSET Current Version: 12.8.0.202407301400 [21:25:41] CCS_INFO: Installing in /home/sreenathv/ti/ccs [21:25:41] CCS_INFO: Components default folder is set to /home/sreenathv/Downloads/components [21:25:41] CCS_INFO: Components override folder is set to /home/sreenathv/Downloads/components [21:25:41] CCS_INFO: Components default url is set to software-dl.ti.com/.../components [21:25:41] CCS_INFO: Components download url is set to software-dl.ti.com/.../components [21:25:41] CCS_INFO: Starting installation [21:25:41] Install Version : 12.8.0.00012 [21:25:41] Install Source : /home/sreenathv/Downloads [21:25:41] Install Temp : /tmp/ccs_c0b85246-0e0b-4d7a-5a95-04d23ee0ea63 [21:25:41] Install Type : Offline [21:25:41] OS : Linux [21:25:41] OS Name : Ubuntu 22.04.4 LTS [21:25:41] OS Version : 22.04 [21:25:41] OS Platform : linux-x64 64-bit [21:25:41] OSD : Ubuntu22.04.4LTS-64-bit [21:25:41] User ID : sreenathv [21:25:41] Timezone : IST [21:25:41] InstallTime(GMT): 09/10/2024 15:55:22(GMT) [21:25:41] IPAddress : 192.168.1.6 [21:25:41] Update/Rerun : false [21:25:41] Install GUID : c0b85246-0e0b-4d7a-5a95-04d23ee0ea63 [21:25:41] Command line : --prefix /home/sreenathv/ti --mode unattended [21:25:41] CCS_INFO: Downloading software-dl.ti.com/.../CCS12.8.0.00012_tia_linux-x64_start_offline.zip [21:25:48] CCS_INFO: Return values from downloadMarker software-dl.ti.com/.../CCS12.8.0.00012_tia_linux-x64_start_offline.zip: 200 [21:25:48] CCS_INFO: Components: [21:25:48] CCS_INFO: ARM_CGT_HELP: 1 [21:25:48] CCS_INFO: C2000_CGT_HELP: 1 [21:25:48] CCS_INFO: C6000_CGT_HELP: 1 [21:25:48] CCS_INFO: CCS_DOC: 1 [21:25:48] CCS_INFO: CCS_LAUNCHER: 1 [21:25:48] CCS_INFO: CCS_UTILS: 1 [21:25:48] CCS_INFO: CGT_DEFAULTLIBS_C2800: 1 [21:25:48] CCS_INFO: CGT_DEFAULTLIBS_C6000_V8P: 1 [21:25:48] CCS_INFO: CGT_DEFAULTLIBS_MSP430: 1 [21:25:48] CCS_INFO: CGT_DEFAULTLIBS_TMS470: 1 [21:25:48] CCS_INFO: CLOUDAGENT: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_AUTOMOTIVE: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_C55XX: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_C6000: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC2538: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC26XX: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC3220: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC3230: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC32XX: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_CC32XX_COMMON: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_DAVINCI: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_INTEGRA: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_MMWAVE: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_OMAP: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_PGA: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_SHARED: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_SITARA: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_SITARA_MCU: 1 [21:25:48] CCS_INFO: DEV_SUPPORT_UCD31XX: 1 [21:25:48] CCS_INFO: DMED: 1 [21:25:48] CCS_INFO: DS: 1 [21:25:48] CCS_INFO: DS_FLASH: 1 [21:25:48] CCS_INFO: DVT: 0 [21:25:48] CCS_INFO: ECLIPSE: 0 [21:25:48] CCS_INFO: EMU_BH: true [21:25:48] CCS_INFO: EMU_C2000: 1 [21:25:48] CCS_INFO: EMU_C2000_FLASH: 1 [21:25:48] CCS_INFO: EMU_HERCULES: 1 [21:25:48] CCS_INFO: EMU_TI: 1 [21:25:48] CCS_INFO: IDE: 0 [21:25:48] CCS_INFO: IDE_CHROME: 0 [21:25:48] CCS_INFO: IDE_GC: 0 [21:25:48] CCS_INFO: IDE_TOOLS_COMMON: 0 [21:25:48] CCS_INFO: INSTALLER: 1 [21:25:48] CCS_INFO: JRE: 0 [21:25:48] CCS_INFO: KEYSTONE2: 1 [21:25:48] CCS_INFO: MSP430_BUILD_DEBUG: 1 [21:25:48] CCS_INFO: MSP430_CGT_HELP: 1 [21:25:48] CCS_INFO: MSP430_GCC_SUPPORT: 1 [21:25:48] CCS_INFO: MSP432_BUILD_DEBUG: 1 [21:25:48] CCS_INFO: MSPM0: 1 [21:25:48] CCS_INFO: NODEJS: 1 [21:25:48] CCS_INFO: P2APP: 0 [21:25:48] CCS_INFO: P2TOOLS: 0 [21:25:48] CCS_INFO: SEGGER_J_LINK: true [21:25:48] CCS_INFO: SYSCONFIG: 1 [21:25:48] CCS_INFO: TARGETDB_DEF_PROPS: 1 [21:25:48] CCS_INFO: TARGET_CONTENT_CORE: 1 [21:25:48] CCS_INFO: TIREX: 1 [21:25:48] CCS_INFO: TIREX4: 1 [21:25:48] CCS_INFO: TIVA_STELLARIS_DRIVERS: 1 [21:25:48] CCS_INFO: TIVA_TM4C: 1 [21:25:48] CCS_INFO: TIVA_TM4E: 1 [21:25:48] CCS_INFO: TI_ARM_CLANG: 1 [21:25:48] CCS_INFO: USERGUIDE: 1 [21:25:48] CCS_INFO: core: 1 [21:25:48] CCS_INFO: rerun/update: false Unable to download component MSP430_BUILD_DEBUG: Error saving URL software-dl.ti.com/.../MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak to /home/sreenathv/Downloads/components/MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak Automatically retrying download Unable to download component MSP430_BUILD_DEBUG: Error saving URL software-dl.ti.com/.../MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak to /home/sreenathv/Downloads/components/MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak Unable to download component MSP430_BUILD_DEBUG: Error saving URL software-dl.ti.com/.../MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak to /home/sreenathv/Downloads/components/MSP430_BUILD_DEBUG-12.8.0.00012-linux-x64.pak Aborting installation due to MSP430_BUILD_DEBUG download error [21:25:49] CCS_INFO: In installationAbortedActionList An issue was encountered while installing CCS. Would you like to submit the installation logs to help us diagnose and fix the issue? no [21:25:49] CCS_ERROR: Code Composer Studio 12.8.0.00012 failed to install. [21:25:49] CCS_INFO: Downloading software-dl.ti.com/.../CCS12.8.0.00012_tia_linux-x64_failed_offline.zip [21:25:52] CCS_INFO: Return values from downloadMarker software-dl.ti.com/.../CCS12.8.0.00012_tia_linux-x64_failed_offline.zip: 200 [21:25:52] CCS_INFO: Deleting /home/sreenathv/ti/ccs? : !false [21:25:52] Moving logfile to /home/sreenathv/ti/ccs/install_logs/20240910212522/ccs_install_12.8.0.00012.log
  • It looks like you are using the web install. Can you try the full off-line installer?
