DRA821U: Watchdog testing
Part Number: DRA821U
Other Parts Discussed in Thread: AM62A7
Hi Team,
I am working on DRA821U CPU with Lnux SDK 09.02, i want to test watchdog feature mentioned in "6.2.3.8 A72SS Watchdog" section of TRM.
When i tried to test this using below command, no reset occurred in A72 core.
root@j7200-evm:~# rmmod rti_wdt
root@j7200-evm:~# modprobe rti_wdt heartbeat=10
[  443.174506] rti-wdt 2200000.watchdog: watchdog already running, ignoring heartbeat config!
root@j7200-evm:~# echo 1 > /dev/watchdog
[  454.165704] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[  454.172612] watchdog: watchdog0: watchdog did not stop!
Kindly share the procedure to enable and test this feature
Reagrds,
Nikhil K
  • Hi Nikhil,
    It looks like we include a set of tests which also tests watchdog. Please refer to this other thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1240469/tda4vm-triggering-the-watchdog-on-the-j721-evaluation-board
    Otherwise, you could use sysrq triggers to trigger a system crash like this "echo c > /proc/sysrq-trigger".
    Takuma
  • Hi Takum,
    "echo c > /proc/sysrq-trigger" i have tried this to make system crash but watchdog is not triggered, is that the pacth mentioned in the below mentioned URL is necessary to trigger main domain watchdog
    Also i have tried with below mentioned commands, i can see only the timer is running no clue of watchdog reset.
    cd /opt/ltp
    ./runltp -P j721e-evm -f ddt/wdt_test -s "WDT_M_FUNC_WRI"
    |TRACE LOG|4 seconds remaining before reboot|
    |TRACE LOG|3 seconds remaining before reboot|
    |TRACE LOG|2 seconds remaining before reboot|
    |TRACE LOG|1 seconds remaining before reboot|
    |TRACE LOG|0 seconds remaining before reboot|
    |TRACE LOG|-1 seconds remaining before reboot|
    |TRACE LOG|-2 seconds remaining before reboot|
    |TRACE LOG|-3 seconds remaining before reboot|
    |TRACE LOG|-4 seconds remaining before reboot|
    |TRACE LOG|-5 seconds remaining before reboot|
    |TRACE LOG|-6 seconds remaining before reboot|
    |TRACE LOG|-7 seconds remaining before reboot|
    |TRACE LOG|-8 seconds remaining before reboot|
    |TRACE LOG|-9 seconds remaining before reboot|
    |TRACE LOG|-10 seconds remaining before reboot|
    |TRACE LOG|-11 seconds remaining before reboot|
    |TRACE LOG|-12 seconds remaining before reboot|
    Here i am using my custom board, is there any changes need to be done for this...?
    Nikhil K
  • Hi Nikhil,
    The default image should work with "echo c > /proc/sysrq-trigger". I tried this on my board and a kernel crash was created. If it is not triggered, then it could be that some kernel configuration is missing, so please check your kernel configuration.
    As for ltp, there should be a platforms folder under /opt/ltp, and j7200 should be a different platform from j721e-evm.
    Takuma
  • Hi Takuma,
    I am using default image with custom board, is there any HW changes required for this?
    Nikhil
  • Hi Nikhil,
    No, there should not be an extra hardware change required for this. Let me check this one more time.
    Takuma
  • Hi Takuma,
    I have checked kernel configurations, also tried with default EVM Kernel image and i'm not observing any watchdog reset when system crashes.
    Also tried to set WDT timeout using rti-wdt.heartbeat=<timeout in sec> in kernel command line arguments, still there is not progress.
    Nikhil K
  • Hi Nikhil,
    I checked runltp and seem to get the same behavior as you.
    Looking through our release notes, I see that watchdog in Linux SDK looks to only be enabled for J721S2 and J784S4 platform. I do not see anything for J7200: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j7200/10_00_07_03/exports/docs/devices/J7_Family/linux/Release_Specific_Release_Notes.html?highlight=watchdog#sdk-features-scoped-in-9-1-release
    I will route this question to Keerthy who has created these FAQs to see if they have some more info: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1261459/faq-j721s2xsomxevm-how-to-enable-main-domain-watchdog.
    Takuma
  • Nikhil,
    Can you wait a little longer with the negative count? I have seen it triggering later. Can you check till -100.
    I tested with a default 9.2 SDK SD card. Watchdog reset works. You have to wait.
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j7200-evm -
    Arago 2023.10 j7200-evm -
    j7200-evm login: root
    [   14.584201] audit: type=1006 audit(1651167757.320:10): pid=1079 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   14.597116] audit: type=1300 audit(1651167757.320:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffeec90108 a2=1 a3=ffff86674020 items=0 ppid=1 p)
    [   14.623811] audit: type=1327 audit(1651167757.320:10): proctitle="(systemd)"
    [   14.631213] audit: type=1334 audit(1651167757.336:11): prog-id=11 op=LOAD
    [   14.638645] audit: type=1300 audit(1651167757.336:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe44380c0 a2=78 a3=0 items=0 ppid=1 pid=1079 a)
    [   14.664414] audit: type=1327 audit(1651167757.336:11): proctitle="(systemd)"
    [   14.671778] audit: type=1334 audit(1651167757.360:12): prog-id=11 op=UNLOAD
    [   14.679053] audit: type=1334 audit(1651167757.360:13): prog-id=12 op=LOAD
    [   14.686221] audit: type=1300 audit(1651167757.360:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe4438160 a2=78 a3=0 items=0 ppid=1 pid=1079 a)
    [   14.711897] audit: type=1327 audit(1651167757.360:13): proctitle="(systemd)"
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~# touch /dev/watchdog
    [  158.463947] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [  158.470866] watchdog: watchdog0: watchdog did not stop!
    root@j7200-evm:~#
    U-Boot SPL 2023.04-ti-gd2612223375a (Mar 13 2024 - 19:15:42 +0000)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
    Loading Environment from nowhere... OK
    Starting ATF on ARM64 core...
    Keerthy
  • Dear Keerthy,
    Even after crossing -100 WDT is not triggering
    Also host shows like j700-evm in the above image.
    In Am62a7 we observed "watchdog-test" command is provided, using this we can trigger watchdog, is there any commandline tool provided for DRA821U also.
    Is there any command line args or dts changes need to be updated to enable watchdog
    Nikhil K
  • Hi Nikhil,
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 11.4.0 (GCC)) #1 Tue Jan 30 10:48:03 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    Detected: J7X-BASE-CPB rev E3
    Detected: J7X-VSC8514-ETH rev E2
    am654_sdhci mmc@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    U-Boot 2023.04-ti-gd2612223375a (Mar 13 2024 - 19:15:42 +0000)
    SoC:   J7200 SR2.0 GP
    Model: Texas Instruments K3 J7200 SoC
    Board: J7200X-PM2-SOM rev E7
    DRAM:  2 GiB (effective 4 GiB)
    Core:  85 devices, 32 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
    Net:   eth0: ethernet@46000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    574 bytes read in 8 ms (69.3 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    gpio: pin gpio@22_17 (gpio 126) value is 1
    gpio: pin gpio@22_16 (gpio 125) value is 0
    k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    73912 bytes read in 12 ms (5.9 MiB/s)
    Load Remote Processor 1 with data@addr=0x82000000 73912 bytes: Success!
    576944 bytes read in 18 ms (30.6 MiB/s)
    Load Remote Processor 2 with data@addr=0x82000000 576944 bytes: Success!
    73912 bytes read in 13 ms (5.4 MiB/s)
    Load Remote Processor 3 with data@addr=0x82000000 73912 bytes: Success!
    19374592 bytes read in 213 ms (86.7 MiB/s)
    69764 bytes read in 10 ms (6.7 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008feeb000, end 000000008fffffff ... OK
    Working FDT set to 8feeb000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.1.80-ti-g1c154b1fe4c4 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT T4
    [    0.000000] Machine model: Texas Instruments J7200 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
    [    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=19be63b4-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
    [    0.000000] Memory: 3897284K/4194304K available (11712K kernel code, 1256K rwdata, 3812K rodata, 1984K init, 440K bss, 264252K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008340] Console: colour dummy device 80x25
    [    0.012906] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023577] pid_max: default: 32768 minimum: 301
    [    0.028315] LSM: Security Framework initializing
    [    0.033094] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040672] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049475] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.056878] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.063148] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.070536] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.076852] rcu: Hierarchical SRCU implementation.
    [    0.081752] rcu:     Max phase no-delay instances is 1000.
    [    0.087261] Platform MSI: msi-controller@1820000 domain created
    [    0.093408] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.102762] EFI services will not be available.
    [    0.107493] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.120669] Detected PIPT I-cache on CPU1
    [    0.120731] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.120746] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.120780] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.120828] smp: Brought up 1 node, 2 CPUs
    [    0.150178] SMP: Total of 2 processors activated.
    [    0.154982] CPU features: detected: 32-bit EL0 Support
    [    0.160236] CPU features: detected: CRC32 instructions
    [    0.165512] CPU: All CPU(s) started at EL2
    [    0.169694] alternatives: applying system-wide alternatives
    [    0.176219] devtmpfs: initialized
    [    0.184222] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.194201] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.201790] pinctrl core: initialized pinctrl subsystem
    [    0.207454] DMI not present or invalid.
    [    0.211704] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.218288] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.225601] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.233637] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.241762] audit: initializing netlink subsys (disabled)
    [    0.247361] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.247550] thermal_sys: Registered thermal governor 'step_wise'
    [    0.255284] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.261439] cpuidle: using governor menu
    [    0.272176] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.279138] ASID allocator initialised with 65536 entries
    [    0.290772] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
    [    0.301673] KASLR disabled due to lack of seed
    [    0.309039] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.316000] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.322409] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.329353] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.335782] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.342716] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.349118] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.356051] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.363229] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
    [    0.372446] iommu: Default domain type: Translated
    [    0.377436] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.383954] SCSI subsystem initialized
    [    0.387942] usbcore: registered new interface driver usbfs
    [    0.393563] usbcore: registered new interface driver hub
    [    0.399001] usbcore: registered new device driver usb
    [    0.404339] pps_core: LinuxPPS API ver. 1 registered
    [    0.409413] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.418757] PTP clock support registered
    [    0.422826] EDAC MC: Ver: 3.0.0
    [    0.426493] FPGA manager framework
    [    0.430005] Advanced Linux Sound Architecture Driver Initialized.
    [    0.436649] clocksource: Switched to clocksource arch_sys_counter
    [    0.443016] VFS: Disk quotas dquot_6.6.0
    [    0.447047] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.457035] NET: Registered PF_INET protocol family
    [    0.462419] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.471562] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.480313] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.488239] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.496472] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.505240] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.512087] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.519010] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.526455] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.532550] RPC: Registered named UNIX socket transport module.
    [    0.538609] RPC: Registered udp transport module.
    [    0.543412] RPC: Registered tcp transport module.
    [    0.548217] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.554799] NET: Registered PF_XDP protocol family
    [    0.559699] PCI: CLS 0 bytes, default 64
    [    0.564064] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.573150] Initialise system trusted keyrings
    [    0.577819] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.586501] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.592772] NFS: Registering the id_resolver key type
    [    0.597951] Key type id_resolver registered
    [    0.602222] Key type id_legacy registered
    [    0.606342] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.613192] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.640549] Key type asymmetric registered
    [    0.644735] Asymmetric key parser 'x509' registered
    [    0.649742] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.657381] io scheduler mq-deadline registered
    [    0.662012] io scheduler kyber registered
    [    0.667895] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [    0.673887] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
    [    0.679685] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
    [    0.685884] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
    [    0.691838] pinctrl-single 11c000.pinctrl: 67 pins, size 268
    [    0.697842] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
    [    0.703903] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.713048] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.724074] loop: module loaded
    [    0.727847] megasas: 07.719.03.00-rc1
    [    0.733061] tun: Universal TUN/TAP device driver, 1.6
    [    0.738590] VFIO - User Level meta-driver version: 0.3
    [    0.744212] usbcore: registered new interface driver usb-storage
    [    0.750637] i2c_dev: i2c /dev entries driver
    [    0.755559] sdhci: Secure Digital Host Controller Interface driver
    [    0.761886] sdhci: Copyright(c) Pierre Ossman
    [    0.766522] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.772585] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.778811] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.785532] usbcore: registered new interface driver usbhid
    [    0.791229] usbhid: USB HID core driver
    [    0.795625] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.800183] optee: revision 4.1 (012cdca4)
    [    0.816609] optee: dynamic shared memory is enabled
    [    0.825988] optee: initialized driver
    [    0.830756] Initializing XFRM netlink socket
    [    0.835162] NET: Registered PF_PACKET protocol family
    [    0.840361] Key type dns_resolver registered
    [    0.844926] registered taskstats version 1
    [    0.849129] Loading compiled-in X.509 certificates
    [    0.860230] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    [    0.889106] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.895503] pca953x 1-0021: supply vcc not found, using dummy regulator
    [    0.902340] pca953x 1-0021: using no AI
    [    0.929055] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    0.935859] pca953x 1-0020: using no AI
    [    0.940412] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    0.947223] pca953x 1-0022: using AI
    [    0.951508] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.957626] pca953x 2-0020: supply vcc not found, using dummy regulator
    [    0.964448] pca953x 2-0020: using no AI
    [    0.988956] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.994709] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.003247] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.012575] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.021164] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    1.030847] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    1.040742] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.047501] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.057287] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    1.067441] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.074200] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.082154] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 251, base_baud = 6000000) is a 8250
    [    1.091665] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 252, base_baud = 3000000) is a 8250
    [    1.100514] printk: console [ttyS2] enabled
    [    1.108955] printk: bootconsole [ns16550a0] disabled
    [    1.119376] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 253, base_baud = 3000000) is a 8250
    [    1.129151] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.172653] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.181501] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.189779] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.202617] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.209826] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.216018] pps pps0: new PPS source ptp0
    [    1.220163] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [    1.230461] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [    1.240014] mmc0: CQHCI version 5.10
    [    1.243661] gpio-mux mux-controller: 2-way mux-controller registered
    [    1.283242] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.377022] mmc0: Command Queue Engine enabled
    [    1.381538] mmc0: new HS400 MMC card at address 0001
    [    1.387166] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.395897]  mmcblk0: p1
    [    1.399107] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.405285] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.411049] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
    [    1.501198] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [    1.507961] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2000-01-01T00:00:08 UTC (946684808)
    [    1.548770] vdd_core_0v85: Bringing 800000uV into 850000-850000uV
    [    1.674407] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
    [    1.681400] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
    [    1.690355] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.701941] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
    [    1.716420] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.721497] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
    [    1.728554] Creating 7 MTD partitions on "47040000.spi.0":
    [    1.734086] 0x000000000000-0x000000100000 : "ospi.tiboot3"
    [    1.740610] 0x000000100000-0x000000300000 : "ospi.tispl"
    [    1.746757] 0x000000300000-0x000000700000 : "ospi.u-boot"
    [    1.753553] 0x000000700000-0x000000740000 : "ospi.env"
    [    1.759656] 0x000000740000-0x000000780000 : "ospi.env.backup"
    [    1.766192] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.772399] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.786719] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.832675] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.841800] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.850106] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.863053] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.870297] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.877712] pps pps0: new PPS source ptp1
    [    1.881974] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [    1.892708] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.901087] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    1.901106] mmc1: CQHCI version 5.10
    [    1.915035] ALSA device list:
    [    1.918062]   No soundcards found.
    [    1.952983] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.960588] Waiting for root device PARTUUID=19be63b4-02...
    [    2.018501] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.025765] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.035021]  mmcblk1: p1 p2
    [    2.064732] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    2.073292] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.085278] devtmpfs: mounted
    [    2.089705] Freeing unused kernel memory: 1984K
    [    2.094382] Run /sbin/init as init process
    [    2.257290] systemd[1]: System time before build time, advancing clock.
    [    2.298580] NET: Registered PF_INET6 protocol family
    [    2.304621] Segment Routing with IPv6
    [    2.308305] In-situ OAM (IOAM) with IPv6
    [    2.339071] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL)
    [    2.370776] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    2.427706] systemd[1]: Hostname set to <j7200-evm>.
    [    2.518471] systemd-sysv-generator[148]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file .
    [    2.741619] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update yo.
    [    2.798459] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update.
    [    2.867252] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.912524] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.935158] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.958859] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.982524] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.005181] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password ��…ts to Console Directory Watch.
    [    3.028985] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R��…uests to Wall Directory Watch.
    [    3.053080] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.072805] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.092798] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.112826] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.172132] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.192941] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.221237] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.245074] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.269460] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.293285] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.317289] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.337419] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.361404] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.381166] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.401201] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.453058] systemd[1]: Mounting Huge Pages File System...
    [    3.473524] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.525045] systemd[1]: Mounting Kernel Debug File System...
    [    3.540995] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.561321] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.582766] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.609131] systemd[1]: Starting Load Kernel Module configfs...
    [    3.629325] systemd[1]: Starting Load Kernel Module drm...
    [    3.647892] systemd[1]: Starting Load Kernel Module fuse...
    [    3.665936] fuse: init (API version 7.37)
    [    3.669801] systemd[1]: Starting RPC Bind...
    [    3.693216] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    3.711725] systemd[1]: Starting Journal Service...
    [    3.736524] systemd[1]: Starting Load Kernel Modules...
    [    3.757025] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network ��…ts from Kernel co[    3.767592] cryptodev: loading out-of-tree module taints kernel.
    mmand line...
    [    3.777624] cryptodev: driver 1.12 loaded.
    [    3.787728] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.815843] systemd[1]: Starting Coldplug All udev Devices...
    [    3.816879] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    3.841947] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.857144] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.160748] systemd-journald[163]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    4.362515] audit: type=1334 audit(1651167747.104:2): prog-id=5 op=LOAD
    [    4.369695] audit: type=1334 audit(1651167747.112:3): prog-id=6 op=LOAD
             Starting Rule-based Manage��…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [    4.830919] CAN device driver interface
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    4.852699] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    k Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    4.936676] random: crng init done
    [    4.944834] ti-udma 285c0000.dma-controller: chan1: is running!
             Starting Weston socket...
    [    4.954562] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.[    5.058668] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    5.080368] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
             Starting DEMO...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
    [    5.270203] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting Expand the rootfs��…ll size of the boot device....
    [  OK  ] Started strongSwan IPsec I��…IKEv2 daemon using ipsec.conf.
    [    5.320105] audit: type=1334 audit(1651180396.352:4): prog-id=7 op=LOAD
    [    5.328520] platform 41000000.r5f: configured R5F for IPC-only mode
    [    5.329365] audit: type=1334 audit(1651180396.360:5): prog-id=8 op=LOAD
             Starting User Login Management...[    5.343932] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    5.355356] remoteproc remoteproc0: 41000000.r5f is available
    [    5.361261] remoteproc remoteproc0: attaching to 41000000.r5f
    [    5.373193] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [  OK  ] Started TEE Supplicant.[    5.381033] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node r5f-dma-memory@a0000000
             Starting Telnet Server...
    [    5.395446] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    5.400250] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.403953] rproc-virtio rproc-virtio.10.auto: registered virtio0 (type 7)
    [    5.417425] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    5.418261] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [  OK  ] Finished IPv6 Packet Filtering Fram[    5.435156] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) !=)
    ework.
    [  OK  ] Finished IPv4 Packet Fi[    5.450883] platform 41400000.r5f: configured R5F for IPC-only mode
    ltering Framework.
    [  OK  ] Reached target     5.463848] platform 41400000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    ;39mPreparation for Network.
             Starting Network Configuration...
    [  OK  ] Finished     5.482836] remoteproc remoteproc1: 41400000.r5f is available
    mTelnet Server.
    [    5.493865] remoteproc remoteproc1: attaching to 41400000.r5f
    [  OK  ] Started DEMO.
    [  OK  ] Started Telephony service.
    [    5.527698] platform 41400000.r5f: R5F core initialized in IPC-only mode
    [    5.610961] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node r5f-dma-memory@a1000000
    [    5.620784] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    5.628119] rproc-virtio rproc-virtio.11.auto: registered virtio1 (type 7)
    [    5.629931] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.635082] remoteproc remoteproc1: remote processor 41400000.r5f is now attached
    [    5.652789] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    5.661034] platform 5c00000.r5f: configured R5F for IPC-only mode
    [    5.668322] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [    5.691408] remoteproc remoteproc2: 5c00000.r5f is available
    [    5.708731] m_can_platform 2701000.can: m_can device registered (irq=684, version=32)
    [    5.725097] m_can_platform 2731000.can: m_can device registered (irq=685, version=32)
    [    5.738055] remoteproc remoteproc2: attaching to 5c00000.r5f
    [    5.741829] m_can_platform 40528000.can: m_can device registered (irq=686, version=32)
    [    5.743976] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [    5.757945] m_can_platform 40568000.can: m_can device registered (irq=687, version=32)
    [    5.760587] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node r5f-dma-memory@a2000000
    [    5.776971] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    5.777518] virtio_rpmsg_bus virtio2: creating channel ti.ethfw.ethdevice addr 0x65
    [    5.782493] rproc-virtio rproc-virtio.12.auto: registered virtio2 (type 7)
    [    5.796365] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [    5.804498] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached
    [    5.818069] platform 5d00000.r5f: configured R5F for IPC-only mode
    [    5.845195] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [    5.853986] remoteproc remoteproc3: 5d00000.r5f is available
    [    5.860036] remoteproc remoteproc3: attaching to 5d00000.r5f
    [    5.869585] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [    5.876274] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node r5f-dma-memory@a3000000
    [    5.888071] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    5.894167] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    5.901989] rproc-virtio rproc-virtio.13.auto: registered virtio3 (type 7)
    [    5.909012] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    5.968483] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached
    [    6.054377] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.063266] Bluetooth: Core ver 2.22
    [    6.066946] NET: Registered PF_BLUETOOTH protocol family
    [    6.075629] Bluetooth: HCI device and connection manager initialized
    [    6.082014] Bluetooth: HCI socket layer initialized
    [    6.088548] Bluetooth: L2CAP socket layer initialized
    [    6.094646] Bluetooth: SCO socket layer initialized
    [    6.103712] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.104019] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Finished Expand the rootfs��…full size of the boot device..
    [  OK  ] Started User Login Management.
    [  OK  ] Started Network Configuration.
    [    6.258465] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
             Starting Network Name Resolution...
    [    6.290090] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    6.309208] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0000:00
    [    6.358225] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    6.432523] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    6.442096] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    6.449388] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
    [    6.456073] pci 0000:00:00.0: supports D1
    [    6.460666] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    6.467386] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
    [    6.478948] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
    [    6.492007] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    6.501479] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    6.508472] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
    [    6.516183] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    6.522030] pcieport 0000:00:00.0: PME: Signaling with IRQ 689
    [    6.528975] pcieport 0000:00:00.0: AER: enabled with IRQ 689
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Simple Network Ma��…ent Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland��…ositor, as a system service...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack[    6.933041] m_can_platform 2701000.can main_mcan0: renamed from can0
    [    6.975363] m_can_platform 2731000.can main_mcan3: renamed from can1
    [    6.992310] m_can_platform 40528000.can mcu_mcan0: renamed from can2
    [    7.042914] m_can_platform 40568000.can mcu_mcan1: renamed from can3
    [  OK  ] Finished Synchronize System and HW clocks.
    [  OK  ] Listening on Load/Save RF ��…itch Status /dev/rfkill Watch.
    [    7.231055] ti_cpsw_proxy_client virtio2.ti.ethfw.ethdevice.-1.101: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
    [    7.256938] ti_cpsw_proxy_client virtio2.ti.ethfw.ethdevice.-1.101: Virt Port: 0, Type: Switch Port, Iface: eth1, Num TX: 2, Num RX: 1, Token: 0
    [    7.291117] audit: type=1334 audit(1651180398.324:6): prog-id=9 op=LOAD
    [    7.301342] audit: type=1334 audit(1651180398.336:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [    7.344040] ti_cpsw_proxy_client virtio2.ti.ethfw.ethdevice.-1.101: Virt Port: 4, Type: MAC Port, Iface: eth2, Num TX: 1, Num RX: 1, Token: 400
    [    7.508376] ti_cpsw_proxy_client virtio2.ti.ethfw.ethdevice.-1.101: started virt port: 0 on interface eth1
    [  OK  ] Started User Database Manager.
    [    7.626555] ti_cpsw_proxy_client virtio2.ti.ethfw.ethdevice.-1.101: started virt port: 4 on interface eth2
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...
    [    7.758135] audit: type=1006 audit(1651180398.792:8): pid=622 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    7.771362] audit: type=1300 audit(1651180398.792:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff9e70eb8 a2=4 a3=ffff873dc020 items=0 ppid=1 pi)
    [    7.798078] audit: type=1327 audit(1651180398.792:8): proctitle="(systemd)"
    [  OK  ] Started Simple Network Man��…ement Protocol (SNMP) Daemon..
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [    8.194245] audit: type=1006 audit(1651180399.224:9): pid=491 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [    8.206736] audit: type=1300 audit(1651180399.224:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff9e70eb8 a2=4 a3=ffff873dc020 items=0 ppid=1 pi)
    [    8.233426] audit: type=1327 audit(1651180399.224:9): proctitle="(weston)"
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/rootfs-mmcblk0p1...
    [    8.325548] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/rootfs-mmcblk0p1.
    [FAILED] Failed to start Weston, a ��…mpositor, as a system service.
    See 'systemctl status weston.service' for details.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5sensors-plugins
            libqt5sensors-qmlplugins
            libqt5sensors5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libqt5webchannel-plugins
            libqt5webchannel-qmlplugins
            libqt5webchannel5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring2
            m4-dev
            m4
            make
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
                  |___|                    |___|
    [   13.329017] audit: type=1006 audit(1651180404.364:10): pid=1080 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   13.341985] audit: type=1300 audit(1651180404.364:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff9e70eb8 a2=1 a3=ffff873dc020 items=0 ppid=1 p)
    [   13.368392] audit: type=1327 audit(1651180404.364:10): proctitle="(systemd)"
    [   13.381931] audit: type=1334 audit(1651180404.416:11): prog-id=11 op=LOAD
    [   13.388778] audit: type=1300 audit(1651180404.416:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffda857ac0 a2=78 a3=0 items=0 ppid=1 pid=1080 a)
    [   13.415917] audit: type=1327 audit(1651180404.416:11): proctitle="(systemd)"
    [   13.423323] audit: type=1334 audit(1651180404.416:12): prog-id=11 op=UNLOAD
    [   13.430710] audit: type=1334 audit(1651180404.416:13): prog-id=12 op=LOAD
    [   13.437846] audit: type=1300 audit(1651180404.416:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffda857b60 a2=78 a3=0 items=0 ppid=1 pid=1080 a)
    [   13.463468] audit: type=1327 audit(1651180404.416:13): proctitle="(systemd)"
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~#
    root@j7200-evm:~# cd /opt/ltp/
    root@j7200-evm:/opt/ltp# ./runltp -P j721e-idk-gw -f ddt/wdt_test -s "WDT_M_FUNC_WRITE "
    INFO: Filtering testscenarios based on j721e-idk-gw capabilities
    awk: cmd. line:1: warning: regexp escape sequence `\&' is not a known regexp operator
    Checking for required user/group ids
    'root' user id and group found.
    'nobody' user id and group found.
    'bin' user id and group found.
    'daemon' user id and group found.
    Users group found.
    Sys group found.
    Required users/groups exist.
    If some fields are empty or look unusual you may have an old version.
    Compare to the current minimal requirements in Documentation/Changes.
    /etc/os-release
    ID=arago
    NAME="Arago"
    VERSION="2023.10"
    VERSION_ID=2023.10
    PRETTY_NAME="Arago 2023.10"
    uname:
    Linux j7200-evm 6.1.80-ti-g1c154b1fe4c4 #1 SMP PREEMPT Thu Mar 14 13:59:07 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
    /proc/cmdline
    Gnu C                  gcc (GCC) 11.4.0
    Clang
    Gnu make               4.3
    util-linux             2.37.4
    mount                  linux 2.37.4 (libmount 2.37.4: btrfs, namespaces, assert, debug)
    modutils               29
    e2fsprogs              1.46.5
    Linux C Library        x 1 root root 1630088 Mar  9  2018 /lib/libc.so.6
    Dynamic linker (ldd)   2.35
    Linux C++ Library      6.0.29
    Procps                 3.3.17-dirty
    Net-tools              2.10
    iproute2               iproute2-5.17.0
    iputils                'V'
    ethtool                5.16
    Sh-utils               9.0
    Modules Loaded         ti_cpsw_proxy_client pci_endpoint_test rpmsg_ctrl rpmsg_char cdns3 cdns_usb_common ti_am335x_adc overlay kfifo_buf cfg80211 bluetooth crc6
    free reports:
                   total        used        free      shared  buff/cache   available
    Mem:         3932036      119236     3670288        9136      142512     3664180
    Swap:              0           0           0
    cpuinfo:
    Architecture:            aarch64
      CPU op-mode(s):        32-bit, 64-bit
      Byte Order:            Little Endian
    CPU(s):                  2
      On-line CPU(s) list:   0,1
    Vendor ID:               ARM
      Model name:            Cortex-A72
        Model:               0
        Thread(s) per core:  1
        Core(s) per cluster: 2
        Socket(s):           -
        Cluster(s):          1
        Stepping:            r1p0
        CPU max MHz:         2000.0000
        CPU min MHz:         750.0000
        BogoMIPS:            400.00
        Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
    Caches (sum of all):
      L1d:                   64 KiB (2 instances)
      L1i:                   96 KiB (2 instances)
      L2:                    1 MiB (1 instance)
    Vulnerabilities:
      Gather data sampling:  Not affected
      Itlb multihit:         Not affected
      L1tf:                  Not affected
      Mds:                   Not affected
      Meltdown:              Not affected
      Mmio stale data:       Not affected
      Retbleed:              Not affected
      Spec rstack overflow:  Not affected
      Spec store bypass:     Not affected
      Spectre v1:            Mitigation; __user pointer sanitization
      Spectre v2:            Mitigation; CSV2, BHB
      Srbds:                 Not affected
      Tsx async abort:       Not affected
    available filesystems:
    autofs bdev bpf cgroup cgroup2 configfs cpuset debugfs devpts devtmpfs ext2 ext3 ext4 fuse fuseblk fusectl hugetlbfs mqueue nfs nfs4 overlay pipefs proc pstore t
    mounted filesystems (/proc/mounts):
    /dev/root / ext4 rw,relatime 0 0
    devtmpfs /dev devtmpfs rw,relatime,size=1948640k,nr_inodes=487160,mode=755 0 0
    proc /proc proc rw,relatime 0 0
    sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
    securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
    tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
    devpts /dev/pts devpts rw,relatime,gid=5,mode=620,ptmxmode=000 0 0
    tmpfs /run tmpfs rw,nosuid,nodev,size=786408k,nr_inodes=819200,mode=755 0 0
    tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755 0 0
    cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
    cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
    pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
    bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
    cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
    cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
    cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
    cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
    cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
    cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
    cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
    cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
    cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
    cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
    hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
    mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
    debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
    tmpfs /tmp tmpfs rw,nosuid,nodev,size=1966020k,nr_inodes=1048576 0 0
    fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
    configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
    tmpfs /media/ram tmpfs rw,relatime,size=16384k 0 0
    tmpfs /var/volatile tmpfs rw,relatime,size=51200k 0 0
    /dev/mmcblk0p1 /run/media/rootfs-mmcblk0p1 ext4 rw,relatime 0 0
    /dev/mmcblk1p1 /run/media/boot-mmcblk1p1 vfat rw,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=r0
    tmpfs /run/user/0 tmpfs rw,nosuid,nodev,relatime,size=393200k,nr_inodes=98300,mode=700 0 0
    mounted filesystems (df):
    Filesystem     Type      Size  Used Avail Use% Mounted on
    /dev/root      ext4       15G  4.6G  9.1G  34% /
    devtmpfs       dev[   26.276362] LTP: starting WDT_M_FUNC_WRITE (source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "e)
    tmpfs  1.9G  4.0K  1.9G   1% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     768M  8.9M  760M   2% /run
    tmpfs          tmpfs     4.0M     0  4.0M   0% /sys/fs/cgroup
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /tmp
    tmpfs          tmpfs      16M     0   16M   0% /media/ram
    tmpfs          tmpfs      50M   12K   50M   1% /var/volatile
    /dev/mmcblk0p1 ext4       90M   62M   21M  75% /run/media/rootfs-mmcblk0p1
    /dev/mmcblk1p1 vfat      127M  2.7M  124M   3% /run/media/boot-mmcblk1p1
    tmpfs          tmpfs     384M     0  384M   0% /run/user/0
    AppArmor disabled
    SELinux mode: unknown
    no big block device was specified on commandline.
    Tests which require a big block device are disabled.
    You can specify it with option -z
    COMMAND:    /opt/ltp/bin/ltp-pan   -e -S   -a 1102     -n 1102 -p -f /tmp/ltp-qr0d78vvpa/alltests -l /tmp/tmp.wOGCoKK6In  -C /opt/ltp/output/LTP_RUN_ON-tmp.wOGCf
    INFO: Restricted to WDT_M_FUNC_WRITE
    LOG File: /tmp/tmp.wOGCoKK6In
    FAILED COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.wOGCoKK6In.failed
    TCONF COMMAND File: /opt/ltp/output/LTP_RUN_ON-tmp.wOGCoKK6In.tconf
    Running tests.......
    <<<test_start>>>
    tag=WDT_M_FUNC_WRITE stime=1651180417
    cmdline="source 'common.sh'; do_cmd install_modules.sh 'wdt' ; DEV_NODE=`get_devnode.sh "wdt"` || die "error getting devnode for wdt"; do_cmd wdt_tests -device "
    contacts=""
    analysis=exit
    <<<test_output>>>
    incrementing stop
    |TRACE LOG|Inside do_cmd:CMD=install_modules.sh wdt|
    |TRACE LOG|Inside do_cmd:CMD=wdt_tests -device /dev/watchdog -ioctl -write|
    |TEST START|wdt_tests|
    |TRACE LOG|******** WDT Testcase  parameters  ******** |
    |TRACE LOG|Device         : /dev/watchdog|
    |TRACE LOG|Loop Count     : 1|
    |TRACE LOG|I/O Operation  : Write|
    |TRACE LOG|Operation      : Ioctl|
    |TRACE LOG|Ioctl Name     : WDIOC_KEEPALIVE|
    |TRACE LOG|Ioctl Arg      : 0 |
    |TRACE LOG| ************* End of Test params ************* |
    |TRACE LOG|Keeping WDT alive, sleep counter -0(sec)|
    |TEST RESULT|PASS|wdt_tests|
    |TEST END|wdt_tests|
    |TRACE LOG|EVM will be rebooted after 60 seconds|
    |TRACE LOG|59 seconds remaining before reboot|
    |TRACE LOG|58 seconds remaining before reboot|
    |TRACE LOG|57 seconds remaining before reboot|
    |TRACE LOG|56 seconds remaining before reboot|
    |TRACE LOG|55 seconds remaining before reboot|
    |TRACE LOG|54 seconds remaining before reboot|
    |TRACE LOG|53 seconds remaining before reboot|
    |TRACE LOG|52 seconds remaining before reboot|
    |TRACE LOG|51 seconds remaining before reboot|
    |TRACE LOG|50 seconds remaining before reboot|
    |TRACE LOG|49 seconds remaining before reboot|
    |TRACE LOG|48 seconds remaining before reboot|
    |TRACE LOG|47 seconds remaining before reboot|
    |TRACE LOG|46 seconds remaining before reboot|
    |TRACE LOG|45 seconds remaining before reboot|
    |TRACE LOG|44 seconds remaining before reboot|
    |TRACE LOG|43 seconds remaining before reboot|
    |TRACE LOG|42 seconds remaining before reboot|
    |TRACE LOG|41 seconds remaining before reboot|
    |TRACE LOG|40 seconds remaining before reboot|
    |TRACE LOG|39 seconds remaining before reboot|
    |TRACE LOG|38 seconds remaining before reboot|
    |TRACE LOG|37 seconds remaining before reboot|
    |TRACE LOG|36 seconds remaining before reboot|
    |TRACE LOG|35 seconds remaining before reboot|
    |TRACE LOG|34 seconds remaining before reboot|
    |TRACE LOG|33 seconds remaining before reboot|
    |TRACE LOG|32 seconds remaining before reboot|
    |TRACE LOG|31 seconds remaining before reboot|
    |TRACE LOG|30 seconds remaining before reboot|
    |TRACE LOG|29 seconds remaining before reboot|
    |TRACE LOG|28 seconds remaining before reboot|
    |TRACE LOG|27 seconds remaining before reboot|
    |TRACE LOG|26 seconds remaining before reboot|
    |TRACE LOG|25 seconds remaining before reboot|
    |TRACE LOG|24 seconds remaining before reboot|
    |TRACE LOG|23 seconds remaining before reboot|
    |TRACE LOG|22 seconds remaining before reboot|
    |TRACE LOG|21 seconds remaining before reboot|
    |TRACE LOG|20 seconds remaining before reboot|
    |TRACE LOG|19 seconds remaining before reboot|
    |TRACE LOG|18 seconds remaining before reboot|
    |TRACE LOG|17 seconds remaining before reboot|
    |TRACE LOG|16 seconds remaining before reboot|
    |TRACE LOG|15 seconds remaining before reboot|
    |TRACE LOG|14 seconds remaining before reboot|
    |TRACE LOG|13 seconds remaining before reboot|
    |TRACE LOG|12 seconds remaining before reboot|
    |TRACE LOG|11 seconds remaining before reboot|
    |TRACE LOG|10 seconds remaining before reboot|
    |TRACE LOG|9 seconds remaining before reboot|
    |TRACE LOG|8 seconds remaining before reboot|
    |TRACE LOG|7 seconds remaining before reboot|
    |TRACE LOG|6 seconds remaining before reboot|
    |TRACE LOG|5 seconds remaining before reboot|
    |TRACE LOG|-13 seconds remaining before reboot|
    |TRACE LOG|-14 seconds remaining before reboot|
    |TRACE LOG|-15 seconds remaining before reboot|
    |TRACE LOG|-16 seconds remaining before reboot|
    |TRACE LOG|-17 seconds remaining before reboot|
    |TRACE LOG|-18 seconds remaining before reboot|
    |TRACE LOG|-19 seconds remaining before reboot|
    |TRACE LOG|-20 seconds remaining before reboot|
    |TRACE LOG|-21 seconds remaining before reboot|
    |TRACE LOG|-22 seconds remaining before reboot|
    |TRACE LOG|-23 seconds remaining before reboot|
    I/TC:
    SoC:   J7200 SR2.0 GP
    Flash: 0 Bytes
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Pasting complete boot logs from J7200-EVM. It works as expected on the default 9.2 SDK.
    - Keerthy
  • Understood, seems like some HW/SW configurations error causing this issue my side.
    Is there any additional kernel modules or dts configuration need to added in kernel or uboot.
    Is there any Hw clocks needed for watchdog.
    Nikhil K
  • Nikhil,
    Can you first try on EVM with the default SDK 9.2? That should not need any additional changes!
    - Keerthy
  • Hi Keerthy,
    unfortunately we dont have evk..
    Nikhil
  • Nikhil,
    From the SOC side. The SDK already covers what you need.
    Sequence is:
    RTI_Watchdog --> ESM --> PMIC
    So RTI watchdog driver is definitely running.
    ESM is also started by R5 SPL.
    The only that is outside and that is different is PMIC for custom boards.
    Do you have the same PMIC as EVM? If not please check with board designers on How the PMIC is connected to handle SOC error signals.
    - Keerthy
  • We are using the TPS65941515RWERQ1 PMIC. The schematics is based on the evk contains "single pmic"
    Nikhil
  • J7200 has dual PMIC solution. So please check with schematics experts on how the error signals are routed to PMIC.
    Keerthy
  • Since we are using the above mentioned pmic and evm is available on ti website with same pmic.
    So please guide us on how to configure watchdog with single pmic
    single pmichttps://www.ti.com/lit/ug/slvucd4/slvucd4.pdf?ts=1726668614759&ref_url=https%253A%252F%252Fwww.google.com%252F
    Attached  pmic section of our custom board
    Nikhil
  • Hi Nikhil,
    Can you dump out the below registers on your board?
    #define INT_ESM_REG 0x6c
    #define INT_ESM_MASK 0x3f
    #define ESM_MCU_START_REG 0x8f
    #define ESM_MCU_MODE_CFG_REG 0x92
    This will help us check if the PMIC driver has probed correctly in the R5 SPL.
    You need to know the PMIC slave ID on your board & then you can use 'i2c md' commands in U-Boot.
    - Keerthy
  • Dear Keerthy,
    Please find the register values in uboot
    0x6c -> 00
    0x3f -> d4
    0x8f -> 00
    0x92 -> 00
    also attaching complete dump values
    > i2c md 0x48 0x00 0xff
    0000: 00 82 15 03 31 2b 20 2b 31 2b 20 2b 31 1b 37 37    ....1+ +1+ +1.77
    0010: 37 37 37 37 37 37 73 73 1b 1b 1b 1b 1b 31 31 31    777777ss.....111
    0020: 31 00 00 3a 12 10 38 1b 1b 1b 1b 20 7f 00 00 00    1..:..8.... ....
    0030: 00 01 01 58 d8 01 03 38 78 21 08 01 11 10 05 d4    ...X...8x!......
    0040: 0f 55 55 05 3e 01 55 55 15 00 00 00 00 00 00 ff    .UU.>.UU........
    0050: ff 3f 11 02 30 00 00 00 00 00 18 00 00 00 00 00    .?..0...........
    0060: 00 00 00 00 00 02 01 00 00 00 00 00 00 00 00 00    ................
    0070: 00 00 00 02 00 00 00 00 00 00 00 80 00 00 00 00    ................
    0080: 00 19 02 00 0f 00 00 00 00 00 1f 0b 00 00 00 00    ................
    0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00a0: 00 00 00 80 00 00 08 00 00 00 00 00 00 00 00 00    ................
    00b0: 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00    ................
    00c0: 00 00 00 eb 80 00 00 00 00 00 00 00 00 58 9d 00    .............X..
    00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
    00f0: 5a a6 28 c9 d3 22 c0 7f af b2 04 b7 00 00 63    Z.(.."........c
    Also i tried to print test debug prints on "pmic_esm_probe" function, but i dont see any test prints on debug log, so seems like pmic itself not probing properly.
    Nikhil
  • Nikhil,
    diff --git a/drivers/misc/esm_pmic.c b/drivers/misc/esm_pmic.c
    index b971f32f..a0465903 100644
    --- a/drivers/misc/esm_pmic.c
    +++ b/drivers/misc/esm_pmic.c
    @@ -38,6 +38,7 @@ static int pmic_esm_probe(struct udevice *dev)
            int ret;
    +       printf("%s\n" __func__);
            ret = pmic_reg_write(dev->parent, INT_ESM_REG, INT_ESM_MASK);
            if (ret) {
                    dev_err(dev, "clearing ESM irqs failed: %d\n", ret);
    Please make sure PMIC ESM driver is getting probed on your board in R5 SPL. If not check R5 SPL DTS:
    &tps659413 {
    esm: esm {
    compatible = "ti,tps659413-esm";
    bootph-pre-ram;
    In arch/arm/dts/k3-j7200-r5-common-proc-board-u-boot.dtsi
    Do you have a different board name for your custom board? If yes you will need to take care of corresponding board-name-u-boot.dtsi.
    - Keerthy
